Date/Time: Fri, 13 Nov 2026 05:17:11 +0000
QuoteBoard Color based on + or - value of last?
View Count: 1194
| [2017-11-09 17:33:41] |
| jsoviero - Posts: 84 |
When using the Sierra Charts QuoteBoard is it possible to have the individual symbols or symbol fields to be colored in red if they have just down ticked or green if they have just up ticked? Please provide a link to the instructions how to enable this tick by tick feature. thank you |
| [2017-11-09 20:07:38] |
Yes this is possible. Here is the relevant documentation for this: Getting Quotes: Setting Colors Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
