Date/Time: Sat, 26 Sep 2026 15:05:36 +0000
BID ASK producing crazy outlier prints.
View Count: 1046
| [2017-10-16 15:56:50] |
| Robert D - Posts: 24 |
The BID and ASK on chart during live trading is showing prints 2 dollars outside of range on a very liquid stock. Example: the ASK on PCG is going 53.47, 53.50, 56.78, 54.75 53.50,53.50,56.23, The ask on the TWS is in line with 53.50, 53.51., 53.47. I am using sierra data with IB data. How can this be corrected.
| [2017-10-16 16:50:09] |
At approximately what time and time zone do you notice this?
| [2017-10-16 17:27:41] |
It is happening now at 13:21 New York. 10:21 PST where Im at. Now the Bid is dropping $2.00 plus on PCG, I am only trading this so not sure if it is doing it on other equities. My Computer clock is 10:21 the Chart clock is on New york time. Feel its a glitch, but creates unnecessary anxiety seeing the bid drop 1.50 below your hard stop!
| [2017-10-16 19:07:30] |
We have to let our data provider Barchart know about this.
| [2017-10-16 19:13:25] |
This is what we are going to show them: http://www.sierrachart.com/image.php?Image=1508181195868.png Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-10-16 20:54:14] |
Thank you hope they can fix it. It was showing bid ask spreads of over $5.00 on JP later in the day. So it is not a problem with that one equity.
| [2017-10-16 21:15:17] |
We have let them know about this. If this is not normal certainly they will fix this. It certainly does not appear normal to us.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-16 21:32:26
