Date/Time: Sun, 28 Apr 2024 14:29:41 +0000
study parameter control
View Count: 3471
[2018-07-01 13:37:54] |
Which specific Input are you referring to because none of the Volume by Price study Inputs contain both the date and time. Either a Date or a Time value. So it would make sense in the case of a date that the time component is all zero.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-01 13:46:22
[2018-07-01 13:49:48] |
dtl-saw - Posts: 79 |
You are correct. There is no issue with the function as reported in #24. It was my misunderstanding of the VbP inputs. Thanks |
[2018-08-09 21:04:02] |
@sstfrederik - Posts: 403 |
Hi SC, Is it possible to add the same functions for SCDateTime? So dates and times in other studies can be reset? Thanks, Frederik |
[2018-08-09 22:48:11] |
For this you can just use the function for changing a Double input. That will also affect SCDateTime values.
[2018-08-09 23:24:17] |
These are the functions we are referring to: sc.GetChartStudyInputFloat() sc.SetChartStudyInputFloat() They do work with doubles and not 4 byte floats. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-09 23:24:51
