Date/Time: Thu, 22 Oct 2026 12:21:25 +0000
ASX live data
View Count: 3300
| [2017-09-03 21:44:23] |
| User838789 - Posts: 2 |
I am looking at using Sierra Charts for ASX stocks. It is not under the supported exchanges area. Does Sierra chart provide historical data for this exchange? If I wanted live ASX data which provider is compatible?
Date Time Of Last Edit: 2017-09-03 22:21:15
| [2017-09-04 01:11:11] |
| Neo - Posts: 198 |
Historical Yes, Real-time No. Interactive Brokers is the only supported option for Real-time ASX stock data. http://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Stocks&ID=1#ASX |
| [2017-09-04 18:44:22] |
For historical data use the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service Here is the symbols page: http://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Stocks&ID=1#ASX For real-time data use Interactive Brokers: Interactive Brokers Trading Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-09-07 10:35:41] |
Is there a way to have the historical data stream? On the trial I am currently only seeing a delayed snapshot each time I load a chart and it doesn't automatically update. Does Sierra provide streaming data that is delayed?
| [2017-09-07 16:57:22] |
Refer to step 14 here: Sierra Chart Historical Data Service: Setup Instructions Does Sierra provide streaming data that is delayed? The most that is available is what is described at step 14 linked above. We would have to check though but this feature may not work with that particular exchange.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-07 16:58:49
| [2018-08-09 01:30:04] |
| User629461 - Posts: 213 |
Hi there, following on from this thread, is Interactive Brokers still the only supported ASX live data provider for SC? I hear mixed reviews about the data quality, particularly around volume accuracy which for me is critical. I've just signed up for a trial and before proceeding would need to clarify this. Any assistance is much appreciated. Thanks |
| [2018-08-09 05:23:57] |
Yes this is still correct.
| [2019-04-17 09:13:44] |
| User745789 - Posts: 402 |
2019 follow up... CQG provides ASX equities data. Can't be used with SC? Feed only, not trading. Date Time Of Last Edit: 2019-04-17 09:24:23
| [2019-04-17 10:33:10] |
You can certainly use whatever market data that CQG provides. You just need to use the appropriate CQG symbols: CQG Trading Platform Service: CQG Symbol Format Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
