Date/Time: Thu, 12 Nov 2026 18:19:11 +0000
NG ERROR - Not plotting data on chart
View Count: 1083
| [2018-01-05 18:25:04] |
| User557464 - Posts: 5 |
Hi, Please, could you help me? All instruments i'm using are plotting data correctly on charts (CL, ES, NQ, YM, 6A, 6E, GC). The only one instrument that is not plotting data anymore is NG. Please, see attached file! |
Private File |
| [2018-01-05 22:56:21] |
Refer to help topic 3: Http://www.sierrachart.com/index.php?page=doc/helpdetails3.html Since you are using CQG, also refer to: CQG Trading Platform Service: Market Data Authorizations for Symbols/Exchanges Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
