Date/Time: Tue, 10 Nov 2026 17:53:11 +0000
Study - Text Dispaly for Study - Cannot remove former Prefix text value
View Count: 958
[2018-03-01 16:23:44]
User360283 - Posts: 538
Prefix value can't be deleted allowing only Suffix test to display
Help Thanks
[2018-03-01 22:14:08]
We will correct this in the next release.
[2018-03-01 22:29:15]
Actually we see no problem with this study. We recommend just removing the study from the chart and adding it again and configuring it as you require.
Date Time Of Last Edit: 2018-03-01 22:29:24
[2018-03-14 12:59:40]
I have both deleted and copied and created new Text Display for Study. In all cases it inserts a Prefix value from one of the existing Text studies and the erroneous inserted Prefix value is retained.
I suspect it is some sort of array overflow or pointer problem caused by having many (currently 27 Text Display) studies in the chart or the chart region.
Would you please check this and let me know how to proceed.
[2018-04-25 16:55:18]
I still have this problem.
32 bit Version 1727
Just in case file enclosed.
Is it fixed ? What version to install
attachmenttextlabels.Cht - Attached On 2018-04-25 16:54:35 UTC - Size: 29.46 KB - 655 views
