Date/Time: Tue, 22 Sep 2026 19:10:44 +0000
SIM Test While Trading Live On Two Separate Computers
View Count: 1096
| [2018-01-06 22:47:27] |
| User240019 - Posts: 112 |
I would like to Simulate a trading strategy live while I trade my regular account live but from another computer on my network. But - if I login from one computer the other computer cannot connect. Is there anyway to solve this? |
| [2018-01-07 01:06:51] |
You need to use the DTC Protocol Server to connect a sub instance to the main instance of Sierra Chart: Using DTC Server for Data and Trading in Another Sierra Chart Instance Although make certain that both instances are on the current version of Sierra Chart for this: Software Download: Fast Update Any instance where you want to do simulated trading, make sure that Trade Simulation Mode is enabled: Trade Simulation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-07 01:07:36
