Date/Time: Thu, 08 Oct 2026 20:49:25 +0000
Volatility Trend Indicator
View Count: 4935
| [2017-06-10 15:19:32] |
| TerellDunn - Posts: 8 |
What is the formula for this indicator? https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=155#Volatility_Trend_Indicator |
| [2017-06-12 17:54:43] |
We will update the documentation with the formula. It will be done by the end of the day tomorrow.
| [2017-06-12 20:01:12] |
Can you also elaborate on what drives the auto coloring of the indicator?
| [2017-06-12 20:13:19] |
We will make sure the documentation explains this.
| [2017-06-19 05:37:53] |
Bump.
| [2017-06-19 18:22:25] |
We should have this out in a couple of hours.
| [2017-06-20 03:11:48] |
| SC Support Tom - Posts: 450 |
Hello Terell, I have just uploaded a complete description of the VTI calculation. http://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=155#Volatility_Trend_Indicator |
| [2017-06-20 15:33:27] |
Thank you. I can see why it took some time.
Date Time Of Last Edit: 2017-06-20 15:34:28
| [2019-02-28 18:11:40] |
| User564539 - Posts: 27 |
Hi Why the value of Volatility Trend is not coming as 1 or -1 as per the color of the graph red or green. Spreadsheet values are showing an average price value as below; [ID7] Volatility Trend Indicator [ID7.SG1] Volatility Trend [ID7.SG5] Dynamic Period Length 3895.883056640625 26 3906 25 3875.506591796875 24 3884.422119140625 23 3884.512939453125 22 3897.558349609375 21 |
| [2019-02-28 22:42:46] |
The price information is the correct result for the Volatility Trend Indicator. This is reflected in the documentation for this study. The values of 1 or -1 are just the directional values of the study and as you state, are reflected in the coloring. You will find the documentation for this study here: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=155#Volatility_Trend_Indicator If the Directional information is something you want to use, you can modify the study, as the code is available in the file studies.cpp. Follow the instructions here for how to build a custom study: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
