Date/Time: Thu, 12 Nov 2026 18:19:07 +0000
Attached order qty 0 from DTC-SubInstance
View Count: 1120
| [2018-01-02 19:20:42] |
| DabbaDo - Posts: 150 |
V1674 Main instance -- submit market order with attached target-stop, all is good, TAL shows target and stop are sent with qty 1. Sub-instance, copy of the same chartbook, same submit, but TAL shows target and stop are sent with qty 0. I've done this with main instance connections to both Gain Demo and Interactive Brokers Demo, with the same result. FYI, I'm using NQH8/NQ-21803-GLOBEX, order qty 1, Targets/Stops Match .twconfig, TIF Day Cheers, Dale |
| [2018-01-03 04:47:44] |
In newer versions, Sierra Chart does use a quantity of zero for child orders when they are sent as part of a server-side bracket order when using the DTC protocol. This is for safety reasons because the quantities have to be controlled by the parent order management of the child orders in the instance where they are managed. But if you are also using server side bracket orders with these particular services there may be a problem. So we will have to test this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-04 18:20:25
| [2018-01-04 18:21:30] |
When not using the DTC protocol, and when a bracket order is received from a sub instance, a bracket order sent out to the external trading service, if supported, now has the proper quantity for child orders. This is in version 1682. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-04 18:21:41
