Date/Time: Fri, 13 Nov 2026 05:45:15 +0000
ZigZag swing volume alerts
View Count: 2808
[2017-10-09 21:50:33]
samual sprat - Posts: 343
I've been using the Zigzag study to plot swings along with volume, using the 'Display ZigZag Volume' option. I would like to create an alert condition that checks to see when a wave is completed and reversal condition is met, and then compares the volume of the wave to the previous swing/swings. If current swing has less volume than the previous it creates an alert. Is this possible using Colour Bar study or Spreadsheet?
S
[2017-10-11 09:52:47]
Yes, this should be possible using the Spreadsheet System/Alert Study:
Spreadsheet Systems, Alerts and Automated Trading
You will want to use the Zig Zag study and also the Zig Zag Cumulative Volume study (for the volume at each chart bar) :
Zig Zag
You will need both of these.
Follow the instructions here to enable the Zig Zag HH,HL,LL,LH labels:
Zig Zag: Text Labels Subgraph Description
Using the Zig Zag Cumulative Volume study, and the Text Labels Subgraph to determine where the reversals occur, you can determine what you need.
Date Time Of Last Edit: 2017-10-11 16:54:59
[2017-10-11 16:56:03]
The prior post has been updated.
You will want to use the Spreadsheet System/Alert Study for this alert:
