Date/Time: Tue, 10 Nov 2026 16:19:05 +0000
[Programming Help] - OCO oder when log out sierra chart
View Count: 1010
| [2018-02-15 06:40:55] |
| User109710 - Posts: 21 |
The sierra chart display this message when I try to log out. You have open orders with your trading services. Do you want to exist ? If these open orders include client-side management attached order or trailing stop order, they will no longer managed. Do it mean the OCO orders will not be executed even I place the OCO order before I log out ? |
| [2018-02-15 18:52:10] |
Yes this is possible. How this works is fully documented here: Attached Orders: General Management of Attached Orders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
