Date/Time: Fri, 13 Nov 2026 05:57:11 +0000
price range became tens of thousands
View Count: 1392
| [2017-09-26 17:38:47] |
| taipeicity - Posts: 52 |
it happened suddently since last week, I have done nothhing to the chart, it happens to almost all symbols, STW, ES, GC , YG http://www.sierrachart.com/image.php?Image=1506447155444.png |
| [2017-09-26 18:35:56] |
Go to the chart and select Chart >> Reset Scales. Here is further information about this: Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales. Make sure that all of the studies in the Chart Region 1 use a Same as Region scale: Chart Scale and Scale Adjusting: Basing Scale Only on Price Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-09-27 01:25:36] |
did what u said, not help as i said, it just happened last week,, no problems for last 3-5 months |
| [2017-09-27 03:34:15] |
We want you to set the Scale Range for the main price graph to Automatic. Follow the instructions here: Chart Scale and Scale Adjusting: Opening the Scale Settings Window for the Main Price Graph After this, go to the chart and select Chart >> Reset Scales. Make sure that all of the studies in the Chart Region 1 use a Same as Region scale: Chart Scale and Scale Adjusting: Basing Scale Only on Price Bars If this still does not help, start a new chart without studies because you apparently are not understanding the instructions we are giving or there is a study working in a way which we do not expect. Possibly it is a custom study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-27 03:35:46
