Date/Time: Fri, 13 Nov 2026 04:50:56 +0000
Cannot connect to Sierra-chart data feed
View Count: 1034
| [2017-12-05 21:19:31] |
| Davidside - Posts: 16 |
Hello, I renew my sierra chart data feed but from start of the month I cannot recieve any data with [M] symbol in the chart for E-mini Nasdaq - NQ. I also filled barchart agreements, but still nothig. Could you please suggest any solution? Thank you very much. David |
| [2017-12-06 00:10:13] |
Make sure Sierra Chart is connected to your live Interactive Brokers account. Refer to the instructions here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#IntegrationWithTradingServices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
