Date/Time: Fri, 13 Nov 2026 22:08:39 +0000
up/down ratio NYSE Volume
View Count: 2051
| [2017-07-23 12:03:27] |
| User968625 - Posts: 260 |
Hello, I have IQFeed with Up volume, down volume, total Volume and Up-Down Volute. I need the simple ratio of up/down. Also, can this be displayed as a number on a any chart chart? Thanks for the help |
| [2017-07-23 14:31:07] |
Use the Ratio study: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=5#Ratio_-_Bar And use the Text Display for Study study: Text Display For Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-07-23 17:08:21] |
thank you
| [2017-07-23 22:04:37] |
Please do not say thank you.
| [2022-11-02 18:47:07] |
| Hopeman - Posts: 166 |
Thank you very much!
