Date/Time: Tue, 10 Nov 2026 16:34:53 +0000
Volume multiplier not affecting current volume on historical chart
View Count: 1507
| [2018-03-01 11:09:09] |
| User612903 - Posts: 51 |
Hello, I'm facing a weird behaviour when changing the volume multiplier in historical chart How I got there : - I'm connected to the Cryptocureencies data feed - I open LTCUSD in timeframe : D1. - I add the volume studie - Then I change in "Advanced settings 2" the "volume multiplier" to 0.0001 to correct the volume. => All volumes are affected except the current one In Intraday chart the current volume is affected normally. Is this a bug or am I missing something ? See screenshot attached. |
| [2018-03-01 22:07:41] |
This is by design. Refer to: Chart Settings: Volume and Open Interest Multiplier (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) What you instead need to use is this particular Volume study: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=336&Name=Volume_Bitcoin Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-01 22:07:56
| [2018-03-01 22:42:33] |
Thank you for coming back to me. I displayed "volume bitcoin" and it works properly. I normally access the volumes by using sc.Volume[sc.Index] in my custom study. Can I access the "volume bitcoin" from a custom study ? Thanks for your help |
| [2018-03-01 23:43:21] |
The solution is to multiply that value by sc.MultiplierFromVolumeValueFormat(). It is always safe to multiply by the value returned by this function. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2018-03-02 10:41:47] |
Refer to: ACSIL Interface Members - Functions: sc.MultiplierFromVolumeValueFormat() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
