Date/Time: Sat, 27 Apr 2024 21:29:28 +0000
New Non-CLR Spreadsheet Study Study Reference Method
View Count: 15095
[2014-08-15 11:05:25] |
Outlander - Posts: 91 |
I still have problem with volume by price indicator.The alternate reference method only works on SG2. I would like to plot SG3 and SG4. Regards Outlander
[2014-08-15 11:31:15] |
It should work fine no matter what the Study Subgraph is. We need more information about the problem. What specifically is the issue? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-15 11:38:25] |
I get the same error "#NAME?" Referring to SG2 works but not SG3 and SG4 Regards Outlander |
[2014-08-15 17:00:35] |
In the case of the Volume by Price study the following Study Subgraphs are set to be excluded from Spreadsheets: Value Area High Value Value Area Low Value We cannot change this because it will affect Study subgraph references when the formulas are using the standard spreadsheet reference method. We recommend using the Volume Value Area Lines study to get this data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-16 11:39:09] |
I use numbers of bars for fixed bar count. The volume area lines dos not have that option. Regards Outlander
[2014-08-19 06:52:38] |
This is not something we can solve without causing problems with cell references in formulas for existing users. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-19 06:53:29
[2014-08-19 13:29:38] |
Sawtooth - Posts: 3980 |
SC, you could do what you do in the Zigzag study: create an option for Additional Outputs for Spreadsheets.
