Date/Time: Fri, 13 Nov 2026 09:51:57 +0000
how to merge old SC scid file
View Count: 1397
| [2017-06-04 20:09:50] |
| User61576 - Posts: 458 |
i have an old tick data file for symbol X 12-2011 till 02-2015 and i have another current scid file for same symbol X from 06-2015 till today how can i merge both files into 1? |
| [2017-06-04 21:25:30] |
Refer to: Join Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
