Date/Time: Tue, 10 Nov 2026 16:08:47 +0000
Linked Studies are not affected by changes via Right clicking the Chart Header
View Count: 1082
| [2018-02-03 13:45:22] |
| Sporken - Posts: 82 |
Minor issues, present in v1689. If you have charts with linked studies and you right click the "chart header menu" and select Hide->Study (for example). It only affects that one chart, and not the studies on charts that are linked to it. The same applies if you modify the settings of that study in the same way (via the chart header). If instead you change the study settings via the "Chart shortcut menu" then the settings are applied correctly to the linked charts. Also, the Study settings "Duplicate" button does not call the newly created study with SetDefaults = 1; Date Time Of Last Edit: 2018-02-03 13:46:12
| [2018-02-03 14:02:34] |
Also, the "Chart Studies" window is annoyingly small. I cant see the study names without scrolling both horizontally and vertically (which is why I was using the Right click chart header to edit/show/hide the studies) Also, in the "Study Settings" window it is enormously laborious to make the same change to multiple subgraphs. It would be good if we could select several and apply the same change to all. Auto-coloring, Drawstyle, Line Style etc, Primary/Secondary colour etc.. Also, the Draw Style drop-down selector only shows 19 entries, which means I need to scroll it to find the one I want. |
| [2018-02-04 04:40:22] |
If you have charts with linked studies and you right click the "chart header menu" and select Hide->Study (for example). It only affects that one chart, and not the studies on charts that are linked to it. The same applies if you modify the settings of that study in the same way (via the chart header). Also, the Study settings "Duplicate" button does not call the newly created study with SetDefaults = 1; This is not supposed to happen! It would defeat the purpose of using Duplicate.Also, the "Chart Studies" window is annoyingly small. I cant see the study names without scrolling both horizontally and vertically (which is why I was using the Right click chart header to edit/show/hide the studies)
Refer to:Graphics Settings: Adjusting Size of Dialog Windows Also, the Draw Style drop-down selector only shows 19 entries, which means I need to scroll it to find the one I want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-04 05:28:44
