Date/Time: Sun, 04 Oct 2026 10:08:56 +0000
hide chart drawings
View Count: 1437
| [2017-08-15 05:53:15] |
| dtl-saw - Posts: 79 |
is there a way using ACSIL to find all the RAY user drawings and hide them (not delete) similar to the "Hide Chart Drawings | HCD" available in the tools menu? I'd like to be able to push a user configurable toolbar button and hide all the 'rays' for example and then later unselect the button to unhide the 'rays'. Behavior similar to the Sierra native HCD button.
| [2017-08-15 17:14:46] |
We will see if we can support this. What we are going to look into, is the ability to hide a chart drawing from ACSIL. The remaining details you will have to work out because we do not provide programming help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-08-18 03:02:53] |
This will be out in the next release.
