Date/Time: Fri, 13 Nov 2026 09:51:56 +0000
Histogram on DOM
View Count: 1109
| [2017-06-02 08:06:46] |
| User240686 - Posts: 86 |
Is it possible to put a histogram on the DOM for the Current Traded Bid and ASK Volume? I can see it can be done on the bid and ask columns but what about the totals for current traded bid and ask Thanks |
| [2017-06-02 17:27:25] |
This is not supported but is currently planned.
