Date/Time: Fri, 13 Nov 2026 09:51:54 +0000
chart update interval
View Count: 2269
| [2017-06-02 20:02:46] |
| User103949 - Posts: 78 |
Hi, Is it possible to set this interval to less than 20 milliseconds? For example 5. Will it still work? Thanks, |
| [2017-06-02 20:08:11] |
You can go down to 10 milliseconds on the chart itself. Refer to: Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-06-02 20:50:57] |
so any number below 10 will not work?
| [2017-06-02 20:57:31] |
No.
| [2017-06-02 21:03:37] |
how can i get the different ticks within minimum update interval?
| [2017-06-02 21:48:36] |
Do you mean using the Advanced Custom Study Interface and Language? If so, use this function for that: ACSIL Interface Members - Functions: sc.GetTimeAndSales() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-06-02 23:03:28] |
Thank you. One related question, if there is a minimum update interval for the chart, sc.Index is referring to number of ticks from the chart but not the actual all ticks which are not showing in the chart in between the update?
| [2017-06-02 23:52:24] |
sc.Index refers to chart bars only. And is fully documented here: Working with ACSIL Arrays and Understanding Looping Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-02 23:52:53
