Date/Time: Fri, 13 Nov 2026 09:51:56 +0000
How to show gap on P&F Chart
View Count: 1767
| [2017-06-01 07:27:26] |
| Fabio - Posts: 154 |
Good morning, I can't find any option that allow me to see where the market close in the evening and reopen the day after. I just have 2 normal bar as the session continues but if I am going to see the same chart on another time frame, such as minute chart, I can notice the existing gap between the closing and opening time. In both chart the session has been set from 7:00a.m. to 20:59:59pm (as per London session) Please, find attached to see what I mean. How can I do in order to fix the problem? Thanks, Fabio. http://www.sierrachart.com/image.php?Image=1496301996821.png http://www.sierrachart.com/image.php?Image=149630203516.png |
| [2017-06-02 03:01:21] |
This actually appears to be a limitation or potential problem with the current Point and Figure bars. We are looking into this now.
| [2017-06-02 17:10:01] |
Update to version 1565. This is the latest "Prerelease". Here are instructions: http://www.sierrachart.com/index.php?page=doc/SoftwareDownload.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-06-03 03:12:31] |
| Quantico - Posts: 45 |
Its an odd question. If you are trading PnF or other non-time based systems like Renko bars, why would you care about gaps unless you are trying to scalp on 1 ATR bars which is kinda lame. Just sayin'...
| [2017-06-03 15:28:36] |
Dear Quantico, I think that the answer is soo obvious, above all if the SC team "fixed" the problem. However, if you are not interested to see how the market really moves, it doesn't mean that other people do the same. Just sayin'....... |
| [2017-06-03 18:44:32] |
The issue is resolved in version 1565.
| [2017-06-03 19:42:55] |
Yes sure, I confirm you that it has been resolved. Thanks for your precious help. Cheers, Fabio. |
