Date/Time: Thu, 12 Nov 2026 18:09:12 +0000
ACSIL Order quantity
View Count: 1809
| [2017-12-19 12:22:28] |
| Trade Nice - Posts: 75 |
With ACSIL 1)How can i access the Default Order Quantity in Chart Settings? 2) Set the order quantity button values on the Trade Window?
| [2017-12-19 19:35:38] |
1. This is not available. 2. This is not available. We know what you want, we will have to add a separate option to reset the order quantities to default when the symbol changes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-12-21 11:11:30] |
Yes, thank you. The issue with default is very important when it comes to Forex in particular. Most trades might be for quantities less than 100, but Forex is going to be a minimum of 25k...that would be a lot of e-mini s&ps if someone forgot to manually change the quantity when they changed symbol....
