Date/Time: Tue, 10 Nov 2026 16:34:57 +0000
User Question
View Count: 979
| [2018-03-06 01:33:20] |
Question. I want/NEED what you would consider to be the fastest and most accurate data feed for bid ask volume and tick data that most likely will not freeze up. if you do not think this is the gain feed then what do I need to pay for with you in order to get the most ROBUST and fastest data possible. I am very frustrated and after getting this set up with you will become a customer. thank you. what do you think is the best data for .. CME and cbot I will add stocks later. by best i mean fastest and not FREEZING on my DOM or my charts We recommend the Sierra Chart Real-Time and Historical Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support |
