Date/Time: Thu, 12 Nov 2026 08:53:03 +0000
Ichimoku cloud indicator
View Count: 11403
[2018-03-01 04:46:58]
Sierra2017 - Posts: 8
Could you please let me know what is the name of Ichimoku indicator in the Sierra chart? I could not find it with this name. Thanks
[2018-03-01 10:33:25]
JoseyWales - Posts: 67
There is no single Ichimoku indicator in Sierra Chart. Ichimoku Kinko Hyo can be represented from its individual indicators by adding each of them to your chart.
The Indicators are:
~Senko Span A & B (This represents the Kumo Cloud)
~Kijun-Sen
~Tenkan-Sen
~Chikou Span
Instead of manually adding each indicator to your chart every time, I made a Study Collection long ago that simplifies this and colors the Kumo cloud semi-transparent red and green instead of just solid green.
Add the attached study collection to your Sierra Chart data folder, and go to the Menubar->Analysis->Ichimoku Kinko Hyo+ to add the Ichimoku system to any chart you wish.
Also note that Senko Span A & B is displaced 26 bars into the future so be sure to scroll enough bars into the future and enable Chart->Lock Fill Space.
The extra indicator in the study collection titled "Senko Span A & B Highlight" is unnecessary but I found that it makes the Kumo cloud stand out better.
Once you apply the study collection to a fresh chart you can change the colors and line draw styles as you wish. When your done you can use the Save Studies As Study Collection, Save All button to overwrite the original with your own settings.
If you're curious as to why I used a Simple moving average length of 1 displaced 26 bars in the past for the Chikou-Span, its because the default Chikou-Span indicator draws all the way to the current bar when looking at the past therefore showing future price movement which is misleading. But I assure you they are the same.
Date Time Of Last Edit: 2018-03-01 10:55:15
attachmentIchimoku Kinko Hyo+.StdyCollct - Attached On 2018-03-01 10:31:20 UTC - Size: 46.61 KB - 2066 views
[2018-03-01 21:56:25]
There is a Study Collection for this on the Additional Files page:
Additional Files (Study Collections, Spreadsheets, Chartbooks)
[2018-08-04 11:30:08]
User803872 - Posts: 14
~Senko Span A & B (official study)
This takes ages to load, then freezes my SC instance v1705
I have to restart wine (using a mac). Have also tried with a clean workbook, makes no difference.
Reading Internal Order ID file. | 2018-08-04 12:27:15
Reading Trade Orders file. | 2018-08-04 12:27:15
Reading Trade Positions file. | 2018-08-04 12:27:15
Using Bid/Ask average for last trade price for GER30 | 2018-08-04 12:27:15
Listening on UDP port 22904. | 2018-08-04 12:27:15
Software version: 1705 | 2018-08-04 12:27:15
Enabled for: Advanced Features. | 2018-08-04 12:27:15
Enabled for: Sierra Chart Historical Data Service. | 2018-08-04 12:27:15
Allow Support for Sierra Chart Data Feeds is enabled. | 2018-08-04 12:27:15
Current selected Data/Trading service: CQG FIX Trading | 2018-08-04 12:27:15
Chart Update Interval: 500 | 2018-08-04 12:27:15
Data/Trade Service Settings automatically set. | 2018-08-04 12:27:15
Time Zone: +01:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2018-08-04 12:27:15
2018-08-04 13:27:15 Local computer time | 2018-08-04 12:27:15
2018-08-04 11:27:15 Local computer time in UTC | 2018-08-04 12:27:15
2018-08-04 12:27:15 Local computer time in SC Time Zone | 2018-08-04 12:27:15
2018-08-04 11:27:13 Server time in UTC | 2018-08-04 12:27:15
Local computer UTC time and Server UTC time difference: 0 seconds. | 2018-08-04 12:27:15
Program path: C:\SierraChart\ | 2018-08-04 12:27:15
Data Files path: C:\SierraChart\Data\ | 2018-08-04 12:27:15
OS Version Number: 5.1 | 2018-08-04 12:27:15
Locale Setting: C | 2018-08-04 12:27:15
Created the DTC Protocol server. | 2018-08-04 12:27:15
DTC Protocol Server listening on port 11099. | 2018-08-04 12:27:15
Created the DTC Protocol historical data server. | 2018-08-04 12:27:15
HD Server Manager | Listening on port 11098 | 2018-08-04 12:27:15
Checking for new symbol settings for service code cqg | 2018-08-04 12:27:15
HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-08-04 12:27:15
HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2018-08-04 12:27:15
Symbol settings are up-to-date for cqg | 2018-08-04 12:27:16
Received 5 login tokens. | 2018-08-04 12:27:16
HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2018-08-04 12:27:17
HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2018-08-04 12:27:17
HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2018-08-04 12:27:21
HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2018-08-04 12:27:21
HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2018-08-04 12:27:21
HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-04 12:27:21
HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2018-08-04 12:27:21
HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-08-04 12:27:21
HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2018-08-04 12:27:21
HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2018-08-04 12:27:21
HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-04 12:27:21
HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2018-08-04 12:27:21
HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2018-08-04 12:27:23
HTTPS connection to www.sierrachart.com:443 (5) | Received socket Close event. | 2018-08-04 12:27:23
HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2018-08-04 12:27:23
HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-04 12:27:23
HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2018-08-04 12:27:23
F.US.ENQU18 [CV] 30 Sec #1 | Reloading chart. | 2018-08-04 12:27:25
Intraday data recording state for symbol F.US.ENQU18 is set to download 'Pending'. | 2018-08-04 12:27:25
HD Request # 2 | Downloading Intraday chart data for F.US.ENQU18 to the file F.US.ENQU18.scid. Service: cqg | 2018-08-04 12:27:25
HD Request # 2 | Download start date-time: 2018-08-03 21:59:59.000 | 2018-08-04 12:27:26
HD Request # 2 | Using server: ds4.sierracharts.com port 10149 | 2018-08-04 12:27:26
Socket (6) | Creating socket. | 2018-08-04 12:27:26
Socket (6) | Error setting send buffer size to 0. Unknown Windows error code 10022. | 2018-08-04 12:27:26 *
Socket (6) | Connecting to IP: 192.81.56.146. | 2018-08-04 12:27:26
HD Request # 2 | Setting DTC encoding to Binary VLS | 2018-08-04 12:27:26
HD Request # 2 | Sending historical data logon request message. | 2018-08-04 12:27:26
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-04 12:27:26
CQG FIX socket (7) | Creating socket. Using TLS 1.2. | 2018-08-04 12:27:26
CQG FIX socket (7) | Error setting send buffer size to 0. Unknown Windows error code 10022. | 2018-08-04 12:27:26 *
CQG FIX socket (7) | Connecting to IP: 208.48.16.214. | 2018-08-04 12:27:26
HD Request # 2 | Requesting Intraday data. Start date-time: 2018-08-03 21:59:59. Record interval: 0. Symbol: F.US.ENQU18 | 2018-08-04 12:27:26
Socket (6) | Initiating close of socket by core. | 2018-08-04 12:27:26
HD Request # 2 | Historical data for F.US.ENQU18 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-08-04 12:27:26
Socket (6) | Shutdown started. Waiting for graceful close. | 2018-08-04 12:27:26
Historical data download thread signaled to stop. | 2018-08-04 12:27:26
HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.ENQU18 | 2018-08-04 12:27:26
HD Request # 2 | Completion time: 1s | 2018-08-04 12:27:26
HD Request # 2 | Intraday data download complete for F.US.ENQU18. Unique request ID: 1 | 2018-08-04 12:27:26
Removed historical data download ID 1 | 2018-08-04 12:27:26
CQG FIX: Sending the Logon message. | 2018-08-04 12:27:26
Socket (6) | Socket gracefully closed by remote side. | 2018-08-04 12:27:26
Socket (6) | Closed. | 2018-08-04 12:27:26
CQG FIX Trading | Connected to trading server. | 2018-08-04 12:27:27
CQG FIX Trading | Connecting to server api.cqg.com | 2018-08-04 12:27:27
CQG WebSocket | Connecting to WebSocket server. | 2018-08-04 12:27:27
CQG WebSocket socket (8) | Creating socket. Using TLS 1.2. | 2018-08-04 12:27:27
CQG WebSocket socket (8) | Error setting send buffer size to 0. Unknown Windows error code 10022. | 2018-08-04 12:27:27 *
CQG WebSocket socket (8) | Connecting to IP: 208.48.16.35. | 2018-08-04 12:27:27
CQG FIX | FCM name: AMP | 2018-08-04 12:27:27
CQG WebSocket | Opening WebSocket. | 2018-08-04 12:27:27
CQG WebSocket | Sending WebSocket handshake. | 2018-08-04 12:27:27
CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-08-04 12:27:27
CQG WebSocket | Header line. Connection: upgrade | 2018-08-04 12:27:27
CQG WebSocket | Header line. Sec-WebSocket-Accept: KZpXRSHGUMAk7DlRWbIWcDf15vM= | 2018-08-04 12:27:27
CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-08-04 12:27:27
CQG WebSocket | Header line. Upgrade: websocket | 2018-08-04 12:27:27
CQG WebSocket | Header line. | 2018-08-04 12:27:27
CQG WebSocket | Web socket state is now open. | 2018-08-04 12:27:27
CQG FIX Trading | WebSocket connected. | 2018-08-04 12:27:27
CQG FIX Trading | Sending market data logon message. | 2018-08-04 12:27:27
CQG FIX Trading | Base Time: 2018-08-04T04:10:57. 2018-08-04 04:10:57 | 2018-08-04 12:27:28
CQG FIX Trading | Logon successful. Session Token = DsTvB1qH1oolUj5Rj5Fz5KzT4QMcNXxHDS0B+Sl2lZI6bVlYncj8ryGkImUtguBCBqU18fp/Wxx | 2018-08-04 12:27:28
CQG FIX Trading | Connected to data and trading server. | 2018-08-04 12:27:28
Using Bid/Ask average for last trade price for GER30 | 2018-08-04 12:27:28
CQG FIX Trading | Starting real-time market data updates for: GER30. ID: 1 | 2018-08-04 12:27:28
CQG FIX Trading | Sending symbol resolution request for GER30. ID: 459403 | 2018-08-04 12:27:28
CQG FIX Trading | Requesting security definition data for: GER30. ID: 1 | 2018-08-04 12:27:28
CQG FIX Trading | Starting real-time market data updates for: F.US.ENQM18. ID: 2 | 2018-08-04 12:27:28
CQG FIX Trading | Sending symbol resolution request for F.US.ENQM18. ID: 459404 | 2018-08-04 12:27:28
CQG FIX Trading | Requesting security definition data for: F.US.ENQM18. ID: 2 | 2018-08-04 12:27:28
CQG FIX Trading | Received message: Requested symbol was not found. | 2018-08-04 12:27:28
Symbol Error - F.US.ENQM18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2018-08-04 12:27:28
Symbol Error - GER30 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2018-08-04 12:27:28
CQG FIX Trading | Starting real-time market data updates for: F.US.ENQU18. ID: 3 | 2018-08-04 12:27:28
CQG FIX Trading | Sending symbol resolution request for F.US.ENQU18. ID: 459405 | 2018-08-04 12:27:28
CQG FIX Trading | Requesting security definition data for: F.US.ENQU18. ID: 3 | 2018-08-04 12:27:28
Intraday data recording state for symbol F.US.ENQU18 is set to download 'Pending'. | 2018-08-04 12:27:28
Delaying start of download for F.US.ENQU18 | 2018-08-04 12:27:28
CQG FIX Trading | Received symbol resolution report for symbol F.US.ENQU8. Search Symbol: F.US.ENQU18. Request ID: 459405. Contract ID: 1. | 2018-08-04 12:27:28
CQG FIX Trading | Requesting market data for F.US.ENQU18 | 2018-08-04 12:27:28
Delaying start of download for F.US.ENQU18 | 2018-08-04 12:27:29
HD Request # 3 | Downloading Intraday chart data for F.US.ENQU18 to the file F.US.ENQU18.scid. Service: cqg | 2018-08-04 12:27:33
HD Request # 3 | Download start date-time: 2018-08-03 21:59:59.000 | 2018-08-04 12:27:33
HD Request # 3 | Using server: ds3.sierracharts.com port 10150 | 2018-08-04 12:27:33
Socket (9) | Creating socket. | 2018-08-04 12:27:33
Socket (9) | Error setting send buffer size to 0. Unknown Windows error code 10022. | 2018-08-04 12:27:33 *
Socket (9) | Connecting to IP: 65.182.172.42. | 2018-08-04 12:27:33
HD Request # 3 | Setting DTC encoding to Binary VLS | 2018-08-04 12:27:33
HD Request # 3 | Sending historical data logon request message. | 2018-08-04 12:27:33
HD Request # 3 | Requesting Intraday data. Start date-time: 2018-08-03 21:59:59. Record interval: 0. Symbol: F.US.ENQU18 | 2018-08-04 12:27:33
HD Request # 3 | Decompressing data. | 2018-08-04 12:27:34
HD Request # 3 | Receiving Intraday data for F.US.ENQU18 starting at 2018-08-03 21:59:59 | 2018-08-04 12:27:34
Socket (9) | Initiating close of socket by core. | 2018-08-04 12:27:34
Socket (9) | Shutdown started. Waiting for graceful close. | 2018-08-04 12:27:34
Historical data download thread signaled to stop. | 2018-08-04 12:27:34
HD Request # 3 | Received 2 records from 2018-08-03 21:59:59 to 2018-08-03 21:59:59 (0.0 seconds) and wrote 0 records for F.US.ENQU18 | 2018-08-04 12:27:34
HD Request # 3 | Completion time: 0s | 2018-08-04 12:27:34
HD Request # 3 | Intraday data download complete for F.US.ENQU18. Unique request ID: 2 | 2018-08-04 12:27:34
Removed historical data download ID 2 | 2018-08-04 12:27:34
Real-time Intraday chart data file updates started for F.US.ENQU18 | 2018-08-04 12:27:34
Intraday chart data file opened for F.US.ENQU18 | 2018-08-04 12:27:34
Socket (9) | Socket gracefully closed by remote side. | 2018-08-04 12:27:34
Socket (9) | Closed. | 2018-08-04 12:27:34
Private File
[2018-08-04 20:15:15]
This definitively is going to be a wine issue and from what we have heard it relates to using Transparency. Are you using a transparent filled Draw Style?
[2018-08-06 08:59:44]
I am not sure how to define that, I just selected the ab study for a blank chart. SC never misses a beat in wine normally and if a filled rectangle can be classed as what you mention above, it works fine.
If it is down to wine, I guess there is nothing I can do right?
[2018-08-06 09:08:59]
Our understanding is that the Wine developers resolved this. Just let us check on this and see what we can find out.
Can you tell us what version of Wine you are running?
[2018-08-06 10:13:03]
Thank you. 2.01 for wine and 4.2.12 for play on mac
[2018-10-12 12:23:12]
Any news on this one, still the same issue here. I'm running latest SC.
Many thanks
[2019-02-04 04:01:45]
uM8137 - Posts: 183
The Wine developers did some fixes in Wine 3.6, according to
comment 5 by Alexandre Julliard 2018-04-13 here, against SierraChart version 1280:
https://bugs.winehq.org/show_bug.cgi?id=39011
The fix mentioned above is viewable here:
https://github.com/wine-mirror/wine/commit/97f996744eafc4ad640ca3b9d97016625443c8cd
As of 2019-Feb-03, using Wine4.0 on Mac OSX 10.13.6 (High Sierra), I still
encounter several minute long hangs with both the
built in Senko-Span A&B, and with the Ichimoku study
collection from the additional files. This is under
SierraChart.exe 1865, 32-bit build. So there has been
a regression (in Wine), or the fix was incomplete. Or
possibly the latest SC is exercising new functionality
in Wine that is buggy.
This is not a SierraChart bug, rather a wine bug. This one instance is the only place where
I have found running SC on wine to have issues.
Date Time Of Last Edit: 2019-02-04 04:12:36
[2019-02-12 17:16:14]
uM8137 - Posts: 183
Follow up to last post:
Darnit. Not being able to view the cloud on wine/OSX is starting to really annoy me. I may have
to put on my C++ dev hat and dive into the wine debugging environment to fix this.
So a quick question for SierraChart developers: does the C++ code in SC for
Senko-Span A&B use some unique/distinct/different windows API calls compared
to other charting functionalities?
If there are different calls used (some distinction), that would help me track down what is
going wrong in WINE more quickly -- thanks!
