Date/Time: Fri, 13 Nov 2026 09:51:57 +0000
Request for feature
View Count: 937
| [2017-06-02 09:21:38] |
| BrMa - Posts: 80 |
Dear ladies and gentlemen, I have a small request for a "new" feature to help me to have a better overview on marks within the chart. Currently the default position of a mark's label is on the left hand side of the drawing and within the options there is a possiblity to put "Labels On Right". Well, if you have historic marks with "Labels on Right" (otherwise you do not see the mark's label in the smaller view) it sums up with labels of the smaller view and they are hard to read. Would it be possible to have a third option that shows the mark's label on the left hand side of "smaller view" window? There is normally plenty of space... I put an example as an attachement to the message - maybe it's easier to imagine what I mean... If you do have any questions or I was not clear enough please don't hesitate coming back to me! Thanks a lot of advance! Regards, Markus |
