Date/Time: Sat, 05 Jul 2025 18:29:17 +0000
Bitmex group orderbook depth
View Count: 4493
[2017-11-10 16:37:32] |
This is resolved.
[2017-12-02 13:01:32] |
User198817 - Posts: 56 |
Ask side is not in sync with the actual market depth. http://www.sierrachart.com/image.php?Image=1512219635920.png Issue has been around the whole day. Date Time Of Last Edit: 2017-12-02 13:42:29
[2017-12-02 18:22:38] |
This is now resolved. Let us know if there any issues. The depth issues were resolved couple of days ago on one of our servers but we did not want to do the release to the other server until we were sure everything was OK. We want to explain why there have been so many issues with BitMEX market depth. In the Crypto currency markets, there can be a large number of market depth levels, and for crypto currencies like Bitcoin with high values, they should be combined into a larger increment. We had developed new code which does very efficient combining rather than performing a full combined of an uncombined order book at every price update. This was worked on by one of the newer developers, and there were some problems with this, but really this code should not be used with BitMEX now that they have increased the increment to .5. So we have simply removed this code. It will be worked on later as we work on integration to other crypto currency exchanges and update the integration to the existing exchanges. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-02 18:26:19
[2017-12-02 18:38:37] |
N!co - Posts: 140 |
Support , I have to disagree with your statement "but really this code should not be used with BitMEX now that they have increased the increment to .5" Bitcoin is VERY volatile eazy it moves +300$ ( @0.5 that makes 600 ! ticks) in 1 minute , see screenshot the DOM is nearly imposible to read without combining the increment of ticks so please do NOT remove this code also I want to ask you to resolve the issue in the following thread as it is related to this ( screenshot) chart dom Date Time Of Last Edit: 2017-12-02 18:40:34
[2017-12-15 19:29:31] |
rocdjc - Posts: 12 |
Can you please add decimal to the Advanced Settings "Market Depth Combine Increment in Ticks" please? Many Crypto coins are sub .0 Thank you. |
[2017-12-15 19:36:48] |
No, this does not make sense because that setting is based on ticks. You need to alter the Tick Size to your requirements: Chart Settings: Tick Size (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-15 19:37:54
[2017-12-15 19:44:19] |
N!co - Posts: 140 |
Support , please adress this issue in this post chart dom i post it again here because it seems that the original post does not receive any response thx |
[2017-12-16 21:32:29] |
We did respond already to that thread.
