Date/Time: Sun, 28 Apr 2024 02:13:50 +0000
New Study Summary Window
View Count: 19350
[2017-12-03 01:04:33] |
I have multiple time frame slow stochastic study price overlays in chart region 2. I need all the data from them to enter the study summary window at all times. Make sure each of these has a different name and change the Short Name for each one to make them unique if necessary. They probably are already unique because the Study/Price Overlay study will create unique names based on the chart and study being referenced.IF I hide the 1 and 2 stochastics from region 2 on the chart, they are also hidden from the study summary window. https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Just let us know what chart number it is you are referring to with the stochastics. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-03 01:06:31
[2017-12-05 03:38:40] |
User379468 - Posts: 508 |
Is it possible to modify this feature to pull from multiple chartbooks (to reduce redundancy of open charts needed), and also to integrate it's output into the quoteboard?
[2017-12-05 04:03:03] |
We will see if we can have it support multiple Chartbooks. Will try that, this evening. It would be best, for the study Summary to add Quote Board fields. That would be most practical. What particular fields are you looking for? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-05 04:03:15
[2017-12-05 04:41:13] |
4646ed - Posts: 230 |
Symbol,position.alert. And could you make it so you can hide/delete columns? Date Time Of Last Edit: 2017-12-05 04:46:59
[2017-12-05 04:48:51] |
Symbol is already in the first column. For Position do you mean the current Trade Position Quantity? And there is already background coloring that can be set when either a chart alert or a Study alert is true. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-05 05:03:01] |
Are you going to add Quote Board Columns to Study Summary or vice versa? If adding TO Study Summary, QuoteBoard "symbol" is more compact than Study Summary "symbol". Trade Position Aggregated Quantity and Trade position Aggregated price. Difference (+/-) between LAST and trade position price would be good. QuoteBoard has a price alert setting that would be good in the study summary. The study and chart alerts are already good, you're right. One study summary window across all chartbooks that incorporates most of quoteboard,alert manager info,some basic trade-info, but compact and column-customizable would be the best. One instead of 3 or more windows saves screen real estate and makes trade assessment and decisions faster and better. Date Time Of Last Edit: 2017-12-05 05:13:11
[2017-12-05 05:18:45] |
Either in the Quoteboard, or in the Study Summary, but ideally one solution which includes both current Quoteboard functionality (Last, High/Low, Percent from High/Low, Net Change, Net Change %, Open, Settlement, Bid-Ask Spread, Volume, Position Qty), and also Study Summary subgraph outputs, and being able to pull from all chartbooks.
[2017-12-05 05:25:36] |
Yes. Same as above post. And customizable. And includes basic current aggregate trade info. And quoteboard style price alerts Date Time Of Last Edit: 2017-12-05 05:38:56
[2017-12-05 20:21:30] |
sampater - Posts: 243 |
One Study Summary Window across all chartbooks that incorporates the Subgraph outputs from all charts from all chartbooks. But compact and column-customizable would be the best. |
[2017-12-07 09:32:45] |
We are working on adding support for all charts in all Chartbooks. This should be out in a couple of hours. And adding customizable Quote Board fields. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-07 10:03:11] |
Prerelease version 1661 with support for multiple Chartbooks in the Study Summary is now available. You need to enable Settings >>Include All Chartbooks Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-14 23:40:54] |
User472677 - Posts: 316 |
Hi, Excellent work! When are you going to add to the summary window day high, day low and alert capability exactly same as is in the quote board. Scree real estate is important. Right now it is taking too much space with both quote board and summary window on the screen. |
[2017-12-15 00:13:45] |
This is currently in progress and we hope it will be out next week.
[2017-12-15 13:29:43] |
infpz - Posts: 826 |
Here is a video on the Study Summary showing a basic example as well as a moderately advanced one: https://www.youtube.com/watch?v=LBSKPjLciIw&t=6s&list=PLxnPJP62Qw4Wvkv6fAiKtyGr3-VdPN21x&index=1
[2017-12-15 17:09:42] |
Thx. Please be sure to include all of the functonality Of the quote board. |
[2017-12-15 23:57:53] |
Sierra Chart, Can you support displaying in the Study Summary Window a value of subgraphs that have the Draw Style: Ignore and Hidden? I have custom studies that have special calculations assigned into subgraphs, which can not be displayed graphically in the chart but i would like using it in the Study Summary Window. Date Time Of Last Edit: 2017-12-16 00:08:08
[2017-12-16 21:12:13] |
In response to post 42, we will add this. It will just be the Subgraphs >> Include in Summary which will control whether the Subgraph is displayed or not in the Study Summary.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-16 22:40:20
[2017-12-16 22:45:25] |
There is also another issue. Currently, the option Subgraphs >> Include in Summary is enabled by default for new studies. But, i have custom studies that contain several dozen subgraphs and only one or a few i want add to the Study Summary Window. Because of it i will have to manually disabled most of them after modyfication that requires the study to be added again. So, can you change it to disabled by default or / and add a possibility to control every subgraph by ACSIL? |
[2017-12-17 05:50:31] |
The Subgraph >> Include in Summary option will be controllable from ACSIL. Also, we decided that as far as including hidden Subgraphs, that will be an option. Not by default. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-17 06:19:12] |
This is a really great video: https://www.youtube.com/watch?v=LBSKPjLciIw&t=6s&list=PLxnPJP62Qw4Wvkv6fAiKtyGr3-VdPN21x&index=1 When you see the particular Alert Condition true for a particular chart, you can then double-click on that line in the Study Summary to jump immediately to that chart: Study Summary Window: Navigating to Charts from Study Summary Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-17 06:19:29
[2017-12-18 21:10:01] |
In prerelease 1671 there is support for all of the standard Quote Board fields. And also the ability to include hidden Study Subgraphs. All of this is controlled through the Settings menu. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-18 23:42:55
[2017-12-19 01:16:45] |
Neo - Posts: 198 |
This is awesome so far! Well done SC.
[2017-12-20 21:18:06] |
Is there any documentation about it?
[2017-12-21 02:24:05] |
In the prerelease 1671, if i add a new study, hidden Subgraphs still have the Include in Summary option enabled by default.
