Date/Time: Tue, 10 Nov 2026 16:19:07 +0000
[Programming Help] - Order fill latency
View Count: 1306
| [2018-02-17 08:34:25] |
| User99735 - Posts: 234 |
Hi, While testing a study, it is found there is approx 1.5 sec delay between the order execution ( ie call to function sc.BuyEntry(NewOrder) / sc.SellEntry(NewOrder)), and the order fill time as it appears in the trade panel. Any suggestions on reducing this latency. Regards Vivek |
| [2018-02-17 23:31:53] |
This in part is going to be affected by the Chart Update Interval: Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) Any other delays are outside of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
