Date/Time: Sat, 22 Aug 2026 17:17:07 +0000
ACSIL - Formating a string that includes a SCDateTime type variable
View Count: 6319
[2018-02-26 18:13:09]
Zosimus - Posts: 345
Which specifier should I use for a SCDateTime variable when formating a string that icludes such a variable?. %f doesn't seem to be the correct specfier (SCDatetime is a double precision variable)
example:
SCString str;
str.Format("DateTime = %?", sc.BaseDateTimeIn[sc.Index])
Which specifier should come instead of the question mark?
[2019-03-08 23:07:43]
Andy Sureway - Posts: 93
Today I also run into this problem. It seems that this fundamental functionality is missing.
[2019-03-09 15:17:12]
ForgivingComputers.com - Posts: 1236
This should work:
SCString IndexDateTime = sc.DateTimeToString(sc.BaseDateTimeIn[Index], FLAG_DT_COMPLETE_DATETIME);
[2019-03-13 23:12:03]
Here is the documentation:
ACSIL Interface Members - Functions: sc.DateTimeToString()
When using the string Format function you would want to use %f if you want to actually see the internal numeric value of a SCDateTime type.
Date Time Of Last Edit: 2019-03-13 23:13:28
