Date/Time: Tue, 22 Sep 2026 18:28:49 +0000
Position line
View Count: 1025
| [2018-01-11 10:51:09] |
| User859795 - Posts: 51 |
Hello, I'm trying to change color on the Position line that shows up on the chart (Limit, Child server, target - stoploss), but no matter, what i change in Global - Graphics Settings, the background of those particular lines won't change. Can you please help? Thank you, Zolie |
| [2018-01-11 16:05:23] |
Make sure that the chart is using the Global Graphics Settings: Graphics Settings: Use Global Graphics Settings Instead of These Settings Sierra Chart Support |
| [2018-01-11 19:02:18] |
What you are referring to is the order lines. And there are Graphics Settings for the chart and also global settings. Make sure you are using the right Graphics Settings window: Graphics Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
