Date/Time: Fri, 13 Nov 2026 05:57:10 +0000
data failure
View Count: 897
| [2017-09-26 19:45:26] |
| haritzaldazabal - Posts: 4 |
sometimes some charts freeze and i have to disconnect and connect again to get live data-I usually have 5 windows opened, maybe 4 of them are working okay but 1 is frozen, whats the problem? i happens with any ticker at any time.
| [2017-09-27 04:08:42] |
How many symbols is Sierra Chart tracking when you have this problem. To determine this, refer to: Status Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
