Date/Time: Fri, 13 Nov 2026 05:05:09 +0000
[Programming Help] - Working with Arrays *** Advanced Custom Study/System Interface and Language (ACSIL)
View Count: 1392
[2017-11-16 12:32:53]
User635423 - Posts: 51
I would like to assign a character string approx. 100 characters to every bar in the study or alternatively an integer values array, consisting of 100 values.
If this is possible what is the maximum length of the character string or the maximum size of the integer values array?
Thank you
[2017-11-16 19:00:49]
Have a look at the available Draw Styles here to see if you can accomplish what you need:
http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#DrawStyle_Line
In particular you might be interested in:
http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#DrawStyle_CustomValueAtY
http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#DrawStyle_Text
[2017-11-17 16:37:54]
User597042 - Posts: 5
My question has nothing to do with drawing. You have probably posted an answer to a wrong question.
