Date/Time: Tue, 22 Sep 2026 19:11:45 +0000
Lost Studies in All Study Collection/Chart Templates
View Count: 2723
[2018-01-06 06:23:55]
User585845 - Posts: 17
I have lost the studies in all of my Study Collection/Chart Templates. Regardless of which Study Collection I select all of the studies are missing and my charts are blank. I am unable to follow the recommended procedure to add a screenshot/image because I have the chart studies window open and can't upload the screenshot this way. I think adding the imagines to my message this way is only way I can capture what the Chart Studies window is displaying. I appreciate your assistance with solving this issue. Thanks.
Date Time Of Last Edit: 2018-01-06 06:27:49
imageDBollingerBandSystem.jpg / V - Attached On 2018-01-06 06:22:30 UTC - Size: 252.95 KB - 541 views
imageIchimoku.jpg / V - Attached On 2018-01-06 06:22:50 UTC - Size: 305.88 KB - 560 views
imageMixedBag.jpg / V - Attached On 2018-01-06 06:23:04 UTC - Size: 339.6 KB - 491 views
imageMovingAverageSystem.jpg / V - Attached On 2018-01-06 06:23:21 UTC - Size: 291.37 KB - 563 views
[2018-01-06 08:11:24]
Many users have been affected by this.
This problem is caused by your antivirus software deleting the SierraChartStudies.dll file. You need to disable your antivirus/security software, at least temporarily.
For more information, refer to:
Software Download: Antivirus/Anti-malware Software Flagging Sierra Chart Installer or other Files as Unsafe/Infected
Once you do that, then update Sierra Chart with Help >> Download Prerelease to get the missing file. Instructions:
Date Time Of Last Edit: 2018-01-06 08:11:44
[2018-01-06 09:44:18]
Thanks for your help. I disabled my antivirus/security software and tried downloading the Prerelease multiple times with no success and kept getting "Installation completed with errors." As a last resort, I checked the quarantine folder of my antivirus/security software and found the SierraChartStudies.dll file in there. I was able to restore it from the folder and now everything is back to normal. Thanks again.
Date Time Of Last Edit: 2018-01-06 10:15:17
[2018-01-07 04:23:49]
Good. Thank you for the details.
