Date/Time: Tue, 10 Nov 2026 16:18:59 +0000
Number Of Bars to Label: -----------can not find it?
View Count: 953
[2018-02-16 06:30:26]
User536256 - Posts: 8
Study: Bar Numbering
Number Of Bars to Label: This Input specifies the number of chart bars to add number labels to. This is counted from the end of the chart. If this is set to -1, then all chart bars will have a label according to the Number Every N Bars Input.
I can not find it.
image无标题.png / V - Attached On 2018-02-16 06:30:08 UTC - Size: 28.18 KB - 423 views
[2018-02-16 17:11:03]
This has been removed in the newer versions because it is not needed to improve performance. Do you require this Input?
Date Time Of Last Edit: 2018-02-16 17:11:29
[2018-02-16 17:11:47]
The documentation has been updated to reflect the current functionality of this study. That Input was removed, as it is no longer necessary - now all chart bars will be numbered depending on the setting for Number Every N Bars.
The new documentation can be found here:
Bar Numbering
