Date/Time: Mon, 23 Nov 2026 12:22:04 +0000
monthly, weekly volume composite profile on TPO chart
View Count: 4380
| [2018-02-05 15:07:11] |
| whats1thingnow - Posts: 418 |
Hi support, Been trying multiple settings (https://www.sierrachart.com//index.php?page=doc/StudiesReference.php&ID=141&Name=Volume_by_Price#ExampleOfInputSettingsForDifferentTimePeriods) and still can't get this to work... I have a TPO chart. On the right side, I want to have a composite volume profile (e.g. volume profile of the last 3 months, last 6 months). Can you please point me to the documentation on how to do this? Thanks! |
| [2018-02-05 18:15:28] |
To do this for a TPO Profile Chart, refer to the particular Input settings here: https://www.sierrachart.com//index.php?page=doc/StudiesReference.php&ID=141&Name=Volume_by_Price#30MinuteVolumeProfileAtEndOfTPOProfileChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-05 18:15:45
| [2018-02-06 05:17:14] |
Thank you for your response. I followed this but changed it to try to get the last 3 months. However, it did not work. Here is what I did, please let me know how I can fix: Ticks Per Volume Bar: 1.
Volume Graph Period Type: One Period From Most Recent Period Start To End. Set As Independent Volume Profile for TPO Chart: Yes. Time Period Type for 'Fixed Time': Days Time Period Length for 'Fixed Time': 90 Maximum Volume Bar Width Percentage: 15. Right Aligned Volume Bars: Yes. Align to Far Right: Yes. I also tried the following and also did not work: Ticks Per Volume Bar: 1.
Volume Graph Period Type: One Period From Most Recent Period Start To End. Set As Independent Volume Profile for TPO Chart: Yes. Time Period Type for 'Fixed Time': Months Time Period Length for 'Fixed Time': 3 Maximum Volume Bar Width Percentage: 15. Right Aligned Volume Bars: Yes. Align to Far Right: Yes. |
| [2018-02-06 07:37:02] |
Set Volume Graph Period Type to: Volume By Price Study: One Period at End of Fixed Time Length Also we do not know what this means: However, it did not work. From our perspective it is meaningless.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-06 07:37:26
