Date/Time: Mon, 10 Aug 2026 07:40:18 +0000
Study - Symbol Display
View Count: 1135
| [2017-09-15 04:11:50] |
| nicktrader - Posts: 811 |
For a long time I use the Study "Symbol Display" and so far everything has been displayed correctly. For some time now I get after starting the platform a faulty display of the Study (Release 1609). To fix the error I change the TF and then return to the original. The problem only occurs on the first chart. |
Attachment Deleted. |
| [2017-09-15 04:58:16] |
Goto that chart and select Tools >> Manage Chart Drawings Window. There will be 2 text drawings from that study there. Remove both of them. We are also making some changes to the study which will be out in version 1612 in about two hours. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
