Date/Time: Sat, 27 Apr 2024 21:42:56 +0000
OandaDTC with SC forex data
View Count: 3330
[2018-01-21 20:54:58] |
onnb - Posts: 660 |
attached updated xml file
oandaforex.dtctrading.xml - Attached On 2018-01-21 20:54:20 UTC - Size: 117.15 KB - 533 views |
[2018-01-23 00:38:38] |
Lets say that I have symbol WHEAT_USD which has a Currency of USD
What we have now realized that <subscribe-to-common-currency-symbol> is not even used any longer. We will take it out. As long as this is the case: Common Profit/Loss set CAD, then Profit/Loss will be in CAD.
In SC, I have the Common Profit/Loss set CAD If subscribe-to-common-currency-symbol is true, I would see WHEAT_USD trade pnl in CAD? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-23 00:45:02
[2018-01-23 00:46:30] |
onnb - Posts: 660 |
Ok 1. Do you need anything from me at this time? 2. Do you have an ETA for a SC version to test/integrate my server with ? (No rush - just so I know roughly what to expect.) |
[2018-01-23 01:01:54] |
1. No. 2. This is done other than the market data support through the Sierra Chart servers. Not sure everything has been released yet but will be later today or tomorrow. Update: Not all of this has been released but will be. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-23 01:22:25
[2018-01-24 23:31:01] |
This has now been released in version 1693.
[2018-01-25 03:45:39] |
onnb - Posts: 660 |
Excellent - we will start to integrate with it in the next couple of days
Date Time Of Last Edit: 2018-01-25 03:45:49
[2018-01-27 01:13:31] |
onnb - Posts: 660 |
We've been integrating with this - the Oanda api key is 66 chartaters long. We see it being sent in the LOGON_REQUEST::GeneralTextData but it's missing 2 characters
[2018-01-27 06:28:21] |
There simply is no other choice but to change to Binary encoding with variable length strings, or use Google protocol buffer encoding.
[2018-01-27 07:14:10] |
onnb - Posts: 660 |
Ouch - I'll need to digest that and get back to you
[2018-01-27 07:20:38] |
Just sent you an email about this. Also refer to: OANDA Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-27 07:20:47
[2018-02-04 20:55:40] |
onnb - Posts: 660 |
I have the VLS change done and it is working very well. About the GlobalSymbolSettings for Oanda After the DTC logon request, we send over the symbol definitions
You do not need to do this. The use of Symbol Settings in a XML file that we provide from our server is much more preferred.
I am no longer going to be sending the symbol definitions through the DTC protocol. How does the OandaDTC global symbol settings xml file get distributed? I currently do not see it in SC folder. Date Time Of Last Edit: 2018-02-04 20:58:09
[2018-02-04 21:04:24] |
How does the OandaDTC global symbol settings xml file get distributed? From the Sierra Chart Web server.I currently do not see it in SC folder. You can confirm the settings are received by seeing the symbols in File >> Find Symbol. We verified that the settings are automatically provided because we see the symbols you set up. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-04 21:04:52
