Date/Time: Fri, 13 Nov 2026 05:45:20 +0000
Failure when compiling google protoc-buffer
View Count: 1366
[2017-10-12 15:30:38]
User178540 - Posts: 15
I am trying to complie the google protoc buffer for JAVA using MAVEN (in order to genrate JAVA class from the .proto file):
I have downloaded version 3.4.0, and also the protoc.exe file with version 3.4.0.
both mvn test & mvn install ends with several failures,
Thanks!
[ERROR] COMPILATION ERROR :
[INFO] -------------------------------------------------------------
[ERROR] /C:/work/proto/3.4.0/protobuf-3.4.0/java/core/src/test/java/com/google/protobuf/TestUtil.java:[33,34] cannot find symbol
symbol: class UnittestLite
[ERROR] /C:/work/proto/3.4.0/protobuf-3.4.0/java/core/src/test/java/com/google/protobuf/TestUtil.java:[33,1] static import only from classes and interfaces
[ERROR] /C:/work/proto/3.4.0/protobuf-3.4.0/java/core/src/test/java/com/google/protobuf/TestUtil.java:[34,34] cannot find symbol
[ERROR] /C:/work/proto/3.4.0/protobuf-3.4.0/java/core/src/test/java/com/google/protobuf/TestUtil.java:[34,1] static import only from classes and interfaces
[ERROR] /C:/work/proto/3.4.0/protobuf-3.4.0/java/core/src/test/java/com/google/protobuf/TestUtil.java:[35,34] cannot find symbol
[ERROR] /C:/work/proto/3.4.0/protobuf-3.4.0/java/core/src/test/java/com/google/protobuf/TestUtil.java:[35,1] static import only from classes and interfaces
[ERROR] /C:/work/proto/3.4.0/protobuf-3.4.0/java/core/src/test/java/com/google/protobuf/TestUtil.java:[36,34] cannot find symbol
Date Time Of Last Edit: 2017-10-12 15:32:52
[2017-10-12 17:26:56]
Make sure you are compiling this particular file:
http://dtcprotocol.org/DTC_Files/DTCProtocol.proto
All of these error messages relate to code outside of the protocol buffer file linked above. We have no idea what the problem is. We recommend running an Internet search for these particular messages.
