Date/Time: Tue, 22 Sep 2026 07:04:37 +0000
IB connection problem
View Count: 2006
| [2013-09-04 22:55:22] |
You need Trader Workstation 9392 or higher. You can get it from here: https://download2.interactivebrokers.com/download/tws40_upgrade_latest.exe Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
