Date/Time: Thu, 12 Nov 2026 18:19:08 +0000
Spotware connect integration - cTrader/Spotware brokers
View Count: 3359
[2018-01-02 14:01:41]
BeardPower - Posts: 55
As Spotware supports a trading API, similar to the DTC protocol, called "Spotware connect" (https://connect.spotware.com/) besides FIX, I wanted to ask if there are already any plans to support it in the future. Spotware is currently designing a new account API based on OpenAPI v2.0, so I asked them to consider DTC as well.
If they don't want to support DTC or SC is not going to support "Spotware connect", I could create a DTC bridge myself. I just want to make sure workforce is not wasted on the same project.
Thank you!
[2018-01-02 18:26:52]
There are no plans to support that API at this time.
[2018-01-04 12:01:33]
ycomp - Posts: 334
please do, would be nice
[2018-01-04 18:41:36]
They really need to support the DTC protocol:
https://www.dtcprotocol.org/
This is the only reasonable possibility. The idea that we can be adding support for all of these external APIs is totally and completely unreasonable. And it is not something that we would do.
