Date/Time: Tue, 10 Nov 2026 16:29:02 +0000
Days full range not captured - ES futures
View Count: 1127
[2018-02-26 06:43:59]
User179195 - Posts: 6
Hi im wondering why the days high wasnt captured in the daily candlestick chart, whereas in my 60 minutes tab it shows the high that the s&p 500 furtures (ES) made late in the day. the daily chart shows the earlier high of the day of 27.75...but not the later high of 25 points higher....are there chart settings not capturing the data? mine is from Interactive brokers feed
[2018-02-26 07:01:03]
This is what we see at the moment:
http://www.sierrachart.com/image.php?Image=1519628378726.png
We need to know what particular Date in the chart you are referring to and the complete values you have a question about.
[2018-02-26 07:28:52]
thanks for quick reply - on Friday my high is showing as 2727.75 (23 Feb), but in your chart..its clearly a lot higher (the big green up candle)
in fact if I go to my own 60m chart, I can see the days high (Fri 23 Feb) is actually 2750.25....so its only my daily chart that doesnt have the complete data...
Is therr a way you could share your settings with me? Looks quite nice too your layout
[2018-02-26 07:35:40]
Right-click on the chart before that date and select Delete and Download Data to re-download the data.
Chartbook is attached.
attachmentChartbook41.Cht - Attached On 2018-02-26 07:35:34 UTC - Size: 31.34 KB - 485 views
