Date/Time: Fri, 13 Nov 2026 09:54:17 +0000
Color-coded chart tabs
View Count: 1804
| [2017-05-27 04:22:33] |
| tobi - Posts: 351 |
Since release 1559 the chart tabs of linked charts are color coded. How can the color be changed of these or be not be colored (as it used to be)? Hopefully this can be done, because I always liked SC of its clearness and simplicity, so the focus can be on the charts! |
| [2017-05-28 17:43:15] |
We will make the color coding an option in the next release. The colors can controlled through Global Settings >> Graphics Settings.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-28 17:44:05
