Date/Time: Tue, 10 Nov 2026 16:19:01 +0000
Trending lines shifting
View Count: 1062
[2018-02-17 03:12:44]
User306226 - Posts: 1
Hi, when I draw trending lines at swings highs/lows they tend to shift a little after zooming in and out.
If I draw paralel lines after a while they are not paralel anymore. What could be the problem?
[2018-02-17 23:33:09]
Refer to:
https://www.sierrachart.com/index.php?page=doc/helpdetails34.html
There has also been some improvement recently, to the extent possible, with this. Update to the latest release which you are not currently running:
Date Time Of Last Edit: 2018-02-17 23:33:22
