Date/Time: Tue, 29 Sep 2026 12:03:26 +0000
[User Discussion] - new release 1649 and error C2758
View Count: 1541
| [2017-11-22 21:15:44] |
| b3cker - Posts: 34 |
After installed upgrade my project in MVS does not build. Error internal to Sierra Charts? 1>c:\sierrachart\acs_source\vapcontainer.h(337): error C2758: 'c_VAPContainerBase<t_VolumeAtPrice>::m_InitialAllocationElements' : must be initialized in constructor base/member initializer list multiple vapcontainer.h errors Thank You Gary |
| [2017-11-22 21:28:31] |
You will need to update Visual C++ to the current version.
| [2017-11-22 21:41:07] |
| gomifromparis - Posts: 244 |
you can also continue building with VS2010 by using an old header file (ie an old version of the acs_source folder)
| [2017-11-22 21:48:37] |
What new version would it be? Where can I downloaded it from? Would it require reconfiguring my build? Thank You |
| [2017-11-22 21:53:55] |
Post #4 is fully outside the scope of our support. Furthermore, Microsoft Visual Studio has become an unstable program. At some point we are going to have to move away from it ourselves. We recommend using the Remote Build command within Sierra Chart. Refer to: Advanced Custom Study Interface and Language (ACSIL): Step-By-Step Instructions to Create an Advanced Custom Study Function Use Visual C++ at your own risk. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-22 21:55:37
| [2017-11-22 21:54:05] |
Is it Visual Studio Community 2017?
| [2017-11-22 21:55:15] |
Yes.
| [2017-11-22 22:09:28] |
Let me see if I understand this correctly, you want me to remote compile witch will expouse my source code to you and your server? The only reason I am using C++ and your application, and not C#, is to secure my code. Regards GB |
| [2017-11-22 22:18:35] |
Where can I get old version of the acs_source folder? Thank You |
| [2017-11-22 22:28:32] |
Let me see if I understand this correctly, you want me to remote compile witch will expouse my source code to you and your server? The code is transmitted over a TLS secure connection and after the compilation, it is simply deleted immediately.Contrary to what anyone would think, we could care less about a users source code. We would never ever look at that. We could care less about it. We only have an interest in the code that we develop. Not others. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-22 22:29:46
| [2017-11-22 22:45:22] |
Just install an old version of sierra and keep the acs source folder. I build using VS2017 but using a VS2010 target, I don't want to have to deploy VS1017 universal CRT stuff on target computers Yes you can also use remote build, but if need to add some files to the linker it won't work. |
