Date/Time: Sun, 04 Oct 2026 11:11:45 +0000
Changing chart symbols using different broker datafeeds
View Count: 1045
| [2017-08-29 20:26:04] |
| Willson - Posts: 176 |
I wish to quickly switch between two brokers each having different symbols for many of the data streams. I am using one SC instance and identical charts (except for symbols). If I use different credentials for account sign-in, will SC change the chart symbols to the alternate set used by the second broker that I sign-in to? I am sure that I can do this with two SC instances, but I make many chart changes and I can't imagine keeping both instances synchronized. |
| [2017-08-29 20:59:25] |
will SC change the chart symbols to the alternate set used by the second broker that I sign-in to? No.
