Date/Time: Tue, 22 Sep 2026 17:37:59 +0000
Quoteboard is not updating Open, Daily Change, Daily Change % ???
View Count: 1316
| [2018-01-29 21:00:25] |
| jsoviero - Posts: 84 |
Hi support, Please tell me what I am doing wrong? Last, High, Low and Volume are all updating normally? Open, Daily Change, Daily Change Percent are only reporting 00.0 Thanks for your reply... completely sorry to bother you with a trivial question |
| [2018-01-29 21:01:31] |
This post pertains to the QUOTEBOARD
| [2018-01-29 21:05:03] |
We checked and we do not observe this problem. Tell us just one of the symbols you are having this problem with. Just one symbol please.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-29 21:05:13
