Date/Time: Fri, 13 Nov 2026 10:00:04 +0000
Connection drop and recalculations make system incredibly slow
View Count: 1457
| [2017-05-22 17:07:16] |
| User953894 - Posts: 59 |
I tried to identify conflicts that are causing the SSL disconnects and recalculations but I don't see any. The system runs terribly slowly. Can you point me to any conflicts--and tell me how to identify problems in this log? HD Request # 319 | Receiving Intraday data for AUDJPY starting at 2017-05-19 16:57:58 | 2017-05-21 05:53:51 HD Request # 319 | Timestamp of first Intraday data file record written: 2017-05-19 16:57:58 | 2017-05-21 05:53:51 Socket (2102) | Shutdown and closed. | 2017-05-21 05:53:51 The network socket for historical data has been closed. | 2017-05-21 05:53:51 HD Request # 319 | Received 1 record from 2017-05-19 16:57:58 to 2017-05-19 16:57:58 (0.0 seconds) and wrote 1 record for AUDJPY | 2017-05-21 05:53:51 HD Request # 319 | Intraday download COMPLETE for AUDJPY. Completion time: 0s. Unique request ID: 495 | 2017-05-21 05:53:51 Removed historical data download ID 495 | 2017-05-21 05:53:51 Real-time Intraday chart data file updates started for AUDJPY | 2017-05-21 05:53:51 Opened cached Intraday file: C:\SierraChart1\Data\AUDJPY.scid | 2017-05-21 05:53:51 Intraday chart data file opened for AUDJPY | 2017-05-21 05:53:51 CTS T4 FIX | Sending security definition request for symbol 6B.20170600.CME_Fo | 2017-05-21 05:53:51 CTS T4 FIX | Received matching security definition for symbol 6B.20170600.CME_Fo. Subscribing to data. | 2017-05-21 05:53:51 CTS T4 FIX | Received 1 security definitions for underlying symbol 6B | 2017-05-21 05:53:51 Contract specifications for 6B.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 6.25 | 2017-05-21 05:53:51 CTS T4 FIX | Sending security definition request for symbol 6C.20160900.CME_Fo | 2017-05-21 05:53:54 Symbol Error - 6C.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 05:53:54 CTS T4 FIX | Received 0 security definitions for underlying symbol 6C | 2017-05-21 05:53:54 CTS T4 FIX | Requesting historical Fills for account: May*. Request ID: 9498231 | 2017-05-21 05:53:56 CTS T4 FIX | Received Account List collateral report. | 2017-05-21 05:53:56 CTS T4 FIX | Server provided no historical order fills for account 1A297B51-A416-42D4-A1C8-C9B1B4125155 | 2017-05-21 05:53:56 CTS T4 FIX | Sending security definition request for symbol 6C.20170600.CME_Fo | 2017-05-21 05:53:57 CTS T4 FIX | Received matching security definition for symbol 6C.20170600.CME_Fo. Subscribing to data. | 2017-05-21 05:53:57 CTS T4 FIX | Received 1 security definitions for underlying symbol 6C | 2017-05-21 05:53:57 Contract specifications for 6C.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 5 | 2017-05-21 05:53:57 CTS T4 FIX | Sending security definition request for symbol 6E.20160900.CME_Fo | 2017-05-21 05:53:59 Symbol Error - 6E.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 05:53:59 CTS T4 FIX | Received 0 security definitions for underlying symbol 6E | 2017-05-21 05:53:59 CTS T4 FIX | Sending security definition request for symbol 6E.20170600.CME_Fo | 2017-05-21 05:54:01 CTS T4 FIX | Received matching security definition for symbol 6E.20170600.CME_Fo. Subscribing to data. | 2017-05-21 05:54:01 CTS T4 FIX | Received 1 security definitions for underlying symbol 6E | 2017-05-21 05:54:01 Contract specifications for 6E.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-05-21 05:54:01 CTS T4 FIX | Sending security definition request for symbol 6J.20160900.CME_Fo | 2017-05-21 05:54:04 Symbol Error - 6J.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 05:54:04 CTS T4 FIX | Received 0 security definitions for underlying symbol 6J | 2017-05-21 05:54:04 CTS T4 FIX | Sending security definition request for symbol 6J.20170600.CME_Fo | 2017-05-21 05:54:07 CTS T4 FIX | Received matching security definition for symbol 6J.20170600.CME_Fo. Subscribing to data. | 2017-05-21 05:54:07 CTS T4 FIX | Received 1 security definitions for underlying symbol 6J | 2017-05-21 05:54:07 Contract specifications for 6J.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-05-21 05:54:07 CTS T4 FIX | Sending security definition request for symbol 6N.20170600.CME_Fo | 2017-05-21 05:54:10 CTS T4 FIX | Received matching security definition for symbol 6N.20170600.CME_Fo. Subscribing to data. | 2017-05-21 05:54:10 CTS T4 FIX | Received 1 security definitions for underlying symbol 6N | 2017-05-21 05:54:10 Contract specifications for 6N.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 05:54:10 CTS T4 FIX | Sending security definition request for symbol 6S.20170600.CME_Fo | 2017-05-21 05:54:13 CTS T4 FIX | Received matching security definition for symbol 6S.20170600.CME_Fo. Subscribing to data. | 2017-05-21 05:54:13 CTS T4 FIX | Received 1 security definitions for underlying symbol 6S | 2017-05-21 05:54:13 Contract specifications for 6S.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 12.5 | 2017-05-21 05:54:13 CTS T4 FIX | Sending security definition request for symbol CL.20160800.CME_NY | 2017-05-21 05:54:16 Symbol Error - CL.20160800.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 05:54:16 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2017-05-21 05:54:16 CTS T4 FIX | Sending security definition request for symbol CL.20170100.CME_NY | 2017-05-21 05:54:19 Symbol Error - CL.20170100.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 05:54:19 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2017-05-21 05:54:19 CTS T4 FIX | Sending security definition request for symbol CL.20170600.CME_NY | 2017-05-21 05:54:22 CTS T4 FIX | Received matching security definition for symbol CL.20170600.CME_NY. Subscribing to data. | 2017-05-21 05:54:22 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 05:54:22 Contract specifications for CL.20170600.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 05:54:22 CTS T4 FIX | Sending security definition request for symbol CL.20170700.CME_NY | 2017-05-21 05:54:25 CTS T4 FIX | Received matching security definition for symbol CL.20170700.CME_NY. Subscribing to data. | 2017-05-21 05:54:25 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 05:54:25 Contract specifications for CL.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 05:54:25 CTS T4 FIX | Sending security definition request for symbol CL.20171200.CME_NY | 2017-05-21 05:54:28 CTS T4 FIX | Received matching security definition for symbol CL.20171200.CME_NY. Subscribing to data. | 2017-05-21 05:54:28 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 05:54:28 Contract specifications for CL.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 05:54:28 CTS T4 FIX | Sending security definition request for symbol ES.20160900.CME_Eq | 2017-05-21 05:54:31 Symbol Error - ES.20160900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 05:54:31 CTS T4 FIX | Received 0 security definitions for underlying symbol ES | 2017-05-21 05:54:31 CTS T4 FIX | Sending security definition request for symbol ES.20170600.CME_Eq | 2017-05-21 05:54:34 CTS T4 FIX | Received matching security definition for symbol ES.20170600.CME_Eq. Subscribing to data. | 2017-05-21 05:54:34 CTS T4 FIX | Received 1 security definitions for underlying symbol ES | 2017-05-21 05:54:34 Contract specifications for ES.20170600.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 12.5 | 2017-05-21 05:54:34 CTS T4 FIX | Sending security definition request for symbol GC.20160800.CME_CO | 2017-05-21 05:54:37 Symbol Error - GC.20160800.CME_CO is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 05:54:37 CTS T4 FIX | Received 0 security definitions for underlying symbol GC | 2017-05-21 05:54:37 CTS T4 FIX | Sending security definition request for symbol GC.20170400.CME_CO | 2017-05-21 05:54:40 Symbol Error - GC.20170400.CME_CO is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 05:54:40 CTS T4 FIX | Received 0 security definitions for underlying symbol GC | 2017-05-21 05:54:40 CTS T4 FIX | Sending security definition request for symbol GC.20170600.CME_CO | 2017-05-21 05:54:43 CTS T4 FIX | Received matching security definition for symbol GC.20170600.CME_CO. Subscribing to data. | 2017-05-21 05:54:43 CTS T4 FIX | Received 1 security definitions for underlying symbol GC | 2017-05-21 05:54:43 Contract specifications for GC.20170600.CME_CO. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 05:54:43 CTS T4 FIX | Sending security definition request for symbol HO.20170700.CME_NY | 2017-05-21 05:54:46 CTS T4 FIX | Received matching security definition for symbol HO.20170700.CME_NY. Subscribing to data. | 2017-05-21 05:54:46 CTS T4 FIX | Received 1 security definitions for underlying symbol HO | 2017-05-21 05:54:46 Contract specifications for HO.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 05:54:46 CTS T4 FIX | Sending security definition request for symbol HO.20171200.CME_NY | 2017-05-21 05:54:49 CTS T4 FIX | Received matching security definition for symbol HO.20171200.CME_NY. Subscribing to data. | 2017-05-21 05:54:49 CTS T4 FIX | Received 1 security definitions for underlying symbol HO | 2017-05-21 05:54:49 Contract specifications for HO.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 05:54:49 CTS T4 FIX | Sending security definition request for symbol NQ.20160900.CME_Eq | 2017-05-21 05:54:52 Symbol Error - NQ.20160900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 05:54:52 CTS T4 FIX | Received 0 security definitions for underlying symbol NQ | 2017-05-21 05:54:52 CTS T4 FIX | Sending security definition request for symbol NQ.20170600.CME_Eq | 2017-05-21 05:54:53 CTS T4 FIX | Received matching security definition for symbol NQ.20170600.CME_Eq. Subscribing to data. | 2017-05-21 05:54:53 CTS T4 FIX | Received 1 security definitions for underlying symbol NQ | 2017-05-21 05:54:53 Contract specifications for NQ.20170600.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 5 | 2017-05-21 05:54:53 CTS T4 FIX | Sending security definition request for symbol RB.20170700.CME_NY | 2017-05-21 05:54:56 CTS T4 FIX | Received matching security definition for symbol RB.20170700.CME_NY. Subscribing to data. | 2017-05-21 05:54:56 CTS T4 FIX | Received 1 security definitions for underlying symbol RB | 2017-05-21 05:54:56 Contract specifications for RB.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 05:54:56 CTS T4 FIX | Sending security definition request for symbol RB.20171200.CME_NY | 2017-05-21 05:54:59 CTS T4 FIX | Received matching security definition for symbol RB.20171200.CME_NY. Subscribing to data. | 2017-05-21 05:54:59 CTS T4 FIX | Received 1 security definitions for underlying symbol RB | 2017-05-21 05:54:59 Contract specifications for RB.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 05:54:59 CTS T4 FIX | Sending security definition request for symbol YM.20160900.CME_E | 2017-05-21 05:55:02 Symbol Error - YM.20160900.CME_E is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 05:55:02 CTS T4 FIX | Received 0 security definitions for underlying symbol YM | 2017-05-21 05:55:02 CTS T4 FIX | Sending security definition request for symbol YM.20170600.CME_E | 2017-05-21 05:55:05 CTS T4 FIX | Received matching security definition for symbol YM.20170600.CME_E. Subscribing to data. | 2017-05-21 05:55:05 CTS T4 FIX | Received matching security definition for symbol YM.20170600.CME_E. Requesting historical data. | 2017-05-21 05:55:05 HD Request # 318 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 05:55:05 CTS T4 FIX | Received 1 security definitions for underlying symbol YM | 2017-05-21 05:55:05 Contract specifications for YM.20170600.CME_E. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 5 | 2017-05-21 05:55:05 HD Request # 318 | Receiving Intraday data for YM.20170600.CME_E starting at 2017-05-18 18:00:00 | 2017-05-21 05:55:07 HD Request # 318 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 05:55:07 HD Request # 318 | Total records received: 19680 | 2017-05-21 05:55:07 HD Request # 318 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 05:55:07 HD Request # 318 | Total records received: 19680 | 2017-05-21 05:55:07 HD Request # 318 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 05:55:07 HD Request # 318 | Total records received: 19680 | 2017-05-21 05:55:07 HD Request # 318 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 05:55:07 HD Request # 318 | Total records received: 19680 | 2017-05-21 05:55:07 HD Request # 318 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 05:55:07 HD Request # 318 | Received 19680 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for YM.20170600.CME_E | 2017-05-21 05:55:07 HD Request # 318 | Intraday download COMPLETE for YM.20170600.CME_E. Completion time: 1m 27s. Unique request ID: 479 | 2017-05-21 05:55:07 Removed historical data download ID 479 | 2017-05-21 05:55:07 Real-time Intraday chart data file updates started for YM.20170600.CME_E | 2017-05-21 05:55:07 Opened cached Intraday file: C:\SierraChart1\Data\YM.20170600.CME_E.scid | 2017-05-21 05:55:07 Intraday chart data file opened for YM.20170600.CME_E | 2017-05-21 05:55:07 Delaying start of download for 6J.20170600.CME_Fo | 2017-05-21 05:55:07 CTS T4 FIX | Sending security definition request for symbol ZB.20160900.CME_F | 2017-05-21 05:55:09 Chart #3 has tagged chart #4 for full recalculation. Chartbook: Futures.cht | 2017-05-21 05:55:09 Symbol Error - ZB.20160900.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 05:55:09 CTS T4 FIX | Received 0 security definitions for underlying symbol ZB | 2017-05-21 05:55:09 ZB.20170600.CME_F 3 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 05:55:10 DTC Client (2101) | Closed. No error. | 2017-05-21 05:55:10 DTC Client (2101) | Shutdown and closed. | 2017-05-21 05:55:10 SC DTC Data | Disconnected from the server. | 2017-05-21 05:55:10 SC DTC Data | Data feed disconnected. Will reconnect in 2 seconds. | 2017-05-21 05:55:10 CTS T4 FIX | Sending security definition request for symbol ZB.20170300.CME_F | 2017-05-21 05:55:10 CTS FIX Historical Data socket (2100) | Closed. No error. | 2017-05-21 05:55:10 CTS FIX Historical Data socket (2100) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-21 05:55:10 CTS FIX Historical Data socket (2100) | SSL has been shut down. | 2017-05-21 05:55:10 CTS FIX Historical Data socket (2100) | SSL object has been freed. SSL state is now disconnected. | 2017-05-21 05:55:10 CTS FIX Historical Data socket (2100) | Shutdown and closed. | 2017-05-21 05:55:10 CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2017-05-21 05:55:10 CTS FIX Historical Data: Disconnected. | 2017-05-21 05:55:10 Symbol Error - ZB.20170300.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 05:55:10 CTS T4 FIX | Received 0 security definitions for underlying symbol ZB | 2017-05-21 05:55:10 CTS T4 FIX | Sending security definition request for symbol ZB.20170600.CME_F | 2017-05-21 05:56:09 CTS T4 FIX | Received matching security definition for symbol ZB.20170600.CME_F. Subscribing to data. | 2017-05-21 05:56:09 CTS T4 FIX | Received 1 security definitions for underlying symbol ZB | 2017-05-21 05:56:09 Contract specifications for ZB.20170600.CME_F. Multiplier: 0.00001000. Tick Size: 0.03125. Value Format: 132. Currency Value per Tick: 31.25 | 2017-05-21 05:56:09 SC DTC Data | Connecting to the server ds4.sierracharts.com. Port 443 | 2017-05-21 05:56:11 DTC Client (0) | Resolved address ds4.sierracharts.com to IP 192.81.56.146. | 2017-05-21 05:56:11 DTC Client (2104) | Connected. | 2017-05-21 05:56:11 SC DTC Data | Connected to server. | 2017-05-21 05:56:11 SC DTC Data | Sending Encoding Request to server | 2017-05-21 05:56:11 SC DTC Data | Setting DTC encoding to Binary VLS | 2017-05-21 05:56:11 SC DTC Data | Sending logon request message. | 2017-05-21 05:56:11 CTS T4 FIX | Sending security definition request for symbol ZN.20170600.CME_F | 2017-05-21 05:56:11 CTS T4 FIX | Received matching security definition for symbol ZN.20170600.CME_F. Subscribing to data. | 2017-05-21 05:56:11 CTS T4 FIX | Received 1 security definitions for underlying symbol ZN | 2017-05-21 05:56:11 Contract specifications for ZN.20170600.CME_F. Multiplier: 0.00000100. Tick Size: 0.015625. Value Format: 132. Currency Value per Tick: 15.625 | 2017-05-21 05:56:11 SC DTC Data | Received logon response. | 2017-05-21 05:56:12 SC DTC Data | Server Name: SC Realtime Server. | 2017-05-21 05:56:12 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2017-05-21 05:56:12 SC DTC Data | Successfully connected. | 2017-05-21 05:56:12 SC DTC Data | Trading is not supported. | 2017-05-21 05:56:12 Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2017-05-21 05:56:12 SC DTC Data | Restarting real-time data updates for symbol: AUDJPY | 2017-05-21 05:56:12 Delaying start of download for AUDJPY | 2017-05-21 05:56:12 SC DTC Data | Received security definition for symbol AUDJPY | 2017-05-21 05:56:12 CTS T4 FIX | Sending security definition request for symbol ZT.20170600.CME_F | 2017-05-21 05:56:12 CTS T4 FIX | Received matching security definition for symbol ZT.20170600.CME_F. Subscribing to data. | 2017-05-21 05:56:12 CTS T4 FIX | Received 1 security definitions for underlying symbol ZT | 2017-05-21 05:56:12 Contract specifications for ZT.20170600.CME_F. Multiplier: 0.00000010. Tick Size: 0.0078125. Value Format: 228. Currency Value per Tick: 15.625 | 2017-05-21 05:56:14 HD Request # 320 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-05-21 05:56:18 HD Request # 320 | Download start date-time: 2017-05-19 16:57:58.000 | 2017-05-21 05:56:18 HD Request # 320 | Using server: ds4.sierracharts.com port 10149 | 2017-05-21 05:56:18 Socket (0) | Resolved address ds4.sierracharts.com to IP 192.81.56.146. | 2017-05-21 05:56:18 Socket (2105) | Connected. | 2017-05-21 05:56:18 HD Request # 320 | Setting DTC encoding to Binary VLS | 2017-05-21 05:56:18 HD Request # 320 | Sending historical data logon request message. | 2017-05-21 05:56:18 HD Request # 320 | Requesting Intraday data. Start date-time: 2017-05-19 16:57:58. Record interval: 1. Symbol: AUDJPY | 2017-05-21 05:56:19 HD Request # 320 | Decompressing data. | 2017-05-21 05:56:19 HD Request # 320 | Receiving Intraday data for AUDJPY starting at 2017-05-19 16:57:58 | 2017-05-21 05:56:19 HD Request # 320 | Timestamp of first Intraday data file record written: 2017-05-19 16:57:58 | 2017-05-21 05:56:19 Socket (2105) | Shutdown and closed. | 2017-05-21 05:56:19 The network socket for historical data has been closed. | 2017-05-21 05:56:19 HD Request # 320 | Received 1 record from 2017-05-19 16:57:58 to 2017-05-19 16:57:58 (0.0 seconds) and wrote 1 record for AUDJPY | 2017-05-21 05:56:19 HD Request # 320 | Intraday download COMPLETE for AUDJPY. Completion time: 1s. Unique request ID: 500 | 2017-05-21 05:56:19 Removed historical data download ID 500 | 2017-05-21 05:56:19 Real-time Intraday chart data file updates started for AUDJPY | 2017-05-21 05:56:19 Opened cached Intraday file: C:\SierraChart1\Data\AUDJPY.scid | 2017-05-21 05:56:19 Intraday chart data file opened for AUDJPY | 2017-05-21 05:56:19 HD Request # 321 | Downloading Intraday chart data for 6J.20170600.CME_Fo to the file 6J.20170600.CME_Fo.scid. Service: cts | 2017-05-21 05:56:29 HD Request # 321 | Download start date-time: 2017-05-19 16:59:51.000 | 2017-05-21 05:56:29 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2017-05-21 05:56:29 CTS FIX Historical Data socket (0) | Resolved address fix-chart-sim.t4login.com to IP 74.201.6.229. | 2017-05-21 05:56:29 CTS FIX Historical Data socket (2106) | Connected. | 2017-05-21 05:56:29 CTS FIX Historical Data socket (2106) | Starting TLS 1.0 connection. | 2017-05-21 05:56:29 CTS FIX Historical Data socket (2106) | SSL connection established. | 2017-05-21 05:56:31 CTS FIX Historical Data: Sending the Logon message. | 2017-05-21 05:56:32 CTS FIX Historical Data: Connected to Historical data server. | 2017-05-21 05:56:32 HD Request # 321 | Requesting historical Second data for 6J.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 05:56:32 HD Request # 321 | Receiving Intraday data for 6J.20170600.CME_Fo starting at 2017-05-18 18:00:00 | 2017-05-21 05:56:34 HD Request # 321 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:51 | 2017-05-21 05:56:34 HD Request # 321 | Total records received: 19164 | 2017-05-21 05:56:34 HD Request # 321 | Requesting historical Second data for 6J.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 05:56:34 HD Request # 321 | Total records received: 19164 | 2017-05-21 05:56:34 HD Request # 321 | Requesting historical Second data for 6J.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 05:56:34 HD Request # 321 | Total records received: 19164 | 2017-05-21 05:56:34 HD Request # 321 | Requesting historical Second data for 6J.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 05:56:34 HD Request # 321 | Total records received: 19164 | 2017-05-21 05:56:34 HD Request # 321 | Requesting historical Second data for 6J.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 05:56:34 HD Request # 321 | Received 19164 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:51 (23.0 hours) and wrote 1 record for 6J.20170600.CME_Fo | 2017-05-21 05:56:35 HD Request # 321 | Intraday download COMPLETE for 6J.20170600.CME_Fo. Completion time: 6s. Unique request ID: 480 | 2017-05-21 05:56:35 Removed historical data download ID 480 | 2017-05-21 05:56:35 Real-time Intraday chart data file updates started for 6J.20170600.CME_Fo | 2017-05-21 05:56:35 Opened cached Intraday file: C:\SierraChart1\Data\6J.20170600.CME_Fo.scid | 2017-05-21 05:56:35 Intraday chart data file opened for 6J.20170600.CME_Fo | 2017-05-21 05:56:35 Delaying start of download for 6A.20170600.CME_Fo | 2017-05-21 05:56:35 Chart #14 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 05:56:35 Chart #14 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 05:56:35 GC.20170600.CME_CO 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 05:56:35 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 05:56:35 ZB.20170600.CME_F 30 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 05:56:35 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 05:56:35 Chart #5 has tagged chart #13 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:56:35 Chart #5 has tagged chart #15 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:56:35 Chart #5 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:56:35 Chart #5 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:56:35 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 05:56:35 Chart #14 has tagged chart #1 for full recalculation. Chartbook: Futures.cht | 2017-05-21 05:56:39 Chart #14 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 05:56:39 Chart #14 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 05:56:39 ZB.20170600.CME_F 3 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 05:56:39 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 05:56:39 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 05:56:39 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:56:39 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:56:39 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:56:39 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:56:39 GC.20170600.CME_CO [C] 30 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:56:39 Chart #13 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:56:39 Chart #13 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:56:39 Chart #13 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:56:39 Chart #13 has tagged chart #4 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:56:39 ZB.20170600.CME_F [C] 30 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:56:39 Chart #15 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:56:39 Chart #15 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:56:39 Chart #15 has tagged chart #26 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:56:39 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 05:56:39 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:56:39 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:56:39 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:56:39 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:56:39 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:56:39 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:56:39 6C.20170600.CME_Fo [C] 30 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:56:39 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 05:56:39 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 05:56:39 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:56:39 GC.20170600.CME_CO 3 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 05:56:39 Chart #1 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 05:56:39 Chart #1 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 05:56:39 ZB.20170600.CME_F [C] 15 Min #26 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:56:44 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:56:44 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:56:44 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:56:44 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:56:44 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 05:56:44 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 05:56:44 HD Request # 322 | Downloading Intraday chart data for 6A.20170600.CME_Fo to the file 6A.20170600.CME_Fo.scid. Service: cts | 2017-05-21 05:57:02 HD Request # 322 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 05:57:02 HD Request # 322 | Requesting historical Second data for 6A.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 05:57:02 HD Request # 322 | Receiving Intraday data for 6A.20170600.CME_Fo starting at 2017-05-18 18:00:00 | 2017-05-21 05:57:04 HD Request # 322 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 05:57:04 HD Request # 322 | Total records received: 6413 | 2017-05-21 05:57:04 HD Request # 322 | Requesting historical Second data for 6A.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 05:57:04 HD Request # 322 | Total records received: 6413 | 2017-05-21 05:57:04 HD Request # 322 | Requesting historical Second data for 6A.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 05:57:04 HD Request # 322 | Total records received: 6413 | 2017-05-21 05:57:04 HD Request # 322 | Requesting historical Second data for 6A.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 05:57:04 HD Request # 322 | Total records received: 6413 | 2017-05-21 05:57:04 HD Request # 322 | Requesting historical Second data for 6A.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 05:57:04 HD Request # 322 | Received 6413 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for 6A.20170600.CME_Fo | 2017-05-21 05:57:05 HD Request # 322 | Intraday download COMPLETE for 6A.20170600.CME_Fo. Completion time: 2s. Unique request ID: 481 | 2017-05-21 05:57:05 Removed historical data download ID 481 | 2017-05-21 05:57:05 Real-time Intraday chart data file updates started for 6A.20170600.CME_Fo | 2017-05-21 05:57:05 Opened cached Intraday file: C:\SierraChart1\Data\6A.20170600.CME_Fo.scid | 2017-05-21 05:57:05 Intraday chart data file opened for 6A.20170600.CME_Fo | 2017-05-21 05:57:05 Delaying start of download for NQ.20170600.CME_Eq | 2017-05-21 05:57:05 HD Request # 323 | Downloading Intraday chart data for NQ.20170600.CME_Eq to the file NQ.20170600.CME_Eq.scid. Service: cts | 2017-05-21 05:57:28 HD Request # 323 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 05:57:28 HD Request # 323 | Requesting historical Second data for NQ.20170600.CME_Eq from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 05:57:28 HD Request # 323 | Receiving Intraday data for NQ.20170600.CME_Eq starting at 2017-05-18 18:00:00 | 2017-05-21 05:57:30 HD Request # 323 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 05:57:30 HD Request # 323 | Total records received: 24898 | 2017-05-21 05:57:30 HD Request # 323 | Requesting historical Second data for NQ.20170600.CME_Eq from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 05:57:30 HD Request # 323 | Total records received: 24898 | 2017-05-21 05:57:30 HD Request # 323 | Requesting historical Second data for NQ.20170600.CME_Eq from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 05:57:30 HD Request # 323 | Total records received: 24898 | 2017-05-21 05:57:30 HD Request # 323 | Requesting historical Second data for NQ.20170600.CME_Eq from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 05:57:30 HD Request # 323 | Total records received: 24898 | 2017-05-21 05:57:30 HD Request # 323 | Requesting historical Second data for NQ.20170600.CME_Eq from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 05:57:30 HD Request # 323 | Received 24898 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for NQ.20170600.CME_Eq | 2017-05-21 05:57:31 HD Request # 323 | Intraday download COMPLETE for NQ.20170600.CME_Eq. Completion time: 3s. Unique request ID: 482 | 2017-05-21 05:57:31 Removed historical data download ID 482 | 2017-05-21 05:57:31 Real-time Intraday chart data file updates started for NQ.20170600.CME_Eq | 2017-05-21 05:57:31 Opened cached Intraday file: C:\SierraChart1\Data\NQ.20170600.CME_Eq.scid | 2017-05-21 05:57:31 Intraday chart data file opened for NQ.20170600.CME_Eq | 2017-05-21 05:57:31 Delaying start of download for GC.20170600.CME_CO | 2017-05-21 05:57:31 HD Request # 324 | Downloading Intraday chart data for GC.20170600.CME_CO to the file GC.20170600.CME_CO.scid. Service: cts | 2017-05-21 05:57:53 HD Request # 324 | Download start date-time: 2017-05-19 16:59:57.000 | 2017-05-21 05:57:53 HD Request # 324 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 05:57:53 HD Request # 324 | Receiving Intraday data for GC.20170600.CME_CO starting at 2017-05-18 18:00:00 | 2017-05-21 05:57:56 HD Request # 324 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:57 | 2017-05-21 05:57:56 HD Request # 324 | Total records received: 26821 | 2017-05-21 05:57:56 HD Request # 324 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 05:57:56 HD Request # 324 | Total records received: 26821 | 2017-05-21 05:57:56 HD Request # 324 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 05:57:56 HD Request # 324 | Total records received: 26821 | 2017-05-21 05:57:56 HD Request # 324 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 05:57:56 HD Request # 324 | Total records received: 26821 | 2017-05-21 05:57:56 HD Request # 324 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 05:57:56 HD Request # 324 | Received 26821 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:57 (23.0 hours) and wrote 1 record for GC.20170600.CME_CO | 2017-05-21 05:57:56 HD Request # 324 | Intraday download COMPLETE for GC.20170600.CME_CO. Completion time: 2s. Unique request ID: 483 | 2017-05-21 05:57:56 Removed historical data download ID 483 | 2017-05-21 05:57:56 Real-time Intraday chart data file updates started for GC.20170600.CME_CO | 2017-05-21 05:57:56 Opened cached Intraday file: C:\SierraChart1\Data\GC.20170600.CME_CO.scid | 2017-05-21 05:57:56 Intraday chart data file opened for GC.20170600.CME_CO | 2017-05-21 05:57:56 Delaying start of download for ZT.20170600.CME_F | 2017-05-21 05:57:56 Chart #1 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 05:57:56 Chart #1 has tagged chart #14 for full recalculation. Chartbook: Futures.cht | 2017-05-21 05:57:56 Chart #1 has tagged chart #17 for full recalculation. Chartbook: Futures.cht | 2017-05-21 05:57:56 Chart #1 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 05:57:56 Chart #1 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 05:57:56 6J.20170600.CME_Fo 3 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 05:57:57 Chart #14 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 05:57:57 ZB.20170600.CME_F 3 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 05:57:57 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 05:57:57 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 05:57:57 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:57:57 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:57:57 Chart #1 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 05:57:57 Chart #1 has tagged chart #14 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 05:57:57 Chart #1 has tagged chart #17 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 05:57:57 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 05:57:57 Chart #13 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:57:57 Chart #13 has tagged chart #15 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:57:57 Chart #13 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:57:57 Chart #13 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:57:57 Chart #13 has tagged chart #4 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:57:57 Chart #13 has tagged chart #5 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:57:57 ZB.20170600.CME_F 30 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 05:57:57 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 05:57:57 ZB.20170600.CME_F [C] 30 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:57:57 Chart #15 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:57:57 Chart #15 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:57:57 Chart #15 has tagged chart #26 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:57:57 6J.20170600.CME_Fo [C] 30 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:57:57 Chart #5 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:57:57 Chart #5 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:57:57 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 05:57:57 ES.20170600.CME_Eq 30 Sec #17 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 05:57:57 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 05:57:57 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 05:57:57 Chart #17 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 05:57:57 ES.20170600.CME_Eq 3 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 05:57:57 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures.cht | 2017-05-21 05:57:57 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 05:57:57 Chart #17 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 05:57:57 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:57:57 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:57:57 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:57:57 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:57:57 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:57:57 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:57:57 6C.20170600.CME_Fo [C] 30 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:57:57 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 05:57:57 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 05:57:57 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:57:57 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 05:57:57 ZB.20170600.CME_F [C] 15 Min #26 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:58:04 6J.20170600.CME_Fo 3 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 05:58:04 Chart #14 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 05:58:04 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:58:04 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:58:04 NQ.20170600.CME_Eq 30 Sec #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 05:58:04 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:58:04 6J.20170600.CME_Fo 30 Sec #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 05:58:04 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:58:04 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 05:58:04 HD Request # 325 | Downloading Intraday chart data for ZT.20170600.CME_F to the file ZT.20170600.CME_F.scid. Service: cts | 2017-05-21 05:58:25 HD Request # 325 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 05:58:25 HD Request # 325 | Requesting historical Second data for ZT.20170600.CME_F from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 05:58:25 HD Request # 325 | Receiving Intraday data for ZT.20170600.CME_F starting at 2017-05-18 18:00:00 | 2017-05-21 05:58:26 HD Request # 325 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 05:58:26 HD Request # 325 | Total records received: 3447 | 2017-05-21 05:58:26 HD Request # 325 | Requesting historical Second data for ZT.20170600.CME_F from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 05:58:26 HD Request # 325 | Total records received: 3447 | 2017-05-21 05:58:26 HD Request # 325 | Requesting historical Second data for ZT.20170600.CME_F from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 05:58:26 HD Request # 325 | Total records received: 3447 | 2017-05-21 05:58:26 HD Request # 325 | Requesting historical Second data for ZT.20170600.CME_F from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 05:58:26 HD Request # 325 | Total records received: 3447 | 2017-05-21 05:58:28 HD Request # 325 | Requesting historical Second data for ZT.20170600.CME_F from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 05:58:28 HD Request # 325 | Received 3447 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for ZT.20170600.CME_F | 2017-05-21 05:58:28 HD Request # 325 | Intraday download COMPLETE for ZT.20170600.CME_F. Completion time: 2s. Unique request ID: 484 | 2017-05-21 05:58:28 Removed historical data download ID 484 | 2017-05-21 05:58:28 Real-time Intraday chart data file updates started for ZT.20170600.CME_F | 2017-05-21 05:58:28 Opened cached Intraday file: C:\SierraChart1\Data\ZT.20170600.CME_F.scid | 2017-05-21 05:58:28 Intraday chart data file opened for ZT.20170600.CME_F | 2017-05-21 05:58:28 Delaying start of download for HO.20170700.CME_NY | 2017-05-21 05:58:28 Chart #9 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 05:58:28 Chart #9 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 05:58:28 GC.20170600.CME_CO 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 05:58:28 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 05:58:28 Chart #9 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 05:58:28 Chart #9 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 05:58:28 Chart #9 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 05:58:28 ZB.20170600.CME_F 30 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 05:58:28 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 05:58:28 Chart #12 has tagged chart #13 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:58:28 Chart #12 has tagged chart #15 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:58:28 Chart #12 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:58:28 Chart #12 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:58:28 ZB.20170600.CME_F [C] 30 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:58:28 Chart #15 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:58:28 Chart #15 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:58:28 Chart #15 has tagged chart #26 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:58:28 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 05:58:28 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:58:28 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:58:28 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:58:28 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:58:28 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:58:28 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:58:28 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 05:58:28 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:58:28 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 05:58:28 ZB.20170600.CME_F [C] 15 Min #26 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:58:33 ZB.20170600.CME_F 3 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 05:58:33 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 05:58:33 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 05:58:33 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:58:33 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:58:33 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:58:33 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:58:33 GC.20170600.CME_CO [C] 30 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:58:33 Chart #13 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:58:33 Chart #13 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:58:33 Chart #13 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:58:33 Chart #13 has tagged chart #4 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:58:33 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:58:33 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:58:33 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:58:33 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:58:33 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:58:33 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:58:33 6C.20170600.CME_Fo [C] 30 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:58:33 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 05:58:33 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 05:58:33 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:58:33 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:58:37 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:58:37 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:58:37 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:58:37 HD Request # 326 | Downloading Intraday chart data for HO.20170700.CME_NY to the file HO.20170700.CME_NY.scid. Service: cts | 2017-05-21 05:58:56 HD Request # 326 | Download start date-time: 2017-05-19 16:59:53.000 | 2017-05-21 05:58:56 HD Request # 326 | Requesting historical Second data for HO.20170700.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 05:58:56 HD Request # 326 | Receiving Intraday data for HO.20170700.CME_NY starting at 2017-05-18 18:00:00 | 2017-05-21 05:58:56 HD Request # 326 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:53 | 2017-05-21 05:58:56 HD Request # 326 | Total records received: 7519 | 2017-05-21 05:58:56 HD Request # 326 | Requesting historical Second data for HO.20170700.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 05:58:56 HD Request # 326 | Total records received: 7519 | 2017-05-21 05:58:56 HD Request # 326 | Requesting historical Second data for HO.20170700.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 05:58:56 HD Request # 326 | Total records received: 7519 | 2017-05-21 05:58:56 HD Request # 326 | Requesting historical Second data for HO.20170700.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 05:58:56 HD Request # 326 | Total records received: 7519 | 2017-05-21 05:58:56 HD Request # 326 | Requesting historical Second data for HO.20170700.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 05:58:56 HD Request # 326 | Received 7519 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:53 (23.0 hours) and wrote 1 record for HO.20170700.CME_NY | 2017-05-21 05:58:58 HD Request # 326 | Intraday download COMPLETE for HO.20170700.CME_NY. Completion time: 1s. Unique request ID: 485 | 2017-05-21 05:58:58 Removed historical data download ID 485 | 2017-05-21 05:58:58 Real-time Intraday chart data file updates started for HO.20170700.CME_NY | 2017-05-21 05:58:58 Opened cached Intraday file: C:\SierraChart1\Data\HO.20170700.CME_NY.scid | 2017-05-21 05:58:58 Intraday chart data file opened for HO.20170700.CME_NY | 2017-05-21 05:58:58 Delaying start of download for CL.20170700.CME_NY | 2017-05-21 05:58:58 Chart #20 has tagged chart #16 for full recalculation. Chartbook: Futures.cht | 2017-05-21 05:58:58 Chart #20 has tagged chart #9 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:58:58 CL.20170700.CME_NY [C] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:58:58 Chart #9 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:58:58 Chart #5 has tagged chart #16 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 05:58:58 CL.20170700.CME_NY 3 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 05:58:58 Chart #16 has tagged chart #15 for full recalculation. Chartbook: Futures.cht | 2017-05-21 05:58:58 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:58:58 CL.20170700.CME_NY 30 Sec #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 05:59:00 6C.20170600.CME_Fo 3 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 05:59:00 HD Request # 327 | Downloading Intraday chart data for CL.20170700.CME_NY to the file CL.20170700.CME_NY.scid. Service: cts | 2017-05-21 05:59:19 HD Request # 327 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 05:59:19 HD Request # 327 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 05:59:19 HD Request # 327 | Receiving Intraday data for CL.20170700.CME_NY starting at 2017-05-18 18:00:00 | 2017-05-21 05:59:22 HD Request # 327 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 05:59:22 HD Request # 327 | Total records received: 33722 | 2017-05-21 05:59:22 HD Request # 327 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 05:59:22 HD Request # 327 | Total records received: 33722 | 2017-05-21 05:59:22 HD Request # 327 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 05:59:22 HD Request # 327 | Total records received: 33722 | 2017-05-21 05:59:22 HD Request # 327 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 05:59:22 HD Request # 327 | Total records received: 33722 | 2017-05-21 05:59:22 HD Request # 327 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 05:59:22 HD Request # 327 | Received 33722 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for CL.20170700.CME_NY | 2017-05-21 05:59:22 HD Request # 327 | Intraday download COMPLETE for CL.20170700.CME_NY. Completion time: 3s. Unique request ID: 486 | 2017-05-21 05:59:22 Removed historical data download ID 486 | 2017-05-21 05:59:22 Real-time Intraday chart data file updates started for CL.20170700.CME_NY | 2017-05-21 05:59:22 Opened cached Intraday file: C:\SierraChart1\Data\CL.20170700.CME_NY.scid | 2017-05-21 05:59:22 Intraday chart data file opened for CL.20170700.CME_NY | 2017-05-21 05:59:22 Delaying start of download for ZB.20170600.CME_F | 2017-05-21 05:59:22 Chart #3 has tagged chart #1 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 05:59:24 Chart #3 has tagged chart #4 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 05:59:24 Chart #3 has tagged chart #5 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 05:59:24 Chart #3 has tagged chart #8 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 05:59:24 CL.20170700.CME_NY 30 Sec #4 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 05:59:24 CL.20170700.CME_NY 3 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 05:59:24 CTS FIX socket (2099) | Closed. No error. | 2017-05-21 05:59:24 CTS FIX: Received a Logout message. Text = Timed out. No valid messages received within the heartbeat interval of 30 seconds | 2017-05-21 05:59:24 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2017-05-21 05:59:24 CTS FIX socket (2099) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-21 05:59:24 CTS FIX socket (2099) | SSL has been shut down. | 2017-05-21 05:59:24 CTS FIX socket (2099) | SSL object has been freed. SSL state is now disconnected. | 2017-05-21 05:59:24 CTS FIX socket (2099) | Shutdown and closed. | 2017-05-21 05:59:24 Connection to the external service has been lost. | 2017-05-21 05:59:24 Chart #9 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 05:59:24 Chart #16 has tagged chart #15 for full recalculation. Chartbook: Futures.cht | 2017-05-21 05:59:24 CL.20170700.CME_NY 3 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 05:59:24 CL.20170700.CME_NY 3 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 05:59:24 6C.20170600.CME_Fo 3 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 05:59:24 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 05:59:24 Canceling historical data download request for ZB.20170600.CME_F Intraday data. | 2017-05-21 06:00:22 Removed historical data download ID 487 | 2017-05-21 06:00:22 Canceling historical data download request for 6B.20170600.CME_Fo Intraday data. | 2017-05-21 06:00:22 Removed historical data download ID 488 | 2017-05-21 06:00:22 Canceling historical data download request for 6C.20170600.CME_Fo Intraday data. | 2017-05-21 06:00:22 Removed historical data download ID 489 | 2017-05-21 06:00:22 Canceling historical data download request for ZN.20170600.CME_F Intraday data. | 2017-05-21 06:00:22 Removed historical data download ID 490 | 2017-05-21 06:00:22 Canceling historical data download request for CL.20171200.CME_NY Intraday data. | 2017-05-21 06:00:22 Removed historical data download ID 491 | 2017-05-21 06:00:22 Canceling historical data download request for ES.20170600.CME_Eq Intraday data. | 2017-05-21 06:00:22 Removed historical data download ID 492 | 2017-05-21 06:00:22 Canceling historical data download request for RB.20170700.CME_NY Intraday data. | 2017-05-21 06:00:22 Removed historical data download ID 493 | 2017-05-21 06:00:22 Canceling historical data download request for 6E.20170600.CME_Fo Intraday data. | 2017-05-21 06:00:22 Removed historical data download ID 494 | 2017-05-21 06:00:22 Canceling historical data download request for 6S.20170600.CME_Fo Intraday data. | 2017-05-21 06:00:22 Removed historical data download ID 496 | 2017-05-21 06:00:22 Canceling historical data download request for HO.20171200.CME_NY Intraday data. | 2017-05-21 06:00:22 Removed historical data download ID 497 | 2017-05-21 06:00:22 Canceling historical data download request for 6N.20170600.CME_Fo Intraday data. | 2017-05-21 06:00:22 Removed historical data download ID 498 | 2017-05-21 06:00:22 Canceling historical data download request for RB.20171200.CME_NY Intraday data. | 2017-05-21 06:00:22 Removed historical data download ID 499 | 2017-05-21 06:00:22 CTS FIX Historical Data: DisconnectFIX called. | 2017-05-21 06:00:22 CTS FIX Historical Data: Sending a Logout message. | 2017-05-21 06:00:22 CTS T4 FIX | Disconnected. | 2017-05-21 06:00:22 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-21 06:00:22 CTS FIX Historical Data socket (2106) | Closed. No error. | 2017-05-21 06:00:22 CTS FIX Historical Data: Received a Logout message. Text = Successful logout upon request | 2017-05-21 06:00:22 CTS FIX Historical Data socket (2106) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-21 06:00:22 CTS FIX Historical Data socket (2106) | SSL has been shut down. | 2017-05-21 06:00:22 CTS FIX Historical Data socket (2106) | SSL object has been freed. SSL state is now disconnected. | 2017-05-21 06:00:22 CTS FIX Historical Data socket (2106) | Shutdown and closed. | 2017-05-21 06:00:22 CTS FIX Historical Data: Disconnected. | 2017-05-21 06:00:22 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2017-05-21 06:00:25 CTS T4 FIX | Firm: PTP | 2017-05-21 06:00:25 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 69.44.110.200. | 2017-05-21 06:00:26 CTS FIX socket (2109) | Connected. | 2017-05-21 06:00:26 CTS FIX socket (2109) | Starting TLS 1.0 connection. | 2017-05-21 06:00:26 CTS FIX socket (2109) | SSL connection established. | 2017-05-21 06:00:26 CTS FIX: Sending the Logon message. | 2017-05-21 06:00:28 CTS T4 FIX | FIX version: 4.3.74.0 | 2017-05-21 06:00:28 CTS T4 FIX | Connected to data and trading server. | 2017-05-21 06:00:28 DTC Client (2104) | Shutdown and closed. | 2017-05-21 06:00:28 SC DTC Data | Disconnected from the server. | 2017-05-21 06:00:28 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:28 CTS T4 FIX | Starting real-time market data updates for: ZB.20160900.CME_F. ID: 1 | 2017-05-21 06:00:28 CTS T4 FIX | Requesting security definition data for: ZB.20160900.CME_F. ID: 1 | 2017-05-21 06:00:28 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:28 CTS T4 FIX | Starting real-time market data updates for: 6E.20160900.CME_Fo. ID: 2 | 2017-05-21 06:00:28 CTS T4 FIX | Requesting security definition data for: 6E.20160900.CME_Fo. ID: 2 | 2017-05-21 06:00:28 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6J.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:28 CTS T4 FIX | Starting real-time market data updates for: 6J.20160900.CME_Fo. ID: 3 | 2017-05-21 06:00:28 CTS T4 FIX | Requesting security definition data for: 6J.20160900.CME_Fo. ID: 3 | 2017-05-21 06:00:28 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6B.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:28 CTS T4 FIX | Starting real-time market data updates for: 6B.20160900.CME_Fo. ID: 4 | 2017-05-21 06:00:28 CTS T4 FIX | Requesting security definition data for: 6B.20160900.CME_Fo. ID: 4 | 2017-05-21 06:00:28 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6C.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:28 CTS T4 FIX | Starting real-time market data updates for: 6C.20160900.CME_Fo. ID: 5 | 2017-05-21 06:00:28 CTS T4 FIX | Requesting security definition data for: 6C.20160900.CME_Fo. ID: 5 | 2017-05-21 06:00:28 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:28 CTS T4 FIX | Starting real-time market data updates for: CL.20160800.CME_NY. ID: 6 | 2017-05-21 06:00:28 CTS T4 FIX | Requesting security definition data for: CL.20160800.CME_NY. ID: 6 | 2017-05-21 06:00:28 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6A.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:28 CTS T4 FIX | Starting real-time market data updates for: 6A.20160900.CME_Fo. ID: 7 | 2017-05-21 06:00:28 CTS T4 FIX | Requesting security definition data for: 6A.20160900.CME_Fo. ID: 7 | 2017-05-21 06:00:28 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:28 CTS T4 FIX | Starting real-time market data updates for: NQ.20160900.CME_Eq. ID: 8 | 2017-05-21 06:00:28 CTS T4 FIX | Requesting security definition data for: NQ.20160900.CME_Eq. ID: 8 | 2017-05-21 06:00:28 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM.######00.CME_E pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:28 CTS T4 FIX | Starting real-time market data updates for: YM.20160900.CME_E. ID: 9 | 2017-05-21 06:00:28 CTS T4 FIX | Requesting security definition data for: YM.20160900.CME_E. ID: 9 | 2017-05-21 06:00:28 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:28 CTS T4 FIX | Starting real-time market data updates for: GC.20160800.CME_CO. ID: 10 | 2017-05-21 06:00:28 CTS T4 FIX | Requesting security definition data for: GC.20160800.CME_CO. ID: 10 | 2017-05-21 06:00:28 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:28 CTS T4 FIX | Starting real-time market data updates for: ES.20160900.CME_Eq. ID: 11 | 2017-05-21 06:00:28 CTS T4 FIX | Requesting security definition data for: ES.20160900.CME_Eq. ID: 11 | 2017-05-21 06:00:28 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:28 CTS T4 FIX | Starting real-time market data updates for: ZB.20170300.CME_F. ID: 12 | 2017-05-21 06:00:28 CTS T4 FIX | Requesting security definition data for: ZB.20170300.CME_F. ID: 12 | 2017-05-21 06:00:28 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:28 CTS T4 FIX | Starting real-time market data updates for: CL.20170100.CME_NY. ID: 13 | 2017-05-21 06:00:28 CTS T4 FIX | Requesting security definition data for: CL.20170100.CME_NY. ID: 13 | 2017-05-21 06:00:28 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:28 CTS T4 FIX | Starting real-time market data updates for: GC.20170400.CME_CO. ID: 14 | 2017-05-21 06:00:28 CTS T4 FIX | Requesting security definition data for: GC.20170400.CME_CO. ID: 14 | 2017-05-21 06:00:28 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:28 CTS T4 FIX | Starting real-time market data updates for: ZB.20170600.CME_F. ID: 15 | 2017-05-21 06:00:28 CTS T4 FIX | Requesting security definition data for: ZB.20170600.CME_F. ID: 15 | 2017-05-21 06:00:28 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6B.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:28 CTS T4 FIX | Starting real-time market data updates for: 6B.20170600.CME_Fo. ID: 16 | 2017-05-21 06:00:28 CTS T4 FIX | Requesting security definition data for: 6B.20170600.CME_Fo. ID: 16 | 2017-05-21 06:00:28 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:28 CTS T4 FIX | Starting real-time market data updates for: CL.20170600.CME_NY. ID: 17 | 2017-05-21 06:00:28 CTS T4 FIX | Requesting security definition data for: CL.20170600.CME_NY. ID: 17 | 2017-05-21 06:00:28 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6N.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:32 CTS T4 FIX | Starting real-time market data updates for: 6N.20170600.CME_Fo. ID: 18 | 2017-05-21 06:00:32 CTS T4 FIX | Requesting security definition data for: 6N.20170600.CME_Fo. ID: 18 | 2017-05-21 06:00:32 CTS T4 FIX | Using primary service for historical data for 6N.20170600.CME_Fo | 2017-05-21 06:00:32 Intraday data recording state for symbol 6N.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:00:32 Delaying start of download for 6N.20170600.CME_Fo | 2017-05-21 06:00:32 CTS T4 FIX | Using primary service for historical data for ZB.20170600.CME_F | 2017-05-21 06:00:32 Intraday data recording state for symbol ZB.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:00:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The RB.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:32 CTS T4 FIX | Starting real-time market data updates for: RB.20171200.CME_NY. ID: 19 | 2017-05-21 06:00:32 CTS T4 FIX | Requesting security definition data for: RB.20171200.CME_NY. ID: 19 | 2017-05-21 06:00:32 CTS T4 FIX | Using primary service for historical data for RB.20171200.CME_NY | 2017-05-21 06:00:32 Intraday data recording state for symbol RB.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:00:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZN.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:32 CTS T4 FIX | Starting real-time market data updates for: ZN.20170600.CME_F. ID: 20 | 2017-05-21 06:00:32 CTS T4 FIX | Requesting security definition data for: ZN.20170600.CME_F. ID: 20 | 2017-05-21 06:00:32 CTS T4 FIX | Using primary service for historical data for ZN.20170600.CME_F | 2017-05-21 06:00:32 Intraday data recording state for symbol ZN.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:00:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6J.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:32 CTS T4 FIX | Starting real-time market data updates for: 6J.20170600.CME_Fo. ID: 21 | 2017-05-21 06:00:32 CTS T4 FIX | Requesting security definition data for: 6J.20170600.CME_Fo. ID: 21 | 2017-05-21 06:00:32 CTS T4 FIX | Using primary service for historical data for 6J.20170600.CME_Fo | 2017-05-21 06:00:32 Intraday data recording state for symbol 6J.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:00:32 CTS T4 FIX | Received Account List collateral report. | 2017-05-21 06:00:32 CTS T4 FIX | Subscribing to account: May* | 2017-05-21 06:00:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6S.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:32 CTS T4 FIX | Starting real-time market data updates for: 6S.20170600.CME_Fo. ID: 22 | 2017-05-21 06:00:32 CTS T4 FIX | Requesting security definition data for: 6S.20170600.CME_Fo. ID: 22 | 2017-05-21 06:00:32 CTS T4 FIX | Using primary service for historical data for 6S.20170600.CME_Fo | 2017-05-21 06:00:32 Intraday data recording state for symbol 6S.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:00:32 Supported exchange: CME_CO (SIM:COMEX Futures) | 2017-05-21 06:00:32 Supported exchange: CME_EqOp (SIM:CME Equity Options) | 2017-05-21 06:00:32 Supported exchange: CME_NYOp (SIM:NYMEX Options) | 2017-05-21 06:00:32 Supported exchange: CME_AgOp (SIM:CME Agricultural Options) | 2017-05-21 06:00:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The RB.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:32 CTS T4 FIX | Starting real-time market data updates for: RB.20170700.CME_NY. ID: 23 | 2017-05-21 06:00:32 CTS T4 FIX | Requesting security definition data for: RB.20170700.CME_NY. ID: 23 | 2017-05-21 06:00:32 CTS T4 FIX | Using primary service for historical data for RB.20170700.CME_NY | 2017-05-21 06:00:32 Intraday data recording state for symbol RB.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:00:32 Supported exchange: CME_Eq (SIM:CME Equity Futures) | 2017-05-21 06:00:32 Supported exchange: CME_In (SIM:CME Interest Rate Futures) | 2017-05-21 06:00:32 Supported exchange: CME_C (SIM:CBOT Commodity Futures) | 2017-05-21 06:00:32 Supported exchange: CME_KOp (SIM:KCBT Options) | 2017-05-21 06:00:32 Supported exchange: CME_F (SIM:CBOT Financial Futures) | 2017-05-21 06:00:32 Supported exchange: CME_E (SIM:CBOT Equity Futures) | 2017-05-21 06:00:32 Supported exchange: CME_COp (SIM:CBOT Commodity Options) | 2017-05-21 06:00:32 Supported exchange: CME_K (SIM:KCBT Futures) | 2017-05-21 06:00:32 Supported exchange: CME_EOp (SIM:CBOT Equity Options) | 2017-05-21 06:00:32 Supported exchange: CME_NY (SIM:NYMEX Futures) | 2017-05-21 06:00:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:32 CTS T4 FIX | Starting real-time market data updates for: CL.20171200.CME_NY. ID: 24 | 2017-05-21 06:00:32 CTS T4 FIX | Requesting security definition data for: CL.20171200.CME_NY. ID: 24 | 2017-05-21 06:00:32 CTS T4 FIX | Using primary service for historical data for CL.20171200.CME_NY | 2017-05-21 06:00:32 Intraday data recording state for symbol CL.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:00:32 Supported exchange: CME_Fo (SIM:CME Foreign Exchange Futures) | 2017-05-21 06:00:32 Supported exchange: CME_Ag (SIM:CME Agricultural Futures) | 2017-05-21 06:00:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:32 CTS T4 FIX | Starting real-time market data updates for: GC.20170600.CME_CO. ID: 25 | 2017-05-21 06:00:32 CTS T4 FIX | Requesting security definition data for: GC.20170600.CME_CO. ID: 25 | 2017-05-21 06:00:32 CTS T4 FIX | Using primary service for historical data for GC.20170600.CME_CO | 2017-05-21 06:00:32 Intraday data recording state for symbol GC.20170600.CME_CO is set to download 'Pending'. | 2017-05-21 06:00:32 Supported exchange: CME_FoOp (SIM:CME Foreign Exchange Options) | 2017-05-21 06:00:32 CTS T4 FIX | Sending security definition request for symbol 6A.20160900.CME_Fo | 2017-05-21 06:00:32 Supported exchange: CME_FOp (SIM:CBOT Financial Options) | 2017-05-21 06:00:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:32 CTS T4 FIX | Starting real-time market data updates for: 6E.20170600.CME_Fo. ID: 26 | 2017-05-21 06:00:32 CTS T4 FIX | Requesting security definition data for: 6E.20170600.CME_Fo. ID: 26 | 2017-05-21 06:00:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6A.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:32 CTS T4 FIX | Starting real-time market data updates for: 6A.20170600.CME_Fo. ID: 27 | 2017-05-21 06:00:32 CTS T4 FIX | Requesting security definition data for: 6A.20170600.CME_Fo. ID: 27 | 2017-05-21 06:00:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6C.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:32 CTS T4 FIX | Starting real-time market data updates for: 6C.20170600.CME_Fo. ID: 28 | 2017-05-21 06:00:32 CTS T4 FIX | Requesting security definition data for: 6C.20170600.CME_Fo. ID: 28 | 2017-05-21 06:00:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:32 CTS T4 FIX | Starting real-time market data updates for: ES.20170600.CME_Eq. ID: 29 | 2017-05-21 06:00:32 CTS T4 FIX | Requesting security definition data for: ES.20170600.CME_Eq. ID: 29 | 2017-05-21 06:00:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM.######00.CME_E pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:32 CTS T4 FIX | Starting real-time market data updates for: YM.20170600.CME_E. ID: 30 | 2017-05-21 06:00:32 CTS T4 FIX | Requesting security definition data for: YM.20170600.CME_E. ID: 30 | 2017-05-21 06:00:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:32 CTS T4 FIX | Starting real-time market data updates for: NQ.20170600.CME_Eq. ID: 31 | 2017-05-21 06:00:32 CTS T4 FIX | Requesting security definition data for: NQ.20170600.CME_Eq. ID: 31 | 2017-05-21 06:00:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:32 CTS T4 FIX | Starting real-time market data updates for: CL.20170700.CME_NY. ID: 32 | 2017-05-21 06:00:32 CTS T4 FIX | Requesting security definition data for: CL.20170700.CME_NY. ID: 32 | 2017-05-21 06:00:32 Supported exchange: CME_InOp (SIM:CME Interest Rate Options) | 2017-05-21 06:00:32 Supported exchange: CME_COOp (SIM:COMEX Options) | 2017-05-21 06:00:32 Requesting market depth updates for: NQ.20170600.CME_Eq if supported. | 2017-05-21 06:00:32 CTS T4 FIX | Using primary service for historical data for NQ.20170600.CME_Eq | 2017-05-21 06:00:32 Intraday data recording state for symbol NQ.20170600.CME_Eq is set to download 'Pending'. | 2017-05-21 06:00:32 Symbol Error - 6A.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:00:32 CTS T4 FIX | Received 0 security definitions for underlying symbol 6A | 2017-05-21 06:00:32 CTS T4 FIX | Using primary service for historical data for YM.20170600.CME_E | 2017-05-21 06:00:32 Intraday data recording state for symbol YM.20170600.CME_E is set to download 'Pending'. | 2017-05-21 06:00:32 HD Request # 328 | Downloading Intraday chart data for 6N.20170600.CME_Fo to the file 6N.20170600.CME_Fo.scid. Service: cts | 2017-05-21 06:00:32 HD Request # 328 | Download start date-time: 2017-05-19 16:59:58.000 | 2017-05-21 06:00:32 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2017-05-21 06:00:32 Requesting market depth updates for: 6J.20170600.CME_Fo if supported. | 2017-05-21 06:00:32 CTS FIX Historical Data socket (0) | Resolved address fix-chart-sim.t4login.com to IP 74.201.6.229. | 2017-05-21 06:00:32 CTS T4 FIX | Using primary service for historical data for CL.20170700.CME_NY | 2017-05-21 06:00:32 Intraday data recording state for symbol CL.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:00:32 CTS FIX Historical Data socket (2110) | Connected. | 2017-05-21 06:00:32 CTS FIX Historical Data socket (2110) | Starting TLS 1.0 connection. | 2017-05-21 06:00:32 CTS T4 FIX | Using primary service for historical data for 6A.20170600.CME_Fo | 2017-05-21 06:00:32 Intraday data recording state for symbol 6A.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:00:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZT.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:32 CTS T4 FIX | Starting real-time market data updates for: ZT.20170600.CME_F. ID: 33 | 2017-05-21 06:00:32 CTS T4 FIX | Requesting security definition data for: ZT.20170600.CME_F. ID: 33 | 2017-05-21 06:00:32 CTS T4 FIX | Using primary service for historical data for ZT.20170600.CME_F | 2017-05-21 06:00:32 Intraday data recording state for symbol ZT.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:00:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The HO.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:32 CTS T4 FIX | Starting real-time market data updates for: HO.20170700.CME_NY. ID: 34 | 2017-05-21 06:00:32 CTS T4 FIX | Requesting security definition data for: HO.20170700.CME_NY. ID: 34 | 2017-05-21 06:00:32 CTS T4 FIX | Using primary service for historical data for HO.20170700.CME_NY | 2017-05-21 06:00:32 Intraday data recording state for symbol HO.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:00:32 Requesting market depth updates for: GC.20170600.CME_CO if supported. | 2017-05-21 06:00:32 CTS FIX Historical Data socket (2110) | SSL connection established. | 2017-05-21 06:00:32 Requesting market depth updates for: CL.20170700.CME_NY if supported. | 2017-05-21 06:00:32 Requesting market depth updates for: ZB.20170600.CME_F if supported. | 2017-05-21 06:00:32 CTS T4 FIX | Using primary service for historical data for 6B.20170600.CME_Fo | 2017-05-21 06:00:32 Intraday data recording state for symbol 6B.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:00:32 CTS T4 FIX | Using primary service for historical data for 6C.20170600.CME_Fo | 2017-05-21 06:00:32 Intraday data recording state for symbol 6C.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:00:32 Requesting market depth updates for: ES.20170600.CME_Eq if supported. | 2017-05-21 06:00:32 CTS T4 FIX | Using primary service for historical data for ES.20170600.CME_Eq | 2017-05-21 06:00:32 Intraday data recording state for symbol ES.20170600.CME_Eq is set to download 'Pending'. | 2017-05-21 06:00:32 CTS T4 FIX | Received 'Account Update/Balance Data' collateral report. | 2017-05-21 06:00:32 CTS T4 FIX | Using primary service for historical data for 6E.20170600.CME_Fo | 2017-05-21 06:00:32 Intraday data recording state for symbol 6E.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:00:32 Using Bid/Ask average for last trade price for AUDJPY | 2017-05-21 06:00:32 SC DTC Data | Starting real-time market data updates for: AUDJPY. ID: 35 | 2017-05-21 06:00:32 SC DTC Data | Connecting to the server ds3.sierracharts.com. Port 10048 | 2017-05-21 06:00:32 SC DTC Data | Requesting security definition data for: AUDJPY. ID: 35 | 2017-05-21 06:00:32 Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2017-05-21 06:00:32 Delaying start of download for AUDJPY | 2017-05-21 06:00:32 DTC Client (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2017-05-21 06:00:32 Requesting market depth updates for: 6E.20170600.CME_Fo if supported. | 2017-05-21 06:00:32 DTC Client (2111) | Connected. | 2017-05-21 06:00:32 SC DTC Data | Connected to server. | 2017-05-21 06:00:32 SC DTC Data | Sending Encoding Request to server | 2017-05-21 06:00:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The HO.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:00:32 CTS T4 FIX | Starting real-time market data updates for: HO.20171200.CME_NY. ID: 36 | 2017-05-21 06:00:32 CTS T4 FIX | Requesting security definition data for: HO.20171200.CME_NY. ID: 36 | 2017-05-21 06:00:32 CTS T4 FIX | Using primary service for historical data for HO.20171200.CME_NY | 2017-05-21 06:00:32 Intraday data recording state for symbol HO.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:00:32 SC DTC Data | Setting DTC encoding to Binary VLS | 2017-05-21 06:00:32 SC DTC Data | Sending logon request message. | 2017-05-21 06:00:32 Requesting market depth updates for: 6B.20170600.CME_Fo if supported. | 2017-05-21 06:00:32 SC DTC Data | Received logon response. | 2017-05-21 06:00:32 SC DTC Data | Server Name: SC Realtime Server. | 2017-05-21 06:00:32 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2017-05-21 06:00:32 SC DTC Data | Successfully connected. | 2017-05-21 06:00:32 SC DTC Data | Trading is not supported. | 2017-05-21 06:00:32 SC DTC Data | Restarting real-time data updates for symbol: AUDJPY | 2017-05-21 06:00:32 Requesting market depth updates for: YM.20170600.CME_E if supported. | 2017-05-21 06:00:32 SC DTC Data | Received security definition for symbol AUDJPY | 2017-05-21 06:00:32 CTS T4 FIX | Sending security definition request for symbol 6A.20170600.CME_Fo | 2017-05-21 06:00:35 CTS T4 FIX | Received matching security definition for symbol 6A.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:00:35 CTS T4 FIX | Received 1 security definitions for underlying symbol 6A | 2017-05-21 06:00:35 Contract specifications for 6A.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:00:35 CTS FIX Historical Data: Sending the Logon message. | 2017-05-21 06:00:35 Delaying start of download for AUDJPY | 2017-05-21 06:00:35 CTS FIX Historical Data: Connected to Historical data server. | 2017-05-21 06:00:37 CTS T4 FIX | Sending security definition request for symbol 6B.20160900.CME_Fo | 2017-05-21 06:00:37 Symbol Error - 6B.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:00:37 CTS T4 FIX | Received 0 security definitions for underlying symbol 6B | 2017-05-21 06:00:37 CTS T4 FIX | Requesting Open Orders for account: May*. Request ID: 9498290 | 2017-05-21 06:00:38 Requesting market depth updates for: 6B.20160900.CME_Fo if supported. | 2017-05-21 06:00:38 Requesting market depth updates for: 6E.20160900.CME_Fo if supported. | 2017-05-21 06:00:38 Requesting market depth updates for: 6J.20160900.CME_Fo if supported. | 2017-05-21 06:00:38 Requesting market depth updates for: 6N.20170600.CME_Fo if supported. | 2017-05-21 06:00:38 Requesting market depth updates for: CL.20160800.CME_NY if supported. | 2017-05-21 06:00:38 Requesting market depth updates for: CL.20170100.CME_NY if supported. | 2017-05-21 06:00:38 Requesting market depth updates for: CL.20170600.CME_NY if supported. | 2017-05-21 06:00:38 Requesting market depth updates for: CL.20171200.CME_NY if supported. | 2017-05-21 06:00:38 Requesting market depth updates for: ES.20160900.CME_Eq if supported. | 2017-05-21 06:00:38 Requesting market depth updates for: GC.20160800.CME_CO if supported. | 2017-05-21 06:00:38 Requesting market depth updates for: GC.20170400.CME_CO if supported. | 2017-05-21 06:00:38 Requesting market depth updates for: NQ.20160900.CME_Eq if supported. | 2017-05-21 06:00:38 Requesting market depth updates for: YM.20160900.CME_E if supported. | 2017-05-21 06:00:38 Requesting market depth updates for: ZB.20160900.CME_F if supported. | 2017-05-21 06:00:38 Requesting market depth updates for: ZB.20170300.CME_F if supported. | 2017-05-21 06:00:38 CTS T4 FIX | No open orders for account May18CCwmitchel | 2017-05-21 06:00:38 CTS T4 FIX | Sending security definition request for symbol 6B.20170600.CME_Fo | 2017-05-21 06:00:40 HD Request # 329 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-05-21 06:00:40 HD Request # 329 | Download start date-time: 2017-05-19 16:57:58.000 | 2017-05-21 06:00:40 HD Request # 329 | Using server: ds3.sierracharts.com port 10149 | 2017-05-21 06:00:40 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2017-05-21 06:00:40 Socket (2112) | Connected. | 2017-05-21 06:00:40 CTS T4 FIX | Received matching security definition for symbol 6B.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:00:40 CTS T4 FIX | Received 1 security definitions for underlying symbol 6B | 2017-05-21 06:00:40 HD Request # 329 | Setting DTC encoding to Binary VLS | 2017-05-21 06:00:40 HD Request # 329 | Sending historical data logon request message. | 2017-05-21 06:00:40 Contract specifications for 6B.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 6.25 | 2017-05-21 06:00:40 HD Request # 329 | Requesting Intraday data. Start date-time: 2017-05-19 16:57:58. Record interval: 1. Symbol: AUDJPY | 2017-05-21 06:00:41 HD Request # 329 | Decompressing data. | 2017-05-21 06:00:41 HD Request # 329 | Receiving Intraday data for AUDJPY starting at 2017-05-19 16:57:58 | 2017-05-21 06:00:41 HD Request # 329 | Timestamp of first Intraday data file record written: 2017-05-19 16:57:58 | 2017-05-21 06:00:41 Socket (2112) | Shutdown and closed. | 2017-05-21 06:00:41 The network socket for historical data has been closed. | 2017-05-21 06:00:41 HD Request # 329 | Received 1 record from 2017-05-19 16:57:58 to 2017-05-19 16:57:58 (0.0 seconds) and wrote 1 record for AUDJPY | 2017-05-21 06:00:41 HD Request # 329 | Intraday download COMPLETE for AUDJPY. Completion time: 1s. Unique request ID: 520 | 2017-05-21 06:00:41 Removed historical data download ID 520 | 2017-05-21 06:00:41 Real-time Intraday chart data file updates started for AUDJPY | 2017-05-21 06:00:41 Opened cached Intraday file: C:\SierraChart1\Data\AUDJPY.scid | 2017-05-21 06:00:41 Intraday chart data file opened for AUDJPY | 2017-05-21 06:00:41 CTS T4 FIX | Sending security definition request for symbol 6C.20160900.CME_Fo | 2017-05-21 06:00:41 Symbol Error - 6C.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:00:43 CTS T4 FIX | Received 0 security definitions for underlying symbol 6C | 2017-05-21 06:00:43 CTS T4 FIX | Sending security definition request for symbol 6C.20170600.CME_Fo | 2017-05-21 06:00:45 CTS T4 FIX | Received matching security definition for symbol 6C.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:00:45 CTS T4 FIX | Received 1 security definitions for underlying symbol 6C | 2017-05-21 06:00:45 Contract specifications for 6C.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 5 | 2017-05-21 06:00:46 CTS T4 FIX | Requesting historical Fills for account: May*. Request ID: 9498293 | 2017-05-21 06:00:48 CTS T4 FIX | Sending security definition request for symbol 6E.20160900.CME_Fo | 2017-05-21 06:00:48 CTS T4 FIX | Received Account List collateral report. | 2017-05-21 06:00:48 CTS T4 FIX | Server provided no historical order fills for account 1A297B51-A416-42D4-A1C8-C9B1B4125155 | 2017-05-21 06:00:48 Symbol Error - 6E.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:00:48 CTS T4 FIX | Received 0 security definitions for underlying symbol 6E | 2017-05-21 06:00:48 CTS T4 FIX | Sending security definition request for symbol 6E.20170600.CME_Fo | 2017-05-21 06:00:51 CTS T4 FIX | Received matching security definition for symbol 6E.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:00:51 CTS T4 FIX | Received 1 security definitions for underlying symbol 6E | 2017-05-21 06:00:51 Contract specifications for 6E.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-05-21 06:00:51 CTS T4 FIX | Sending security definition request for symbol 6J.20160900.CME_Fo | 2017-05-21 06:00:54 Symbol Error - 6J.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:00:54 CTS T4 FIX | Received 0 security definitions for underlying symbol 6J | 2017-05-21 06:00:54 CTS T4 FIX | Sending security definition request for symbol 6J.20170600.CME_Fo | 2017-05-21 06:00:57 CTS T4 FIX | Received matching security definition for symbol 6J.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:00:57 CTS T4 FIX | Received 1 security definitions for underlying symbol 6J | 2017-05-21 06:00:57 Contract specifications for 6J.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-05-21 06:00:57 CTS T4 FIX | Sending security definition request for symbol 6N.20170600.CME_Fo | 2017-05-21 06:00:58 CTS T4 FIX | Received matching security definition for symbol 6N.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:00:58 CTS T4 FIX | Received matching security definition for symbol 6N.20170600.CME_Fo. Requesting historical data. | 2017-05-21 06:00:58 HD Request # 328 | Requesting historical Second data for 6N.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:00:58 CTS T4 FIX | Received 1 security definitions for underlying symbol 6N | 2017-05-21 06:00:58 Contract specifications for 6N.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:01:00 HD Request # 328 | Receiving Intraday data for 6N.20170600.CME_Fo starting at 2017-05-18 18:00:03 | 2017-05-21 06:01:00 HD Request # 328 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:58 | 2017-05-21 06:01:00 HD Request # 328 | Total records received: 3666 | 2017-05-21 06:01:00 HD Request # 328 | Requesting historical Second data for 6N.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:01:00 HD Request # 328 | Total records received: 3666 | 2017-05-21 06:01:00 HD Request # 328 | Requesting historical Second data for 6N.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:01:00 HD Request # 328 | Total records received: 3666 | 2017-05-21 06:01:00 HD Request # 328 | Requesting historical Second data for 6N.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:01:00 HD Request # 328 | Total records received: 3666 | 2017-05-21 06:01:00 HD Request # 328 | Requesting historical Second data for 6N.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:01:00 HD Request # 328 | Received 3666 records from 2017-05-18 18:00:03 to 2017-05-19 16:59:58 (23.0 hours) and wrote 1 record for 6N.20170600.CME_Fo | 2017-05-21 06:01:00 HD Request # 328 | Intraday download COMPLETE for 6N.20170600.CME_Fo. Completion time: 28s. Unique request ID: 501 | 2017-05-21 06:01:00 Removed historical data download ID 501 | 2017-05-21 06:01:00 Real-time Intraday chart data file updates started for 6N.20170600.CME_Fo | 2017-05-21 06:01:00 Opened cached Intraday file: C:\SierraChart1\Data\6N.20170600.CME_Fo.scid | 2017-05-21 06:01:00 Intraday chart data file opened for 6N.20170600.CME_Fo | 2017-05-21 06:01:00 Delaying start of download for ZB.20170600.CME_F | 2017-05-21 06:01:00 CTS T4 FIX | Sending security definition request for symbol 6S.20170600.CME_Fo | 2017-05-21 06:01:00 Chart #6 has tagged chart #19 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:01:01 Chart #6 has tagged chart #9 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:01:01 CTS T4 FIX | Received matching security definition for symbol 6S.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:01:01 CTS T4 FIX | Received 1 security definitions for underlying symbol 6S | 2017-05-21 06:01:01 Contract specifications for 6S.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 12.5 | 2017-05-21 06:01:01 ZT.20170600.CME_F 3 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:01:01 Chart #9 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:01:01 Chart #9 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:01:01 Chart #9 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:01:01 ZN.20170600.CME_F 3 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:01:01 Chart #19 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:01:01 Chart #19 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:01:01 Chart #19 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:01:01 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:01:01 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:01:01 ZB.20170600.CME_F 3 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:01:03 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:01:03 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:01:03 CTS T4 FIX | Sending security definition request for symbol CL.20160800.CME_NY | 2017-05-21 06:01:03 Symbol Error - CL.20160800.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:01:03 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2017-05-21 06:01:03 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:01:03 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:01:03 CTS T4 FIX | Sending security definition request for symbol CL.20170100.CME_NY | 2017-05-21 06:01:06 Symbol Error - CL.20170100.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:01:06 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2017-05-21 06:01:06 CTS T4 FIX | Sending security definition request for symbol CL.20170600.CME_NY | 2017-05-21 06:01:08 CTS T4 FIX | Received matching security definition for symbol CL.20170600.CME_NY. Subscribing to data. | 2017-05-21 06:01:08 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:01:08 Contract specifications for CL.20170600.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:01:08 CTS T4 FIX | Sending security definition request for symbol CL.20170700.CME_NY | 2017-05-21 06:01:11 CTS T4 FIX | Received matching security definition for symbol CL.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:01:11 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:01:11 Contract specifications for CL.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:01:11 CTS T4 FIX | Sending security definition request for symbol CL.20171200.CME_NY | 2017-05-21 06:01:13 CTS T4 FIX | Received matching security definition for symbol CL.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:01:13 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:01:13 Contract specifications for CL.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:01:13 CTS T4 FIX | Sending security definition request for symbol ES.20160900.CME_Eq | 2017-05-21 06:01:15 Symbol Error - ES.20160900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:01:15 CTS T4 FIX | Received 0 security definitions for underlying symbol ES | 2017-05-21 06:01:15 CTS T4 FIX | Sending security definition request for symbol ES.20170600.CME_Eq | 2017-05-21 06:01:18 CTS T4 FIX | Received matching security definition for symbol ES.20170600.CME_Eq. Subscribing to data. | 2017-05-21 06:01:19 CTS T4 FIX | Received 1 security definitions for underlying symbol ES | 2017-05-21 06:01:19 Contract specifications for ES.20170600.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 12.5 | 2017-05-21 06:01:19 CTS T4 FIX | Sending security definition request for symbol GC.20160800.CME_CO | 2017-05-21 06:01:22 Symbol Error - GC.20160800.CME_CO is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:01:22 CTS T4 FIX | Received 0 security definitions for underlying symbol GC | 2017-05-21 06:01:22 HD Request # 330 | Downloading Intraday chart data for ZB.20170600.CME_F to the file ZB.20170600.CME_F.scid. Service: cts | 2017-05-21 06:01:23 HD Request # 330 | Download start date-time: 2017-05-19 16:59:56.000 | 2017-05-21 06:01:23 CTS T4 FIX | Sending security definition request for symbol GC.20170400.CME_CO | 2017-05-21 06:01:24 Symbol Error - GC.20170400.CME_CO is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:01:24 CTS T4 FIX | Received 0 security definitions for underlying symbol GC | 2017-05-21 06:01:24 CTS T4 FIX | Sending security definition request for symbol GC.20170600.CME_CO | 2017-05-21 06:01:27 CTS T4 FIX | Received matching security definition for symbol GC.20170600.CME_CO. Subscribing to data. | 2017-05-21 06:01:27 CTS T4 FIX | Received 1 security definitions for underlying symbol GC | 2017-05-21 06:01:27 Contract specifications for GC.20170600.CME_CO. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:01:27 CTS T4 FIX | Sending security definition request for symbol HO.20170700.CME_NY | 2017-05-21 06:01:29 CTS T4 FIX | Received matching security definition for symbol HO.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:01:29 CTS T4 FIX | Received 1 security definitions for underlying symbol HO | 2017-05-21 06:01:29 Contract specifications for HO.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:01:29 CTS T4 FIX | Sending security definition request for symbol HO.20171200.CME_NY | 2017-05-21 06:01:31 CTS T4 FIX | Received matching security definition for symbol HO.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:01:31 CTS T4 FIX | Received 1 security definitions for underlying symbol HO | 2017-05-21 06:01:31 Contract specifications for HO.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:01:31 CTS T4 FIX | Sending security definition request for symbol NQ.20160900.CME_Eq | 2017-05-21 06:01:34 Symbol Error - NQ.20160900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:01:36 CTS T4 FIX | Received 0 security definitions for underlying symbol NQ | 2017-05-21 06:01:36 CTS T4 FIX | Sending security definition request for symbol NQ.20170600.CME_Eq | 2017-05-21 06:01:38 CTS T4 FIX | Received matching security definition for symbol NQ.20170600.CME_Eq. Subscribing to data. | 2017-05-21 06:01:38 CTS T4 FIX | Received 1 security definitions for underlying symbol NQ | 2017-05-21 06:01:38 Contract specifications for NQ.20170600.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 5 | 2017-05-21 06:01:38 CTS T4 FIX | Sending security definition request for symbol RB.20170700.CME_NY | 2017-05-21 06:01:40 CTS T4 FIX | Received matching security definition for symbol RB.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:01:40 CTS T4 FIX | Received 1 security definitions for underlying symbol RB | 2017-05-21 06:01:40 Contract specifications for RB.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:01:40 CTS T4 FIX | Sending security definition request for symbol RB.20171200.CME_NY | 2017-05-21 06:01:41 CTS T4 FIX | Received matching security definition for symbol RB.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:01:41 CTS T4 FIX | Received 1 security definitions for underlying symbol RB | 2017-05-21 06:01:41 Contract specifications for RB.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:01:41 CTS T4 FIX | Sending security definition request for symbol YM.20160900.CME_E | 2017-05-21 06:01:44 Symbol Error - YM.20160900.CME_E is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:01:44 CTS T4 FIX | Received 0 security definitions for underlying symbol YM | 2017-05-21 06:01:44 CTS T4 FIX | Sending security definition request for symbol YM.20170600.CME_E | 2017-05-21 06:01:45 CTS T4 FIX | Received matching security definition for symbol YM.20170600.CME_E. Subscribing to data. | 2017-05-21 06:01:45 CTS T4 FIX | Received 1 security definitions for underlying symbol YM | 2017-05-21 06:01:45 Contract specifications for YM.20170600.CME_E. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 5 | 2017-05-21 06:01:45 CTS T4 FIX | Sending security definition request for symbol ZB.20160900.CME_F | 2017-05-21 06:01:48 Symbol Error - ZB.20160900.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:01:48 CTS T4 FIX | Received 0 security definitions for underlying symbol ZB | 2017-05-21 06:01:48 CTS T4 FIX | Sending security definition request for symbol ZB.20170300.CME_F | 2017-05-21 06:01:49 Symbol Error - ZB.20170300.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:01:49 CTS T4 FIX | Received 0 security definitions for underlying symbol ZB | 2017-05-21 06:01:49 CTS T4 FIX | Sending security definition request for symbol ZB.20170600.CME_F | 2017-05-21 06:01:51 CTS T4 FIX | Received matching security definition for symbol ZB.20170600.CME_F. Subscribing to data. | 2017-05-21 06:01:51 CTS T4 FIX | Received matching security definition for symbol ZB.20170600.CME_F. Requesting historical data. | 2017-05-21 06:01:51 HD Request # 330 | Requesting historical Second data for ZB.20170600.CME_F from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:01:51 CTS T4 FIX | Received 1 security definitions for underlying symbol ZB | 2017-05-21 06:01:51 Contract specifications for ZB.20170600.CME_F. Multiplier: 0.00001000. Tick Size: 0.03125. Value Format: 132. Currency Value per Tick: 31.25 | 2017-05-21 06:01:52 HD Request # 330 | Receiving Intraday data for ZB.20170600.CME_F starting at 2017-05-18 18:00:00 | 2017-05-21 06:01:52 HD Request # 330 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:56 | 2017-05-21 06:01:52 HD Request # 330 | Total records received: 6509 | 2017-05-21 06:01:52 HD Request # 330 | Requesting historical Second data for ZB.20170600.CME_F from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:01:52 HD Request # 330 | Total records received: 6509 | 2017-05-21 06:01:52 HD Request # 330 | Requesting historical Second data for ZB.20170600.CME_F from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:01:52 HD Request # 330 | Total records received: 6509 | 2017-05-21 06:01:52 HD Request # 330 | Requesting historical Second data for ZB.20170600.CME_F from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:01:52 HD Request # 330 | Total records received: 6509 | 2017-05-21 06:01:52 HD Request # 330 | Requesting historical Second data for ZB.20170600.CME_F from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:01:52 CTS T4 FIX | Sending security definition request for symbol ZN.20170600.CME_F | 2017-05-21 06:01:52 HD Request # 330 | Received 6509 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:56 (23.0 hours) and wrote 1 record for ZB.20170600.CME_F | 2017-05-21 06:01:52 HD Request # 330 | Intraday download COMPLETE for ZB.20170600.CME_F. Completion time: 29s. Unique request ID: 502 | 2017-05-21 06:01:52 Removed historical data download ID 502 | 2017-05-21 06:01:52 Real-time Intraday chart data file updates started for ZB.20170600.CME_F | 2017-05-21 06:01:52 Opened cached Intraday file: C:\SierraChart1\Data\ZB.20170600.CME_F.scid | 2017-05-21 06:01:52 Intraday chart data file opened for ZB.20170600.CME_F | 2017-05-21 06:01:52 Delaying start of download for RB.20171200.CME_NY | 2017-05-21 06:01:52 Chart #13 has tagged chart #1 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:01:53 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:01:53 Chart #13 has tagged chart #14 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:01:53 Chart #13 has tagged chart #17 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:01:53 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:01:53 CTS T4 FIX | Received matching security definition for symbol ZN.20170600.CME_F. Subscribing to data. | 2017-05-21 06:01:53 CTS T4 FIX | Received 1 security definitions for underlying symbol ZN | 2017-05-21 06:01:53 Contract specifications for ZN.20170600.CME_F. Multiplier: 0.00000100. Tick Size: 0.015625. Value Format: 132. Currency Value per Tick: 15.625 | 2017-05-21 06:01:53 Chart #13 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:01:53 Chart #13 has tagged chart #14 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:01:53 Chart #13 has tagged chart #17 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:01:53 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:01:53 Chart #15 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:01:53 Chart #15 has tagged chart #13 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:01:53 Chart #15 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:01:53 Chart #15 has tagged chart #26 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:01:53 Chart #15 has tagged chart #5 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:01:53 6J.20170600.CME_Fo [C] 30 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:01:53 Chart #5 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:01:53 Chart #5 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:01:53 ES.20170600.CME_Eq 30 Sec #17 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:01:53 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:01:53 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:01:53 Chart #17 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:01:53 ES.20170600.CME_Eq 3 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:01:53 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:01:53 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:01:53 Chart #17 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:01:53 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:01:53 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:01:53 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:01:53 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:01:53 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:01:53 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:01:53 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:01:53 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:01:53 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:01:53 GC.20170600.CME_CO 3 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:01:53 Chart #1 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:01:53 Chart #1 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:01:53 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:01:53 ZB.20170600.CME_F [C] 15 Min #26 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:01:57 6J.20170600.CME_Fo 3 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:01:57 Chart #14 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:01:57 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:01:57 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:01:57 NQ.20170600.CME_Eq 30 Sec #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:01:57 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:01:57 6J.20170600.CME_Fo 30 Sec #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:01:57 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:01:57 GC.20170600.CME_CO 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:01:57 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:01:57 GC.20170600.CME_CO [C] 30 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:01:57 Chart #13 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:01:57 Chart #13 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:01:57 Chart #13 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:01:57 Chart #13 has tagged chart #4 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:01:57 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:01:57 CTS T4 FIX | Sending security definition request for symbol ZT.20170600.CME_F | 2017-05-21 06:01:57 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:01:57 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:01:57 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:01:57 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:01:57 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:01:57 CTS T4 FIX | Received matching security definition for symbol ZT.20170600.CME_F. Subscribing to data. | 2017-05-21 06:01:57 CTS T4 FIX | Received 1 security definitions for underlying symbol ZT | 2017-05-21 06:01:57 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:01:57 6C.20170600.CME_Fo [C] 30 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:01:57 Contract specifications for ZT.20170600.CME_F. Multiplier: 0.00000010. Tick Size: 0.0078125. Value Format: 228. Currency Value per Tick: 15.625 | 2017-05-21 06:01:57 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:01:57 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:01:57 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:01:57 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:02:04 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:02:04 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:02:04 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:02:04 HD Request # 331 | Downloading Intraday chart data for RB.20171200.CME_NY to the file RB.20171200.CME_NY.scid. Service: cts | 2017-05-21 06:02:22 HD Request # 331 | Download start date-time: 2017-05-19 16:18:13.000 | 2017-05-21 06:02:22 HD Request # 331 | Requesting historical Second data for RB.20171200.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:02:22 HD Request # 331 | Receiving Intraday data for RB.20171200.CME_NY starting at 2017-05-18 21:53:54 | 2017-05-21 06:02:22 HD Request # 331 | Timestamp of first Intraday data file record written: 2017-05-19 16:18:13 | 2017-05-21 06:02:22 HD Request # 331 | Total records received: 758 | 2017-05-21 06:02:22 HD Request # 331 | Requesting historical Second data for RB.20171200.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:02:22 HD Request # 331 | Total records received: 758 | 2017-05-21 06:02:22 HD Request # 331 | Requesting historical Second data for RB.20171200.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:02:22 HD Request # 331 | Total records received: 758 | 2017-05-21 06:02:22 HD Request # 331 | Requesting historical Second data for RB.20171200.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:02:22 HD Request # 331 | Total records received: 758 | 2017-05-21 06:02:22 HD Request # 331 | Requesting historical Second data for RB.20171200.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:02:22 HD Request # 331 | Received 758 records from 2017-05-18 21:53:54 to 2017-05-19 16:18:13 (18.4 hours) and wrote 1 record for RB.20171200.CME_NY | 2017-05-21 06:02:24 HD Request # 331 | Intraday download COMPLETE for RB.20171200.CME_NY. Completion time: 2s. Unique request ID: 503 | 2017-05-21 06:02:24 Removed historical data download ID 503 | 2017-05-21 06:02:24 Real-time Intraday chart data file updates started for RB.20171200.CME_NY | 2017-05-21 06:02:24 Opened cached Intraday file: C:\SierraChart1\Data\RB.20171200.CME_NY.scid | 2017-05-21 06:02:24 Intraday chart data file opened for RB.20171200.CME_NY | 2017-05-21 06:02:24 Delaying start of download for ZN.20170600.CME_F | 2017-05-21 06:02:24 Chart #23 has tagged chart #16 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:02:25 CL.20170700.CME_NY 3 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:02:25 Chart #16 has tagged chart #15 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:02:25 6C.20170600.CME_Fo 3 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:02:27 HD Request # 332 | Downloading Intraday chart data for ZN.20170600.CME_F to the file ZN.20170600.CME_F.scid. Service: cts | 2017-05-21 06:02:46 HD Request # 332 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:02:46 HD Request # 332 | Requesting historical Second data for ZN.20170600.CME_F from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:02:46 HD Request # 332 | Receiving Intraday data for ZN.20170600.CME_F starting at 2017-05-18 18:00:00 | 2017-05-21 06:02:48 HD Request # 332 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:02:48 HD Request # 332 | Total records received: 10370 | 2017-05-21 06:02:48 HD Request # 332 | Requesting historical Second data for ZN.20170600.CME_F from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:02:48 HD Request # 332 | Total records received: 10370 | 2017-05-21 06:02:48 HD Request # 332 | Requesting historical Second data for ZN.20170600.CME_F from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:02:48 HD Request # 332 | Total records received: 10370 | 2017-05-21 06:02:48 HD Request # 332 | Requesting historical Second data for ZN.20170600.CME_F from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:02:48 HD Request # 332 | Total records received: 10370 | 2017-05-21 06:02:48 HD Request # 332 | Requesting historical Second data for ZN.20170600.CME_F from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:02:48 HD Request # 332 | Received 10370 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for ZN.20170600.CME_F | 2017-05-21 06:02:48 HD Request # 332 | Intraday download COMPLETE for ZN.20170600.CME_F. Completion time: 2s. Unique request ID: 504 | 2017-05-21 06:02:48 Removed historical data download ID 504 | 2017-05-21 06:02:48 Real-time Intraday chart data file updates started for ZN.20170600.CME_F | 2017-05-21 06:02:48 Opened cached Intraday file: C:\SierraChart1\Data\ZN.20170600.CME_F.scid | 2017-05-21 06:02:48 Intraday chart data file opened for ZN.20170600.CME_F | 2017-05-21 06:02:48 Delaying start of download for 6J.20170600.CME_Fo | 2017-05-21 06:02:48 Chart #19 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:02:49 Chart #19 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:02:49 Chart #16 has tagged chart #13 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:02:49 Chart #16 has tagged chart #15 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:02:49 Chart #16 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:02:49 Chart #16 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:02:49 Chart #16 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:02:49 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:02:49 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:02:49 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:02:49 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:02:49 GC.20170600.CME_CO 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:02:49 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:02:49 GC.20170600.CME_CO [C] 30 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:02:49 Chart #13 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:02:49 Chart #13 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:02:49 Chart #13 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:02:49 Chart #13 has tagged chart #4 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:02:49 ZB.20170600.CME_F 30 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:02:49 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:02:49 ZB.20170600.CME_F [C] 30 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:02:49 Chart #15 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:02:49 Chart #15 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:02:49 Chart #15 has tagged chart #26 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:02:49 Chart #19 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:02:49 Chart #19 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:02:49 Chart #19 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:02:49 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:02:49 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:02:49 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:02:49 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:02:49 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:02:49 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:02:49 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:02:49 6C.20170600.CME_Fo [C] 30 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:02:49 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:02:49 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:02:49 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:02:49 ZB.20170600.CME_F [C] 15 Min #26 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:02:55 ZB.20170600.CME_F 3 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:02:55 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:02:55 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:02:55 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:02:55 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:02:55 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:02:55 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:02:55 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:02:55 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:02:55 HD Request # 333 | Downloading Intraday chart data for 6J.20170600.CME_Fo to the file 6J.20170600.CME_Fo.scid. Service: cts | 2017-05-21 06:03:17 HD Request # 333 | Download start date-time: 2017-05-19 16:59:51.000 | 2017-05-21 06:03:17 HD Request # 333 | Requesting historical Second data for 6J.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:03:17 HD Request # 333 | Receiving Intraday data for 6J.20170600.CME_Fo starting at 2017-05-18 18:00:00 | 2017-05-21 06:03:20 HD Request # 333 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:51 | 2017-05-21 06:03:20 HD Request # 333 | Total records received: 19164 | 2017-05-21 06:03:20 HD Request # 333 | Requesting historical Second data for 6J.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:03:20 HD Request # 333 | Total records received: 19164 | 2017-05-21 06:03:20 HD Request # 333 | Requesting historical Second data for 6J.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:03:20 HD Request # 333 | Total records received: 19164 | 2017-05-21 06:03:20 HD Request # 333 | Requesting historical Second data for 6J.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:03:20 HD Request # 333 | Total records received: 19164 | 2017-05-21 06:03:20 HD Request # 333 | Requesting historical Second data for 6J.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:03:20 HD Request # 333 | Received 19164 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:51 (23.0 hours) and wrote 1 record for 6J.20170600.CME_Fo | 2017-05-21 06:03:20 HD Request # 333 | Intraday download COMPLETE for 6J.20170600.CME_Fo. Completion time: 4s. Unique request ID: 505 | 2017-05-21 06:03:20 Removed historical data download ID 505 | 2017-05-21 06:03:20 Real-time Intraday chart data file updates started for 6J.20170600.CME_Fo | 2017-05-21 06:03:20 Opened cached Intraday file: C:\SierraChart1\Data\6J.20170600.CME_Fo.scid | 2017-05-21 06:03:20 Intraday chart data file opened for 6J.20170600.CME_Fo | 2017-05-21 06:03:20 Delaying start of download for 6S.20170600.CME_Fo | 2017-05-21 06:03:20 Chart #14 has tagged chart #1 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:03:22 Chart #14 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:03:22 Chart #14 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:03:22 ZB.20170600.CME_F 3 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:03:22 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:03:22 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:03:22 Chart #14 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:03:22 Chart #14 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:03:22 GC.20170600.CME_CO 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:03:22 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:03:22 ZB.20170600.CME_F 30 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:03:22 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:03:22 Chart #5 has tagged chart #13 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:03:22 Chart #5 has tagged chart #15 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:03:22 Chart #5 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:03:22 Chart #5 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:03:22 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:03:22 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:03:22 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:03:22 GC.20170600.CME_CO 3 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:03:22 Chart #1 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:03:22 Chart #1 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:03:22 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:03:22 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:03:27 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:03:27 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:03:27 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:03:27 GC.20170600.CME_CO [C] 30 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:03:27 Chart #13 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:03:27 Chart #13 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:03:27 Chart #13 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:03:27 Chart #13 has tagged chart #4 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:03:27 ZB.20170600.CME_F [C] 30 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:03:27 Chart #15 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:03:27 Chart #15 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:03:27 Chart #15 has tagged chart #26 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:03:27 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:03:27 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:03:27 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:03:27 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:03:27 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:03:27 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:03:27 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:03:27 6C.20170600.CME_Fo [C] 30 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:03:27 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:03:27 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:03:27 ZB.20170600.CME_F [C] 15 Min #26 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:03:31 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:03:31 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:03:31 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:03:31 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:03:31 HD Request # 334 | Downloading Intraday chart data for 6S.20170600.CME_Fo to the file 6S.20170600.CME_Fo.scid. Service: cts | 2017-05-21 06:03:53 HD Request # 334 | Download start date-time: 2017-05-19 16:59:35.000 | 2017-05-21 06:03:53 HD Request # 334 | Requesting historical Second data for 6S.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:03:53 HD Request # 334 | Receiving Intraday data for 6S.20170600.CME_Fo starting at 2017-05-18 18:00:00 | 2017-05-21 06:03:53 HD Request # 334 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:35 | 2017-05-21 06:03:53 HD Request # 334 | Total records received: 4884 | 2017-05-21 06:03:53 HD Request # 334 | Requesting historical Second data for 6S.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:03:53 HD Request # 334 | Total records received: 4884 | 2017-05-21 06:03:53 HD Request # 334 | Requesting historical Second data for 6S.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:03:53 HD Request # 334 | Total records received: 4884 | 2017-05-21 06:03:53 HD Request # 334 | Requesting historical Second data for 6S.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:03:53 HD Request # 334 | Total records received: 4884 | 2017-05-21 06:03:53 HD Request # 334 | Requesting historical Second data for 6S.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:03:53 HD Request # 334 | Received 4884 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:35 (23.0 hours) and wrote 1 record for 6S.20170600.CME_Fo | 2017-05-21 06:03:55 HD Request # 334 | Intraday download COMPLETE for 6S.20170600.CME_Fo. Completion time: 0s. Unique request ID: 506 | 2017-05-21 06:03:55 Removed historical data download ID 506 | 2017-05-21 06:03:55 Real-time Intraday chart data file updates started for 6S.20170600.CME_Fo | 2017-05-21 06:03:55 Opened cached Intraday file: C:\SierraChart1\Data\6S.20170600.CME_Fo.scid | 2017-05-21 06:03:55 Intraday chart data file opened for 6S.20170600.CME_Fo | 2017-05-21 06:03:55 Delaying start of download for RB.20170700.CME_NY | 2017-05-21 06:03:55 HD Request # 335 | Downloading Intraday chart data for RB.20170700.CME_NY to the file RB.20170700.CME_NY.scid. Service: cts | 2017-05-21 06:04:20 HD Request # 335 | Download start date-time: 2017-05-19 16:59:53.000 | 2017-05-21 06:04:20 HD Request # 335 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:04:20 HD Request # 335 | Receiving Intraday data for RB.20170700.CME_NY starting at 2017-05-18 18:00:00 | 2017-05-21 06:04:20 HD Request # 335 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:53 | 2017-05-21 06:04:20 HD Request # 335 | Total records received: 7454 | 2017-05-21 06:04:20 HD Request # 335 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:04:20 HD Request # 335 | Total records received: 7454 | 2017-05-21 06:04:20 HD Request # 335 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:04:20 HD Request # 335 | Total records received: 7454 | 2017-05-21 06:04:20 HD Request # 335 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:04:20 HD Request # 335 | Total records received: 7454 | 2017-05-21 06:04:20 HD Request # 335 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:04:20 HD Request # 335 | Received 7454 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:53 (23.0 hours) and wrote 1 record for RB.20170700.CME_NY | 2017-05-21 06:04:22 HD Request # 335 | Intraday download COMPLETE for RB.20170700.CME_NY. Completion time: 2s. Unique request ID: 507 | 2017-05-21 06:04:22 Removed historical data download ID 507 | 2017-05-21 06:04:22 Real-time Intraday chart data file updates started for RB.20170700.CME_NY | 2017-05-21 06:04:22 Opened cached Intraday file: C:\SierraChart1\Data\RB.20170700.CME_NY.scid | 2017-05-21 06:04:22 Intraday chart data file opened for RB.20170700.CME_NY | 2017-05-21 06:04:22 Delaying start of download for CL.20171200.CME_NY | 2017-05-21 06:04:22 Chart #18 has tagged chart #16 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:04:22 Chart #21 has tagged chart #9 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:04:22 Chart #22 has tagged chart #16 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:04:24 CL.20170700.CME_NY 30 Sec #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:04:24 CL.20170700.CME_NY [C] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:04:24 Chart #9 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:04:24 CL.20170700.CME_NY 3 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:04:24 Chart #16 has tagged chart #15 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:04:24 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:04:24 6C.20170600.CME_Fo 3 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:04:27 HD Request # 336 | Downloading Intraday chart data for CL.20171200.CME_NY to the file CL.20171200.CME_NY.scid. Service: cts | 2017-05-21 06:04:48 HD Request # 336 | Download start date-time: 2017-05-19 16:59:47.000 | 2017-05-21 06:04:48 HD Request # 336 | Requesting historical Second data for CL.20171200.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:04:48 HD Request # 336 | Receiving Intraday data for CL.20171200.CME_NY starting at 2017-05-18 18:00:18 | 2017-05-21 06:04:48 HD Request # 336 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:47 | 2017-05-21 06:04:48 HD Request # 336 | Total records received: 2449 | 2017-05-21 06:04:48 HD Request # 336 | Requesting historical Second data for CL.20171200.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:04:48 HD Request # 336 | Total records received: 2449 | 2017-05-21 06:04:48 HD Request # 336 | Requesting historical Second data for CL.20171200.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:04:48 HD Request # 336 | Total records received: 2449 | 2017-05-21 06:04:48 HD Request # 336 | Requesting historical Second data for CL.20171200.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:04:48 HD Request # 336 | Total records received: 2449 | 2017-05-21 06:04:48 HD Request # 336 | Requesting historical Second data for CL.20171200.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:04:48 HD Request # 336 | Received 2449 records from 2017-05-18 18:00:18 to 2017-05-19 16:59:47 (23.0 hours) and wrote 1 record for CL.20171200.CME_NY | 2017-05-21 06:04:49 HD Request # 336 | Intraday download COMPLETE for CL.20171200.CME_NY. Completion time: 1s. Unique request ID: 508 | 2017-05-21 06:04:49 Removed historical data download ID 508 | 2017-05-21 06:04:49 Real-time Intraday chart data file updates started for CL.20171200.CME_NY | 2017-05-21 06:04:49 Opened cached Intraday file: C:\SierraChart1\Data\CL.20171200.CME_NY.scid | 2017-05-21 06:04:49 Intraday chart data file opened for CL.20171200.CME_NY | 2017-05-21 06:04:49 Delaying start of download for GC.20170600.CME_CO | 2017-05-21 06:04:49 Chart #6 has tagged chart #19 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:04:49 Chart #6 has tagged chart #9 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:04:49 ZN.20170600.CME_F 30 Sec #19 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:04:51 Chart #19 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:04:51 Chart #19 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:04:51 Chart #17 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:04:51 Chart #17 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:04:51 Chart #17 has tagged chart #9 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:04:51 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:04:51 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:04:51 Chart #21 has tagged chart #16 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:04:51 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:04:51 ZT.20170600.CME_F 30 Sec #9 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:04:51 Chart #9 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:04:51 Chart #9 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:04:51 GC.20170600.CME_CO 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:04:51 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:04:51 ZB.20170600.CME_F 30 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:04:51 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:04:51 CL.20170700.CME_NY [C] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:04:51 Chart #9 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:04:51 CL.20170700.CME_NY 3 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:04:51 Chart #16 has tagged chart #15 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:04:51 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:04:51 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:04:51 6C.20170600.CME_Fo 3 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:04:57 HD Request # 337 | Downloading Intraday chart data for GC.20170600.CME_CO to the file GC.20170600.CME_CO.scid. Service: cts | 2017-05-21 06:05:18 HD Request # 337 | Download start date-time: 2017-05-19 16:59:57.000 | 2017-05-21 06:05:18 HD Request # 337 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:05:18 HD Request # 337 | Receiving Intraday data for GC.20170600.CME_CO starting at 2017-05-18 18:00:00 | 2017-05-21 06:05:20 HD Request # 337 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:57 | 2017-05-21 06:05:20 HD Request # 337 | Total records received: 26821 | 2017-05-21 06:05:20 HD Request # 337 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:05:20 HD Request # 337 | Total records received: 26821 | 2017-05-21 06:05:20 HD Request # 337 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:05:20 HD Request # 337 | Total records received: 26821 | 2017-05-21 06:05:20 HD Request # 337 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:05:20 HD Request # 337 | Total records received: 26821 | 2017-05-21 06:05:20 HD Request # 337 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:05:20 HD Request # 337 | Received 26821 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:57 (23.0 hours) and wrote 1 record for GC.20170600.CME_CO | 2017-05-21 06:05:20 HD Request # 337 | Intraday download COMPLETE for GC.20170600.CME_CO. Completion time: 3s. Unique request ID: 509 | 2017-05-21 06:05:20 Removed historical data download ID 509 | 2017-05-21 06:05:20 Real-time Intraday chart data file updates started for GC.20170600.CME_CO | 2017-05-21 06:05:20 Opened cached Intraday file: C:\SierraChart1\Data\GC.20170600.CME_CO.scid | 2017-05-21 06:05:20 Intraday chart data file opened for GC.20170600.CME_CO | 2017-05-21 06:05:20 Delaying start of download for NQ.20170600.CME_Eq | 2017-05-21 06:05:20 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:05:22 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:05:22 Chart #1 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:05:22 Chart #1 has tagged chart #14 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:05:22 Chart #1 has tagged chart #17 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:05:22 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:05:22 Chart #13 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:05:22 Chart #13 has tagged chart #15 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:05:22 Chart #13 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:05:22 Chart #13 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:05:22 Chart #13 has tagged chart #4 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:05:22 Chart #13 has tagged chart #5 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:05:22 ZB.20170600.CME_F 30 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:05:22 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:05:22 ZB.20170600.CME_F [C] 30 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:05:22 Chart #15 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:05:22 Chart #15 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:05:22 Chart #15 has tagged chart #26 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:05:22 6J.20170600.CME_Fo [C] 30 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:05:22 Chart #5 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:05:22 Chart #5 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:05:22 ES.20170600.CME_Eq 30 Sec #17 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:05:22 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:05:22 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:05:22 Chart #17 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:05:22 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:05:22 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:05:22 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:05:22 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:05:22 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:05:22 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:05:22 6C.20170600.CME_Fo [C] 30 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:05:22 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:05:22 Chart #1 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:05:22 Chart #1 has tagged chart #14 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:05:22 Chart #1 has tagged chart #17 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:05:22 Chart #1 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:05:22 Chart #1 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:05:22 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:05:22 ZB.20170600.CME_F [C] 15 Min #26 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:05:27 6J.20170600.CME_Fo 3 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:05:27 Chart #14 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:05:27 ZB.20170600.CME_F 3 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:05:27 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:05:27 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:05:27 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:05:27 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:05:27 NQ.20170600.CME_Eq 30 Sec #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:05:27 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:05:27 6J.20170600.CME_Fo 30 Sec #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:05:27 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:05:27 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:05:27 ES.20170600.CME_Eq 3 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:05:27 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:05:27 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:05:27 Chart #17 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:05:27 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:05:27 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:05:27 6J.20170600.CME_Fo 3 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:05:32 Chart #14 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:05:32 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:05:32 HD Request # 338 | Downloading Intraday chart data for NQ.20170600.CME_Eq to the file NQ.20170600.CME_Eq.scid. Service: cts | 2017-05-21 06:05:52 HD Request # 338 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:05:52 HD Request # 338 | Requesting historical Second data for NQ.20170600.CME_Eq from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:05:52 HD Request # 338 | Receiving Intraday data for NQ.20170600.CME_Eq starting at 2017-05-18 18:00:00 | 2017-05-21 06:05:55 HD Request # 338 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:05:55 HD Request # 338 | Total records received: 24898 | 2017-05-21 06:05:55 HD Request # 338 | Requesting historical Second data for NQ.20170600.CME_Eq from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:05:55 HD Request # 338 | Total records received: 24898 | 2017-05-21 06:05:55 HD Request # 338 | Requesting historical Second data for NQ.20170600.CME_Eq from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:05:55 HD Request # 338 | Total records received: 24898 | 2017-05-21 06:05:55 HD Request # 338 | Requesting historical Second data for NQ.20170600.CME_Eq from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:05:55 HD Request # 338 | Total records received: 24898 | 2017-05-21 06:05:55 HD Request # 338 | Requesting historical Second data for NQ.20170600.CME_Eq from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:05:55 HD Request # 338 | Received 24898 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for NQ.20170600.CME_Eq | 2017-05-21 06:05:55 HD Request # 338 | Intraday download COMPLETE for NQ.20170600.CME_Eq. Completion time: 3s. Unique request ID: 510 | 2017-05-21 06:05:55 Removed historical data download ID 510 | 2017-05-21 06:05:55 Real-time Intraday chart data file updates started for NQ.20170600.CME_Eq | 2017-05-21 06:05:55 Opened cached Intraday file: C:\SierraChart1\Data\NQ.20170600.CME_Eq.scid | 2017-05-21 06:05:55 Intraday chart data file opened for NQ.20170600.CME_Eq | 2017-05-21 06:05:55 Delaying start of download for YM.20170600.CME_E | 2017-05-21 06:05:55 HD Request # 339 | Downloading Intraday chart data for YM.20170600.CME_E to the file YM.20170600.CME_E.scid. Service: cts | 2017-05-21 06:06:18 HD Request # 339 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:06:18 HD Request # 339 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:06:18 HD Request # 339 | Receiving Intraday data for YM.20170600.CME_E starting at 2017-05-18 18:00:00 | 2017-05-21 06:06:19 HD Request # 339 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:06:19 HD Request # 339 | Total records received: 19680 | 2017-05-21 06:06:19 HD Request # 339 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:06:19 HD Request # 339 | Total records received: 19680 | 2017-05-21 06:06:19 HD Request # 339 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:06:19 HD Request # 339 | Total records received: 19680 | 2017-05-21 06:06:19 HD Request # 339 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:06:19 HD Request # 339 | Total records received: 19680 | 2017-05-21 06:06:19 HD Request # 339 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:06:19 HD Request # 339 | Received 19680 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for YM.20170600.CME_E | 2017-05-21 06:06:21 HD Request # 339 | Intraday download COMPLETE for YM.20170600.CME_E. Completion time: 2s. Unique request ID: 511 | 2017-05-21 06:06:21 Removed historical data download ID 511 | 2017-05-21 06:06:21 Real-time Intraday chart data file updates started for YM.20170600.CME_E | 2017-05-21 06:06:21 Opened cached Intraday file: C:\SierraChart1\Data\YM.20170600.CME_E.scid | 2017-05-21 06:06:21 Intraday chart data file opened for YM.20170600.CME_E | 2017-05-21 06:06:21 Delaying start of download for CL.20170700.CME_NY | 2017-05-21 06:06:21 Chart #3 has tagged chart #4 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:06:21 ZB.20170600.CME_F 3 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:06:23 CTS FIX socket (2109) | Closed. No error. | 2017-05-21 06:06:23 CTS FIX socket (2109) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-21 06:06:23 CTS FIX socket (2109) | SSL has been shut down. | 2017-05-21 06:06:23 CTS FIX socket (2109) | SSL object has been freed. SSL state is now disconnected. | 2017-05-21 06:06:23 CTS FIX socket (2109) | Shutdown and closed. | 2017-05-21 06:06:23 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2017-05-21 06:06:23 Connection to the external service has been lost. | 2017-05-21 06:06:23 CTS FIX Historical Data socket (2110) | Closed. No error. | 2017-05-21 06:06:23 CTS FIX Historical Data: Received a Logout message. Text = Timed out. No valid messages received within the heartbeat interval of 30 seconds | 2017-05-21 06:06:23 CTS FIX Historical Data: Sending a Logout message. Text = Received Logout message. | 2017-05-21 06:06:23 CTS FIX Historical Data socket (2110) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-21 06:06:23 CTS FIX Historical Data socket (2110) | SSL has been shut down. | 2017-05-21 06:06:23 CTS FIX Historical Data socket (2110) | SSL object has been freed. SSL state is now disconnected. | 2017-05-21 06:06:23 CTS FIX Historical Data socket (2110) | Shutdown and closed. | 2017-05-21 06:06:23 CTS FIX Historical Data: Disconnected. | 2017-05-21 06:06:23 Canceling historical data download request for CL.20170700.CME_NY Intraday data. | 2017-05-21 06:07:26 Removed historical data download ID 512 | 2017-05-21 06:07:26 Canceling historical data download request for 6A.20170600.CME_Fo Intraday data. | 2017-05-21 06:07:26 Removed historical data download ID 513 | 2017-05-21 06:07:26 Canceling historical data download request for ZT.20170600.CME_F Intraday data. | 2017-05-21 06:07:26 Removed historical data download ID 514 | 2017-05-21 06:07:26 Canceling historical data download request for HO.20170700.CME_NY Intraday data. | 2017-05-21 06:07:26 Removed historical data download ID 515 | 2017-05-21 06:07:26 Canceling historical data download request for 6B.20170600.CME_Fo Intraday data. | 2017-05-21 06:07:26 Removed historical data download ID 516 | 2017-05-21 06:07:26 Canceling historical data download request for 6C.20170600.CME_Fo Intraday data. | 2017-05-21 06:07:26 Removed historical data download ID 517 | 2017-05-21 06:07:26 Canceling historical data download request for ES.20170600.CME_Eq Intraday data. | 2017-05-21 06:07:26 Removed historical data download ID 518 | 2017-05-21 06:07:26 Canceling historical data download request for 6E.20170600.CME_Fo Intraday data. | 2017-05-21 06:07:26 Removed historical data download ID 519 | 2017-05-21 06:07:26 Canceling historical data download request for HO.20171200.CME_NY Intraday data. | 2017-05-21 06:07:26 Removed historical data download ID 521 | 2017-05-21 06:07:26 CTS T4 FIX | Disconnected. | 2017-05-21 06:07:26 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-21 06:07:26 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2017-05-21 06:07:29 CTS T4 FIX | Firm: PTP | 2017-05-21 06:07:29 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 69.44.110.200. | 2017-05-21 06:07:29 CTS FIX socket (2117) | Connected. | 2017-05-21 06:07:29 CTS FIX socket (2117) | Starting TLS 1.0 connection. | 2017-05-21 06:07:29 CTS FIX socket (2117) | SSL connection established. | 2017-05-21 06:07:31 CTS FIX: Sending the Logon message. | 2017-05-21 06:07:32 CTS T4 FIX | FIX version: 4.3.74.0 | 2017-05-21 06:07:32 CTS T4 FIX | Connected to data and trading server. | 2017-05-21 06:07:32 DTC Client (2111) | Shutdown and closed. | 2017-05-21 06:07:32 SC DTC Data | Disconnected from the server. | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: ZB.20160900.CME_F. ID: 1 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: ZB.20160900.CME_F. ID: 1 | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: 6E.20160900.CME_Fo. ID: 2 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: 6E.20160900.CME_Fo. ID: 2 | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6J.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: 6J.20160900.CME_Fo. ID: 3 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: 6J.20160900.CME_Fo. ID: 3 | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6B.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: 6B.20160900.CME_Fo. ID: 4 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: 6B.20160900.CME_Fo. ID: 4 | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6C.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: 6C.20160900.CME_Fo. ID: 5 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: 6C.20160900.CME_Fo. ID: 5 | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: CL.20160800.CME_NY. ID: 6 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: CL.20160800.CME_NY. ID: 6 | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6A.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: 6A.20160900.CME_Fo. ID: 7 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: 6A.20160900.CME_Fo. ID: 7 | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: NQ.20160900.CME_Eq. ID: 8 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: NQ.20160900.CME_Eq. ID: 8 | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM.######00.CME_E pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: YM.20160900.CME_E. ID: 9 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: YM.20160900.CME_E. ID: 9 | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: GC.20160800.CME_CO. ID: 10 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: GC.20160800.CME_CO. ID: 10 | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: ES.20160900.CME_Eq. ID: 11 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: ES.20160900.CME_Eq. ID: 11 | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: ZB.20170300.CME_F. ID: 12 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: ZB.20170300.CME_F. ID: 12 | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: CL.20170100.CME_NY. ID: 13 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: CL.20170100.CME_NY. ID: 13 | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: GC.20170400.CME_CO. ID: 14 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: GC.20170400.CME_CO. ID: 14 | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: ZB.20170600.CME_F. ID: 15 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: ZB.20170600.CME_F. ID: 15 | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6B.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: 6B.20170600.CME_Fo. ID: 16 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: 6B.20170600.CME_Fo. ID: 16 | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: CL.20170600.CME_NY. ID: 17 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: CL.20170600.CME_NY. ID: 17 | 2017-05-21 06:07:32 CTS T4 FIX | Sending security definition request for symbol 6A.20160900.CME_Fo | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: CL.20170700.CME_NY. ID: 18 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: CL.20170700.CME_NY. ID: 18 | 2017-05-21 06:07:32 CTS T4 FIX | Using primary service for historical data for CL.20170700.CME_NY | 2017-05-21 06:07:32 Intraday data recording state for symbol CL.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:07:32 Delaying start of download for CL.20170700.CME_NY | 2017-05-21 06:07:32 CTS T4 FIX | Received Account List collateral report. | 2017-05-21 06:07:32 CTS T4 FIX | Subscribing to account: May* | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The RB.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: RB.20170700.CME_NY. ID: 19 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: RB.20170700.CME_NY. ID: 19 | 2017-05-21 06:07:32 CTS T4 FIX | Using primary service for historical data for RB.20170700.CME_NY | 2017-05-21 06:07:32 Intraday data recording state for symbol RB.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:07:32 CTS T4 FIX | Using primary service for historical data for 6B.20170600.CME_Fo | 2017-05-21 06:07:32 Intraday data recording state for symbol 6B.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: 6E.20170600.CME_Fo. ID: 20 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: 6E.20170600.CME_Fo. ID: 20 | 2017-05-21 06:07:32 CTS T4 FIX | Using primary service for historical data for 6E.20170600.CME_Fo | 2017-05-21 06:07:32 Intraday data recording state for symbol 6E.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM.######00.CME_E pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: YM.20170600.CME_E. ID: 21 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: YM.20170600.CME_E. ID: 21 | 2017-05-21 06:07:32 CTS T4 FIX | Using primary service for historical data for YM.20170600.CME_E | 2017-05-21 06:07:32 Intraday data recording state for symbol YM.20170600.CME_E is set to download 'Pending'. | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: ES.20170600.CME_Eq. ID: 22 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: ES.20170600.CME_Eq. ID: 22 | 2017-05-21 06:07:32 CTS T4 FIX | Using primary service for historical data for ES.20170600.CME_Eq | 2017-05-21 06:07:32 Intraday data recording state for symbol ES.20170600.CME_Eq is set to download 'Pending'. | 2017-05-21 06:07:32 Using Bid/Ask average for last trade price for AUDJPY | 2017-05-21 06:07:32 SC DTC Data | Starting real-time market data updates for: AUDJPY. ID: 23 | 2017-05-21 06:07:32 SC DTC Data | Connecting to the server ds4.sierracharts.com. Port 443 | 2017-05-21 06:07:32 SC DTC Data | Requesting security definition data for: AUDJPY. ID: 23 | 2017-05-21 06:07:32 Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2017-05-21 06:07:32 DTC Client (0) | Resolved address ds4.sierracharts.com to IP 192.81.56.146. | 2017-05-21 06:07:32 Delaying start of download for AUDJPY | 2017-05-21 06:07:32 Supported exchange: CME_CO (SIM:COMEX Futures) | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6S.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: 6S.20170600.CME_Fo. ID: 24 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: 6S.20170600.CME_Fo. ID: 24 | 2017-05-21 06:07:32 CTS T4 FIX | Using primary service for historical data for 6S.20170600.CME_Fo | 2017-05-21 06:07:32 Intraday data recording state for symbol 6S.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:07:32 Supported exchange: CME_EqOp (SIM:CME Equity Options) | 2017-05-21 06:07:32 Requesting market depth updates for: 6E.20170600.CME_Fo if supported. | 2017-05-21 06:07:32 Supported exchange: CME_NYOp (SIM:NYMEX Options) | 2017-05-21 06:07:32 DTC Client (2118) | Connected. | 2017-05-21 06:07:32 SC DTC Data | Connected to server. | 2017-05-21 06:07:32 SC DTC Data | Sending Encoding Request to server | 2017-05-21 06:07:32 Supported exchange: CME_AgOp (SIM:CME Agricultural Options) | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The HO.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: HO.20170700.CME_NY. ID: 25 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: HO.20170700.CME_NY. ID: 25 | 2017-05-21 06:07:32 CTS T4 FIX | Using primary service for historical data for HO.20170700.CME_NY | 2017-05-21 06:07:32 Intraday data recording state for symbol HO.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:07:32 Supported exchange: CME_Eq (SIM:CME Equity Futures) | 2017-05-21 06:07:32 Supported exchange: CME_In (SIM:CME Interest Rate Futures) | 2017-05-21 06:07:32 Supported exchange: CME_C (SIM:CBOT Commodity Futures) | 2017-05-21 06:07:32 Supported exchange: CME_KOp (SIM:KCBT Options) | 2017-05-21 06:07:32 Supported exchange: CME_F (SIM:CBOT Financial Futures) | 2017-05-21 06:07:32 Supported exchange: CME_E (SIM:CBOT Equity Futures) | 2017-05-21 06:07:32 Supported exchange: CME_COp (SIM:CBOT Commodity Options) | 2017-05-21 06:07:32 Supported exchange: CME_K (SIM:KCBT Futures) | 2017-05-21 06:07:32 Supported exchange: CME_EOp (SIM:CBOT Equity Options) | 2017-05-21 06:07:32 Supported exchange: CME_NY (SIM:NYMEX Futures) | 2017-05-21 06:07:32 Supported exchange: CME_Fo (SIM:CME Foreign Exchange Futures) | 2017-05-21 06:07:32 Supported exchange: CME_Ag (SIM:CME Agricultural Futures) | 2017-05-21 06:07:32 Supported exchange: CME_FoOp (SIM:CME Foreign Exchange Options) | 2017-05-21 06:07:32 Supported exchange: CME_FOp (SIM:CBOT Financial Options) | 2017-05-21 06:07:32 Supported exchange: CME_InOp (SIM:CME Interest Rate Options) | 2017-05-21 06:07:32 Supported exchange: CME_COOp (SIM:COMEX Options) | 2017-05-21 06:07:32 Symbol Error - 6A.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:07:32 CTS T4 FIX | Received 0 security definitions for underlying symbol 6A | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6C.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: 6C.20170600.CME_Fo. ID: 26 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: 6C.20170600.CME_Fo. ID: 26 | 2017-05-21 06:07:32 CTS T4 FIX | Using primary service for historical data for 6C.20170600.CME_Fo | 2017-05-21 06:07:32 Intraday data recording state for symbol 6C.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The HO.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: HO.20171200.CME_NY. ID: 27 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: HO.20171200.CME_NY. ID: 27 | 2017-05-21 06:07:32 CTS T4 FIX | Using primary service for historical data for HO.20171200.CME_NY | 2017-05-21 06:07:32 Intraday data recording state for symbol HO.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6N.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: 6N.20170600.CME_Fo. ID: 28 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: 6N.20170600.CME_Fo. ID: 28 | 2017-05-21 06:07:32 CTS T4 FIX | Using primary service for historical data for 6N.20170600.CME_Fo | 2017-05-21 06:07:32 Intraday data recording state for symbol 6N.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:07:32 HD Request # 340 | Downloading Intraday chart data for CL.20170700.CME_NY to the file CL.20170700.CME_NY.scid. Service: cts | 2017-05-21 06:07:32 HD Request # 340 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:07:32 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2017-05-21 06:07:32 SC DTC Data | Setting DTC encoding to Binary VLS | 2017-05-21 06:07:32 SC DTC Data | Sending logon request message. | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The RB.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: RB.20171200.CME_NY. ID: 29 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: RB.20171200.CME_NY. ID: 29 | 2017-05-21 06:07:32 CTS T4 FIX | Using primary service for historical data for RB.20171200.CME_NY | 2017-05-21 06:07:32 Intraday data recording state for symbol RB.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: NQ.20170600.CME_Eq. ID: 30 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: NQ.20170600.CME_Eq. ID: 30 | 2017-05-21 06:07:32 CTS T4 FIX | Using primary service for historical data for NQ.20170600.CME_Eq | 2017-05-21 06:07:32 Intraday data recording state for symbol NQ.20170600.CME_Eq is set to download 'Pending'. | 2017-05-21 06:07:32 CTS T4 FIX | Using primary service for historical data for ZB.20170600.CME_F | 2017-05-21 06:07:32 Intraday data recording state for symbol ZB.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6A.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: 6A.20170600.CME_Fo. ID: 31 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: 6A.20170600.CME_Fo. ID: 31 | 2017-05-21 06:07:32 CTS T4 FIX | Using primary service for historical data for 6A.20170600.CME_Fo | 2017-05-21 06:07:32 Intraday data recording state for symbol 6A.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:07:32 CTS FIX Historical Data socket (0) | Resolved address fix-chart-sim.t4login.com to IP 74.201.6.229. | 2017-05-21 06:07:32 Requesting market depth updates for: 6B.20170600.CME_Fo if supported. | 2017-05-21 06:07:32 CTS FIX Historical Data socket (2119) | Connected. | 2017-05-21 06:07:32 CTS FIX Historical Data socket (2119) | Starting TLS 1.0 connection. | 2017-05-21 06:07:32 SC DTC Data | Received logon response. | 2017-05-21 06:07:32 SC DTC Data | Server Name: SC Realtime Server. | 2017-05-21 06:07:32 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2017-05-21 06:07:32 SC DTC Data | Successfully connected. | 2017-05-21 06:07:32 SC DTC Data | Trading is not supported. | 2017-05-21 06:07:32 SC DTC Data | Restarting real-time data updates for symbol: AUDJPY | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:32 CTS T4 FIX | Starting real-time market data updates for: GC.20170600.CME_CO. ID: 32 | 2017-05-21 06:07:32 CTS T4 FIX | Requesting security definition data for: GC.20170600.CME_CO. ID: 32 | 2017-05-21 06:07:32 CTS T4 FIX | Using primary service for historical data for GC.20170600.CME_CO | 2017-05-21 06:07:32 Intraday data recording state for symbol GC.20170600.CME_CO is set to download 'Pending'. | 2017-05-21 06:07:32 SC DTC Data | Received security definition for symbol AUDJPY | 2017-05-21 06:07:32 Requesting market depth updates for: YM.20170600.CME_E if supported. | 2017-05-21 06:07:32 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZN.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:38 CTS T4 FIX | Starting real-time market data updates for: ZN.20170600.CME_F. ID: 33 | 2017-05-21 06:07:38 CTS T4 FIX | Requesting security definition data for: ZN.20170600.CME_F. ID: 33 | 2017-05-21 06:07:38 CTS T4 FIX | Using primary service for historical data for ZN.20170600.CME_F | 2017-05-21 06:07:38 Intraday data recording state for symbol ZN.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:07:38 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6J.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:38 CTS T4 FIX | Starting real-time market data updates for: 6J.20170600.CME_Fo. ID: 34 | 2017-05-21 06:07:38 CTS T4 FIX | Requesting security definition data for: 6J.20170600.CME_Fo. ID: 34 | 2017-05-21 06:07:38 CTS T4 FIX | Using primary service for historical data for 6J.20170600.CME_Fo | 2017-05-21 06:07:38 Intraday data recording state for symbol 6J.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:07:38 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:38 CTS T4 FIX | Starting real-time market data updates for: CL.20171200.CME_NY. ID: 35 | 2017-05-21 06:07:38 CTS T4 FIX | Requesting security definition data for: CL.20171200.CME_NY. ID: 35 | 2017-05-21 06:07:38 CTS T4 FIX | Using primary service for historical data for CL.20171200.CME_NY | 2017-05-21 06:07:38 Intraday data recording state for symbol CL.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:07:38 Requesting market depth updates for: NQ.20170600.CME_Eq if supported. | 2017-05-21 06:07:38 CTS FIX Historical Data socket (2119) | SSL connection established. | 2017-05-21 06:07:38 Requesting market depth updates for: 6J.20170600.CME_Fo if supported. | 2017-05-21 06:07:38 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZT.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:07:38 CTS T4 FIX | Starting real-time market data updates for: ZT.20170600.CME_F. ID: 36 | 2017-05-21 06:07:38 CTS T4 FIX | Requesting security definition data for: ZT.20170600.CME_F. ID: 36 | 2017-05-21 06:07:38 CTS T4 FIX | Using primary service for historical data for ZT.20170600.CME_F | 2017-05-21 06:07:38 Intraday data recording state for symbol ZT.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:07:38 Requesting market depth updates for: GC.20170600.CME_CO if supported. | 2017-05-21 06:07:38 Requesting market depth updates for: CL.20170700.CME_NY if supported. | 2017-05-21 06:07:38 Requesting market depth updates for: ZB.20170600.CME_F if supported. | 2017-05-21 06:07:38 Requesting market depth updates for: ES.20170600.CME_Eq if supported. | 2017-05-21 06:07:38 CTS T4 FIX | Received 'Account Update/Balance Data' collateral report. | 2017-05-21 06:07:38 CTS T4 FIX | Sending security definition request for symbol 6A.20170600.CME_Fo | 2017-05-21 06:07:38 CTS T4 FIX | Received matching security definition for symbol 6A.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:07:38 CTS T4 FIX | Received 1 security definitions for underlying symbol 6A | 2017-05-21 06:07:38 Contract specifications for 6A.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:07:38 HD Request # 341 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-05-21 06:07:38 HD Request # 341 | Download start date-time: 2017-05-19 16:57:58.000 | 2017-05-21 06:07:38 HD Request # 341 | Using server: ds4.sierracharts.com port 10149 | 2017-05-21 06:07:38 Socket (0) | Resolved address ds4.sierracharts.com to IP 192.81.56.146. | 2017-05-21 06:07:40 Socket (2120) | Connected. | 2017-05-21 06:07:40 HD Request # 341 | Setting DTC encoding to Binary VLS | 2017-05-21 06:07:40 HD Request # 341 | Sending historical data logon request message. | 2017-05-21 06:07:40 HD Request # 341 | Requesting Intraday data. Start date-time: 2017-05-19 16:57:58. Record interval: 1. Symbol: AUDJPY | 2017-05-21 06:07:40 HD Request # 341 | Decompressing data. | 2017-05-21 06:07:40 HD Request # 341 | Receiving Intraday data for AUDJPY starting at 2017-05-19 16:57:58 | 2017-05-21 06:07:40 HD Request # 341 | Timestamp of first Intraday data file record written: 2017-05-19 16:57:58 | 2017-05-21 06:07:40 Socket (2120) | Shutdown and closed. | 2017-05-21 06:07:40 The network socket for historical data has been closed. | 2017-05-21 06:07:40 HD Request # 341 | Received 1 record from 2017-05-19 16:57:58 to 2017-05-19 16:57:58 (0.0 seconds) and wrote 1 record for AUDJPY | 2017-05-21 06:07:40 HD Request # 341 | Intraday download COMPLETE for AUDJPY. Completion time: 0s. Unique request ID: 528 | 2017-05-21 06:07:40 Removed historical data download ID 528 | 2017-05-21 06:07:40 Real-time Intraday chart data file updates started for AUDJPY | 2017-05-21 06:07:40 Opened cached Intraday file: C:\SierraChart1\Data\AUDJPY.scid | 2017-05-21 06:07:40 Intraday chart data file opened for AUDJPY | 2017-05-21 06:07:40 CTS FIX Historical Data: Sending the Logon message. | 2017-05-21 06:07:40 CTS FIX Historical Data: Connected to Historical data server. | 2017-05-21 06:07:40 CTS T4 FIX | Sending security definition request for symbol 6B.20160900.CME_Fo | 2017-05-21 06:07:42 Requesting market depth updates for: 6B.20160900.CME_Fo if supported. | 2017-05-21 06:07:42 Requesting market depth updates for: 6E.20160900.CME_Fo if supported. | 2017-05-21 06:07:42 Requesting market depth updates for: 6J.20160900.CME_Fo if supported. | 2017-05-21 06:07:42 Requesting market depth updates for: 6N.20170600.CME_Fo if supported. | 2017-05-21 06:07:42 Requesting market depth updates for: CL.20160800.CME_NY if supported. | 2017-05-21 06:07:42 Requesting market depth updates for: CL.20170100.CME_NY if supported. | 2017-05-21 06:07:42 Requesting market depth updates for: CL.20170600.CME_NY if supported. | 2017-05-21 06:07:42 Requesting market depth updates for: CL.20171200.CME_NY if supported. | 2017-05-21 06:07:42 Requesting market depth updates for: ES.20160900.CME_Eq if supported. | 2017-05-21 06:07:42 Requesting market depth updates for: GC.20160800.CME_CO if supported. | 2017-05-21 06:07:42 Requesting market depth updates for: GC.20170400.CME_CO if supported. | 2017-05-21 06:07:42 Requesting market depth updates for: NQ.20160900.CME_Eq if supported. | 2017-05-21 06:07:42 Requesting market depth updates for: YM.20160900.CME_E if supported. | 2017-05-21 06:07:42 Requesting market depth updates for: ZB.20160900.CME_F if supported. | 2017-05-21 06:07:42 Requesting market depth updates for: ZB.20170300.CME_F if supported. | 2017-05-21 06:07:42 CTS T4 FIX | Requesting Open Orders for account: May*. Request ID: 9498351 | 2017-05-21 06:07:42 Symbol Error - 6B.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:07:42 CTS T4 FIX | Received 0 security definitions for underlying symbol 6B | 2017-05-21 06:07:42 CTS T4 FIX | No open orders for account May18CCwmitchel | 2017-05-21 06:07:42 CTS T4 FIX | Sending security definition request for symbol 6B.20170600.CME_Fo | 2017-05-21 06:07:45 CTS T4 FIX | Received matching security definition for symbol 6B.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:07:45 CTS T4 FIX | Received 1 security definitions for underlying symbol 6B | 2017-05-21 06:07:45 Contract specifications for 6B.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 6.25 | 2017-05-21 06:07:45 CTS T4 FIX | Sending security definition request for symbol 6C.20160900.CME_Fo | 2017-05-21 06:07:48 Symbol Error - 6C.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:07:48 CTS T4 FIX | Received 0 security definitions for underlying symbol 6C | 2017-05-21 06:07:48 CTS T4 FIX | Sending security definition request for symbol 6C.20170600.CME_Fo | 2017-05-21 06:07:51 CTS T4 FIX | Received matching security definition for symbol 6C.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:07:51 CTS T4 FIX | Received 1 security definitions for underlying symbol 6C | 2017-05-21 06:07:51 Contract specifications for 6C.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 5 | 2017-05-21 06:07:51 CTS T4 FIX | Requesting historical Fills for account: May*. Request ID: 9498354 | 2017-05-21 06:07:52 CTS T4 FIX | Received Account List collateral report. | 2017-05-21 06:07:52 CTS T4 FIX | Server provided no historical order fills for account 1A297B51-A416-42D4-A1C8-C9B1B4125155 | 2017-05-21 06:07:52 CTS T4 FIX | Sending security definition request for symbol 6E.20160900.CME_Fo | 2017-05-21 06:07:54 Symbol Error - 6E.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:07:54 CTS T4 FIX | Received 0 security definitions for underlying symbol 6E | 2017-05-21 06:07:54 CTS T4 FIX | Sending security definition request for symbol 6E.20170600.CME_Fo | 2017-05-21 06:07:57 CTS T4 FIX | Received matching security definition for symbol 6E.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:07:57 CTS T4 FIX | Received 1 security definitions for underlying symbol 6E | 2017-05-21 06:07:57 Contract specifications for 6E.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-05-21 06:07:57 CTS T4 FIX | Sending security definition request for symbol 6J.20160900.CME_Fo | 2017-05-21 06:08:00 Symbol Error - 6J.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:08:00 CTS T4 FIX | Received 0 security definitions for underlying symbol 6J | 2017-05-21 06:08:00 CTS T4 FIX | Sending security definition request for symbol 6J.20170600.CME_Fo | 2017-05-21 06:08:03 CTS T4 FIX | Received matching security definition for symbol 6J.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:08:03 CTS T4 FIX | Received 1 security definitions for underlying symbol 6J | 2017-05-21 06:08:03 Contract specifications for 6J.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-05-21 06:08:03 CTS T4 FIX | Sending security definition request for symbol 6N.20170600.CME_Fo | 2017-05-21 06:08:06 CTS T4 FIX | Received matching security definition for symbol 6N.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:08:06 CTS T4 FIX | Received 1 security definitions for underlying symbol 6N | 2017-05-21 06:08:06 Contract specifications for 6N.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:08:06 CTS T4 FIX | Sending security definition request for symbol 6S.20170600.CME_Fo | 2017-05-21 06:08:09 CTS T4 FIX | Received matching security definition for symbol 6S.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:08:09 CTS T4 FIX | Received 1 security definitions for underlying symbol 6S | 2017-05-21 06:08:09 Contract specifications for 6S.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 12.5 | 2017-05-21 06:08:09 CTS T4 FIX | Sending security definition request for symbol CL.20160800.CME_NY | 2017-05-21 06:08:11 Symbol Error - CL.20160800.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:08:13 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2017-05-21 06:08:13 CTS T4 FIX | Sending security definition request for symbol CL.20170100.CME_NY | 2017-05-21 06:08:15 Symbol Error - CL.20170100.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:08:15 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2017-05-21 06:08:15 CTS T4 FIX | Sending security definition request for symbol CL.20170600.CME_NY | 2017-05-21 06:08:18 CTS T4 FIX | Received matching security definition for symbol CL.20170600.CME_NY. Subscribing to data. | 2017-05-21 06:08:18 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:08:18 Contract specifications for CL.20170600.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:08:18 CTS T4 FIX | Sending security definition request for symbol CL.20170700.CME_NY | 2017-05-21 06:08:21 CTS T4 FIX | Received matching security definition for symbol CL.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:08:21 CTS T4 FIX | Received matching security definition for symbol CL.20170700.CME_NY. Requesting historical data. | 2017-05-21 06:08:21 HD Request # 340 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:08:21 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:08:21 Contract specifications for CL.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:08:21 HD Request # 340 | Receiving Intraday data for CL.20170700.CME_NY starting at 2017-05-18 18:00:00 | 2017-05-21 06:08:23 HD Request # 340 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:08:23 HD Request # 340 | Total records received: 33722 | 2017-05-21 06:08:23 HD Request # 340 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:08:23 HD Request # 340 | Total records received: 33722 | 2017-05-21 06:08:23 HD Request # 340 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:08:23 HD Request # 340 | Total records received: 33722 | 2017-05-21 06:08:23 HD Request # 340 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:08:23 CTS T4 FIX | Sending security definition request for symbol CL.20171200.CME_NY | 2017-05-21 06:08:23 CTS T4 FIX | Received matching security definition for symbol CL.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:08:25 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:08:25 HD Request # 340 | Total records received: 33722 | 2017-05-21 06:08:25 HD Request # 340 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:08:25 Contract specifications for CL.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:08:25 HD Request # 340 | Received 33722 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for CL.20170700.CME_NY | 2017-05-21 06:08:25 HD Request # 340 | Intraday download COMPLETE for CL.20170700.CME_NY. Completion time: 49s. Unique request ID: 522 | 2017-05-21 06:08:25 Removed historical data download ID 522 | 2017-05-21 06:08:25 Real-time Intraday chart data file updates started for CL.20170700.CME_NY | 2017-05-21 06:08:25 Opened cached Intraday file: C:\SierraChart1\Data\CL.20170700.CME_NY.scid | 2017-05-21 06:08:25 Intraday chart data file opened for CL.20170700.CME_NY | 2017-05-21 06:08:25 Delaying start of download for RB.20170700.CME_NY | 2017-05-21 06:08:25 Chart #9 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:08:25 Chart #16 has tagged chart #15 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:08:25 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:08:25 Chart #3 has tagged chart #1 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:08:27 Chart #3 has tagged chart #4 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:08:27 Chart #3 has tagged chart #5 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:08:27 Chart #3 has tagged chart #8 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:08:27 CL.20170700.CME_NY 30 Sec #4 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:08:27 CL.20170700.CME_NY 3 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:08:27 DTC Client (2118) | Closed. No error. | 2017-05-21 06:08:27 DTC Client (2118) | Shutdown and closed. | 2017-05-21 06:08:27 SC DTC Data | Disconnected from the server. | 2017-05-21 06:08:27 SC DTC Data | Data feed disconnected. Will reconnect in 2 seconds. | 2017-05-21 06:08:27 CTS FIX socket (2117) | Closed. No error. | 2017-05-21 06:08:27 CTS FIX socket (2117) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-21 06:08:27 CTS FIX socket (2117) | SSL has been shut down. | 2017-05-21 06:08:27 CTS FIX socket (2117) | SSL object has been freed. SSL state is now disconnected. | 2017-05-21 06:08:27 CTS FIX socket (2117) | Shutdown and closed. | 2017-05-21 06:08:27 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2017-05-21 06:08:27 Connection to the external service has been lost. | 2017-05-21 06:08:27 CTS FIX Historical Data socket (2119) | Closed. No error. | 2017-05-21 06:08:27 CTS FIX Historical Data: Received a Logout message. Text = Timed out. No valid messages received within the heartbeat interval of 30 seconds | 2017-05-21 06:08:27 CTS FIX Historical Data: Sending a Logout message. Text = Received Logout message. | 2017-05-21 06:08:27 CTS FIX Historical Data socket (2119) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-21 06:08:27 CTS FIX Historical Data socket (2119) | SSL has been shut down. | 2017-05-21 06:08:27 CTS FIX Historical Data socket (2119) | SSL object has been freed. SSL state is now disconnected. | 2017-05-21 06:08:27 CTS FIX Historical Data socket (2119) | Shutdown and closed. | 2017-05-21 06:08:27 CTS FIX Historical Data: Disconnected. | 2017-05-21 06:08:27 CL.20170700.CME_NY 3 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:08:27 CTS T4 FIX | Sending security definition request for symbol ES.20160900.CME_Eq | 2017-05-21 06:08:27 CL.20170700.CME_NY 3 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:08:27 6C.20170600.CME_Fo 3 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:08:27 SC DTC Data | Connecting to the server ds3.sierracharts.com. Port 10048 | 2017-05-21 06:09:32 Canceling historical data download request for RB.20170700.CME_NY Intraday data. | 2017-05-21 06:09:32 Removed historical data download ID 523 | 2017-05-21 06:09:32 Canceling historical data download request for 6B.20170600.CME_Fo Intraday data. | 2017-05-21 06:09:32 Removed historical data download ID 524 | 2017-05-21 06:09:32 Canceling historical data download request for 6E.20170600.CME_Fo Intraday data. | 2017-05-21 06:09:32 Removed historical data download ID 525 | 2017-05-21 06:09:32 Canceling historical data download request for YM.20170600.CME_E Intraday data. | 2017-05-21 06:09:32 Removed historical data download ID 526 | 2017-05-21 06:09:32 Canceling historical data download request for ES.20170600.CME_Eq Intraday data. | 2017-05-21 06:09:32 Removed historical data download ID 527 | 2017-05-21 06:09:32 Canceling historical data download request for 6S.20170600.CME_Fo Intraday data. | 2017-05-21 06:09:32 Removed historical data download ID 529 | 2017-05-21 06:09:32 Canceling historical data download request for HO.20170700.CME_NY Intraday data. | 2017-05-21 06:09:32 Removed historical data download ID 530 | 2017-05-21 06:09:32 Canceling historical data download request for 6C.20170600.CME_Fo Intraday data. | 2017-05-21 06:09:32 Removed historical data download ID 531 | 2017-05-21 06:09:32 Canceling historical data download request for HO.20171200.CME_NY Intraday data. | 2017-05-21 06:09:32 Removed historical data download ID 532 | 2017-05-21 06:09:32 Canceling historical data download request for 6N.20170600.CME_Fo Intraday data. | 2017-05-21 06:09:32 Removed historical data download ID 533 | 2017-05-21 06:09:32 Canceling historical data download request for RB.20171200.CME_NY Intraday data. | 2017-05-21 06:09:32 Removed historical data download ID 534 | 2017-05-21 06:09:32 Canceling historical data download request for NQ.20170600.CME_Eq Intraday data. | 2017-05-21 06:09:32 Removed historical data download ID 535 | 2017-05-21 06:09:32 Canceling historical data download request for ZB.20170600.CME_F Intraday data. | 2017-05-21 06:09:32 Removed historical data download ID 536 | 2017-05-21 06:09:32 Canceling historical data download request for 6A.20170600.CME_Fo Intraday data. | 2017-05-21 06:09:32 Removed historical data download ID 537 | 2017-05-21 06:09:32 Canceling historical data download request for GC.20170600.CME_CO Intraday data. | 2017-05-21 06:09:32 Removed historical data download ID 538 | 2017-05-21 06:09:32 Canceling historical data download request for ZN.20170600.CME_F Intraday data. | 2017-05-21 06:09:32 Removed historical data download ID 539 | 2017-05-21 06:09:32 Canceling historical data download request for 6J.20170600.CME_Fo Intraday data. | 2017-05-21 06:09:32 Removed historical data download ID 540 | 2017-05-21 06:09:32 Canceling historical data download request for CL.20171200.CME_NY Intraday data. | 2017-05-21 06:09:32 Removed historical data download ID 541 | 2017-05-21 06:09:32 Canceling historical data download request for ZT.20170600.CME_F Intraday data. | 2017-05-21 06:09:32 Removed historical data download ID 542 | 2017-05-21 06:09:32 CTS T4 FIX | Disconnected. | 2017-05-21 06:09:32 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-21 06:09:32 DTC Client (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2017-05-21 06:09:32 DTC Client (2122) | Connected. | 2017-05-21 06:09:32 SC DTC Data | Connected to server. | 2017-05-21 06:09:32 SC DTC Data | Sending Encoding Request to server | 2017-05-21 06:09:32 SC DTC Data | Setting DTC encoding to Binary VLS | 2017-05-21 06:09:32 SC DTC Data | Sending logon request message. | 2017-05-21 06:09:32 SC DTC Data | Received logon response. | 2017-05-21 06:09:34 SC DTC Data | Server Name: SC Realtime Server. | 2017-05-21 06:09:34 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2017-05-21 06:09:34 SC DTC Data | Successfully connected. | 2017-05-21 06:09:34 SC DTC Data | Trading is not supported. | 2017-05-21 06:09:34 Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2017-05-21 06:09:34 SC DTC Data | Restarting real-time data updates for symbol: AUDJPY | 2017-05-21 06:09:34 HD Request # 342 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-05-21 06:09:34 HD Request # 342 | Download start date-time: 2017-05-19 16:57:58.000 | 2017-05-21 06:09:34 HD Request # 342 | Using server: ds3.sierracharts.com port 10149 | 2017-05-21 06:09:34 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2017-05-21 06:09:34 Socket (2123) | Connected. | 2017-05-21 06:09:34 HD Request # 342 | Setting DTC encoding to Binary VLS | 2017-05-21 06:09:34 HD Request # 342 | Sending historical data logon request message. | 2017-05-21 06:09:34 SC DTC Data | Received security definition for symbol AUDJPY | 2017-05-21 06:09:34 HD Request # 342 | Requesting Intraday data. Start date-time: 2017-05-19 16:57:58. Record interval: 1. Symbol: AUDJPY | 2017-05-21 06:09:34 HD Request # 342 | Decompressing data. | 2017-05-21 06:09:34 HD Request # 342 | Receiving Intraday data for AUDJPY starting at 2017-05-19 16:57:58 | 2017-05-21 06:09:34 HD Request # 342 | Timestamp of first Intraday data file record written: 2017-05-19 16:57:58 | 2017-05-21 06:09:34 Socket (2123) | Shutdown and closed. | 2017-05-21 06:09:34 The network socket for historical data has been closed. | 2017-05-21 06:09:34 HD Request # 342 | Historical data for AUDJPY is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-05-21 06:09:34 HD Request # 342 | Received 1 record from 2017-05-19 16:57:58 to 2017-05-19 16:57:58 (0.0 seconds) and wrote 1 record for AUDJPY | 2017-05-21 06:09:34 HD Request # 342 | Intraday download COMPLETE for AUDJPY. Completion time: 1s. Unique request ID: 543 | 2017-05-21 06:09:34 Removed historical data download ID 543 | 2017-05-21 06:09:34 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2017-05-21 06:09:37 CTS T4 FIX | Firm: PTP | 2017-05-21 06:09:37 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 69.44.110.200. | 2017-05-21 06:09:37 CTS FIX socket (2124) | Connected. | 2017-05-21 06:09:37 CTS FIX socket (2124) | Starting TLS 1.0 connection. | 2017-05-21 06:09:37 CTS FIX socket (2124) | SSL connection established. | 2017-05-21 06:09:37 CTS FIX: Sending the Logon message. | 2017-05-21 06:09:38 CTS T4 FIX | FIX version: 4.3.74.0 | 2017-05-21 06:09:40 CTS T4 FIX | Connected to data and trading server. | 2017-05-21 06:09:40 DTC Client (2122) | Shutdown and closed. | 2017-05-21 06:09:40 SC DTC Data | Disconnected from the server. | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: ZB.20160900.CME_F. ID: 1 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: ZB.20160900.CME_F. ID: 1 | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: 6E.20160900.CME_Fo. ID: 2 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: 6E.20160900.CME_Fo. ID: 2 | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6J.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: 6J.20160900.CME_Fo. ID: 3 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: 6J.20160900.CME_Fo. ID: 3 | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6B.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: 6B.20160900.CME_Fo. ID: 4 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: 6B.20160900.CME_Fo. ID: 4 | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6C.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: 6C.20160900.CME_Fo. ID: 5 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: 6C.20160900.CME_Fo. ID: 5 | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: CL.20160800.CME_NY. ID: 6 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: CL.20160800.CME_NY. ID: 6 | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6A.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: 6A.20160900.CME_Fo. ID: 7 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: 6A.20160900.CME_Fo. ID: 7 | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: NQ.20160900.CME_Eq. ID: 8 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: NQ.20160900.CME_Eq. ID: 8 | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM.######00.CME_E pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: YM.20160900.CME_E. ID: 9 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: YM.20160900.CME_E. ID: 9 | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: GC.20160800.CME_CO. ID: 10 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: GC.20160800.CME_CO. ID: 10 | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: ES.20160900.CME_Eq. ID: 11 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: ES.20160900.CME_Eq. ID: 11 | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: ZB.20170300.CME_F. ID: 12 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: ZB.20170300.CME_F. ID: 12 | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: CL.20170100.CME_NY. ID: 13 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: CL.20170100.CME_NY. ID: 13 | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: GC.20170400.CME_CO. ID: 14 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: GC.20170400.CME_CO. ID: 14 | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: ZB.20170600.CME_F. ID: 15 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: ZB.20170600.CME_F. ID: 15 | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6B.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: 6B.20170600.CME_Fo. ID: 16 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: 6B.20170600.CME_Fo. ID: 16 | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: CL.20170600.CME_NY. ID: 17 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: CL.20170600.CME_NY. ID: 17 | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: CL.20170700.CME_NY. ID: 18 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: CL.20170700.CME_NY. ID: 18 | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The RB.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: RB.20170700.CME_NY. ID: 19 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: RB.20170700.CME_NY. ID: 19 | 2017-05-21 06:09:40 CTS T4 FIX | Using primary service for historical data for RB.20170700.CME_NY | 2017-05-21 06:09:40 Intraday data recording state for symbol RB.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:09:40 Delaying start of download for RB.20170700.CME_NY | 2017-05-21 06:09:40 CTS T4 FIX | Using primary service for historical data for 6B.20170600.CME_Fo | 2017-05-21 06:09:40 Intraday data recording state for symbol 6B.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: 6E.20170600.CME_Fo. ID: 20 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: 6E.20170600.CME_Fo. ID: 20 | 2017-05-21 06:09:40 CTS T4 FIX | Using primary service for historical data for 6E.20170600.CME_Fo | 2017-05-21 06:09:40 Intraday data recording state for symbol 6E.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM.######00.CME_E pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: YM.20170600.CME_E. ID: 21 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: YM.20170600.CME_E. ID: 21 | 2017-05-21 06:09:40 CTS T4 FIX | Using primary service for historical data for YM.20170600.CME_E | 2017-05-21 06:09:40 Intraday data recording state for symbol YM.20170600.CME_E is set to download 'Pending'. | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: ES.20170600.CME_Eq. ID: 22 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: ES.20170600.CME_Eq. ID: 22 | 2017-05-21 06:09:40 CTS T4 FIX | Using primary service for historical data for ES.20170600.CME_Eq | 2017-05-21 06:09:40 Intraday data recording state for symbol ES.20170600.CME_Eq is set to download 'Pending'. | 2017-05-21 06:09:40 CTS T4 FIX | Received Account List collateral report. | 2017-05-21 06:09:40 CTS T4 FIX | Subscribing to account: May* | 2017-05-21 06:09:40 Using Bid/Ask average for last trade price for AUDJPY | 2017-05-21 06:09:40 SC DTC Data | Starting real-time market data updates for: AUDJPY. ID: 23 | 2017-05-21 06:09:40 SC DTC Data | Connecting to the server ds4.sierracharts.com. Port 443 | 2017-05-21 06:09:40 SC DTC Data | Requesting security definition data for: AUDJPY. ID: 23 | 2017-05-21 06:09:40 Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2017-05-21 06:09:40 DTC Client (0) | Resolved address ds4.sierracharts.com to IP 192.81.56.146. | 2017-05-21 06:09:40 Delaying start of download for AUDJPY | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6S.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: 6S.20170600.CME_Fo. ID: 24 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: 6S.20170600.CME_Fo. ID: 24 | 2017-05-21 06:09:40 CTS T4 FIX | Using primary service for historical data for 6S.20170600.CME_Fo | 2017-05-21 06:09:40 Intraday data recording state for symbol 6S.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:09:40 Requesting market depth updates for: 6E.20170600.CME_Fo if supported. | 2017-05-21 06:09:40 DTC Client (2125) | Connected. | 2017-05-21 06:09:40 SC DTC Data | Connected to server. | 2017-05-21 06:09:40 SC DTC Data | Sending Encoding Request to server | 2017-05-21 06:09:40 Supported exchange: CME_CO (SIM:COMEX Futures) | 2017-05-21 06:09:40 Supported exchange: CME_EqOp (SIM:CME Equity Options) | 2017-05-21 06:09:40 Supported exchange: CME_NYOp (SIM:NYMEX Options) | 2017-05-21 06:09:40 Supported exchange: CME_AgOp (SIM:CME Agricultural Options) | 2017-05-21 06:09:40 Supported exchange: CME_Eq (SIM:CME Equity Futures) | 2017-05-21 06:09:40 Supported exchange: CME_In (SIM:CME Interest Rate Futures) | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The HO.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: HO.20170700.CME_NY. ID: 25 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: HO.20170700.CME_NY. ID: 25 | 2017-05-21 06:09:40 CTS T4 FIX | Using primary service for historical data for HO.20170700.CME_NY | 2017-05-21 06:09:40 Intraday data recording state for symbol HO.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:09:40 Supported exchange: CME_C (SIM:CBOT Commodity Futures) | 2017-05-21 06:09:40 Supported exchange: CME_KOp (SIM:KCBT Options) | 2017-05-21 06:09:40 Supported exchange: CME_F (SIM:CBOT Financial Futures) | 2017-05-21 06:09:40 Supported exchange: CME_E (SIM:CBOT Equity Futures) | 2017-05-21 06:09:40 Supported exchange: CME_COp (SIM:CBOT Commodity Options) | 2017-05-21 06:09:40 Supported exchange: CME_K (SIM:KCBT Futures) | 2017-05-21 06:09:40 Supported exchange: CME_EOp (SIM:CBOT Equity Options) | 2017-05-21 06:09:40 Supported exchange: CME_NY (SIM:NYMEX Futures) | 2017-05-21 06:09:40 Supported exchange: CME_Fo (SIM:CME Foreign Exchange Futures) | 2017-05-21 06:09:40 Supported exchange: CME_Ag (SIM:CME Agricultural Futures) | 2017-05-21 06:09:40 Supported exchange: CME_FoOp (SIM:CME Foreign Exchange Options) | 2017-05-21 06:09:40 Supported exchange: CME_FOp (SIM:CBOT Financial Options) | 2017-05-21 06:09:40 Supported exchange: CME_InOp (SIM:CME Interest Rate Options) | 2017-05-21 06:09:40 Supported exchange: CME_COOp (SIM:COMEX Options) | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6C.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: 6C.20170600.CME_Fo. ID: 26 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: 6C.20170600.CME_Fo. ID: 26 | 2017-05-21 06:09:40 CTS T4 FIX | Using primary service for historical data for 6C.20170600.CME_Fo | 2017-05-21 06:09:40 Intraday data recording state for symbol 6C.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The HO.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: HO.20171200.CME_NY. ID: 27 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: HO.20171200.CME_NY. ID: 27 | 2017-05-21 06:09:40 CTS T4 FIX | Using primary service for historical data for HO.20171200.CME_NY | 2017-05-21 06:09:40 Intraday data recording state for symbol HO.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:09:40 CTS T4 FIX | Using primary service for historical data for CL.20170700.CME_NY | 2017-05-21 06:09:40 Intraday data recording state for symbol CL.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:09:40 SC DTC Data | Setting DTC encoding to Binary VLS | 2017-05-21 06:09:40 SC DTC Data | Sending logon request message. | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6N.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: 6N.20170600.CME_Fo. ID: 28 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: 6N.20170600.CME_Fo. ID: 28 | 2017-05-21 06:09:40 CTS T4 FIX | Using primary service for historical data for 6N.20170600.CME_Fo | 2017-05-21 06:09:40 Intraday data recording state for symbol 6N.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:09:40 HD Request # 343 | Downloading Intraday chart data for RB.20170700.CME_NY to the file RB.20170700.CME_NY.scid. Service: cts | 2017-05-21 06:09:40 HD Request # 343 | Download start date-time: 2017-05-19 16:59:53.000 | 2017-05-21 06:09:40 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The RB.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: RB.20171200.CME_NY. ID: 29 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: RB.20171200.CME_NY. ID: 29 | 2017-05-21 06:09:40 CTS T4 FIX | Using primary service for historical data for RB.20171200.CME_NY | 2017-05-21 06:09:40 Intraday data recording state for symbol RB.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: NQ.20170600.CME_Eq. ID: 30 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: NQ.20170600.CME_Eq. ID: 30 | 2017-05-21 06:09:40 CTS T4 FIX | Using primary service for historical data for NQ.20170600.CME_Eq | 2017-05-21 06:09:40 Intraday data recording state for symbol NQ.20170600.CME_Eq is set to download 'Pending'. | 2017-05-21 06:09:40 SC DTC Data | Received logon response. | 2017-05-21 06:09:40 SC DTC Data | Server Name: SC Realtime Server. | 2017-05-21 06:09:40 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2017-05-21 06:09:40 SC DTC Data | Successfully connected. | 2017-05-21 06:09:40 SC DTC Data | Trading is not supported. | 2017-05-21 06:09:40 SC DTC Data | Restarting real-time data updates for symbol: AUDJPY | 2017-05-21 06:09:40 CTS T4 FIX | Using primary service for historical data for ZB.20170600.CME_F | 2017-05-21 06:09:40 Intraday data recording state for symbol ZB.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6A.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: 6A.20170600.CME_Fo. ID: 31 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: 6A.20170600.CME_Fo. ID: 31 | 2017-05-21 06:09:40 CTS T4 FIX | Using primary service for historical data for 6A.20170600.CME_Fo | 2017-05-21 06:09:40 Intraday data recording state for symbol 6A.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:09:40 CTS FIX Historical Data socket (0) | Resolved address fix-chart-sim.t4login.com to IP 74.201.6.229. | 2017-05-21 06:09:40 Requesting market depth updates for: 6B.20170600.CME_Fo if supported. | 2017-05-21 06:09:40 SC DTC Data | Received security definition for symbol AUDJPY | 2017-05-21 06:09:40 CTS FIX Historical Data socket (2126) | Connected. | 2017-05-21 06:09:40 CTS FIX Historical Data socket (2126) | Starting TLS 1.0 connection. | 2017-05-21 06:09:40 CTS T4 FIX | Received 'Account Update/Balance Data' collateral report. | 2017-05-21 06:09:40 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:40 CTS T4 FIX | Starting real-time market data updates for: GC.20170600.CME_CO. ID: 32 | 2017-05-21 06:09:40 CTS T4 FIX | Requesting security definition data for: GC.20170600.CME_CO. ID: 32 | 2017-05-21 06:09:40 CTS T4 FIX | Using primary service for historical data for GC.20170600.CME_CO | 2017-05-21 06:09:40 Intraday data recording state for symbol GC.20170600.CME_CO is set to download 'Pending'. | 2017-05-21 06:09:40 Requesting market depth updates for: YM.20170600.CME_E if supported. | 2017-05-21 06:09:40 CTS T4 FIX | Sending security definition request for symbol 6A.20160900.CME_Fo | 2017-05-21 06:09:45 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZN.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:45 CTS T4 FIX | Starting real-time market data updates for: ZN.20170600.CME_F. ID: 33 | 2017-05-21 06:09:45 CTS T4 FIX | Requesting security definition data for: ZN.20170600.CME_F. ID: 33 | 2017-05-21 06:09:45 CTS T4 FIX | Using primary service for historical data for ZN.20170600.CME_F | 2017-05-21 06:09:45 Intraday data recording state for symbol ZN.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:09:45 CTS FIX Historical Data socket (2126) | SSL connection established. | 2017-05-21 06:09:45 Symbol Error - 6A.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:09:45 CTS T4 FIX | Received 0 security definitions for underlying symbol 6A | 2017-05-21 06:09:45 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6J.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:45 CTS T4 FIX | Starting real-time market data updates for: 6J.20170600.CME_Fo. ID: 34 | 2017-05-21 06:09:45 CTS T4 FIX | Requesting security definition data for: 6J.20170600.CME_Fo. ID: 34 | 2017-05-21 06:09:45 CTS T4 FIX | Using primary service for historical data for 6J.20170600.CME_Fo | 2017-05-21 06:09:45 Intraday data recording state for symbol 6J.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:09:45 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:45 CTS T4 FIX | Starting real-time market data updates for: CL.20171200.CME_NY. ID: 35 | 2017-05-21 06:09:45 CTS T4 FIX | Requesting security definition data for: CL.20171200.CME_NY. ID: 35 | 2017-05-21 06:09:45 CTS T4 FIX | Using primary service for historical data for CL.20171200.CME_NY | 2017-05-21 06:09:45 Intraday data recording state for symbol CL.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:09:45 Requesting market depth updates for: NQ.20170600.CME_Eq if supported. | 2017-05-21 06:09:45 Requesting market depth updates for: 6J.20170600.CME_Fo if supported. | 2017-05-21 06:09:45 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZT.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:09:45 CTS T4 FIX | Starting real-time market data updates for: ZT.20170600.CME_F. ID: 36 | 2017-05-21 06:09:45 CTS T4 FIX | Requesting security definition data for: ZT.20170600.CME_F. ID: 36 | 2017-05-21 06:09:45 CTS T4 FIX | Using primary service for historical data for ZT.20170600.CME_F | 2017-05-21 06:09:45 Intraday data recording state for symbol ZT.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:09:45 Requesting market depth updates for: GC.20170600.CME_CO if supported. | 2017-05-21 06:09:45 Requesting market depth updates for: CL.20170700.CME_NY if supported. | 2017-05-21 06:09:45 Requesting market depth updates for: ZB.20170600.CME_F if supported. | 2017-05-21 06:09:45 Requesting market depth updates for: ES.20170600.CME_Eq if supported. | 2017-05-21 06:09:45 HD Request # 344 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-05-21 06:09:45 HD Request # 344 | Download start date-time: 2017-05-19 16:57:58.000 | 2017-05-21 06:09:45 HD Request # 344 | Using server: ds4.sierracharts.com port 10149 | 2017-05-21 06:09:45 Socket (0) | Resolved address ds4.sierracharts.com to IP 192.81.56.146. | 2017-05-21 06:09:45 Socket (2127) | Connected. | 2017-05-21 06:09:45 HD Request # 344 | Setting DTC encoding to Binary VLS | 2017-05-21 06:09:45 HD Request # 344 | Sending historical data logon request message. | 2017-05-21 06:09:45 HD Request # 344 | Requesting Intraday data. Start date-time: 2017-05-19 16:57:58. Record interval: 1. Symbol: AUDJPY | 2017-05-21 06:09:45 HD Request # 344 | Decompressing data. | 2017-05-21 06:09:45 HD Request # 344 | Receiving Intraday data for AUDJPY starting at 2017-05-19 16:57:58 | 2017-05-21 06:09:45 HD Request # 344 | Timestamp of first Intraday data file record written: 2017-05-19 16:57:58 | 2017-05-21 06:09:45 Socket (2127) | Shutdown and closed. | 2017-05-21 06:09:45 The network socket for historical data has been closed. | 2017-05-21 06:09:45 HD Request # 344 | Received 1 record from 2017-05-19 16:57:58 to 2017-05-19 16:57:58 (0.0 seconds) and wrote 1 record for AUDJPY | 2017-05-21 06:09:45 HD Request # 344 | Intraday download COMPLETE for AUDJPY. Completion time: 0s. Unique request ID: 549 | 2017-05-21 06:09:45 Removed historical data download ID 549 | 2017-05-21 06:09:45 Real-time Intraday chart data file updates started for AUDJPY | 2017-05-21 06:09:45 Opened cached Intraday file: C:\SierraChart1\Data\AUDJPY.scid | 2017-05-21 06:09:45 Intraday chart data file opened for AUDJPY | 2017-05-21 06:09:45 CTS FIX Historical Data: Sending the Logon message. | 2017-05-21 06:09:48 CTS T4 FIX | Sending security definition request for symbol 6A.20170600.CME_Fo | 2017-05-21 06:09:48 CTS FIX Historical Data: Connected to Historical data server. | 2017-05-21 06:09:48 CTS T4 FIX | Received matching security definition for symbol 6A.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:09:48 CTS T4 FIX | Received 1 security definitions for underlying symbol 6A | 2017-05-21 06:09:48 Contract specifications for 6A.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:09:49 CTS T4 FIX | Sending security definition request for symbol 6B.20160900.CME_Fo | 2017-05-21 06:09:49 Requesting market depth updates for: 6B.20160900.CME_Fo if supported. | 2017-05-21 06:09:49 Requesting market depth updates for: 6E.20160900.CME_Fo if supported. | 2017-05-21 06:09:49 Requesting market depth updates for: 6J.20160900.CME_Fo if supported. | 2017-05-21 06:09:49 Requesting market depth updates for: 6N.20170600.CME_Fo if supported. | 2017-05-21 06:09:49 Requesting market depth updates for: CL.20160800.CME_NY if supported. | 2017-05-21 06:09:49 Requesting market depth updates for: CL.20170100.CME_NY if supported. | 2017-05-21 06:09:49 Requesting market depth updates for: CL.20170600.CME_NY if supported. | 2017-05-21 06:09:49 Requesting market depth updates for: CL.20171200.CME_NY if supported. | 2017-05-21 06:09:49 Requesting market depth updates for: ES.20160900.CME_Eq if supported. | 2017-05-21 06:09:49 Requesting market depth updates for: GC.20160800.CME_CO if supported. | 2017-05-21 06:09:49 Requesting market depth updates for: GC.20170400.CME_CO if supported. | 2017-05-21 06:09:49 Requesting market depth updates for: NQ.20160900.CME_Eq if supported. | 2017-05-21 06:09:49 Requesting market depth updates for: YM.20160900.CME_E if supported. | 2017-05-21 06:09:49 Requesting market depth updates for: ZB.20160900.CME_F if supported. | 2017-05-21 06:09:49 Requesting market depth updates for: ZB.20170300.CME_F if supported. | 2017-05-21 06:09:49 CTS T4 FIX | Requesting Open Orders for account: May*. Request ID: 9498401 | 2017-05-21 06:09:49 Symbol Error - 6B.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:09:49 CTS T4 FIX | Received 0 security definitions for underlying symbol 6B | 2017-05-21 06:09:49 CTS T4 FIX | No open orders for account May18CCwmitchel | 2017-05-21 06:09:49 CTS T4 FIX | Sending security definition request for symbol 6B.20170600.CME_Fo | 2017-05-21 06:09:51 CTS T4 FIX | Received matching security definition for symbol 6B.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:09:51 CTS T4 FIX | Received 1 security definitions for underlying symbol 6B | 2017-05-21 06:09:51 Contract specifications for 6B.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 6.25 | 2017-05-21 06:09:51 CTS T4 FIX | Sending security definition request for symbol 6C.20160900.CME_Fo | 2017-05-21 06:09:54 Symbol Error - 6C.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:09:54 CTS T4 FIX | Received 0 security definitions for underlying symbol 6C | 2017-05-21 06:09:54 CTS T4 FIX | Sending security definition request for symbol 6C.20170600.CME_Fo | 2017-05-21 06:09:57 CTS T4 FIX | Received matching security definition for symbol 6C.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:09:57 CTS T4 FIX | Received 1 security definitions for underlying symbol 6C | 2017-05-21 06:09:57 Contract specifications for 6C.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 5 | 2017-05-21 06:09:57 CTS T4 FIX | Requesting historical Fills for account: May*. Request ID: 9498404 | 2017-05-21 06:10:00 CTS T4 FIX | Received Account List collateral report. | 2017-05-21 06:10:00 CTS T4 FIX | Server provided no historical order fills for account 1A297B51-A416-42D4-A1C8-C9B1B4125155 | 2017-05-21 06:10:00 CTS T4 FIX | Sending security definition request for symbol 6E.20160900.CME_Fo | 2017-05-21 06:10:00 Symbol Error - 6E.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:10:00 CTS T4 FIX | Received 0 security definitions for underlying symbol 6E | 2017-05-21 06:10:00 CTS T4 FIX | Sending security definition request for symbol 6E.20170600.CME_Fo | 2017-05-21 06:10:03 CTS T4 FIX | Received matching security definition for symbol 6E.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:10:03 CTS T4 FIX | Received 1 security definitions for underlying symbol 6E | 2017-05-21 06:10:03 Contract specifications for 6E.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-05-21 06:10:03 CTS T4 FIX | Sending security definition request for symbol 6J.20160900.CME_Fo | 2017-05-21 06:10:07 Symbol Error - 6J.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:10:07 CTS T4 FIX | Received 0 security definitions for underlying symbol 6J | 2017-05-21 06:10:07 CTS T4 FIX | Sending security definition request for symbol 6J.20170600.CME_Fo | 2017-05-21 06:10:08 CTS T4 FIX | Received matching security definition for symbol 6J.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:10:10 CTS T4 FIX | Received 1 security definitions for underlying symbol 6J | 2017-05-21 06:10:10 Contract specifications for 6J.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-05-21 06:10:10 CTS T4 FIX | Sending security definition request for symbol 6N.20170600.CME_Fo | 2017-05-21 06:10:12 CTS T4 FIX | Received matching security definition for symbol 6N.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:10:12 CTS T4 FIX | Received 1 security definitions for underlying symbol 6N | 2017-05-21 06:10:12 Contract specifications for 6N.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:10:12 CTS T4 FIX | Sending security definition request for symbol 6S.20170600.CME_Fo | 2017-05-21 06:10:15 CTS T4 FIX | Received matching security definition for symbol 6S.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:10:15 CTS T4 FIX | Received 1 security definitions for underlying symbol 6S | 2017-05-21 06:10:15 Contract specifications for 6S.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 12.5 | 2017-05-21 06:10:15 CTS T4 FIX | Sending security definition request for symbol CL.20160800.CME_NY | 2017-05-21 06:10:19 Symbol Error - CL.20160800.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:10:19 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2017-05-21 06:10:19 CTS T4 FIX | Sending security definition request for symbol CL.20170100.CME_NY | 2017-05-21 06:10:22 Symbol Error - CL.20170100.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:10:22 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2017-05-21 06:10:22 CTS T4 FIX | Sending security definition request for symbol CL.20170600.CME_NY | 2017-05-21 06:10:24 CTS T4 FIX | Received matching security definition for symbol CL.20170600.CME_NY. Subscribing to data. | 2017-05-21 06:10:24 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:10:24 Contract specifications for CL.20170600.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:10:24 CTS T4 FIX | Sending security definition request for symbol CL.20170700.CME_NY | 2017-05-21 06:10:27 CTS T4 FIX | Received matching security definition for symbol CL.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:10:27 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:10:27 Contract specifications for CL.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:10:27 CTS T4 FIX | Sending security definition request for symbol CL.20171200.CME_NY | 2017-05-21 06:10:31 CTS T4 FIX | Received matching security definition for symbol CL.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:10:31 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:10:31 Contract specifications for CL.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:10:31 CTS T4 FIX | Sending security definition request for symbol ES.20160900.CME_Eq | 2017-05-21 06:10:33 Symbol Error - ES.20160900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:10:33 CTS T4 FIX | Received 0 security definitions for underlying symbol ES | 2017-05-21 06:10:33 CTS T4 FIX | Sending security definition request for symbol ES.20170600.CME_Eq | 2017-05-21 06:10:37 CTS T4 FIX | Received matching security definition for symbol ES.20170600.CME_Eq. Subscribing to data. | 2017-05-21 06:10:37 CTS T4 FIX | Received 1 security definitions for underlying symbol ES | 2017-05-21 06:10:37 Contract specifications for ES.20170600.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 12.5 | 2017-05-21 06:10:37 CTS T4 FIX | Sending security definition request for symbol GC.20160800.CME_CO | 2017-05-21 06:10:40 Symbol Error - GC.20160800.CME_CO is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:10:40 CTS T4 FIX | Received 0 security definitions for underlying symbol GC | 2017-05-21 06:10:40 CTS T4 FIX | Sending security definition request for symbol GC.20170400.CME_CO | 2017-05-21 06:10:42 Symbol Error - GC.20170400.CME_CO is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:10:42 CTS T4 FIX | Received 0 security definitions for underlying symbol GC | 2017-05-21 06:10:42 CTS T4 FIX | Sending security definition request for symbol GC.20170600.CME_CO | 2017-05-21 06:10:46 CTS T4 FIX | Received matching security definition for symbol GC.20170600.CME_CO. Subscribing to data. | 2017-05-21 06:10:46 CTS T4 FIX | Received 1 security definitions for underlying symbol GC | 2017-05-21 06:10:46 Contract specifications for GC.20170600.CME_CO. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:10:46 CTS T4 FIX | Sending security definition request for symbol HO.20170700.CME_NY | 2017-05-21 06:10:48 CTS T4 FIX | Received matching security definition for symbol HO.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:10:48 CTS T4 FIX | Received 1 security definitions for underlying symbol HO | 2017-05-21 06:10:48 Contract specifications for HO.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:10:48 CTS T4 FIX | Sending security definition request for symbol HO.20171200.CME_NY | 2017-05-21 06:10:52 CTS T4 FIX | Received matching security definition for symbol HO.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:10:52 CTS T4 FIX | Received 1 security definitions for underlying symbol HO | 2017-05-21 06:10:52 Contract specifications for HO.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:10:52 CTS T4 FIX | Sending security definition request for symbol NQ.20160900.CME_Eq | 2017-05-21 06:10:55 Symbol Error - NQ.20160900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:10:55 CTS T4 FIX | Received 0 security definitions for underlying symbol NQ | 2017-05-21 06:10:55 CTS T4 FIX | Sending security definition request for symbol NQ.20170600.CME_Eq | 2017-05-21 06:10:57 CTS T4 FIX | Received matching security definition for symbol NQ.20170600.CME_Eq. Subscribing to data. | 2017-05-21 06:10:59 CTS T4 FIX | Received 1 security definitions for underlying symbol NQ | 2017-05-21 06:10:59 Contract specifications for NQ.20170600.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 5 | 2017-05-21 06:10:59 CTS T4 FIX | Sending security definition request for symbol RB.20170700.CME_NY | 2017-05-21 06:11:00 CTS T4 FIX | Received matching security definition for symbol RB.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:11:00 CTS T4 FIX | Received matching security definition for symbol RB.20170700.CME_NY. Requesting historical data. | 2017-05-21 06:11:00 HD Request # 343 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:11:00 CTS T4 FIX | Received 1 security definitions for underlying symbol RB | 2017-05-21 06:11:00 Contract specifications for RB.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:11:00 HD Request # 343 | Receiving Intraday data for RB.20170700.CME_NY starting at 2017-05-18 18:00:00 | 2017-05-21 06:11:02 HD Request # 343 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:53 | 2017-05-21 06:11:02 HD Request # 343 | Total records received: 7454 | 2017-05-21 06:11:02 HD Request # 343 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:11:02 HD Request # 343 | Total records received: 7454 | 2017-05-21 06:11:02 HD Request # 343 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:11:02 HD Request # 343 | Total records received: 7454 | 2017-05-21 06:11:02 HD Request # 343 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:11:02 HD Request # 343 | Total records received: 7454 | 2017-05-21 06:11:02 HD Request # 343 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:11:02 HD Request # 343 | Received 7454 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:53 (23.0 hours) and wrote 1 record for RB.20170700.CME_NY | 2017-05-21 06:11:02 HD Request # 343 | Intraday download COMPLETE for RB.20170700.CME_NY. Completion time: 1m 19s. Unique request ID: 544 | 2017-05-21 06:11:02 Removed historical data download ID 544 | 2017-05-21 06:11:02 Real-time Intraday chart data file updates started for RB.20170700.CME_NY | 2017-05-21 06:11:02 Opened cached Intraday file: C:\SierraChart1\Data\RB.20170700.CME_NY.scid | 2017-05-21 06:11:02 Intraday chart data file opened for RB.20170700.CME_NY | 2017-05-21 06:11:02 Delaying start of download for 6B.20170600.CME_Fo | 2017-05-21 06:11:02 Chart #22 has tagged chart #16 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:11:04 CTS T4 FIX | Sending security definition request for symbol RB.20171200.CME_NY | 2017-05-21 06:11:04 CTS T4 FIX | Received matching security definition for symbol RB.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:11:04 CTS T4 FIX | Received 1 security definitions for underlying symbol RB | 2017-05-21 06:11:04 Contract specifications for RB.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:11:04 Chart #18 has tagged chart #16 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:11:04 CL.20170700.CME_NY 3 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:11:04 Chart #16 has tagged chart #15 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:11:04 Chart #21 has tagged chart #9 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:11:04 CL.20170700.CME_NY 30 Sec #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:11:06 6C.20170600.CME_Fo 3 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:11:06 CL.20170700.CME_NY [C] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:11:06 Chart #9 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:11:06 CTS T4 FIX | Sending security definition request for symbol YM.20160900.CME_E | 2017-05-21 06:11:06 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:11:06 Symbol Error - YM.20160900.CME_E is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:11:06 CTS T4 FIX | Received 0 security definitions for underlying symbol YM | 2017-05-21 06:11:06 CTS T4 FIX | Sending security definition request for symbol YM.20170600.CME_E | 2017-05-21 06:11:09 CTS T4 FIX | Received matching security definition for symbol YM.20170600.CME_E. Subscribing to data. | 2017-05-21 06:11:09 CTS T4 FIX | Received 1 security definitions for underlying symbol YM | 2017-05-21 06:11:09 Contract specifications for YM.20170600.CME_E. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 5 | 2017-05-21 06:11:10 CTS T4 FIX | Sending security definition request for symbol ZB.20160900.CME_F | 2017-05-21 06:11:12 Symbol Error - ZB.20160900.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:11:12 CTS T4 FIX | Received 0 security definitions for underlying symbol ZB | 2017-05-21 06:11:12 CTS T4 FIX | Sending security definition request for symbol ZB.20170300.CME_F | 2017-05-21 06:11:14 Symbol Error - ZB.20170300.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:11:14 CTS T4 FIX | Received 0 security definitions for underlying symbol ZB | 2017-05-21 06:11:14 CTS T4 FIX | Sending security definition request for symbol ZB.20170600.CME_F | 2017-05-21 06:11:17 CTS T4 FIX | Received matching security definition for symbol ZB.20170600.CME_F. Subscribing to data. | 2017-05-21 06:11:17 CTS T4 FIX | Received 1 security definitions for underlying symbol ZB | 2017-05-21 06:11:17 Contract specifications for ZB.20170600.CME_F. Multiplier: 0.00001000. Tick Size: 0.03125. Value Format: 132. Currency Value per Tick: 31.25 | 2017-05-21 06:11:17 CTS T4 FIX | Sending security definition request for symbol ZN.20170600.CME_F | 2017-05-21 06:11:20 CTS T4 FIX | Received matching security definition for symbol ZN.20170600.CME_F. Subscribing to data. | 2017-05-21 06:11:20 CTS T4 FIX | Received 1 security definitions for underlying symbol ZN | 2017-05-21 06:11:20 Contract specifications for ZN.20170600.CME_F. Multiplier: 0.00000100. Tick Size: 0.015625. Value Format: 132. Currency Value per Tick: 15.625 | 2017-05-21 06:11:20 CTS T4 FIX | Sending security definition request for symbol ZT.20170600.CME_F | 2017-05-21 06:11:23 CTS T4 FIX | Received matching security definition for symbol ZT.20170600.CME_F. Subscribing to data. | 2017-05-21 06:11:23 CTS T4 FIX | Received 1 security definitions for underlying symbol ZT | 2017-05-21 06:11:23 Contract specifications for ZT.20170600.CME_F. Multiplier: 0.00000010. Tick Size: 0.0078125. Value Format: 228. Currency Value per Tick: 15.625 | 2017-05-21 06:11:23 HD Request # 345 | Downloading Intraday chart data for 6B.20170600.CME_Fo to the file 6B.20170600.CME_Fo.scid. Service: cts | 2017-05-21 06:11:28 HD Request # 345 | Download start date-time: 2017-05-19 16:59:54.000 | 2017-05-21 06:11:28 HD Request # 345 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:11:28 HD Request # 345 | Receiving Intraday data for 6B.20170600.CME_Fo starting at 2017-05-18 18:00:00 | 2017-05-21 06:11:30 HD Request # 345 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:54 | 2017-05-21 06:11:30 HD Request # 345 | Total records received: 8374 | 2017-05-21 06:11:30 HD Request # 345 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:11:30 HD Request # 345 | Total records received: 8374 | 2017-05-21 06:11:30 HD Request # 345 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:11:30 HD Request # 345 | Total records received: 8374 | 2017-05-21 06:11:30 HD Request # 345 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:11:30 HD Request # 345 | Total records received: 8374 | 2017-05-21 06:11:30 HD Request # 345 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:11:30 HD Request # 345 | Received 8374 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:54 (23.0 hours) and wrote 1 record for 6B.20170600.CME_Fo | 2017-05-21 06:11:30 HD Request # 345 | Intraday download COMPLETE for 6B.20170600.CME_Fo. Completion time: 2s. Unique request ID: 545 | 2017-05-21 06:11:30 Removed historical data download ID 545 | 2017-05-21 06:11:30 Real-time Intraday chart data file updates started for 6B.20170600.CME_Fo | 2017-05-21 06:11:30 Opened cached Intraday file: C:\SierraChart1\Data\6B.20170600.CME_Fo.scid | 2017-05-21 06:11:30 Intraday chart data file opened for 6B.20170600.CME_Fo | 2017-05-21 06:11:30 Delaying start of download for 6E.20170600.CME_Fo | 2017-05-21 06:11:30 Chart #12 has tagged chart #8 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:11:32 Chart #12 has tagged chart #8 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:11:32 6A.20170600.CME_Fo 3 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:11:32 6A.20170600.CME_Fo 3 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:11:34 HD Request # 346 | Downloading Intraday chart data for 6E.20170600.CME_Fo to the file 6E.20170600.CME_Fo.scid. Service: cts | 2017-05-21 06:11:55 HD Request # 346 | Download start date-time: 2017-05-19 16:59:58.000 | 2017-05-21 06:11:55 HD Request # 346 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:11:55 HD Request # 346 | Receiving Intraday data for 6E.20170600.CME_Fo starting at 2017-05-18 18:00:00 | 2017-05-21 06:11:57 HD Request # 346 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:58 | 2017-05-21 06:11:57 HD Request # 346 | Total records received: 17398 | 2017-05-21 06:11:57 HD Request # 346 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:11:57 HD Request # 346 | Total records received: 17398 | 2017-05-21 06:11:57 HD Request # 346 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:11:57 HD Request # 346 | Total records received: 17398 | 2017-05-21 06:11:57 HD Request # 346 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:11:57 HD Request # 346 | Total records received: 17398 | 2017-05-21 06:11:57 HD Request # 346 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:11:57 HD Request # 346 | Received 17398 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:58 (23.0 hours) and wrote 1 record for 6E.20170600.CME_Fo | 2017-05-21 06:11:59 HD Request # 346 | Intraday download COMPLETE for 6E.20170600.CME_Fo. Completion time: 2s. Unique request ID: 546 | 2017-05-21 06:11:59 Removed historical data download ID 546 | 2017-05-21 06:11:59 Real-time Intraday chart data file updates started for 6E.20170600.CME_Fo | 2017-05-21 06:11:59 Opened cached Intraday file: C:\SierraChart1\Data\6E.20170600.CME_Fo.scid | 2017-05-21 06:11:59 Intraday chart data file opened for 6E.20170600.CME_Fo | 2017-05-21 06:11:59 Delaying start of download for YM.20170600.CME_E | 2017-05-21 06:11:59 Chart #15 has tagged chart #4 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:11:59 6B.20170600.CME_Fo 30 Sec #4 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:11:59 HD Request # 347 | Downloading Intraday chart data for YM.20170600.CME_E to the file YM.20170600.CME_E.scid. Service: cts | 2017-05-21 06:12:24 HD Request # 347 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:12:24 HD Request # 347 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:12:24 HD Request # 347 | Receiving Intraday data for YM.20170600.CME_E starting at 2017-05-18 18:00:00 | 2017-05-21 06:12:27 HD Request # 347 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:12:27 HD Request # 347 | Total records received: 19680 | 2017-05-21 06:12:27 HD Request # 347 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:12:27 HD Request # 347 | Total records received: 19680 | 2017-05-21 06:12:27 HD Request # 347 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:12:27 HD Request # 347 | Total records received: 19680 | 2017-05-21 06:12:27 HD Request # 347 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:12:27 HD Request # 347 | Total records received: 19680 | 2017-05-21 06:12:27 HD Request # 347 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:12:27 HD Request # 347 | Received 19680 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for YM.20170600.CME_E | 2017-05-21 06:12:28 HD Request # 347 | Intraday download COMPLETE for YM.20170600.CME_E. Completion time: 4s. Unique request ID: 547 | 2017-05-21 06:12:28 Removed historical data download ID 547 | 2017-05-21 06:12:28 Real-time Intraday chart data file updates started for YM.20170600.CME_E | 2017-05-21 06:12:28 Opened cached Intraday file: C:\SierraChart1\Data\YM.20170600.CME_E.scid | 2017-05-21 06:12:28 Intraday chart data file opened for YM.20170600.CME_E | 2017-05-21 06:12:28 Delaying start of download for ES.20170600.CME_Eq | 2017-05-21 06:12:28 Chart #3 has tagged chart #4 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:12:28 ZB.20170600.CME_F 3 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:12:30 CTS FIX socket (2124) | Closed. No error. | 2017-05-21 06:12:30 CTS FIX socket (2124) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-21 06:12:30 CTS FIX socket (2124) | SSL has been shut down. | 2017-05-21 06:12:30 CTS FIX socket (2124) | SSL object has been freed. SSL state is now disconnected. | 2017-05-21 06:12:30 CTS FIX socket (2124) | Shutdown and closed. | 2017-05-21 06:12:30 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2017-05-21 06:12:30 Connection to the external service has been lost. | 2017-05-21 06:12:30 CTS FIX Historical Data socket (2126) | Closed. No error. | 2017-05-21 06:12:30 CTS FIX Historical Data socket (2126) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-21 06:12:30 CTS FIX Historical Data socket (2126) | SSL has been shut down. | 2017-05-21 06:12:30 CTS FIX Historical Data socket (2126) | SSL object has been freed. SSL state is now disconnected. | 2017-05-21 06:12:30 CTS FIX Historical Data socket (2126) | Shutdown and closed. | 2017-05-21 06:12:30 CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2017-05-21 06:12:30 CTS FIX Historical Data: Disconnected. | 2017-05-21 06:12:30 Canceling historical data download request for ES.20170600.CME_Eq Intraday data. | 2017-05-21 06:13:31 Removed historical data download ID 548 | 2017-05-21 06:13:31 Canceling historical data download request for 6S.20170600.CME_Fo Intraday data. | 2017-05-21 06:13:31 Removed historical data download ID 550 | 2017-05-21 06:13:31 Canceling historical data download request for HO.20170700.CME_NY Intraday data. | 2017-05-21 06:13:31 Removed historical data download ID 551 | 2017-05-21 06:13:31 Canceling historical data download request for 6C.20170600.CME_Fo Intraday data. | 2017-05-21 06:13:31 Removed historical data download ID 552 | 2017-05-21 06:13:31 Canceling historical data download request for HO.20171200.CME_NY Intraday data. | 2017-05-21 06:13:31 Removed historical data download ID 553 | 2017-05-21 06:13:31 Canceling historical data download request for CL.20170700.CME_NY Intraday data. | 2017-05-21 06:13:31 Removed historical data download ID 554 | 2017-05-21 06:13:31 Canceling historical data download request for 6N.20170600.CME_Fo Intraday data. | 2017-05-21 06:13:31 Removed historical data download ID 555 | 2017-05-21 06:13:31 Canceling historical data download request for RB.20171200.CME_NY Intraday data. | 2017-05-21 06:13:31 Removed historical data download ID 556 | 2017-05-21 06:13:31 Canceling historical data download request for NQ.20170600.CME_Eq Intraday data. | 2017-05-21 06:13:31 Removed historical data download ID 557 | 2017-05-21 06:13:31 Canceling historical data download request for ZB.20170600.CME_F Intraday data. | 2017-05-21 06:13:31 Removed historical data download ID 558 | 2017-05-21 06:13:31 Canceling historical data download request for 6A.20170600.CME_Fo Intraday data. | 2017-05-21 06:13:31 Removed historical data download ID 559 | 2017-05-21 06:13:31 Canceling historical data download request for GC.20170600.CME_CO Intraday data. | 2017-05-21 06:13:31 Removed historical data download ID 560 | 2017-05-21 06:13:31 Canceling historical data download request for ZN.20170600.CME_F Intraday data. | 2017-05-21 06:13:31 Removed historical data download ID 561 | 2017-05-21 06:13:31 Canceling historical data download request for 6J.20170600.CME_Fo Intraday data. | 2017-05-21 06:13:31 Removed historical data download ID 562 | 2017-05-21 06:13:31 Canceling historical data download request for CL.20171200.CME_NY Intraday data. | 2017-05-21 06:13:31 Removed historical data download ID 563 | 2017-05-21 06:13:31 Canceling historical data download request for ZT.20170600.CME_F Intraday data. | 2017-05-21 06:13:31 Removed historical data download ID 564 | 2017-05-21 06:13:31 CTS T4 FIX | Disconnected. | 2017-05-21 06:13:31 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-21 06:13:31 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2017-05-21 06:13:34 CTS T4 FIX | Firm: PTP | 2017-05-21 06:13:34 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199. | 2017-05-21 06:13:34 CTS FIX socket (2130) | Connected. | 2017-05-21 06:13:34 CTS FIX socket (2130) | Starting TLS 1.0 connection. | 2017-05-21 06:13:34 CTS FIX socket (2130) | SSL connection established. | 2017-05-21 06:13:36 CTS FIX: Sending the Logon message. | 2017-05-21 06:13:37 CTS T4 FIX | FIX version: 4.3.74.0 | 2017-05-21 06:13:37 CTS T4 FIX | Connected to data and trading server. | 2017-05-21 06:13:37 DTC Client (2125) | Shutdown and closed. | 2017-05-21 06:13:37 SC DTC Data | Disconnected from the server. | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: ZB.20160900.CME_F. ID: 1 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: ZB.20160900.CME_F. ID: 1 | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: 6E.20160900.CME_Fo. ID: 2 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: 6E.20160900.CME_Fo. ID: 2 | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6J.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: 6J.20160900.CME_Fo. ID: 3 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: 6J.20160900.CME_Fo. ID: 3 | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6B.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: 6B.20160900.CME_Fo. ID: 4 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: 6B.20160900.CME_Fo. ID: 4 | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6C.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: 6C.20160900.CME_Fo. ID: 5 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: 6C.20160900.CME_Fo. ID: 5 | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: CL.20160800.CME_NY. ID: 6 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: CL.20160800.CME_NY. ID: 6 | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6A.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: 6A.20160900.CME_Fo. ID: 7 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: 6A.20160900.CME_Fo. ID: 7 | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: NQ.20160900.CME_Eq. ID: 8 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: NQ.20160900.CME_Eq. ID: 8 | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM.######00.CME_E pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: YM.20160900.CME_E. ID: 9 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: YM.20160900.CME_E. ID: 9 | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: GC.20160800.CME_CO. ID: 10 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: GC.20160800.CME_CO. ID: 10 | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: ES.20160900.CME_Eq. ID: 11 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: ES.20160900.CME_Eq. ID: 11 | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: ZB.20170300.CME_F. ID: 12 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: ZB.20170300.CME_F. ID: 12 | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: CL.20170100.CME_NY. ID: 13 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: CL.20170100.CME_NY. ID: 13 | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: GC.20170400.CME_CO. ID: 14 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: GC.20170400.CME_CO. ID: 14 | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: ZB.20170600.CME_F. ID: 15 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: ZB.20170600.CME_F. ID: 15 | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6B.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: 6B.20170600.CME_Fo. ID: 16 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: 6B.20170600.CME_Fo. ID: 16 | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: CL.20170600.CME_NY. ID: 17 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: CL.20170600.CME_NY. ID: 17 | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The RB.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: RB.20170700.CME_NY. ID: 18 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: RB.20170700.CME_NY. ID: 18 | 2017-05-21 06:13:37 CTS T4 FIX | Using primary service for historical data for RB.20170700.CME_NY | 2017-05-21 06:13:37 Intraday data recording state for symbol RB.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:13:37 Delaying start of download for RB.20170700.CME_NY | 2017-05-21 06:13:37 CTS T4 FIX | Using primary service for historical data for 6B.20170600.CME_Fo | 2017-05-21 06:13:37 Intraday data recording state for symbol 6B.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: 6E.20170600.CME_Fo. ID: 19 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: 6E.20170600.CME_Fo. ID: 19 | 2017-05-21 06:13:37 CTS T4 FIX | Using primary service for historical data for 6E.20170600.CME_Fo | 2017-05-21 06:13:37 Intraday data recording state for symbol 6E.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM.######00.CME_E pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: YM.20170600.CME_E. ID: 20 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: YM.20170600.CME_E. ID: 20 | 2017-05-21 06:13:37 CTS T4 FIX | Using primary service for historical data for YM.20170600.CME_E | 2017-05-21 06:13:37 Intraday data recording state for symbol YM.20170600.CME_E is set to download 'Pending'. | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: ES.20170600.CME_Eq. ID: 21 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: ES.20170600.CME_Eq. ID: 21 | 2017-05-21 06:13:37 CTS T4 FIX | Using primary service for historical data for ES.20170600.CME_Eq | 2017-05-21 06:13:37 Intraday data recording state for symbol ES.20170600.CME_Eq is set to download 'Pending'. | 2017-05-21 06:13:37 CTS T4 FIX | Received Account List collateral report. | 2017-05-21 06:13:37 CTS T4 FIX | Subscribing to account: May* | 2017-05-21 06:13:37 Using Bid/Ask average for last trade price for AUDJPY | 2017-05-21 06:13:37 SC DTC Data | Starting real-time market data updates for: AUDJPY. ID: 22 | 2017-05-21 06:13:37 SC DTC Data | Connecting to the server ds3.sierracharts.com. Port 10048 | 2017-05-21 06:13:37 SC DTC Data | Requesting security definition data for: AUDJPY. ID: 22 | 2017-05-21 06:13:37 Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2017-05-21 06:13:37 DTC Client (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2017-05-21 06:13:37 Delaying start of download for AUDJPY | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6S.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: 6S.20170600.CME_Fo. ID: 23 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: 6S.20170600.CME_Fo. ID: 23 | 2017-05-21 06:13:37 CTS T4 FIX | Using primary service for historical data for 6S.20170600.CME_Fo | 2017-05-21 06:13:37 Intraday data recording state for symbol 6S.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:13:37 Requesting market depth updates for: 6E.20170600.CME_Fo if supported. | 2017-05-21 06:13:37 DTC Client (2131) | Connected. | 2017-05-21 06:13:37 SC DTC Data | Connected to server. | 2017-05-21 06:13:37 SC DTC Data | Sending Encoding Request to server | 2017-05-21 06:13:37 Supported exchange: CME_CO (SIM:COMEX Futures) | 2017-05-21 06:13:37 Supported exchange: CME_EqOp (SIM:CME Equity Options) | 2017-05-21 06:13:37 Supported exchange: CME_NYOp (SIM:NYMEX Options) | 2017-05-21 06:13:37 Supported exchange: CME_AgOp (SIM:CME Agricultural Options) | 2017-05-21 06:13:37 Supported exchange: CME_Eq (SIM:CME Equity Futures) | 2017-05-21 06:13:37 Supported exchange: CME_In (SIM:CME Interest Rate Futures) | 2017-05-21 06:13:37 Supported exchange: CME_C (SIM:CBOT Commodity Futures) | 2017-05-21 06:13:37 Supported exchange: CME_KOp (SIM:KCBT Options) | 2017-05-21 06:13:37 Supported exchange: CME_F (SIM:CBOT Financial Futures) | 2017-05-21 06:13:37 Supported exchange: CME_E (SIM:CBOT Equity Futures) | 2017-05-21 06:13:37 Supported exchange: CME_COp (SIM:CBOT Commodity Options) | 2017-05-21 06:13:37 Supported exchange: CME_K (SIM:KCBT Futures) | 2017-05-21 06:13:37 Supported exchange: CME_EOp (SIM:CBOT Equity Options) | 2017-05-21 06:13:37 Supported exchange: CME_NY (SIM:NYMEX Futures) | 2017-05-21 06:13:37 Supported exchange: CME_Fo (SIM:CME Foreign Exchange Futures) | 2017-05-21 06:13:37 Supported exchange: CME_Ag (SIM:CME Agricultural Futures) | 2017-05-21 06:13:37 Supported exchange: CME_FoOp (SIM:CME Foreign Exchange Options) | 2017-05-21 06:13:37 Supported exchange: CME_FOp (SIM:CBOT Financial Options) | 2017-05-21 06:13:37 Supported exchange: CME_InOp (SIM:CME Interest Rate Options) | 2017-05-21 06:13:37 Supported exchange: CME_COOp (SIM:COMEX Options) | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The HO.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: HO.20170700.CME_NY. ID: 24 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: HO.20170700.CME_NY. ID: 24 | 2017-05-21 06:13:37 CTS T4 FIX | Using primary service for historical data for HO.20170700.CME_NY | 2017-05-21 06:13:37 Intraday data recording state for symbol HO.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6C.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: 6C.20170600.CME_Fo. ID: 25 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: 6C.20170600.CME_Fo. ID: 25 | 2017-05-21 06:13:37 CTS T4 FIX | Using primary service for historical data for 6C.20170600.CME_Fo | 2017-05-21 06:13:37 Intraday data recording state for symbol 6C.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The HO.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: HO.20171200.CME_NY. ID: 26 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: HO.20171200.CME_NY. ID: 26 | 2017-05-21 06:13:37 CTS T4 FIX | Using primary service for historical data for HO.20171200.CME_NY | 2017-05-21 06:13:37 Intraday data recording state for symbol HO.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: CL.20170700.CME_NY. ID: 27 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: CL.20170700.CME_NY. ID: 27 | 2017-05-21 06:13:37 CTS T4 FIX | Using primary service for historical data for CL.20170700.CME_NY | 2017-05-21 06:13:37 Intraday data recording state for symbol CL.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6N.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: 6N.20170600.CME_Fo. ID: 28 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: 6N.20170600.CME_Fo. ID: 28 | 2017-05-21 06:13:37 CTS T4 FIX | Using primary service for historical data for 6N.20170600.CME_Fo | 2017-05-21 06:13:37 Intraday data recording state for symbol 6N.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:13:37 HD Request # 348 | Downloading Intraday chart data for RB.20170700.CME_NY to the file RB.20170700.CME_NY.scid. Service: cts | 2017-05-21 06:13:37 HD Request # 348 | Download start date-time: 2017-05-19 16:59:53.000 | 2017-05-21 06:13:37 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The RB.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: RB.20171200.CME_NY. ID: 29 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: RB.20171200.CME_NY. ID: 29 | 2017-05-21 06:13:37 CTS T4 FIX | Using primary service for historical data for RB.20171200.CME_NY | 2017-05-21 06:13:37 Intraday data recording state for symbol RB.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: NQ.20170600.CME_Eq. ID: 30 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: NQ.20170600.CME_Eq. ID: 30 | 2017-05-21 06:13:37 CTS T4 FIX | Using primary service for historical data for NQ.20170600.CME_Eq | 2017-05-21 06:13:37 Intraday data recording state for symbol NQ.20170600.CME_Eq is set to download 'Pending'. | 2017-05-21 06:13:37 SC DTC Data | Setting DTC encoding to Binary VLS | 2017-05-21 06:13:37 SC DTC Data | Sending logon request message. | 2017-05-21 06:13:37 CTS FIX Historical Data socket (0) | Resolved address fix-chart-sim.t4login.com to IP 74.201.6.229. | 2017-05-21 06:13:37 CTS FIX Historical Data socket (2132) | Connected. | 2017-05-21 06:13:37 CTS FIX Historical Data socket (2132) | Starting TLS 1.0 connection. | 2017-05-21 06:13:37 CTS T4 FIX | Using primary service for historical data for ZB.20170600.CME_F | 2017-05-21 06:13:37 Intraday data recording state for symbol ZB.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6A.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: 6A.20170600.CME_Fo. ID: 31 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: 6A.20170600.CME_Fo. ID: 31 | 2017-05-21 06:13:37 CTS T4 FIX | Using primary service for historical data for 6A.20170600.CME_Fo | 2017-05-21 06:13:37 Intraday data recording state for symbol 6A.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:13:37 Requesting market depth updates for: 6B.20170600.CME_Fo if supported. | 2017-05-21 06:13:37 SC DTC Data | Received logon response. | 2017-05-21 06:13:37 SC DTC Data | Server Name: SC Realtime Server. | 2017-05-21 06:13:37 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2017-05-21 06:13:37 SC DTC Data | Successfully connected. | 2017-05-21 06:13:37 SC DTC Data | Trading is not supported. | 2017-05-21 06:13:37 SC DTC Data | Restarting real-time data updates for symbol: AUDJPY | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:37 CTS T4 FIX | Starting real-time market data updates for: GC.20170600.CME_CO. ID: 32 | 2017-05-21 06:13:37 CTS T4 FIX | Requesting security definition data for: GC.20170600.CME_CO. ID: 32 | 2017-05-21 06:13:37 CTS T4 FIX | Using primary service for historical data for GC.20170600.CME_CO | 2017-05-21 06:13:37 Intraday data recording state for symbol GC.20170600.CME_CO is set to download 'Pending'. | 2017-05-21 06:13:37 Requesting market depth updates for: YM.20170600.CME_E if supported. | 2017-05-21 06:13:37 SC DTC Data | Received security definition for symbol AUDJPY | 2017-05-21 06:13:37 CTS FIX Historical Data socket (2132) | SSL connection established. | 2017-05-21 06:13:37 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZN.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:42 CTS T4 FIX | Starting real-time market data updates for: ZN.20170600.CME_F. ID: 33 | 2017-05-21 06:13:42 CTS T4 FIX | Requesting security definition data for: ZN.20170600.CME_F. ID: 33 | 2017-05-21 06:13:42 CTS T4 FIX | Using primary service for historical data for ZN.20170600.CME_F | 2017-05-21 06:13:42 Intraday data recording state for symbol ZN.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:13:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6J.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:42 CTS T4 FIX | Starting real-time market data updates for: 6J.20170600.CME_Fo. ID: 34 | 2017-05-21 06:13:42 CTS T4 FIX | Requesting security definition data for: 6J.20170600.CME_Fo. ID: 34 | 2017-05-21 06:13:42 CTS T4 FIX | Using primary service for historical data for 6J.20170600.CME_Fo | 2017-05-21 06:13:42 Intraday data recording state for symbol 6J.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:13:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:42 CTS T4 FIX | Starting real-time market data updates for: CL.20171200.CME_NY. ID: 35 | 2017-05-21 06:13:42 CTS T4 FIX | Requesting security definition data for: CL.20171200.CME_NY. ID: 35 | 2017-05-21 06:13:42 CTS T4 FIX | Using primary service for historical data for CL.20171200.CME_NY | 2017-05-21 06:13:42 Intraday data recording state for symbol CL.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:13:42 Requesting market depth updates for: NQ.20170600.CME_Eq if supported. | 2017-05-21 06:13:42 Requesting market depth updates for: 6J.20170600.CME_Fo if supported. | 2017-05-21 06:13:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZT.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:13:42 CTS T4 FIX | Starting real-time market data updates for: ZT.20170600.CME_F. ID: 36 | 2017-05-21 06:13:42 CTS T4 FIX | Requesting security definition data for: ZT.20170600.CME_F. ID: 36 | 2017-05-21 06:13:42 CTS T4 FIX | Using primary service for historical data for ZT.20170600.CME_F | 2017-05-21 06:13:42 Intraday data recording state for symbol ZT.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:13:42 Requesting market depth updates for: GC.20170600.CME_CO if supported. | 2017-05-21 06:13:42 CTS T4 FIX | Sending security definition request for symbol 6A.20160900.CME_Fo | 2017-05-21 06:13:42 Requesting market depth updates for: CL.20170700.CME_NY if supported. | 2017-05-21 06:13:42 Symbol Error - 6A.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:13:42 CTS T4 FIX | Received 0 security definitions for underlying symbol 6A | 2017-05-21 06:13:42 Requesting market depth updates for: ZB.20170600.CME_F if supported. | 2017-05-21 06:13:42 Requesting market depth updates for: ES.20170600.CME_Eq if supported. | 2017-05-21 06:13:42 HD Request # 349 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-05-21 06:13:42 HD Request # 349 | Download start date-time: 2017-05-19 16:57:58.000 | 2017-05-21 06:13:42 HD Request # 349 | Using server: ds3.sierracharts.com port 10149 | 2017-05-21 06:13:42 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2017-05-21 06:13:42 Socket (2133) | Connected. | 2017-05-21 06:13:42 HD Request # 349 | Setting DTC encoding to Binary VLS | 2017-05-21 06:13:42 HD Request # 349 | Sending historical data logon request message. | 2017-05-21 06:13:42 CTS FIX Historical Data: Sending the Logon message. | 2017-05-21 06:13:44 HD Request # 349 | Requesting Intraday data. Start date-time: 2017-05-19 16:57:58. Record interval: 1. Symbol: AUDJPY | 2017-05-21 06:13:44 HD Request # 349 | Decompressing data. | 2017-05-21 06:13:44 HD Request # 349 | Receiving Intraday data for AUDJPY starting at 2017-05-19 16:57:58 | 2017-05-21 06:13:44 HD Request # 349 | Timestamp of first Intraday data file record written: 2017-05-19 16:57:58 | 2017-05-21 06:13:44 Socket (2133) | Shutdown and closed. | 2017-05-21 06:13:44 The network socket for historical data has been closed. | 2017-05-21 06:13:44 CTS T4 FIX | Sending security definition request for symbol 6A.20170600.CME_Fo | 2017-05-21 06:13:44 HD Request # 349 | Received 1 record from 2017-05-19 16:57:58 to 2017-05-19 16:57:58 (0.0 seconds) and wrote 1 record for AUDJPY | 2017-05-21 06:13:46 HD Request # 349 | Intraday download COMPLETE for AUDJPY. Completion time: 2s. Unique request ID: 570 | 2017-05-21 06:13:46 Removed historical data download ID 570 | 2017-05-21 06:13:46 Real-time Intraday chart data file updates started for AUDJPY | 2017-05-21 06:13:46 Opened cached Intraday file: C:\SierraChart1\Data\AUDJPY.scid | 2017-05-21 06:13:46 Intraday chart data file opened for AUDJPY | 2017-05-21 06:13:46 CTS FIX Historical Data: Connected to Historical data server. | 2017-05-21 06:13:46 CTS T4 FIX | Received 'Account Update/Balance Data' collateral report. | 2017-05-21 06:13:46 CTS T4 FIX | Received matching security definition for symbol 6A.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:13:46 CTS T4 FIX | Received 1 security definitions for underlying symbol 6A | 2017-05-21 06:13:46 Contract specifications for 6A.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:13:46 CTS T4 FIX | Sending security definition request for symbol 6B.20160900.CME_Fo | 2017-05-21 06:13:46 Symbol Error - 6B.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:13:46 CTS T4 FIX | Received 0 security definitions for underlying symbol 6B | 2017-05-21 06:13:46 CTS T4 FIX | Requesting Open Orders for account: May*. Request ID: 9498462 | 2017-05-21 06:13:46 Requesting market depth updates for: 6B.20160900.CME_Fo if supported. | 2017-05-21 06:13:46 Requesting market depth updates for: 6E.20160900.CME_Fo if supported. | 2017-05-21 06:13:46 Requesting market depth updates for: 6J.20160900.CME_Fo if supported. | 2017-05-21 06:13:46 Requesting market depth updates for: 6N.20170600.CME_Fo if supported. | 2017-05-21 06:13:46 Requesting market depth updates for: CL.20160800.CME_NY if supported. | 2017-05-21 06:13:46 Requesting market depth updates for: CL.20170100.CME_NY if supported. | 2017-05-21 06:13:46 Requesting market depth updates for: CL.20170600.CME_NY if supported. | 2017-05-21 06:13:46 Requesting market depth updates for: CL.20171200.CME_NY if supported. | 2017-05-21 06:13:46 Requesting market depth updates for: ES.20160900.CME_Eq if supported. | 2017-05-21 06:13:46 Requesting market depth updates for: GC.20160800.CME_CO if supported. | 2017-05-21 06:13:46 Requesting market depth updates for: GC.20170400.CME_CO if supported. | 2017-05-21 06:13:46 Requesting market depth updates for: NQ.20160900.CME_Eq if supported. | 2017-05-21 06:13:46 Requesting market depth updates for: YM.20160900.CME_E if supported. | 2017-05-21 06:13:46 Requesting market depth updates for: ZB.20160900.CME_F if supported. | 2017-05-21 06:13:46 Requesting market depth updates for: ZB.20170300.CME_F if supported. | 2017-05-21 06:13:46 CTS T4 FIX | No open orders for account May18CCwmitchel | 2017-05-21 06:13:46 CTS T4 FIX | Sending security definition request for symbol 6B.20170600.CME_Fo | 2017-05-21 06:13:48 CTS T4 FIX | Received matching security definition for symbol 6B.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:13:48 CTS T4 FIX | Received 1 security definitions for underlying symbol 6B | 2017-05-21 06:13:48 Contract specifications for 6B.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 6.25 | 2017-05-21 06:13:48 CTS T4 FIX | Sending security definition request for symbol 6C.20160900.CME_Fo | 2017-05-21 06:13:49 Symbol Error - 6C.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:13:49 CTS T4 FIX | Received 0 security definitions for underlying symbol 6C | 2017-05-21 06:13:49 CTS T4 FIX | Sending security definition request for symbol 6C.20170600.CME_Fo | 2017-05-21 06:13:51 CTS T4 FIX | Received matching security definition for symbol 6C.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:13:51 CTS T4 FIX | Received 1 security definitions for underlying symbol 6C | 2017-05-21 06:13:51 Contract specifications for 6C.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 5 | 2017-05-21 06:13:51 CTS T4 FIX | Sending security definition request for symbol 6E.20160900.CME_Fo | 2017-05-21 06:13:52 Symbol Error - 6E.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:13:52 CTS T4 FIX | Received 0 security definitions for underlying symbol 6E | 2017-05-21 06:13:52 CTS T4 FIX | Sending security definition request for symbol 6E.20170600.CME_Fo | 2017-05-21 06:13:54 CTS T4 FIX | Received matching security definition for symbol 6E.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:13:54 CTS T4 FIX | Received 1 security definitions for underlying symbol 6E | 2017-05-21 06:13:54 Contract specifications for 6E.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-05-21 06:13:54 CTS T4 FIX | Sending security definition request for symbol 6J.20160900.CME_Fo | 2017-05-21 06:13:55 Symbol Error - 6J.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:13:55 CTS T4 FIX | Received 0 security definitions for underlying symbol 6J | 2017-05-21 06:13:55 CTS T4 FIX | Requesting historical Fills for account: May*. Request ID: 9498466 | 2017-05-21 06:13:57 CTS T4 FIX | Sending security definition request for symbol 6J.20170600.CME_Fo | 2017-05-21 06:13:57 CTS T4 FIX | Received Account List collateral report. | 2017-05-21 06:13:57 CTS T4 FIX | Server provided no historical order fills for account 1A297B51-A416-42D4-A1C8-C9B1B4125155 | 2017-05-21 06:13:57 CTS T4 FIX | Received matching security definition for symbol 6J.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:13:57 CTS T4 FIX | Received 1 security definitions for underlying symbol 6J | 2017-05-21 06:13:57 Contract specifications for 6J.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-05-21 06:13:57 CTS T4 FIX | Sending security definition request for symbol 6N.20170600.CME_Fo | 2017-05-21 06:13:58 CTS T4 FIX | Received matching security definition for symbol 6N.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:13:58 CTS T4 FIX | Received 1 security definitions for underlying symbol 6N | 2017-05-21 06:13:58 Contract specifications for 6N.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:13:58 CTS T4 FIX | Sending security definition request for symbol 6S.20170600.CME_Fo | 2017-05-21 06:14:00 CTS T4 FIX | Received matching security definition for symbol 6S.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:14:00 CTS T4 FIX | Received 1 security definitions for underlying symbol 6S | 2017-05-21 06:14:00 Contract specifications for 6S.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 12.5 | 2017-05-21 06:14:00 CTS T4 FIX | Sending security definition request for symbol CL.20160800.CME_NY | 2017-05-21 06:14:01 Symbol Error - CL.20160800.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:14:01 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2017-05-21 06:14:01 CTS T4 FIX | Sending security definition request for symbol CL.20170100.CME_NY | 2017-05-21 06:14:02 Symbol Error - CL.20170100.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:14:02 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2017-05-21 06:14:02 CTS T4 FIX | Sending security definition request for symbol CL.20170600.CME_NY | 2017-05-21 06:14:04 CTS T4 FIX | Received matching security definition for symbol CL.20170600.CME_NY. Subscribing to data. | 2017-05-21 06:14:04 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:14:04 Contract specifications for CL.20170600.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:14:05 CTS T4 FIX | Sending security definition request for symbol CL.20170700.CME_NY | 2017-05-21 06:14:05 CTS T4 FIX | Received matching security definition for symbol CL.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:14:05 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:14:05 Contract specifications for CL.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:14:07 CTS T4 FIX | Sending security definition request for symbol CL.20171200.CME_NY | 2017-05-21 06:14:07 CTS T4 FIX | Received matching security definition for symbol CL.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:14:07 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:14:07 Contract specifications for CL.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:14:08 CTS T4 FIX | Sending security definition request for symbol ES.20160900.CME_Eq | 2017-05-21 06:14:08 Symbol Error - ES.20160900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:14:08 CTS T4 FIX | Received 0 security definitions for underlying symbol ES | 2017-05-21 06:14:08 CTS T4 FIX | Sending security definition request for symbol ES.20170600.CME_Eq | 2017-05-21 06:14:10 CTS T4 FIX | Received matching security definition for symbol ES.20170600.CME_Eq. Subscribing to data. | 2017-05-21 06:14:10 CTS T4 FIX | Received 1 security definitions for underlying symbol ES | 2017-05-21 06:14:10 Contract specifications for ES.20170600.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 12.5 | 2017-05-21 06:14:12 CTS T4 FIX | Sending security definition request for symbol GC.20160800.CME_CO | 2017-05-21 06:14:12 Symbol Error - GC.20160800.CME_CO is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:14:12 CTS T4 FIX | Received 0 security definitions for underlying symbol GC | 2017-05-21 06:14:12 CTS T4 FIX | Sending security definition request for symbol GC.20170400.CME_CO | 2017-05-21 06:14:13 Symbol Error - GC.20170400.CME_CO is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:14:13 CTS T4 FIX | Received 0 security definitions for underlying symbol GC | 2017-05-21 06:14:13 CTS T4 FIX | Sending security definition request for symbol GC.20170600.CME_CO | 2017-05-21 06:14:15 CTS T4 FIX | Received matching security definition for symbol GC.20170600.CME_CO. Subscribing to data. | 2017-05-21 06:14:15 CTS T4 FIX | Received 1 security definitions for underlying symbol GC | 2017-05-21 06:14:15 Contract specifications for GC.20170600.CME_CO. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:14:16 CTS T4 FIX | Sending security definition request for symbol HO.20170700.CME_NY | 2017-05-21 06:14:16 CTS T4 FIX | Received matching security definition for symbol HO.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:14:16 CTS T4 FIX | Received 1 security definitions for underlying symbol HO | 2017-05-21 06:14:16 Contract specifications for HO.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:14:18 CTS T4 FIX | Sending security definition request for symbol HO.20171200.CME_NY | 2017-05-21 06:14:18 CTS T4 FIX | Received matching security definition for symbol HO.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:14:18 CTS T4 FIX | Received 1 security definitions for underlying symbol HO | 2017-05-21 06:14:18 Contract specifications for HO.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:14:19 CTS T4 FIX | Sending security definition request for symbol NQ.20160900.CME_Eq | 2017-05-21 06:14:19 Symbol Error - NQ.20160900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:14:19 CTS T4 FIX | Received 0 security definitions for underlying symbol NQ | 2017-05-21 06:14:19 CTS T4 FIX | Sending security definition request for symbol NQ.20170600.CME_Eq | 2017-05-21 06:14:20 CTS T4 FIX | Received matching security definition for symbol NQ.20170600.CME_Eq. Subscribing to data. | 2017-05-21 06:14:20 CTS T4 FIX | Received 1 security definitions for underlying symbol NQ | 2017-05-21 06:14:20 Contract specifications for NQ.20170600.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 5 | 2017-05-21 06:14:22 CTS T4 FIX | Sending security definition request for symbol RB.20170700.CME_NY | 2017-05-21 06:14:22 CTS T4 FIX | Received matching security definition for symbol RB.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:14:22 CTS T4 FIX | Received matching security definition for symbol RB.20170700.CME_NY. Requesting historical data. | 2017-05-21 06:14:22 HD Request # 348 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:14:22 CTS T4 FIX | Received 1 security definitions for underlying symbol RB | 2017-05-21 06:14:22 Contract specifications for RB.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:14:23 HD Request # 348 | Receiving Intraday data for RB.20170700.CME_NY starting at 2017-05-18 18:00:00 | 2017-05-21 06:14:23 HD Request # 348 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:53 | 2017-05-21 06:14:23 HD Request # 348 | Total records received: 7454 | 2017-05-21 06:14:23 HD Request # 348 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:14:23 HD Request # 348 | Total records received: 7454 | 2017-05-21 06:14:23 HD Request # 348 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:14:23 HD Request # 348 | Total records received: 7454 | 2017-05-21 06:14:23 HD Request # 348 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:14:23 HD Request # 348 | Total records received: 7454 | 2017-05-21 06:14:23 HD Request # 348 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:14:23 CTS T4 FIX | Sending security definition request for symbol RB.20171200.CME_NY | 2017-05-21 06:14:23 CTS T4 FIX | Received matching security definition for symbol RB.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:14:23 CTS T4 FIX | Received 1 security definitions for underlying symbol RB | 2017-05-21 06:14:23 HD Request # 348 | Received 7454 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:53 (23.0 hours) and wrote 1 record for RB.20170700.CME_NY | 2017-05-21 06:14:23 HD Request # 348 | Intraday download COMPLETE for RB.20170700.CME_NY. Completion time: 43s. Unique request ID: 565 | 2017-05-21 06:14:23 Removed historical data download ID 565 | 2017-05-21 06:14:23 Real-time Intraday chart data file updates started for RB.20170700.CME_NY | 2017-05-21 06:14:23 Opened cached Intraday file: C:\SierraChart1\Data\RB.20170700.CME_NY.scid | 2017-05-21 06:14:23 Intraday chart data file opened for RB.20170700.CME_NY | 2017-05-21 06:14:23 Delaying start of download for 6B.20170600.CME_Fo | 2017-05-21 06:14:23 Contract specifications for RB.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:14:25 Chart #18 has tagged chart #16 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:14:25 Chart #21 has tagged chart #9 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:14:25 CTS T4 FIX | Sending security definition request for symbol YM.20160900.CME_E | 2017-05-21 06:14:25 Chart #22 has tagged chart #16 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:14:25 Symbol Error - YM.20160900.CME_E is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:14:25 CTS T4 FIX | Received 0 security definitions for underlying symbol YM | 2017-05-21 06:14:25 CL.20170700.CME_NY 30 Sec #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:14:26 CL.20170700.CME_NY [C] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:14:26 Chart #9 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:14:26 CL.20170700.CME_NY 3 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:14:26 Chart #16 has tagged chart #15 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:14:26 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:14:26 CTS T4 FIX | Sending security definition request for symbol YM.20170600.CME_E | 2017-05-21 06:14:26 CTS T4 FIX | Received matching security definition for symbol YM.20170600.CME_E. Subscribing to data. | 2017-05-21 06:14:26 CTS T4 FIX | Received 1 security definitions for underlying symbol YM | 2017-05-21 06:14:26 Contract specifications for YM.20170600.CME_E. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 5 | 2017-05-21 06:14:29 6C.20170600.CME_Fo 3 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:14:29 CTS T4 FIX | Sending security definition request for symbol ZB.20160900.CME_F | 2017-05-21 06:14:29 Symbol Error - ZB.20160900.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:14:29 CTS T4 FIX | Received 0 security definitions for underlying symbol ZB | 2017-05-21 06:14:29 CTS T4 FIX | Sending security definition request for symbol ZB.20170300.CME_F | 2017-05-21 06:14:31 Symbol Error - ZB.20170300.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:14:31 CTS T4 FIX | Received 0 security definitions for underlying symbol ZB | 2017-05-21 06:14:31 CTS T4 FIX | Sending security definition request for symbol ZB.20170600.CME_F | 2017-05-21 06:14:32 CTS T4 FIX | Received matching security definition for symbol ZB.20170600.CME_F. Subscribing to data. | 2017-05-21 06:14:32 CTS T4 FIX | Received 1 security definitions for underlying symbol ZB | 2017-05-21 06:14:32 Contract specifications for ZB.20170600.CME_F. Multiplier: 0.00001000. Tick Size: 0.03125. Value Format: 132. Currency Value per Tick: 31.25 | 2017-05-21 06:14:34 CTS T4 FIX | Sending security definition request for symbol ZN.20170600.CME_F | 2017-05-21 06:14:34 CTS T4 FIX | Received matching security definition for symbol ZN.20170600.CME_F. Subscribing to data. | 2017-05-21 06:14:34 CTS T4 FIX | Received 1 security definitions for underlying symbol ZN | 2017-05-21 06:14:34 Contract specifications for ZN.20170600.CME_F. Multiplier: 0.00000100. Tick Size: 0.015625. Value Format: 132. Currency Value per Tick: 15.625 | 2017-05-21 06:14:35 CTS T4 FIX | Sending security definition request for symbol ZT.20170600.CME_F | 2017-05-21 06:14:35 CTS T4 FIX | Received matching security definition for symbol ZT.20170600.CME_F. Subscribing to data. | 2017-05-21 06:14:35 CTS T4 FIX | Received 1 security definitions for underlying symbol ZT | 2017-05-21 06:14:35 Contract specifications for ZT.20170600.CME_F. Multiplier: 0.00000010. Tick Size: 0.0078125. Value Format: 228. Currency Value per Tick: 15.625 | 2017-05-21 06:14:37 HD Request # 350 | Downloading Intraday chart data for 6B.20170600.CME_Fo to the file 6B.20170600.CME_Fo.scid. Service: cts | 2017-05-21 06:14:50 HD Request # 350 | Download start date-time: 2017-05-19 16:59:54.000 | 2017-05-21 06:14:50 HD Request # 350 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:14:50 HD Request # 350 | Receiving Intraday data for 6B.20170600.CME_Fo starting at 2017-05-18 18:00:00 | 2017-05-21 06:14:50 HD Request # 350 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:54 | 2017-05-21 06:14:50 HD Request # 350 | Total records received: 8374 | 2017-05-21 06:14:50 HD Request # 350 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:14:50 HD Request # 350 | Total records received: 8374 | 2017-05-21 06:14:50 HD Request # 350 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:14:50 HD Request # 350 | Total records received: 8374 | 2017-05-21 06:14:51 HD Request # 350 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:14:51 HD Request # 350 | Total records received: 8374 | 2017-05-21 06:14:51 HD Request # 350 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:14:51 HD Request # 350 | Received 8374 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:54 (23.0 hours) and wrote 1 record for 6B.20170600.CME_Fo | 2017-05-21 06:14:51 HD Request # 350 | Intraday download COMPLETE for 6B.20170600.CME_Fo. Completion time: 2s. Unique request ID: 566 | 2017-05-21 06:14:51 Removed historical data download ID 566 | 2017-05-21 06:14:51 Real-time Intraday chart data file updates started for 6B.20170600.CME_Fo | 2017-05-21 06:14:51 Opened cached Intraday file: C:\SierraChart1\Data\6B.20170600.CME_Fo.scid | 2017-05-21 06:14:51 Intraday chart data file opened for 6B.20170600.CME_Fo | 2017-05-21 06:14:51 Delaying start of download for 6E.20170600.CME_Fo | 2017-05-21 06:14:51 Chart #12 has tagged chart #8 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:14:51 6A.20170600.CME_Fo 3 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:14:51 Chart #12 has tagged chart #8 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:14:53 6A.20170600.CME_Fo 3 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:14:55 HD Request # 351 | Downloading Intraday chart data for 6E.20170600.CME_Fo to the file 6E.20170600.CME_Fo.scid. Service: cts | 2017-05-21 06:15:16 HD Request # 351 | Download start date-time: 2017-05-19 16:59:58.000 | 2017-05-21 06:15:16 HD Request # 351 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:15:16 HD Request # 351 | Receiving Intraday data for 6E.20170600.CME_Fo starting at 2017-05-18 18:00:00 | 2017-05-21 06:15:17 HD Request # 351 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:58 | 2017-05-21 06:15:17 HD Request # 351 | Total records received: 17398 | 2017-05-21 06:15:17 HD Request # 351 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:15:17 HD Request # 351 | Total records received: 17398 | 2017-05-21 06:15:17 HD Request # 351 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:15:17 HD Request # 351 | Total records received: 17398 | 2017-05-21 06:15:17 HD Request # 351 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:15:17 HD Request # 351 | Total records received: 17398 | 2017-05-21 06:15:17 HD Request # 351 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:15:17 HD Request # 351 | Received 17398 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:58 (23.0 hours) and wrote 1 record for 6E.20170600.CME_Fo | 2017-05-21 06:15:17 HD Request # 351 | Intraday download COMPLETE for 6E.20170600.CME_Fo. Completion time: 2s. Unique request ID: 567 | 2017-05-21 06:15:17 Removed historical data download ID 567 | 2017-05-21 06:15:17 Real-time Intraday chart data file updates started for 6E.20170600.CME_Fo | 2017-05-21 06:15:17 Opened cached Intraday file: C:\SierraChart1\Data\6E.20170600.CME_Fo.scid | 2017-05-21 06:15:17 Intraday chart data file opened for 6E.20170600.CME_Fo | 2017-05-21 06:15:17 Delaying start of download for YM.20170600.CME_E | 2017-05-21 06:15:17 Chart #15 has tagged chart #4 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:15:19 6B.20170600.CME_Fo 30 Sec #4 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:15:19 HD Request # 352 | Downloading Intraday chart data for YM.20170600.CME_E to the file YM.20170600.CME_E.scid. Service: cts | 2017-05-21 06:15:43 HD Request # 352 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:15:43 HD Request # 352 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:15:43 HD Request # 352 | Receiving Intraday data for YM.20170600.CME_E starting at 2017-05-18 18:00:00 | 2017-05-21 06:15:43 HD Request # 352 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:15:43 HD Request # 352 | Total records received: 19680 | 2017-05-21 06:15:43 HD Request # 352 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:15:43 HD Request # 352 | Total records received: 19680 | 2017-05-21 06:15:44 HD Request # 352 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:15:44 HD Request # 352 | Total records received: 19680 | 2017-05-21 06:15:44 HD Request # 352 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:15:44 HD Request # 352 | Total records received: 19680 | 2017-05-21 06:15:44 HD Request # 352 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:15:44 HD Request # 352 | Received 19680 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for YM.20170600.CME_E | 2017-05-21 06:15:44 HD Request # 352 | Intraday download COMPLETE for YM.20170600.CME_E. Completion time: 3s. Unique request ID: 568 | 2017-05-21 06:15:44 Removed historical data download ID 568 | 2017-05-21 06:15:44 Real-time Intraday chart data file updates started for YM.20170600.CME_E | 2017-05-21 06:15:44 Opened cached Intraday file: C:\SierraChart1\Data\YM.20170600.CME_E.scid | 2017-05-21 06:15:44 Intraday chart data file opened for YM.20170600.CME_E | 2017-05-21 06:15:44 Delaying start of download for ES.20170600.CME_Eq | 2017-05-21 06:15:44 Chart #3 has tagged chart #4 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:15:44 ZB.20170600.CME_F 3 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:15:46 CTS FIX socket (2130) | Closed. No error. | 2017-05-21 06:15:46 CTS FIX: Received a Logout message. Text = Timed out. No valid messages received within the heartbeat interval of 30 seconds | 2017-05-21 06:15:46 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2017-05-21 06:15:46 CTS FIX socket (2130) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-21 06:15:46 CTS FIX socket (2130) | SSL has been shut down. | 2017-05-21 06:15:46 CTS FIX socket (2130) | SSL object has been freed. SSL state is now disconnected. | 2017-05-21 06:15:46 CTS FIX socket (2130) | Shutdown and closed. | 2017-05-21 06:15:46 Connection to the external service has been lost. | 2017-05-21 06:15:46 CTS FIX Historical Data socket (2132) | Closed. No error. | 2017-05-21 06:15:46 CTS FIX Historical Data socket (2132) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-21 06:15:46 CTS FIX Historical Data socket (2132) | SSL has been shut down. | 2017-05-21 06:15:46 CTS FIX Historical Data socket (2132) | SSL object has been freed. SSL state is now disconnected. | 2017-05-21 06:15:46 CTS FIX Historical Data socket (2132) | Shutdown and closed. | 2017-05-21 06:15:46 CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2017-05-21 06:15:46 CTS FIX Historical Data: Disconnected. | 2017-05-21 06:15:46 Canceling historical data download request for ES.20170600.CME_Eq Intraday data. | 2017-05-21 06:16:49 Removed historical data download ID 569 | 2017-05-21 06:16:49 Canceling historical data download request for 6S.20170600.CME_Fo Intraday data. | 2017-05-21 06:16:49 Removed historical data download ID 571 | 2017-05-21 06:16:49 Canceling historical data download request for HO.20170700.CME_NY Intraday data. | 2017-05-21 06:16:49 Removed historical data download ID 572 | 2017-05-21 06:16:49 Canceling historical data download request for 6C.20170600.CME_Fo Intraday data. | 2017-05-21 06:16:49 Removed historical data download ID 573 | 2017-05-21 06:16:49 Canceling historical data download request for HO.20171200.CME_NY Intraday data. | 2017-05-21 06:16:49 Removed historical data download ID 574 | 2017-05-21 06:16:49 Canceling historical data download request for CL.20170700.CME_NY Intraday data. | 2017-05-21 06:16:49 Removed historical data download ID 575 | 2017-05-21 06:16:49 Canceling historical data download request for 6N.20170600.CME_Fo Intraday data. | 2017-05-21 06:16:49 Removed historical data download ID 576 | 2017-05-21 06:16:49 Canceling historical data download request for RB.20171200.CME_NY Intraday data. | 2017-05-21 06:16:49 Removed historical data download ID 577 | 2017-05-21 06:16:49 Canceling historical data download request for NQ.20170600.CME_Eq Intraday data. | 2017-05-21 06:16:49 Removed historical data download ID 578 | 2017-05-21 06:16:49 Canceling historical data download request for ZB.20170600.CME_F Intraday data. | 2017-05-21 06:16:49 Removed historical data download ID 579 | 2017-05-21 06:16:49 Canceling historical data download request for 6A.20170600.CME_Fo Intraday data. | 2017-05-21 06:16:49 Removed historical data download ID 580 | 2017-05-21 06:16:49 Canceling historical data download request for GC.20170600.CME_CO Intraday data. | 2017-05-21 06:16:49 Removed historical data download ID 581 | 2017-05-21 06:16:49 Canceling historical data download request for ZN.20170600.CME_F Intraday data. | 2017-05-21 06:16:49 Removed historical data download ID 582 | 2017-05-21 06:16:49 Canceling historical data download request for 6J.20170600.CME_Fo Intraday data. | 2017-05-21 06:16:49 Removed historical data download ID 583 | 2017-05-21 06:16:49 Canceling historical data download request for CL.20171200.CME_NY Intraday data. | 2017-05-21 06:16:49 Removed historical data download ID 584 | 2017-05-21 06:16:49 Canceling historical data download request for ZT.20170600.CME_F Intraday data. | 2017-05-21 06:16:49 Removed historical data download ID 585 | 2017-05-21 06:16:49 CTS T4 FIX | Disconnected. | 2017-05-21 06:16:49 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-21 06:16:49 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2017-05-21 06:16:54 CTS T4 FIX | Firm: PTP | 2017-05-21 06:16:54 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199. | 2017-05-21 06:16:54 CTS FIX socket (2136) | Connected. | 2017-05-21 06:16:54 CTS FIX socket (2136) | Starting TLS 1.0 connection. | 2017-05-21 06:16:54 CTS FIX socket (2136) | SSL connection established. | 2017-05-21 06:16:56 CTS FIX: Sending the Logon message. | 2017-05-21 06:16:57 CTS T4 FIX | FIX version: 4.3.74.0 | 2017-05-21 06:16:57 CTS T4 FIX | Connected to data and trading server. | 2017-05-21 06:16:57 DTC Client (2131) | Shutdown and closed. | 2017-05-21 06:16:57 SC DTC Data | Disconnected from the server. | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: ZB.20160900.CME_F. ID: 1 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: ZB.20160900.CME_F. ID: 1 | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: 6E.20160900.CME_Fo. ID: 2 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: 6E.20160900.CME_Fo. ID: 2 | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6J.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: 6J.20160900.CME_Fo. ID: 3 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: 6J.20160900.CME_Fo. ID: 3 | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6B.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: 6B.20160900.CME_Fo. ID: 4 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: 6B.20160900.CME_Fo. ID: 4 | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6C.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: 6C.20160900.CME_Fo. ID: 5 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: 6C.20160900.CME_Fo. ID: 5 | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: CL.20160800.CME_NY. ID: 6 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: CL.20160800.CME_NY. ID: 6 | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6A.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: 6A.20160900.CME_Fo. ID: 7 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: 6A.20160900.CME_Fo. ID: 7 | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: NQ.20160900.CME_Eq. ID: 8 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: NQ.20160900.CME_Eq. ID: 8 | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM.######00.CME_E pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: YM.20160900.CME_E. ID: 9 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: YM.20160900.CME_E. ID: 9 | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: GC.20160800.CME_CO. ID: 10 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: GC.20160800.CME_CO. ID: 10 | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: ES.20160900.CME_Eq. ID: 11 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: ES.20160900.CME_Eq. ID: 11 | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: ZB.20170300.CME_F. ID: 12 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: ZB.20170300.CME_F. ID: 12 | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: CL.20170100.CME_NY. ID: 13 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: CL.20170100.CME_NY. ID: 13 | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: GC.20170400.CME_CO. ID: 14 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: GC.20170400.CME_CO. ID: 14 | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: ZB.20170600.CME_F. ID: 15 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: ZB.20170600.CME_F. ID: 15 | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6B.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: 6B.20170600.CME_Fo. ID: 16 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: 6B.20170600.CME_Fo. ID: 16 | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: CL.20170600.CME_NY. ID: 17 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: CL.20170600.CME_NY. ID: 17 | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The RB.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: RB.20170700.CME_NY. ID: 18 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: RB.20170700.CME_NY. ID: 18 | 2017-05-21 06:16:57 CTS T4 FIX | Using primary service for historical data for RB.20170700.CME_NY | 2017-05-21 06:16:57 Intraday data recording state for symbol RB.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:16:57 Delaying start of download for RB.20170700.CME_NY | 2017-05-21 06:16:57 CTS T4 FIX | Using primary service for historical data for 6B.20170600.CME_Fo | 2017-05-21 06:16:57 Intraday data recording state for symbol 6B.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: 6E.20170600.CME_Fo. ID: 19 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: 6E.20170600.CME_Fo. ID: 19 | 2017-05-21 06:16:57 CTS T4 FIX | Using primary service for historical data for 6E.20170600.CME_Fo | 2017-05-21 06:16:57 Intraday data recording state for symbol 6E.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM.######00.CME_E pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: YM.20170600.CME_E. ID: 20 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: YM.20170600.CME_E. ID: 20 | 2017-05-21 06:16:57 CTS T4 FIX | Using primary service for historical data for YM.20170600.CME_E | 2017-05-21 06:16:57 Intraday data recording state for symbol YM.20170600.CME_E is set to download 'Pending'. | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: ES.20170600.CME_Eq. ID: 21 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: ES.20170600.CME_Eq. ID: 21 | 2017-05-21 06:16:57 CTS T4 FIX | Using primary service for historical data for ES.20170600.CME_Eq | 2017-05-21 06:16:57 Intraday data recording state for symbol ES.20170600.CME_Eq is set to download 'Pending'. | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: CL.20170700.CME_NY. ID: 22 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: CL.20170700.CME_NY. ID: 22 | 2017-05-21 06:16:57 CTS T4 FIX | Using primary service for historical data for CL.20170700.CME_NY | 2017-05-21 06:16:57 Intraday data recording state for symbol CL.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:16:57 CTS T4 FIX | Received Account List collateral report. | 2017-05-21 06:16:57 CTS T4 FIX | Subscribing to account: May* | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6A.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: 6A.20170600.CME_Fo. ID: 23 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: 6A.20170600.CME_Fo. ID: 23 | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6C.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: 6C.20170600.CME_Fo. ID: 24 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: 6C.20170600.CME_Fo. ID: 24 | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6J.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: 6J.20170600.CME_Fo. ID: 25 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: 6J.20170600.CME_Fo. ID: 25 | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6S.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: 6S.20170600.CME_Fo. ID: 26 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: 6S.20170600.CME_Fo. ID: 26 | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: NQ.20170600.CME_Eq. ID: 27 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: NQ.20170600.CME_Eq. ID: 27 | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6N.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: 6N.20170600.CME_Fo. ID: 28 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: 6N.20170600.CME_Fo. ID: 28 | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: GC.20170600.CME_CO. ID: 29 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: GC.20170600.CME_CO. ID: 29 | 2017-05-21 06:16:57 Supported exchange: CME_CO (SIM:COMEX Futures) | 2017-05-21 06:16:57 Supported exchange: CME_EqOp (SIM:CME Equity Options) | 2017-05-21 06:16:57 Supported exchange: CME_NYOp (SIM:NYMEX Options) | 2017-05-21 06:16:57 Supported exchange: CME_AgOp (SIM:CME Agricultural Options) | 2017-05-21 06:16:57 Supported exchange: CME_Eq (SIM:CME Equity Futures) | 2017-05-21 06:16:57 Supported exchange: CME_In (SIM:CME Interest Rate Futures) | 2017-05-21 06:16:57 Supported exchange: CME_C (SIM:CBOT Commodity Futures) | 2017-05-21 06:16:57 Supported exchange: CME_KOp (SIM:KCBT Options) | 2017-05-21 06:16:57 Supported exchange: CME_F (SIM:CBOT Financial Futures) | 2017-05-21 06:16:57 Supported exchange: CME_E (SIM:CBOT Equity Futures) | 2017-05-21 06:16:57 Supported exchange: CME_COp (SIM:CBOT Commodity Options) | 2017-05-21 06:16:57 Supported exchange: CME_K (SIM:KCBT Futures) | 2017-05-21 06:16:57 Supported exchange: CME_EOp (SIM:CBOT Equity Options) | 2017-05-21 06:16:57 Supported exchange: CME_NY (SIM:NYMEX Futures) | 2017-05-21 06:16:57 Supported exchange: CME_Fo (SIM:CME Foreign Exchange Futures) | 2017-05-21 06:16:57 Supported exchange: CME_Ag (SIM:CME Agricultural Futures) | 2017-05-21 06:16:57 Supported exchange: CME_FoOp (SIM:CME Foreign Exchange Options) | 2017-05-21 06:16:57 Supported exchange: CME_FOp (SIM:CBOT Financial Options) | 2017-05-21 06:16:57 Supported exchange: CME_InOp (SIM:CME Interest Rate Options) | 2017-05-21 06:16:57 Supported exchange: CME_COOp (SIM:COMEX Options) | 2017-05-21 06:16:57 Using Bid/Ask average for last trade price for AUDJPY | 2017-05-21 06:16:57 SC DTC Data | Starting real-time market data updates for: AUDJPY. ID: 30 | 2017-05-21 06:16:57 SC DTC Data | Connecting to the server ds4.sierracharts.com. Port 443 | 2017-05-21 06:16:57 SC DTC Data | Requesting security definition data for: AUDJPY. ID: 30 | 2017-05-21 06:16:57 Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2017-05-21 06:16:57 Delaying start of download for AUDJPY | 2017-05-21 06:16:57 DTC Client (0) | Resolved address ds4.sierracharts.com to IP 192.81.56.146. | 2017-05-21 06:16:57 CTS T4 FIX | Using primary service for historical data for 6S.20170600.CME_Fo | 2017-05-21 06:16:57 Intraday data recording state for symbol 6S.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:16:57 Requesting market depth updates for: 6E.20170600.CME_Fo if supported. | 2017-05-21 06:16:57 DTC Client (2137) | Connected. | 2017-05-21 06:16:57 SC DTC Data | Connected to server. | 2017-05-21 06:16:57 SC DTC Data | Sending Encoding Request to server | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The HO.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: HO.20170700.CME_NY. ID: 31 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: HO.20170700.CME_NY. ID: 31 | 2017-05-21 06:16:57 CTS T4 FIX | Using primary service for historical data for HO.20170700.CME_NY | 2017-05-21 06:16:57 Intraday data recording state for symbol HO.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:16:57 CTS T4 FIX | Using primary service for historical data for 6C.20170600.CME_Fo | 2017-05-21 06:16:57 Intraday data recording state for symbol 6C.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The HO.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: HO.20171200.CME_NY. ID: 32 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: HO.20171200.CME_NY. ID: 32 | 2017-05-21 06:16:57 CTS T4 FIX | Using primary service for historical data for HO.20171200.CME_NY | 2017-05-21 06:16:57 Intraday data recording state for symbol HO.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:16:57 CTS T4 FIX | Using primary service for historical data for 6N.20170600.CME_Fo | 2017-05-21 06:16:57 Intraday data recording state for symbol 6N.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:16:57 HD Request # 353 | Downloading Intraday chart data for RB.20170700.CME_NY to the file RB.20170700.CME_NY.scid. Service: cts | 2017-05-21 06:16:57 HD Request # 353 | Download start date-time: 2017-05-19 16:59:53.000 | 2017-05-21 06:16:57 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The RB.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: RB.20171200.CME_NY. ID: 33 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: RB.20171200.CME_NY. ID: 33 | 2017-05-21 06:16:57 CTS T4 FIX | Using primary service for historical data for RB.20171200.CME_NY | 2017-05-21 06:16:57 Intraday data recording state for symbol RB.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:16:57 CTS T4 FIX | Using primary service for historical data for NQ.20170600.CME_Eq | 2017-05-21 06:16:57 Intraday data recording state for symbol NQ.20170600.CME_Eq is set to download 'Pending'. | 2017-05-21 06:16:57 CTS T4 FIX | Using primary service for historical data for ZB.20170600.CME_F | 2017-05-21 06:16:57 Intraday data recording state for symbol ZB.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:16:57 SC DTC Data | Setting DTC encoding to Binary VLS | 2017-05-21 06:16:57 SC DTC Data | Sending logon request message. | 2017-05-21 06:16:57 CTS T4 FIX | Using primary service for historical data for 6A.20170600.CME_Fo | 2017-05-21 06:16:57 Intraday data recording state for symbol 6A.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:16:57 CTS FIX Historical Data socket (0) | Resolved address fix-chart-sim.t4login.com to IP 74.201.6.229. | 2017-05-21 06:16:57 Requesting market depth updates for: 6B.20170600.CME_Fo if supported. | 2017-05-21 06:16:57 CTS FIX Historical Data socket (2138) | Connected. | 2017-05-21 06:16:57 CTS FIX Historical Data socket (2138) | Starting TLS 1.0 connection. | 2017-05-21 06:16:57 CTS T4 FIX | Using primary service for historical data for GC.20170600.CME_CO | 2017-05-21 06:16:57 Intraday data recording state for symbol GC.20170600.CME_CO is set to download 'Pending'. | 2017-05-21 06:16:57 Requesting market depth updates for: YM.20170600.CME_E if supported. | 2017-05-21 06:16:57 SC DTC Data | Received logon response. | 2017-05-21 06:16:57 SC DTC Data | Server Name: SC Realtime Server. | 2017-05-21 06:16:57 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2017-05-21 06:16:57 SC DTC Data | Successfully connected. | 2017-05-21 06:16:57 SC DTC Data | Trading is not supported. | 2017-05-21 06:16:57 SC DTC Data | Restarting real-time data updates for symbol: AUDJPY | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZN.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: ZN.20170600.CME_F. ID: 34 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: ZN.20170600.CME_F. ID: 34 | 2017-05-21 06:16:57 CTS T4 FIX | Using primary service for historical data for ZN.20170600.CME_F | 2017-05-21 06:16:57 Intraday data recording state for symbol ZN.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:16:57 SC DTC Data | Received security definition for symbol AUDJPY | 2017-05-21 06:16:57 CTS FIX Historical Data socket (2138) | SSL connection established. | 2017-05-21 06:16:57 CTS T4 FIX | Using primary service for historical data for 6J.20170600.CME_Fo | 2017-05-21 06:16:57 Intraday data recording state for symbol 6J.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:16:57 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:16:57 CTS T4 FIX | Starting real-time market data updates for: CL.20171200.CME_NY. ID: 35 | 2017-05-21 06:16:57 CTS T4 FIX | Requesting security definition data for: CL.20171200.CME_NY. ID: 35 | 2017-05-21 06:16:57 CTS T4 FIX | Using primary service for historical data for CL.20171200.CME_NY | 2017-05-21 06:16:57 Intraday data recording state for symbol CL.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:16:57 Requesting market depth updates for: 6J.20170600.CME_Fo if supported. | 2017-05-21 06:16:57 Requesting market depth updates for: NQ.20170600.CME_Eq if supported. | 2017-05-21 06:17:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZT.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:17:02 CTS T4 FIX | Starting real-time market data updates for: ZT.20170600.CME_F. ID: 36 | 2017-05-21 06:17:02 CTS T4 FIX | Requesting security definition data for: ZT.20170600.CME_F. ID: 36 | 2017-05-21 06:17:02 CTS T4 FIX | Using primary service for historical data for ZT.20170600.CME_F | 2017-05-21 06:17:02 Intraday data recording state for symbol ZT.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:17:02 Requesting market depth updates for: GC.20170600.CME_CO if supported. | 2017-05-21 06:17:02 CTS T4 FIX | Sending security definition request for symbol 6A.20160900.CME_Fo | 2017-05-21 06:17:02 Requesting market depth updates for: CL.20170700.CME_NY if supported. | 2017-05-21 06:17:02 Requesting market depth updates for: ZB.20170600.CME_F if supported. | 2017-05-21 06:17:02 Symbol Error - 6A.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:17:02 CTS T4 FIX | Received 0 security definitions for underlying symbol 6A | 2017-05-21 06:17:02 Requesting market depth updates for: ES.20170600.CME_Eq if supported. | 2017-05-21 06:17:02 HD Request # 354 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-05-21 06:17:02 HD Request # 354 | Download start date-time: 2017-05-19 16:57:58.000 | 2017-05-21 06:17:02 HD Request # 354 | Using server: ds4.sierracharts.com port 10149 | 2017-05-21 06:17:02 Socket (0) | Resolved address ds4.sierracharts.com to IP 192.81.56.146. | 2017-05-21 06:17:02 Socket (2139) | Connected. | 2017-05-21 06:17:02 HD Request # 354 | Setting DTC encoding to Binary VLS | 2017-05-21 06:17:02 HD Request # 354 | Sending historical data logon request message. | 2017-05-21 06:17:02 HD Request # 354 | Requesting Intraday data. Start date-time: 2017-05-19 16:57:58. Record interval: 1. Symbol: AUDJPY | 2017-05-21 06:17:02 HD Request # 354 | Decompressing data. | 2017-05-21 06:17:02 HD Request # 354 | Receiving Intraday data for AUDJPY starting at 2017-05-19 16:57:58 | 2017-05-21 06:17:02 HD Request # 354 | Timestamp of first Intraday data file record written: 2017-05-19 16:57:58 | 2017-05-21 06:17:02 Socket (2139) | Shutdown and closed. | 2017-05-21 06:17:02 The network socket for historical data has been closed. | 2017-05-21 06:17:02 HD Request # 354 | Received 1 record from 2017-05-19 16:57:58 to 2017-05-19 16:57:58 (0.0 seconds) and wrote 1 record for AUDJPY | 2017-05-21 06:17:02 HD Request # 354 | Intraday download COMPLETE for AUDJPY. Completion time: 1s. Unique request ID: 592 | 2017-05-21 06:17:02 Removed historical data download ID 592 | 2017-05-21 06:17:02 Real-time Intraday chart data file updates started for AUDJPY | 2017-05-21 06:17:02 Opened cached Intraday file: C:\SierraChart1\Data\AUDJPY.scid | 2017-05-21 06:17:02 Intraday chart data file opened for AUDJPY | 2017-05-21 06:17:02 CTS FIX Historical Data: Sending the Logon message. | 2017-05-21 06:17:02 CTS FIX Historical Data: Connected to Historical data server. | 2017-05-21 06:17:04 CTS T4 FIX | Sending security definition request for symbol 6A.20170600.CME_Fo | 2017-05-21 06:17:04 CTS T4 FIX | Received matching security definition for symbol 6A.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:17:04 CTS T4 FIX | Received 1 security definitions for underlying symbol 6A | 2017-05-21 06:17:04 Contract specifications for 6A.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:17:04 CTS T4 FIX | Received 'Account Update/Balance Data' collateral report. | 2017-05-21 06:17:04 CTS T4 FIX | Sending security definition request for symbol 6B.20160900.CME_Fo | 2017-05-21 06:17:06 Symbol Error - 6B.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:17:06 CTS T4 FIX | Received 0 security definitions for underlying symbol 6B | 2017-05-21 06:17:06 Requesting market depth updates for: 6B.20160900.CME_Fo if supported. | 2017-05-21 06:17:06 Requesting market depth updates for: 6E.20160900.CME_Fo if supported. | 2017-05-21 06:17:06 Requesting market depth updates for: 6J.20160900.CME_Fo if supported. | 2017-05-21 06:17:06 Requesting market depth updates for: 6N.20170600.CME_Fo if supported. | 2017-05-21 06:17:06 Requesting market depth updates for: CL.20160800.CME_NY if supported. | 2017-05-21 06:17:06 Requesting market depth updates for: CL.20170100.CME_NY if supported. | 2017-05-21 06:17:06 Requesting market depth updates for: CL.20170600.CME_NY if supported. | 2017-05-21 06:17:06 Requesting market depth updates for: CL.20171200.CME_NY if supported. | 2017-05-21 06:17:06 Requesting market depth updates for: ES.20160900.CME_Eq if supported. | 2017-05-21 06:17:06 Requesting market depth updates for: GC.20160800.CME_CO if supported. | 2017-05-21 06:17:06 Requesting market depth updates for: GC.20170400.CME_CO if supported. | 2017-05-21 06:17:06 Requesting market depth updates for: NQ.20160900.CME_Eq if supported. | 2017-05-21 06:17:06 Requesting market depth updates for: YM.20160900.CME_E if supported. | 2017-05-21 06:17:06 Requesting market depth updates for: ZB.20160900.CME_F if supported. | 2017-05-21 06:17:06 Requesting market depth updates for: ZB.20170300.CME_F if supported. | 2017-05-21 06:17:06 CTS T4 FIX | Requesting Open Orders for account: May*. Request ID: 9498523 | 2017-05-21 06:17:06 CTS T4 FIX | No open orders for account May18CCwmitchel | 2017-05-21 06:17:06 CTS T4 FIX | Sending security definition request for symbol 6B.20170600.CME_Fo | 2017-05-21 06:17:07 CTS T4 FIX | Received matching security definition for symbol 6B.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:17:07 CTS T4 FIX | Received 1 security definitions for underlying symbol 6B | 2017-05-21 06:17:07 Contract specifications for 6B.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 6.25 | 2017-05-21 06:17:07 CTS T4 FIX | Sending security definition request for symbol 6C.20160900.CME_Fo | 2017-05-21 06:17:09 Symbol Error - 6C.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:17:09 CTS T4 FIX | Received 0 security definitions for underlying symbol 6C | 2017-05-21 06:17:09 CTS T4 FIX | Sending security definition request for symbol 6C.20170600.CME_Fo | 2017-05-21 06:17:10 CTS T4 FIX | Received matching security definition for symbol 6C.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:17:10 CTS T4 FIX | Received 1 security definitions for underlying symbol 6C | 2017-05-21 06:17:10 Contract specifications for 6C.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 5 | 2017-05-21 06:17:10 CTS T4 FIX | Sending security definition request for symbol 6E.20160900.CME_Fo | 2017-05-21 06:17:12 Symbol Error - 6E.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:17:12 CTS T4 FIX | Received 0 security definitions for underlying symbol 6E | 2017-05-21 06:17:12 CTS T4 FIX | Sending security definition request for symbol 6E.20170600.CME_Fo | 2017-05-21 06:17:14 CTS T4 FIX | Received matching security definition for symbol 6E.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:17:14 CTS T4 FIX | Received 1 security definitions for underlying symbol 6E | 2017-05-21 06:17:14 Contract specifications for 6E.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-05-21 06:17:14 CTS T4 FIX | Sending security definition request for symbol 6J.20160900.CME_Fo | 2017-05-21 06:17:15 Symbol Error - 6J.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:17:15 CTS T4 FIX | Received 0 security definitions for underlying symbol 6J | 2017-05-21 06:17:15 CTS T4 FIX | Requesting historical Fills for account: May*. Request ID: 9498527 | 2017-05-21 06:17:17 CTS T4 FIX | Received Account List collateral report. | 2017-05-21 06:17:17 CTS T4 FIX | Server provided no historical order fills for account 1A297B51-A416-42D4-A1C8-C9B1B4125155 | 2017-05-21 06:17:17 CTS T4 FIX | Sending security definition request for symbol 6J.20170600.CME_Fo | 2017-05-21 06:17:18 CTS T4 FIX | Received matching security definition for symbol 6J.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:17:18 CTS T4 FIX | Received 1 security definitions for underlying symbol 6J | 2017-05-21 06:17:18 Contract specifications for 6J.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-05-21 06:17:18 CTS T4 FIX | Sending security definition request for symbol 6N.20170600.CME_Fo | 2017-05-21 06:17:20 CTS T4 FIX | Received matching security definition for symbol 6N.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:17:20 CTS T4 FIX | Received 1 security definitions for underlying symbol 6N | 2017-05-21 06:17:20 Contract specifications for 6N.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:17:20 CTS T4 FIX | Sending security definition request for symbol 6S.20170600.CME_Fo | 2017-05-21 06:17:21 CTS T4 FIX | Received matching security definition for symbol 6S.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:17:21 CTS T4 FIX | Received 1 security definitions for underlying symbol 6S | 2017-05-21 06:17:21 Contract specifications for 6S.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 12.5 | 2017-05-21 06:17:21 CTS T4 FIX | Sending security definition request for symbol CL.20160800.CME_NY | 2017-05-21 06:17:23 Symbol Error - CL.20160800.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:17:23 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2017-05-21 06:17:23 CTS T4 FIX | Sending security definition request for symbol CL.20170100.CME_NY | 2017-05-21 06:17:26 Symbol Error - CL.20170100.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:17:26 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2017-05-21 06:17:26 CTS T4 FIX | Sending security definition request for symbol CL.20170600.CME_NY | 2017-05-21 06:17:27 CTS T4 FIX | Received matching security definition for symbol CL.20170600.CME_NY. Subscribing to data. | 2017-05-21 06:17:27 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:17:27 Contract specifications for CL.20170600.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:17:27 CTS T4 FIX | Sending security definition request for symbol CL.20170700.CME_NY | 2017-05-21 06:17:29 CTS T4 FIX | Received matching security definition for symbol CL.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:17:29 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:17:29 Contract specifications for CL.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:17:29 CTS T4 FIX | Sending security definition request for symbol CL.20171200.CME_NY | 2017-05-21 06:17:29 CTS T4 FIX | Received matching security definition for symbol CL.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:17:31 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:17:31 Contract specifications for CL.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:17:31 CTS T4 FIX | Sending security definition request for symbol ES.20160900.CME_Eq | 2017-05-21 06:17:31 Symbol Error - ES.20160900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:17:32 CTS T4 FIX | Received 0 security definitions for underlying symbol ES | 2017-05-21 06:17:32 CTS T4 FIX | Sending security definition request for symbol ES.20170600.CME_Eq | 2017-05-21 06:17:32 CTS T4 FIX | Received matching security definition for symbol ES.20170600.CME_Eq. Subscribing to data. | 2017-05-21 06:17:34 CTS T4 FIX | Received 1 security definitions for underlying symbol ES | 2017-05-21 06:17:34 Contract specifications for ES.20170600.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 12.5 | 2017-05-21 06:17:34 CTS T4 FIX | Sending security definition request for symbol GC.20160800.CME_CO | 2017-05-21 06:17:34 Symbol Error - GC.20160800.CME_CO is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:17:35 CTS T4 FIX | Received 0 security definitions for underlying symbol GC | 2017-05-21 06:17:35 CTS T4 FIX | Sending security definition request for symbol GC.20170400.CME_CO | 2017-05-21 06:17:35 Symbol Error - GC.20170400.CME_CO is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:17:36 CTS T4 FIX | Received 0 security definitions for underlying symbol GC | 2017-05-21 06:17:36 CTS T4 FIX | Sending security definition request for symbol GC.20170600.CME_CO | 2017-05-21 06:17:36 CTS T4 FIX | Received matching security definition for symbol GC.20170600.CME_CO. Subscribing to data. | 2017-05-21 06:17:38 CTS T4 FIX | Received 1 security definitions for underlying symbol GC | 2017-05-21 06:17:38 Contract specifications for GC.20170600.CME_CO. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:17:38 CTS T4 FIX | Sending security definition request for symbol HO.20170700.CME_NY | 2017-05-21 06:17:39 CTS T4 FIX | Received matching security definition for symbol HO.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:17:39 CTS T4 FIX | Received 1 security definitions for underlying symbol HO | 2017-05-21 06:17:39 Contract specifications for HO.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:17:39 CTS T4 FIX | Sending security definition request for symbol HO.20171200.CME_NY | 2017-05-21 06:17:41 CTS T4 FIX | Received matching security definition for symbol HO.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:17:41 CTS T4 FIX | Received 1 security definitions for underlying symbol HO | 2017-05-21 06:17:41 Contract specifications for HO.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:17:41 CTS T4 FIX | Sending security definition request for symbol NQ.20160900.CME_Eq | 2017-05-21 06:17:42 Symbol Error - NQ.20160900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:17:42 CTS T4 FIX | Received 0 security definitions for underlying symbol NQ | 2017-05-21 06:17:42 CTS T4 FIX | Sending security definition request for symbol NQ.20170600.CME_Eq | 2017-05-21 06:17:44 CTS T4 FIX | Received matching security definition for symbol NQ.20170600.CME_Eq. Subscribing to data. | 2017-05-21 06:17:44 CTS T4 FIX | Received 1 security definitions for underlying symbol NQ | 2017-05-21 06:17:44 Contract specifications for NQ.20170600.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 5 | 2017-05-21 06:17:44 CTS T4 FIX | Sending security definition request for symbol RB.20170700.CME_NY | 2017-05-21 06:17:45 CTS T4 FIX | Received matching security definition for symbol RB.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:17:45 CTS T4 FIX | Received matching security definition for symbol RB.20170700.CME_NY. Requesting historical data. | 2017-05-21 06:17:45 HD Request # 353 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:17:45 CTS T4 FIX | Received 1 security definitions for underlying symbol RB | 2017-05-21 06:17:45 Contract specifications for RB.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:17:45 HD Request # 353 | Receiving Intraday data for RB.20170700.CME_NY starting at 2017-05-18 18:00:00 | 2017-05-21 06:17:45 HD Request # 353 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:53 | 2017-05-21 06:17:45 HD Request # 353 | Total records received: 7454 | 2017-05-21 06:17:45 HD Request # 353 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:17:45 HD Request # 353 | Total records received: 7454 | 2017-05-21 06:17:47 HD Request # 353 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:17:47 HD Request # 353 | Total records received: 7454 | 2017-05-21 06:17:47 HD Request # 353 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:17:47 CTS T4 FIX | Sending security definition request for symbol RB.20171200.CME_NY | 2017-05-21 06:17:47 CTS T4 FIX | Received matching security definition for symbol RB.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:17:47 CTS T4 FIX | Received 1 security definitions for underlying symbol RB | 2017-05-21 06:17:47 HD Request # 353 | Total records received: 7454 | 2017-05-21 06:17:47 HD Request # 353 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:17:47 Contract specifications for RB.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:17:47 HD Request # 353 | Received 7454 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:53 (23.0 hours) and wrote 1 record for RB.20170700.CME_NY | 2017-05-21 06:17:47 HD Request # 353 | Intraday download COMPLETE for RB.20170700.CME_NY. Completion time: 47s. Unique request ID: 586 | 2017-05-21 06:17:47 Removed historical data download ID 586 | 2017-05-21 06:17:47 Real-time Intraday chart data file updates started for RB.20170700.CME_NY | 2017-05-21 06:17:47 Opened cached Intraday file: C:\SierraChart1\Data\RB.20170700.CME_NY.scid | 2017-05-21 06:17:47 Intraday chart data file opened for RB.20170700.CME_NY | 2017-05-21 06:17:47 Delaying start of download for 6B.20170600.CME_Fo | 2017-05-21 06:17:47 Chart #22 has tagged chart #16 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:17:47 CTS T4 FIX | Sending security definition request for symbol YM.20160900.CME_E | 2017-05-21 06:17:48 Symbol Error - YM.20160900.CME_E is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:17:48 CTS T4 FIX | Received 0 security definitions for underlying symbol YM | 2017-05-21 06:17:48 Chart #18 has tagged chart #16 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:17:48 CL.20170700.CME_NY 3 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:17:48 Chart #16 has tagged chart #15 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:17:48 Chart #21 has tagged chart #9 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:17:48 CTS T4 FIX | Sending security definition request for symbol YM.20170600.CME_E | 2017-05-21 06:17:50 CL.20170700.CME_NY 30 Sec #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:17:50 CTS T4 FIX | Received matching security definition for symbol YM.20170600.CME_E. Subscribing to data. | 2017-05-21 06:17:50 CTS T4 FIX | Received 1 security definitions for underlying symbol YM | 2017-05-21 06:17:50 6C.20170600.CME_Fo 3 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:17:50 Contract specifications for YM.20170600.CME_E. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 5 | 2017-05-21 06:17:50 CL.20170700.CME_NY [C] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:17:50 Chart #9 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:17:50 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:17:50 CTS T4 FIX | Sending security definition request for symbol ZB.20160900.CME_F | 2017-05-21 06:17:52 Symbol Error - ZB.20160900.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:17:52 CTS T4 FIX | Received 0 security definitions for underlying symbol ZB | 2017-05-21 06:17:52 CTS T4 FIX | Sending security definition request for symbol ZB.20170300.CME_F | 2017-05-21 06:17:54 Symbol Error - ZB.20170300.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:17:54 CTS T4 FIX | Received 0 security definitions for underlying symbol ZB | 2017-05-21 06:17:54 CTS T4 FIX | Sending security definition request for symbol ZB.20170600.CME_F | 2017-05-21 06:17:55 CTS T4 FIX | Received matching security definition for symbol ZB.20170600.CME_F. Subscribing to data. | 2017-05-21 06:17:55 CTS T4 FIX | Received 1 security definitions for underlying symbol ZB | 2017-05-21 06:17:55 Contract specifications for ZB.20170600.CME_F. Multiplier: 0.00001000. Tick Size: 0.03125. Value Format: 132. Currency Value per Tick: 31.25 | 2017-05-21 06:17:55 CTS T4 FIX | Sending security definition request for symbol ZN.20170600.CME_F | 2017-05-21 06:17:56 CTS T4 FIX | Received matching security definition for symbol ZN.20170600.CME_F. Subscribing to data. | 2017-05-21 06:17:56 CTS T4 FIX | Received 1 security definitions for underlying symbol ZN | 2017-05-21 06:17:56 Contract specifications for ZN.20170600.CME_F. Multiplier: 0.00000100. Tick Size: 0.015625. Value Format: 132. Currency Value per Tick: 15.625 | 2017-05-21 06:17:58 CTS T4 FIX | Sending security definition request for symbol ZT.20170600.CME_F | 2017-05-21 06:17:58 CTS T4 FIX | Received matching security definition for symbol ZT.20170600.CME_F. Subscribing to data. | 2017-05-21 06:17:58 CTS T4 FIX | Received 1 security definitions for underlying symbol ZT | 2017-05-21 06:17:58 Contract specifications for ZT.20170600.CME_F. Multiplier: 0.00000010. Tick Size: 0.0078125. Value Format: 228. Currency Value per Tick: 15.625 | 2017-05-21 06:17:59 HD Request # 355 | Downloading Intraday chart data for 6B.20170600.CME_Fo to the file 6B.20170600.CME_Fo.scid. Service: cts | 2017-05-21 06:18:11 HD Request # 355 | Download start date-time: 2017-05-19 16:59:54.000 | 2017-05-21 06:18:11 HD Request # 355 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:18:11 HD Request # 355 | Receiving Intraday data for 6B.20170600.CME_Fo starting at 2017-05-18 18:00:00 | 2017-05-21 06:18:11 HD Request # 355 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:54 | 2017-05-21 06:18:11 HD Request # 355 | Total records received: 8374 | 2017-05-21 06:18:11 HD Request # 355 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:18:11 HD Request # 355 | Total records received: 8374 | 2017-05-21 06:18:11 HD Request # 355 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:18:11 HD Request # 355 | Total records received: 8374 | 2017-05-21 06:18:12 HD Request # 355 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:18:12 HD Request # 355 | Total records received: 8374 | 2017-05-21 06:18:12 HD Request # 355 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:18:12 HD Request # 355 | Received 8374 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:54 (23.0 hours) and wrote 1 record for 6B.20170600.CME_Fo | 2017-05-21 06:18:12 HD Request # 355 | Intraday download COMPLETE for 6B.20170600.CME_Fo. Completion time: 2s. Unique request ID: 587 | 2017-05-21 06:18:12 Removed historical data download ID 587 | 2017-05-21 06:18:12 Real-time Intraday chart data file updates started for 6B.20170600.CME_Fo | 2017-05-21 06:18:12 Opened cached Intraday file: C:\SierraChart1\Data\6B.20170600.CME_Fo.scid | 2017-05-21 06:18:12 Intraday chart data file opened for 6B.20170600.CME_Fo | 2017-05-21 06:18:12 Delaying start of download for 6E.20170600.CME_Fo | 2017-05-21 06:18:12 Chart #12 has tagged chart #8 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:18:12 6A.20170600.CME_Fo 3 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:18:12 Chart #12 has tagged chart #8 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:18:14 6A.20170600.CME_Fo 3 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:18:16 HD Request # 356 | Downloading Intraday chart data for 6E.20170600.CME_Fo to the file 6E.20170600.CME_Fo.scid. Service: cts | 2017-05-21 06:18:34 HD Request # 356 | Download start date-time: 2017-05-19 16:59:58.000 | 2017-05-21 06:18:34 HD Request # 356 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:18:34 HD Request # 356 | Receiving Intraday data for 6E.20170600.CME_Fo starting at 2017-05-18 18:00:00 | 2017-05-21 06:18:35 HD Request # 356 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:58 | 2017-05-21 06:18:35 HD Request # 356 | Total records received: 17398 | 2017-05-21 06:18:35 HD Request # 356 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:18:35 HD Request # 356 | Total records received: 17398 | 2017-05-21 06:18:35 HD Request # 356 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:18:35 HD Request # 356 | Total records received: 17398 | 2017-05-21 06:18:35 HD Request # 356 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:18:35 HD Request # 356 | Total records received: 17398 | 2017-05-21 06:18:35 HD Request # 356 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:18:35 HD Request # 356 | Received 17398 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:58 (23.0 hours) and wrote 1 record for 6E.20170600.CME_Fo | 2017-05-21 06:18:37 HD Request # 356 | Intraday download COMPLETE for 6E.20170600.CME_Fo. Completion time: 2s. Unique request ID: 588 | 2017-05-21 06:18:37 Removed historical data download ID 588 | 2017-05-21 06:18:37 Real-time Intraday chart data file updates started for 6E.20170600.CME_Fo | 2017-05-21 06:18:37 Opened cached Intraday file: C:\SierraChart1\Data\6E.20170600.CME_Fo.scid | 2017-05-21 06:18:37 Intraday chart data file opened for 6E.20170600.CME_Fo | 2017-05-21 06:18:37 Delaying start of download for YM.20170600.CME_E | 2017-05-21 06:18:37 Chart #15 has tagged chart #4 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:18:37 6B.20170600.CME_Fo 30 Sec #4 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:18:37 HD Request # 357 | Downloading Intraday chart data for YM.20170600.CME_E to the file YM.20170600.CME_E.scid. Service: cts | 2017-05-21 06:18:59 HD Request # 357 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:18:59 HD Request # 357 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:18:59 HD Request # 357 | Receiving Intraday data for YM.20170600.CME_E starting at 2017-05-18 18:00:00 | 2017-05-21 06:19:01 HD Request # 357 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:19:01 HD Request # 357 | Total records received: 19680 | 2017-05-21 06:19:01 HD Request # 357 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:19:01 HD Request # 357 | Total records received: 19680 | 2017-05-21 06:19:01 HD Request # 357 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:19:01 HD Request # 357 | Total records received: 19680 | 2017-05-21 06:19:01 HD Request # 357 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:19:01 HD Request # 357 | Total records received: 19680 | 2017-05-21 06:19:01 HD Request # 357 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:19:01 HD Request # 357 | Received 19680 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for YM.20170600.CME_E | 2017-05-21 06:19:01 HD Request # 357 | Intraday download COMPLETE for YM.20170600.CME_E. Completion time: 3s. Unique request ID: 589 | 2017-05-21 06:19:01 Removed historical data download ID 589 | 2017-05-21 06:19:01 Real-time Intraday chart data file updates started for YM.20170600.CME_E | 2017-05-21 06:19:01 Opened cached Intraday file: C:\SierraChart1\Data\YM.20170600.CME_E.scid | 2017-05-21 06:19:01 Intraday chart data file opened for YM.20170600.CME_E | 2017-05-21 06:19:01 Delaying start of download for ES.20170600.CME_Eq | 2017-05-21 06:19:01 Chart #3 has tagged chart #4 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:19:02 ZB.20170600.CME_F 3 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:19:04 CTS FIX Historical Data socket (2138) | Closed. No error. | 2017-05-21 06:20:01 CTS FIX Historical Data socket (2138) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-21 06:20:01 CTS FIX Historical Data socket (2138) | SSL has been shut down. | 2017-05-21 06:20:01 CTS FIX Historical Data socket (2138) | SSL object has been freed. SSL state is now disconnected. | 2017-05-21 06:20:01 CTS FIX Historical Data socket (2138) | Shutdown and closed. | 2017-05-21 06:20:01 CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2017-05-21 06:20:01 CTS FIX Historical Data: Disconnected. | 2017-05-21 06:20:01 HD Request # 358 | Downloading Intraday chart data for ES.20170600.CME_Eq to the file ES.20170600.CME_Eq.scid. Service: cts | 2017-05-21 06:20:18 HD Request # 358 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:20:18 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2017-05-21 06:20:18 CTS FIX Historical Data socket (0) | Resolved address fix-chart-sim.t4login.com to IP 74.201.6.229. | 2017-05-21 06:20:18 CTS FIX Historical Data socket (2141) | Connected. | 2017-05-21 06:20:18 CTS FIX Historical Data socket (2141) | Starting TLS 1.0 connection. | 2017-05-21 06:20:18 CTS FIX Historical Data socket (2141) | SSL connection established. | 2017-05-21 06:20:20 CTS FIX Historical Data: Sending the Logon message. | 2017-05-21 06:20:21 CTS FIX Historical Data: Connected to Historical data server. | 2017-05-21 06:20:21 HD Request # 358 | Requesting historical Second data for ES.20170600.CME_Eq from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:20:21 HD Request # 358 | Receiving Intraday data for ES.20170600.CME_Eq starting at 2017-05-18 18:00:00 | 2017-05-21 06:20:23 HD Request # 358 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:20:23 HD Request # 358 | Total records received: 27907 | 2017-05-21 06:20:23 HD Request # 358 | Requesting historical Second data for ES.20170600.CME_Eq from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:20:23 HD Request # 358 | Total records received: 27907 | 2017-05-21 06:20:23 HD Request # 358 | Requesting historical Second data for ES.20170600.CME_Eq from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:20:23 HD Request # 358 | Total records received: 27907 | 2017-05-21 06:20:23 HD Request # 358 | Requesting historical Second data for ES.20170600.CME_Eq from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:20:23 HD Request # 358 | Total records received: 27907 | 2017-05-21 06:20:23 HD Request # 358 | Requesting historical Second data for ES.20170600.CME_Eq from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:20:23 HD Request # 358 | Received 27907 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for ES.20170600.CME_Eq | 2017-05-21 06:20:24 HD Request # 358 | Intraday download COMPLETE for ES.20170600.CME_Eq. Completion time: 5s. Unique request ID: 590 | 2017-05-21 06:20:24 Removed historical data download ID 590 | 2017-05-21 06:20:24 Real-time Intraday chart data file updates started for ES.20170600.CME_Eq | 2017-05-21 06:20:24 Opened cached Intraday file: C:\SierraChart1\Data\ES.20170600.CME_Eq.scid | 2017-05-21 06:20:24 Intraday chart data file opened for ES.20170600.CME_Eq | 2017-05-21 06:20:24 Delaying start of download for CL.20170700.CME_NY | 2017-05-21 06:20:24 Chart #17 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:20:24 Chart #17 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:20:24 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:20:24 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:20:24 Chart #17 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:20:24 Chart #17 has tagged chart #1 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:20:24 Chart #17 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:20:24 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:20:24 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:20:24 Chart #17 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:20:24 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:20:24 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:20:24 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:20:24 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:20:24 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:20:24 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:20:24 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:20:24 GC.20170600.CME_CO 3 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:20:24 Chart #1 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:20:24 Chart #1 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:20:24 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:20:24 6J.20170600.CME_Fo 3 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:20:24 Chart #14 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:20:24 ZB.20170600.CME_F 3 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:20:24 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:20:24 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:20:24 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:20:24 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:20:24 6J.20170600.CME_Fo 30 Sec #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:20:24 NQ.20170600.CME_Eq 30 Sec #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:20:29 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:20:29 GC.20170600.CME_CO 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:20:29 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:20:29 ZB.20170600.CME_F 30 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:20:29 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:20:29 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:20:29 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:20:29 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:20:29 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:20:29 HD Request # 359 | Downloading Intraday chart data for CL.20170700.CME_NY to the file CL.20170700.CME_NY.scid. Service: cts | 2017-05-21 06:20:52 HD Request # 359 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:20:52 HD Request # 359 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:20:52 HD Request # 359 | Receiving Intraday data for CL.20170700.CME_NY starting at 2017-05-18 18:00:00 | 2017-05-21 06:20:53 HD Request # 359 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:20:53 HD Request # 359 | Total records received: 33722 | 2017-05-21 06:20:53 HD Request # 359 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:20:53 HD Request # 359 | Total records received: 33722 | 2017-05-21 06:20:53 HD Request # 359 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:20:53 HD Request # 359 | Total records received: 33722 | 2017-05-21 06:20:55 HD Request # 359 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:20:55 HD Request # 359 | Total records received: 33722 | 2017-05-21 06:20:55 HD Request # 359 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:20:55 HD Request # 359 | Received 33722 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for CL.20170700.CME_NY | 2017-05-21 06:20:55 HD Request # 359 | Intraday download COMPLETE for CL.20170700.CME_NY. Completion time: 4s. Unique request ID: 591 | 2017-05-21 06:20:55 Removed historical data download ID 591 | 2017-05-21 06:20:55 Real-time Intraday chart data file updates started for CL.20170700.CME_NY | 2017-05-21 06:20:55 Opened cached Intraday file: C:\SierraChart1\Data\CL.20170700.CME_NY.scid | 2017-05-21 06:20:55 Intraday chart data file opened for CL.20170700.CME_NY | 2017-05-21 06:20:55 Delaying start of download for 6S.20170600.CME_Fo | 2017-05-21 06:20:55 Chart #16 has tagged chart #15 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:20:55 Chart #3 has tagged chart #1 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:20:57 Chart #3 has tagged chart #4 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:20:57 Chart #3 has tagged chart #5 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:20:57 Chart #3 has tagged chart #8 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:20:57 CL.20170700.CME_NY 30 Sec #4 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:20:57 CL.20170700.CME_NY 3 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:20:57 CTS FIX socket (2136) | Closed. No error. | 2017-05-21 06:20:57 CTS FIX socket (2136) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-21 06:20:57 CTS FIX socket (2136) | SSL has been shut down. | 2017-05-21 06:20:57 CTS FIX socket (2136) | SSL object has been freed. SSL state is now disconnected. | 2017-05-21 06:20:57 CTS FIX socket (2136) | Shutdown and closed. | 2017-05-21 06:20:57 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2017-05-21 06:20:57 Connection to the external service has been lost. | 2017-05-21 06:20:57 Chart #9 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:20:57 CL.20170700.CME_NY 3 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:20:57 CL.20170700.CME_NY 3 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:20:57 6C.20170600.CME_Fo 3 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:20:57 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:20:57 Canceling historical data download request for 6S.20170600.CME_Fo Intraday data. | 2017-05-21 06:21:55 Removed historical data download ID 593 | 2017-05-21 06:21:55 Canceling historical data download request for HO.20170700.CME_NY Intraday data. | 2017-05-21 06:21:55 Removed historical data download ID 594 | 2017-05-21 06:21:55 Canceling historical data download request for 6C.20170600.CME_Fo Intraday data. | 2017-05-21 06:21:55 Removed historical data download ID 595 | 2017-05-21 06:21:55 Canceling historical data download request for HO.20171200.CME_NY Intraday data. | 2017-05-21 06:21:55 Removed historical data download ID 596 | 2017-05-21 06:21:55 Canceling historical data download request for 6N.20170600.CME_Fo Intraday data. | 2017-05-21 06:21:55 Removed historical data download ID 597 | 2017-05-21 06:21:55 Canceling historical data download request for RB.20171200.CME_NY Intraday data. | 2017-05-21 06:21:55 Removed historical data download ID 598 | 2017-05-21 06:21:55 Canceling historical data download request for NQ.20170600.CME_Eq Intraday data. | 2017-05-21 06:21:55 Removed historical data download ID 599 | 2017-05-21 06:21:55 Canceling historical data download request for ZB.20170600.CME_F Intraday data. | 2017-05-21 06:21:55 Removed historical data download ID 600 | 2017-05-21 06:21:55 Canceling historical data download request for 6A.20170600.CME_Fo Intraday data. | 2017-05-21 06:21:55 Removed historical data download ID 601 | 2017-05-21 06:21:55 Canceling historical data download request for GC.20170600.CME_CO Intraday data. | 2017-05-21 06:21:55 Removed historical data download ID 602 | 2017-05-21 06:21:55 Canceling historical data download request for ZN.20170600.CME_F Intraday data. | 2017-05-21 06:21:55 Removed historical data download ID 603 | 2017-05-21 06:21:55 Canceling historical data download request for 6J.20170600.CME_Fo Intraday data. | 2017-05-21 06:21:55 Removed historical data download ID 604 | 2017-05-21 06:21:55 Canceling historical data download request for CL.20171200.CME_NY Intraday data. | 2017-05-21 06:21:55 Removed historical data download ID 605 | 2017-05-21 06:21:55 Canceling historical data download request for ZT.20170600.CME_F Intraday data. | 2017-05-21 06:21:55 Removed historical data download ID 606 | 2017-05-21 06:21:55 CTS FIX Historical Data: DisconnectFIX called. | 2017-05-21 06:21:55 CTS FIX Historical Data: Sending a Logout message. | 2017-05-21 06:21:55 CTS T4 FIX | Disconnected. | 2017-05-21 06:21:55 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-21 06:21:55 CTS FIX Historical Data socket (2141) | Closed. No error. | 2017-05-21 06:21:55 CTS FIX Historical Data: Received a Logout message. Text = Successful logout upon request | 2017-05-21 06:21:55 CTS FIX Historical Data socket (2141) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-21 06:21:55 CTS FIX Historical Data socket (2141) | SSL has been shut down. | 2017-05-21 06:21:55 CTS FIX Historical Data socket (2141) | SSL object has been freed. SSL state is now disconnected. | 2017-05-21 06:21:55 CTS FIX Historical Data socket (2141) | Shutdown and closed. | 2017-05-21 06:21:55 CTS FIX Historical Data: Disconnected. | 2017-05-21 06:21:55 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2017-05-21 06:21:59 CTS T4 FIX | Firm: PTP | 2017-05-21 06:21:59 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199. | 2017-05-21 06:21:59 CTS FIX socket (2143) | Connected. | 2017-05-21 06:21:59 CTS FIX socket (2143) | Starting TLS 1.0 connection. | 2017-05-21 06:21:59 CTS FIX socket (2143) | SSL connection established. | 2017-05-21 06:21:59 CTS FIX: Sending the Logon message. | 2017-05-21 06:22:02 CTS T4 FIX | FIX version: 4.3.74.0 | 2017-05-21 06:22:02 CTS T4 FIX | Connected to data and trading server. | 2017-05-21 06:22:02 DTC Client (2137) | Shutdown and closed. | 2017-05-21 06:22:02 SC DTC Data | Disconnected from the server. | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: ZB.20160900.CME_F. ID: 1 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: ZB.20160900.CME_F. ID: 1 | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: 6E.20160900.CME_Fo. ID: 2 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: 6E.20160900.CME_Fo. ID: 2 | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6J.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: 6J.20160900.CME_Fo. ID: 3 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: 6J.20160900.CME_Fo. ID: 3 | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6B.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: 6B.20160900.CME_Fo. ID: 4 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: 6B.20160900.CME_Fo. ID: 4 | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6C.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: 6C.20160900.CME_Fo. ID: 5 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: 6C.20160900.CME_Fo. ID: 5 | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: CL.20160800.CME_NY. ID: 6 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: CL.20160800.CME_NY. ID: 6 | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6A.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: 6A.20160900.CME_Fo. ID: 7 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: 6A.20160900.CME_Fo. ID: 7 | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: NQ.20160900.CME_Eq. ID: 8 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: NQ.20160900.CME_Eq. ID: 8 | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM.######00.CME_E pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: YM.20160900.CME_E. ID: 9 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: YM.20160900.CME_E. ID: 9 | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: GC.20160800.CME_CO. ID: 10 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: GC.20160800.CME_CO. ID: 10 | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: ES.20160900.CME_Eq. ID: 11 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: ES.20160900.CME_Eq. ID: 11 | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: ZB.20170300.CME_F. ID: 12 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: ZB.20170300.CME_F. ID: 12 | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: CL.20170100.CME_NY. ID: 13 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: CL.20170100.CME_NY. ID: 13 | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: GC.20170400.CME_CO. ID: 14 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: GC.20170400.CME_CO. ID: 14 | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: ZB.20170600.CME_F. ID: 15 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: ZB.20170600.CME_F. ID: 15 | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6B.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: 6B.20170600.CME_Fo. ID: 16 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: 6B.20170600.CME_Fo. ID: 16 | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: CL.20170600.CME_NY. ID: 17 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: CL.20170600.CME_NY. ID: 17 | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The RB.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: RB.20170700.CME_NY. ID: 18 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: RB.20170700.CME_NY. ID: 18 | 2017-05-21 06:22:02 CTS T4 FIX | Using primary service for historical data for RB.20170700.CME_NY | 2017-05-21 06:22:02 Intraday data recording state for symbol RB.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:22:02 Delaying start of download for RB.20170700.CME_NY | 2017-05-21 06:22:02 CTS T4 FIX | Using primary service for historical data for 6B.20170600.CME_Fo | 2017-05-21 06:22:02 Intraday data recording state for symbol 6B.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: 6E.20170600.CME_Fo. ID: 19 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: 6E.20170600.CME_Fo. ID: 19 | 2017-05-21 06:22:02 CTS T4 FIX | Using primary service for historical data for 6E.20170600.CME_Fo | 2017-05-21 06:22:02 Intraday data recording state for symbol 6E.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM.######00.CME_E pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: YM.20170600.CME_E. ID: 20 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: YM.20170600.CME_E. ID: 20 | 2017-05-21 06:22:02 CTS T4 FIX | Using primary service for historical data for YM.20170600.CME_E | 2017-05-21 06:22:02 Intraday data recording state for symbol YM.20170600.CME_E is set to download 'Pending'. | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: ES.20170600.CME_Eq. ID: 21 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: ES.20170600.CME_Eq. ID: 21 | 2017-05-21 06:22:02 CTS T4 FIX | Using primary service for historical data for ES.20170600.CME_Eq | 2017-05-21 06:22:02 Intraday data recording state for symbol ES.20170600.CME_Eq is set to download 'Pending'. | 2017-05-21 06:22:02 Using Bid/Ask average for last trade price for AUDJPY | 2017-05-21 06:22:02 SC DTC Data | Starting real-time market data updates for: AUDJPY. ID: 22 | 2017-05-21 06:22:02 SC DTC Data | Connecting to the server ds3.sierracharts.com. Port 10048 | 2017-05-21 06:22:02 SC DTC Data | Requesting security definition data for: AUDJPY. ID: 22 | 2017-05-21 06:22:02 Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2017-05-21 06:22:02 DTC Client (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2017-05-21 06:22:02 Delaying start of download for AUDJPY | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6S.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: 6S.20170600.CME_Fo. ID: 23 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: 6S.20170600.CME_Fo. ID: 23 | 2017-05-21 06:22:02 CTS T4 FIX | Using primary service for historical data for 6S.20170600.CME_Fo | 2017-05-21 06:22:02 Intraday data recording state for symbol 6S.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:22:02 Requesting market depth updates for: 6E.20170600.CME_Fo if supported. | 2017-05-21 06:22:02 DTC Client (2144) | Connected. | 2017-05-21 06:22:02 SC DTC Data | Connected to server. | 2017-05-21 06:22:02 SC DTC Data | Sending Encoding Request to server | 2017-05-21 06:22:02 CTS T4 FIX | Received Account List collateral report. | 2017-05-21 06:22:02 CTS T4 FIX | Subscribing to account: May* | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The HO.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: HO.20170700.CME_NY. ID: 24 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: HO.20170700.CME_NY. ID: 24 | 2017-05-21 06:22:02 CTS T4 FIX | Using primary service for historical data for HO.20170700.CME_NY | 2017-05-21 06:22:02 Intraday data recording state for symbol HO.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:22:02 Supported exchange: CME_CO (SIM:COMEX Futures) | 2017-05-21 06:22:02 Supported exchange: CME_EqOp (SIM:CME Equity Options) | 2017-05-21 06:22:02 Supported exchange: CME_NYOp (SIM:NYMEX Options) | 2017-05-21 06:22:02 Supported exchange: CME_AgOp (SIM:CME Agricultural Options) | 2017-05-21 06:22:02 Supported exchange: CME_Eq (SIM:CME Equity Futures) | 2017-05-21 06:22:02 Supported exchange: CME_In (SIM:CME Interest Rate Futures) | 2017-05-21 06:22:02 Supported exchange: CME_C (SIM:CBOT Commodity Futures) | 2017-05-21 06:22:02 Supported exchange: CME_KOp (SIM:KCBT Options) | 2017-05-21 06:22:02 Supported exchange: CME_F (SIM:CBOT Financial Futures) | 2017-05-21 06:22:02 Supported exchange: CME_E (SIM:CBOT Equity Futures) | 2017-05-21 06:22:02 Supported exchange: CME_COp (SIM:CBOT Commodity Options) | 2017-05-21 06:22:02 Supported exchange: CME_K (SIM:KCBT Futures) | 2017-05-21 06:22:02 Supported exchange: CME_EOp (SIM:CBOT Equity Options) | 2017-05-21 06:22:02 Supported exchange: CME_NY (SIM:NYMEX Futures) | 2017-05-21 06:22:02 Supported exchange: CME_Fo (SIM:CME Foreign Exchange Futures) | 2017-05-21 06:22:02 Supported exchange: CME_Ag (SIM:CME Agricultural Futures) | 2017-05-21 06:22:02 Supported exchange: CME_FoOp (SIM:CME Foreign Exchange Options) | 2017-05-21 06:22:02 Supported exchange: CME_FOp (SIM:CBOT Financial Options) | 2017-05-21 06:22:02 Supported exchange: CME_InOp (SIM:CME Interest Rate Options) | 2017-05-21 06:22:02 Supported exchange: CME_COOp (SIM:COMEX Options) | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6C.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: 6C.20170600.CME_Fo. ID: 25 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: 6C.20170600.CME_Fo. ID: 25 | 2017-05-21 06:22:02 CTS T4 FIX | Using primary service for historical data for 6C.20170600.CME_Fo | 2017-05-21 06:22:02 Intraday data recording state for symbol 6C.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The HO.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: HO.20171200.CME_NY. ID: 26 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: HO.20171200.CME_NY. ID: 26 | 2017-05-21 06:22:02 CTS T4 FIX | Using primary service for historical data for HO.20171200.CME_NY | 2017-05-21 06:22:02 Intraday data recording state for symbol HO.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: CL.20170700.CME_NY. ID: 27 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: CL.20170700.CME_NY. ID: 27 | 2017-05-21 06:22:02 CTS T4 FIX | Using primary service for historical data for CL.20170700.CME_NY | 2017-05-21 06:22:02 Intraday data recording state for symbol CL.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6N.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: 6N.20170600.CME_Fo. ID: 28 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: 6N.20170600.CME_Fo. ID: 28 | 2017-05-21 06:22:02 CTS T4 FIX | Using primary service for historical data for 6N.20170600.CME_Fo | 2017-05-21 06:22:02 Intraday data recording state for symbol 6N.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:22:02 HD Request # 360 | Downloading Intraday chart data for RB.20170700.CME_NY to the file RB.20170700.CME_NY.scid. Service: cts | 2017-05-21 06:22:02 HD Request # 360 | Download start date-time: 2017-05-19 16:59:53.000 | 2017-05-21 06:22:02 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The RB.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: RB.20171200.CME_NY. ID: 29 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: RB.20171200.CME_NY. ID: 29 | 2017-05-21 06:22:02 CTS T4 FIX | Using primary service for historical data for RB.20171200.CME_NY | 2017-05-21 06:22:02 Intraday data recording state for symbol RB.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: NQ.20170600.CME_Eq. ID: 30 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: NQ.20170600.CME_Eq. ID: 30 | 2017-05-21 06:22:02 CTS T4 FIX | Using primary service for historical data for NQ.20170600.CME_Eq | 2017-05-21 06:22:02 Intraday data recording state for symbol NQ.20170600.CME_Eq is set to download 'Pending'. | 2017-05-21 06:22:02 SC DTC Data | Setting DTC encoding to Binary VLS | 2017-05-21 06:22:02 SC DTC Data | Sending logon request message. | 2017-05-21 06:22:02 CTS T4 FIX | Using primary service for historical data for ZB.20170600.CME_F | 2017-05-21 06:22:02 Intraday data recording state for symbol ZB.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6A.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: 6A.20170600.CME_Fo. ID: 31 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: 6A.20170600.CME_Fo. ID: 31 | 2017-05-21 06:22:02 CTS T4 FIX | Using primary service for historical data for 6A.20170600.CME_Fo | 2017-05-21 06:22:02 Intraday data recording state for symbol 6A.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:22:02 Requesting market depth updates for: 6B.20170600.CME_Fo if supported. | 2017-05-21 06:22:02 SC DTC Data | Received logon response. | 2017-05-21 06:22:02 SC DTC Data | Server Name: SC Realtime Server. | 2017-05-21 06:22:02 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2017-05-21 06:22:02 SC DTC Data | Successfully connected. | 2017-05-21 06:22:02 SC DTC Data | Trading is not supported. | 2017-05-21 06:22:02 SC DTC Data | Restarting real-time data updates for symbol: AUDJPY | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: GC.20170600.CME_CO. ID: 32 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: GC.20170600.CME_CO. ID: 32 | 2017-05-21 06:22:02 CTS T4 FIX | Using primary service for historical data for GC.20170600.CME_CO | 2017-05-21 06:22:02 Intraday data recording state for symbol GC.20170600.CME_CO is set to download 'Pending'. | 2017-05-21 06:22:02 CTS T4 FIX | Received 'Account Update/Balance Data' collateral report. | 2017-05-21 06:22:02 SC DTC Data | Received security definition for symbol AUDJPY | 2017-05-21 06:22:02 Requesting market depth updates for: YM.20170600.CME_E if supported. | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6J.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: 6J.20170600.CME_Fo. ID: 33 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: 6J.20170600.CME_Fo. ID: 33 | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZN.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: ZN.20170600.CME_F. ID: 34 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: ZN.20170600.CME_F. ID: 34 | 2017-05-21 06:22:02 CTS T4 FIX | Using primary service for historical data for ZN.20170600.CME_F | 2017-05-21 06:22:02 Intraday data recording state for symbol ZN.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:22:02 CTS T4 FIX | Using primary service for historical data for 6J.20170600.CME_Fo | 2017-05-21 06:22:02 Intraday data recording state for symbol 6J.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:22:02 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:02 CTS T4 FIX | Starting real-time market data updates for: CL.20171200.CME_NY. ID: 35 | 2017-05-21 06:22:02 CTS T4 FIX | Requesting security definition data for: CL.20171200.CME_NY. ID: 35 | 2017-05-21 06:22:02 CTS T4 FIX | Using primary service for historical data for CL.20171200.CME_NY | 2017-05-21 06:22:02 Intraday data recording state for symbol CL.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:22:02 Requesting market depth updates for: 6J.20170600.CME_Fo if supported. | 2017-05-21 06:22:02 Requesting market depth updates for: NQ.20170600.CME_Eq if supported. | 2017-05-21 06:22:07 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZT.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:22:07 CTS T4 FIX | Starting real-time market data updates for: ZT.20170600.CME_F. ID: 36 | 2017-05-21 06:22:07 CTS T4 FIX | Requesting security definition data for: ZT.20170600.CME_F. ID: 36 | 2017-05-21 06:22:07 CTS T4 FIX | Using primary service for historical data for ZT.20170600.CME_F | 2017-05-21 06:22:07 Intraday data recording state for symbol ZT.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:22:07 Requesting market depth updates for: GC.20170600.CME_CO if supported. | 2017-05-21 06:22:07 CTS T4 FIX | Sending security definition request for symbol 6A.20160900.CME_Fo | 2017-05-21 06:22:07 Requesting market depth updates for: CL.20170700.CME_NY if supported. | 2017-05-21 06:22:07 Symbol Error - 6A.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:22:07 CTS T4 FIX | Received 0 security definitions for underlying symbol 6A | 2017-05-21 06:22:07 Requesting market depth updates for: ZB.20170600.CME_F if supported. | 2017-05-21 06:22:07 Requesting market depth updates for: ES.20170600.CME_Eq if supported. | 2017-05-21 06:22:07 HD Request # 361 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-05-21 06:22:07 HD Request # 361 | Download start date-time: 2017-05-19 16:57:58.000 | 2017-05-21 06:22:07 HD Request # 361 | Using server: ds3.sierracharts.com port 10149 | 2017-05-21 06:22:07 CTS T4 FIX | Sending security definition request for symbol 6A.20170600.CME_Fo | 2017-05-21 06:22:09 CTS T4 FIX | Received matching security definition for symbol 6A.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:22:10 CTS T4 FIX | Received 1 security definitions for underlying symbol 6A | 2017-05-21 06:22:10 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2017-05-21 06:22:10 Socket (2145) | Connected. | 2017-05-21 06:22:10 HD Request # 361 | Setting DTC encoding to Binary VLS | 2017-05-21 06:22:10 HD Request # 361 | Sending historical data logon request message. | 2017-05-21 06:22:10 CTS FIX Historical Data socket (0) | Resolved address fix-chart-sim.t4login.com to IP 74.201.6.229. | 2017-05-21 06:22:10 Contract specifications for 6A.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:22:10 HD Request # 361 | Requesting Intraday data. Start date-time: 2017-05-19 16:57:58. Record interval: 1. Symbol: AUDJPY | 2017-05-21 06:22:10 CTS FIX Historical Data socket (2146) | Connected. | 2017-05-21 06:22:10 CTS FIX Historical Data socket (2146) | Starting TLS 1.0 connection. | 2017-05-21 06:22:10 HD Request # 361 | Decompressing data. | 2017-05-21 06:22:10 HD Request # 361 | Receiving Intraday data for AUDJPY starting at 2017-05-19 16:57:58 | 2017-05-21 06:22:10 HD Request # 361 | Timestamp of first Intraday data file record written: 2017-05-19 16:57:58 | 2017-05-21 06:22:10 Socket (2145) | Shutdown and closed. | 2017-05-21 06:22:10 The network socket for historical data has been closed. | 2017-05-21 06:22:10 HD Request # 361 | Received 1 record from 2017-05-19 16:57:58 to 2017-05-19 16:57:58 (0.0 seconds) and wrote 1 record for AUDJPY | 2017-05-21 06:22:10 HD Request # 361 | Intraday download COMPLETE for AUDJPY. Completion time: 3s. Unique request ID: 612 | 2017-05-21 06:22:10 Removed historical data download ID 612 | 2017-05-21 06:22:10 Real-time Intraday chart data file updates started for AUDJPY | 2017-05-21 06:22:10 Opened cached Intraday file: C:\SierraChart1\Data\AUDJPY.scid | 2017-05-21 06:22:10 Intraday chart data file opened for AUDJPY | 2017-05-21 06:22:10 CTS FIX Historical Data socket (2146) | SSL connection established. | 2017-05-21 06:22:10 CTS T4 FIX | Requesting Open Orders for account: May*. Request ID: 9498584 | 2017-05-21 06:22:10 Requesting market depth updates for: 6B.20160900.CME_Fo if supported. | 2017-05-21 06:22:10 Requesting market depth updates for: 6E.20160900.CME_Fo if supported. | 2017-05-21 06:22:10 Requesting market depth updates for: 6J.20160900.CME_Fo if supported. | 2017-05-21 06:22:10 Requesting market depth updates for: 6N.20170600.CME_Fo if supported. | 2017-05-21 06:22:10 Requesting market depth updates for: CL.20160800.CME_NY if supported. | 2017-05-21 06:22:10 Requesting market depth updates for: CL.20170100.CME_NY if supported. | 2017-05-21 06:22:10 Requesting market depth updates for: CL.20170600.CME_NY if supported. | 2017-05-21 06:22:10 Requesting market depth updates for: CL.20171200.CME_NY if supported. | 2017-05-21 06:22:10 Requesting market depth updates for: ES.20160900.CME_Eq if supported. | 2017-05-21 06:22:10 Requesting market depth updates for: GC.20160800.CME_CO if supported. | 2017-05-21 06:22:10 Requesting market depth updates for: GC.20170400.CME_CO if supported. | 2017-05-21 06:22:10 Requesting market depth updates for: NQ.20160900.CME_Eq if supported. | 2017-05-21 06:22:10 Requesting market depth updates for: YM.20160900.CME_E if supported. | 2017-05-21 06:22:10 Requesting market depth updates for: ZB.20160900.CME_F if supported. | 2017-05-21 06:22:10 Requesting market depth updates for: ZB.20170300.CME_F if supported. | 2017-05-21 06:22:10 CTS T4 FIX | No open orders for account May18CCwmitchel | 2017-05-21 06:22:12 CTS FIX Historical Data: Sending the Logon message. | 2017-05-21 06:22:12 CTS T4 FIX | Sending security definition request for symbol 6B.20160900.CME_Fo | 2017-05-21 06:22:12 Symbol Error - 6B.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:22:13 CTS T4 FIX | Received 0 security definitions for underlying symbol 6B | 2017-05-21 06:22:13 CTS FIX Historical Data: Connected to Historical data server. | 2017-05-21 06:22:13 CTS T4 FIX | Sending security definition request for symbol 6B.20170600.CME_Fo | 2017-05-21 06:22:13 CTS T4 FIX | Received matching security definition for symbol 6B.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:22:15 CTS T4 FIX | Received 1 security definitions for underlying symbol 6B | 2017-05-21 06:22:15 Contract specifications for 6B.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 6.25 | 2017-05-21 06:22:15 CTS T4 FIX | Sending security definition request for symbol 6C.20160900.CME_Fo | 2017-05-21 06:22:15 Symbol Error - 6C.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:22:16 CTS T4 FIX | Received 0 security definitions for underlying symbol 6C | 2017-05-21 06:22:16 CTS T4 FIX | Sending security definition request for symbol 6C.20170600.CME_Fo | 2017-05-21 06:22:16 CTS T4 FIX | Received matching security definition for symbol 6C.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:22:17 CTS T4 FIX | Received 1 security definitions for underlying symbol 6C | 2017-05-21 06:22:17 Contract specifications for 6C.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 5 | 2017-05-21 06:22:17 CTS T4 FIX | Sending security definition request for symbol 6E.20160900.CME_Fo | 2017-05-21 06:22:19 Symbol Error - 6E.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:22:19 CTS T4 FIX | Received 0 security definitions for underlying symbol 6E | 2017-05-21 06:22:19 CTS T4 FIX | Sending security definition request for symbol 6E.20170600.CME_Fo | 2017-05-21 06:22:20 CTS T4 FIX | Received matching security definition for symbol 6E.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:22:20 CTS T4 FIX | Received 1 security definitions for underlying symbol 6E | 2017-05-21 06:22:20 Contract specifications for 6E.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-05-21 06:22:20 CTS T4 FIX | Requesting historical Fills for account: May*. Request ID: 9498588 | 2017-05-21 06:22:20 CTS T4 FIX | Received Account List collateral report. | 2017-05-21 06:22:22 CTS T4 FIX | Server provided no historical order fills for account 1A297B51-A416-42D4-A1C8-C9B1B4125155 | 2017-05-21 06:22:22 CTS T4 FIX | Sending security definition request for symbol 6J.20160900.CME_Fo | 2017-05-21 06:22:22 Symbol Error - 6J.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:22:22 CTS T4 FIX | Received 0 security definitions for underlying symbol 6J | 2017-05-21 06:22:22 CTS T4 FIX | Sending security definition request for symbol 6J.20170600.CME_Fo | 2017-05-21 06:22:24 CTS T4 FIX | Received matching security definition for symbol 6J.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:22:24 CTS T4 FIX | Received 1 security definitions for underlying symbol 6J | 2017-05-21 06:22:24 Contract specifications for 6J.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-05-21 06:22:24 CTS T4 FIX | Sending security definition request for symbol 6N.20170600.CME_Fo | 2017-05-21 06:22:26 CTS T4 FIX | Received matching security definition for symbol 6N.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:22:26 CTS T4 FIX | Received 1 security definitions for underlying symbol 6N | 2017-05-21 06:22:26 Contract specifications for 6N.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:22:26 CTS T4 FIX | Sending security definition request for symbol 6S.20170600.CME_Fo | 2017-05-21 06:22:27 CTS T4 FIX | Received matching security definition for symbol 6S.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:22:27 CTS T4 FIX | Received 1 security definitions for underlying symbol 6S | 2017-05-21 06:22:27 Contract specifications for 6S.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 12.5 | 2017-05-21 06:22:27 CTS T4 FIX | Sending security definition request for symbol CL.20160800.CME_NY | 2017-05-21 06:22:29 Symbol Error - CL.20160800.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:22:29 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2017-05-21 06:22:29 CTS T4 FIX | Sending security definition request for symbol CL.20170100.CME_NY | 2017-05-21 06:22:30 Symbol Error - CL.20170100.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:22:30 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2017-05-21 06:22:30 CTS T4 FIX | Sending security definition request for symbol CL.20170600.CME_NY | 2017-05-21 06:22:31 CTS T4 FIX | Received matching security definition for symbol CL.20170600.CME_NY. Subscribing to data. | 2017-05-21 06:22:31 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:22:31 Contract specifications for CL.20170600.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:22:33 CTS T4 FIX | Sending security definition request for symbol CL.20170700.CME_NY | 2017-05-21 06:22:33 CTS T4 FIX | Received matching security definition for symbol CL.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:22:33 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:22:33 Contract specifications for CL.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:22:34 CTS T4 FIX | Sending security definition request for symbol CL.20171200.CME_NY | 2017-05-21 06:22:34 CTS T4 FIX | Received matching security definition for symbol CL.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:22:36 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:22:36 Contract specifications for CL.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:22:36 CTS T4 FIX | Sending security definition request for symbol ES.20160900.CME_Eq | 2017-05-21 06:22:37 Symbol Error - ES.20160900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:22:38 CTS T4 FIX | Received 0 security definitions for underlying symbol ES | 2017-05-21 06:22:38 CTS T4 FIX | Sending security definition request for symbol ES.20170600.CME_Eq | 2017-05-21 06:22:38 CTS T4 FIX | Received matching security definition for symbol ES.20170600.CME_Eq. Subscribing to data. | 2017-05-21 06:22:40 CTS T4 FIX | Received 1 security definitions for underlying symbol ES | 2017-05-21 06:22:40 Contract specifications for ES.20170600.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 12.5 | 2017-05-21 06:22:40 CTS T4 FIX | Sending security definition request for symbol GC.20160800.CME_CO | 2017-05-21 06:22:41 Symbol Error - GC.20160800.CME_CO is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:22:41 CTS T4 FIX | Received 0 security definitions for underlying symbol GC | 2017-05-21 06:22:41 CTS T4 FIX | Sending security definition request for symbol GC.20170400.CME_CO | 2017-05-21 06:22:43 Symbol Error - GC.20170400.CME_CO is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:22:43 CTS T4 FIX | Received 0 security definitions for underlying symbol GC | 2017-05-21 06:22:43 CTS T4 FIX | Sending security definition request for symbol GC.20170600.CME_CO | 2017-05-21 06:22:44 CTS T4 FIX | Received matching security definition for symbol GC.20170600.CME_CO. Subscribing to data. | 2017-05-21 06:22:44 CTS T4 FIX | Received 1 security definitions for underlying symbol GC | 2017-05-21 06:22:44 Contract specifications for GC.20170600.CME_CO. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:22:44 CTS T4 FIX | Sending security definition request for symbol HO.20170700.CME_NY | 2017-05-21 06:22:46 CTS T4 FIX | Received matching security definition for symbol HO.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:22:46 CTS T4 FIX | Received 1 security definitions for underlying symbol HO | 2017-05-21 06:22:46 Contract specifications for HO.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:22:46 CTS T4 FIX | Sending security definition request for symbol HO.20171200.CME_NY | 2017-05-21 06:22:48 CTS T4 FIX | Received matching security definition for symbol HO.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:22:48 CTS T4 FIX | Received 1 security definitions for underlying symbol HO | 2017-05-21 06:22:48 Contract specifications for HO.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:22:48 CTS T4 FIX | Sending security definition request for symbol NQ.20160900.CME_Eq | 2017-05-21 06:22:51 Symbol Error - NQ.20160900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:22:51 CTS T4 FIX | Received 0 security definitions for underlying symbol NQ | 2017-05-21 06:22:51 CTS T4 FIX | Sending security definition request for symbol NQ.20170600.CME_Eq | 2017-05-21 06:22:53 CTS T4 FIX | Received matching security definition for symbol NQ.20170600.CME_Eq. Subscribing to data. | 2017-05-21 06:22:53 CTS T4 FIX | Received 1 security definitions for underlying symbol NQ | 2017-05-21 06:22:53 Contract specifications for NQ.20170600.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 5 | 2017-05-21 06:22:53 CTS T4 FIX | Sending security definition request for symbol RB.20170700.CME_NY | 2017-05-21 06:22:54 CTS T4 FIX | Received matching security definition for symbol RB.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:22:54 CTS T4 FIX | Received matching security definition for symbol RB.20170700.CME_NY. Requesting historical data. | 2017-05-21 06:22:54 HD Request # 360 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:22:54 CTS T4 FIX | Received 1 security definitions for underlying symbol RB | 2017-05-21 06:22:54 Contract specifications for RB.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:22:54 HD Request # 360 | Receiving Intraday data for RB.20170700.CME_NY starting at 2017-05-18 18:00:00 | 2017-05-21 06:22:54 HD Request # 360 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:53 | 2017-05-21 06:22:54 HD Request # 360 | Total records received: 7454 | 2017-05-21 06:22:54 HD Request # 360 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:22:54 HD Request # 360 | Total records received: 7454 | 2017-05-21 06:22:56 HD Request # 360 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:22:56 HD Request # 360 | Total records received: 7454 | 2017-05-21 06:22:56 HD Request # 360 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:22:56 HD Request # 360 | Total records received: 7454 | 2017-05-21 06:22:56 HD Request # 360 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:22:56 CTS T4 FIX | Sending security definition request for symbol RB.20171200.CME_NY | 2017-05-21 06:22:56 CTS T4 FIX | Received matching security definition for symbol RB.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:22:56 CTS T4 FIX | Received 1 security definitions for underlying symbol RB | 2017-05-21 06:22:56 HD Request # 360 | Received 7454 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:53 (23.0 hours) and wrote 1 record for RB.20170700.CME_NY | 2017-05-21 06:22:56 HD Request # 360 | Intraday download COMPLETE for RB.20170700.CME_NY. Completion time: 51s. Unique request ID: 607 | 2017-05-21 06:22:56 Removed historical data download ID 607 | 2017-05-21 06:22:56 Real-time Intraday chart data file updates started for RB.20170700.CME_NY | 2017-05-21 06:22:56 Opened cached Intraday file: C:\SierraChart1\Data\RB.20170700.CME_NY.scid | 2017-05-21 06:22:56 Intraday chart data file opened for RB.20170700.CME_NY | 2017-05-21 06:22:56 Delaying start of download for 6B.20170600.CME_Fo | 2017-05-21 06:22:56 Contract specifications for RB.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:22:56 Chart #22 has tagged chart #16 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:22:56 CTS T4 FIX | Sending security definition request for symbol YM.20160900.CME_E | 2017-05-21 06:22:57 Chart #18 has tagged chart #16 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:22:57 CL.20170700.CME_NY 3 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:22:57 Chart #16 has tagged chart #15 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:22:57 Symbol Error - YM.20160900.CME_E is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:22:57 CTS T4 FIX | Received 0 security definitions for underlying symbol YM | 2017-05-21 06:22:57 Chart #21 has tagged chart #9 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:22:57 CL.20170700.CME_NY 30 Sec #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:22:59 6C.20170600.CME_Fo 3 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:22:59 CL.20170700.CME_NY [C] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:22:59 Chart #9 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:22:59 CTS T4 FIX | Sending security definition request for symbol YM.20170600.CME_E | 2017-05-21 06:22:59 CTS T4 FIX | Received matching security definition for symbol YM.20170600.CME_E. Subscribing to data. | 2017-05-21 06:22:59 CTS T4 FIX | Received 1 security definitions for underlying symbol YM | 2017-05-21 06:22:59 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:22:59 Contract specifications for YM.20170600.CME_E. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 5 | 2017-05-21 06:22:59 CTS T4 FIX | Sending security definition request for symbol ZB.20160900.CME_F | 2017-05-21 06:23:01 Symbol Error - ZB.20160900.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:23:01 CTS T4 FIX | Received 0 security definitions for underlying symbol ZB | 2017-05-21 06:23:01 CTS T4 FIX | Sending security definition request for symbol ZB.20170300.CME_F | 2017-05-21 06:23:03 Symbol Error - ZB.20170300.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:23:03 CTS T4 FIX | Received 0 security definitions for underlying symbol ZB | 2017-05-21 06:23:03 CTS T4 FIX | Sending security definition request for symbol ZB.20170600.CME_F | 2017-05-21 06:23:04 CTS T4 FIX | Received matching security definition for symbol ZB.20170600.CME_F. Subscribing to data. | 2017-05-21 06:23:06 CTS T4 FIX | Received 1 security definitions for underlying symbol ZB | 2017-05-21 06:23:06 Contract specifications for ZB.20170600.CME_F. Multiplier: 0.00001000. Tick Size: 0.03125. Value Format: 132. Currency Value per Tick: 31.25 | 2017-05-21 06:23:06 CTS T4 FIX | Sending security definition request for symbol ZN.20170600.CME_F | 2017-05-21 06:23:06 CTS T4 FIX | Received matching security definition for symbol ZN.20170600.CME_F. Subscribing to data. | 2017-05-21 06:23:07 CTS T4 FIX | Received 1 security definitions for underlying symbol ZN | 2017-05-21 06:23:07 Contract specifications for ZN.20170600.CME_F. Multiplier: 0.00000100. Tick Size: 0.015625. Value Format: 132. Currency Value per Tick: 15.625 | 2017-05-21 06:23:07 CTS T4 FIX | Sending security definition request for symbol ZT.20170600.CME_F | 2017-05-21 06:23:07 CTS T4 FIX | Received matching security definition for symbol ZT.20170600.CME_F. Subscribing to data. | 2017-05-21 06:23:08 CTS T4 FIX | Received 1 security definitions for underlying symbol ZT | 2017-05-21 06:23:08 Contract specifications for ZT.20170600.CME_F. Multiplier: 0.00000010. Tick Size: 0.0078125. Value Format: 228. Currency Value per Tick: 15.625 | 2017-05-21 06:23:08 HD Request # 362 | Downloading Intraday chart data for 6B.20170600.CME_Fo to the file 6B.20170600.CME_Fo.scid. Service: cts | 2017-05-21 06:23:18 HD Request # 362 | Download start date-time: 2017-05-19 16:59:54.000 | 2017-05-21 06:23:18 HD Request # 362 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:23:18 HD Request # 362 | Receiving Intraday data for 6B.20170600.CME_Fo starting at 2017-05-18 18:00:00 | 2017-05-21 06:23:20 HD Request # 362 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:54 | 2017-05-21 06:23:20 HD Request # 362 | Total records received: 8374 | 2017-05-21 06:23:20 HD Request # 362 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:23:20 HD Request # 362 | Total records received: 8374 | 2017-05-21 06:23:20 HD Request # 362 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:23:20 HD Request # 362 | Total records received: 8374 | 2017-05-21 06:23:20 HD Request # 362 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:23:20 HD Request # 362 | Total records received: 8374 | 2017-05-21 06:23:20 HD Request # 362 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:23:20 HD Request # 362 | Received 8374 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:54 (23.0 hours) and wrote 1 record for 6B.20170600.CME_Fo | 2017-05-21 06:23:20 HD Request # 362 | Intraday download COMPLETE for 6B.20170600.CME_Fo. Completion time: 2s. Unique request ID: 608 | 2017-05-21 06:23:20 Removed historical data download ID 608 | 2017-05-21 06:23:20 Real-time Intraday chart data file updates started for 6B.20170600.CME_Fo | 2017-05-21 06:23:20 Opened cached Intraday file: C:\SierraChart1\Data\6B.20170600.CME_Fo.scid | 2017-05-21 06:23:20 Intraday chart data file opened for 6B.20170600.CME_Fo | 2017-05-21 06:23:20 Delaying start of download for 6E.20170600.CME_Fo | 2017-05-21 06:23:20 Chart #12 has tagged chart #8 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:23:21 Chart #12 has tagged chart #8 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:23:21 6A.20170600.CME_Fo 3 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:23:21 6A.20170600.CME_Fo 3 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:23:23 HD Request # 363 | Downloading Intraday chart data for 6E.20170600.CME_Fo to the file 6E.20170600.CME_Fo.scid. Service: cts | 2017-05-21 06:23:43 HD Request # 363 | Download start date-time: 2017-05-19 16:59:58.000 | 2017-05-21 06:23:43 HD Request # 363 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:23:43 HD Request # 363 | Receiving Intraday data for 6E.20170600.CME_Fo starting at 2017-05-18 18:00:00 | 2017-05-21 06:23:44 HD Request # 363 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:58 | 2017-05-21 06:23:44 HD Request # 363 | Total records received: 17398 | 2017-05-21 06:23:44 HD Request # 363 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:23:44 HD Request # 363 | Total records received: 17398 | 2017-05-21 06:23:44 HD Request # 363 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:23:44 HD Request # 363 | Total records received: 17398 | 2017-05-21 06:23:44 HD Request # 363 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:23:44 HD Request # 363 | Total records received: 17398 | 2017-05-21 06:23:44 HD Request # 363 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:23:44 HD Request # 363 | Received 17398 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:58 (23.0 hours) and wrote 1 record for 6E.20170600.CME_Fo | 2017-05-21 06:23:46 HD Request # 363 | Intraday download COMPLETE for 6E.20170600.CME_Fo. Completion time: 2s. Unique request ID: 609 | 2017-05-21 06:23:46 Removed historical data download ID 609 | 2017-05-21 06:23:46 Real-time Intraday chart data file updates started for 6E.20170600.CME_Fo | 2017-05-21 06:23:46 Opened cached Intraday file: C:\SierraChart1\Data\6E.20170600.CME_Fo.scid | 2017-05-21 06:23:46 Intraday chart data file opened for 6E.20170600.CME_Fo | 2017-05-21 06:23:46 Delaying start of download for YM.20170600.CME_E | 2017-05-21 06:23:46 Chart #15 has tagged chart #4 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:23:46 6B.20170600.CME_Fo 30 Sec #4 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:23:46 HD Request # 364 | Downloading Intraday chart data for YM.20170600.CME_E to the file YM.20170600.CME_E.scid. Service: cts | 2017-05-21 06:24:09 HD Request # 364 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:24:09 HD Request # 364 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:24:09 HD Request # 364 | Receiving Intraday data for YM.20170600.CME_E starting at 2017-05-18 18:00:00 | 2017-05-21 06:24:11 HD Request # 364 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:24:11 HD Request # 364 | Total records received: 19680 | 2017-05-21 06:24:11 HD Request # 364 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:24:11 HD Request # 364 | Total records received: 19680 | 2017-05-21 06:24:11 HD Request # 364 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:24:11 HD Request # 364 | Total records received: 19680 | 2017-05-21 06:24:11 HD Request # 364 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:24:11 HD Request # 364 | Total records received: 19680 | 2017-05-21 06:24:11 HD Request # 364 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:24:11 HD Request # 364 | Received 19680 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for YM.20170600.CME_E | 2017-05-21 06:24:11 HD Request # 364 | Intraday download COMPLETE for YM.20170600.CME_E. Completion time: 3s. Unique request ID: 610 | 2017-05-21 06:24:11 Removed historical data download ID 610 | 2017-05-21 06:24:11 Real-time Intraday chart data file updates started for YM.20170600.CME_E | 2017-05-21 06:24:11 Opened cached Intraday file: C:\SierraChart1\Data\YM.20170600.CME_E.scid | 2017-05-21 06:24:11 Intraday chart data file opened for YM.20170600.CME_E | 2017-05-21 06:24:11 Delaying start of download for ES.20170600.CME_Eq | 2017-05-21 06:24:11 Chart #3 has tagged chart #4 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:24:12 ZB.20170600.CME_F 3 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:24:14 CTS FIX socket (2143) | Closed. No error. | 2017-05-21 06:24:14 CTS FIX socket (2143) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-21 06:24:14 CTS FIX socket (2143) | SSL has been shut down. | 2017-05-21 06:24:14 CTS FIX socket (2143) | SSL object has been freed. SSL state is now disconnected. | 2017-05-21 06:24:14 CTS FIX socket (2143) | Shutdown and closed. | 2017-05-21 06:24:14 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2017-05-21 06:24:14 Connection to the external service has been lost. | 2017-05-21 06:24:14 DTC Client (2144) | Closed. No error. | 2017-05-21 06:24:14 DTC Client (2144) | Shutdown and closed. | 2017-05-21 06:24:14 SC DTC Data | Disconnected from the server. | 2017-05-21 06:24:14 SC DTC Data | Data feed disconnected. Will reconnect in 2 seconds. | 2017-05-21 06:24:14 CTS FIX Historical Data socket (2146) | Closed. No error. | 2017-05-21 06:25:11 CTS FIX Historical Data socket (2146) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-21 06:25:11 CTS FIX Historical Data socket (2146) | SSL has been shut down. | 2017-05-21 06:25:11 CTS FIX Historical Data socket (2146) | SSL object has been freed. SSL state is now disconnected. | 2017-05-21 06:25:11 CTS FIX Historical Data socket (2146) | Shutdown and closed. | 2017-05-21 06:25:11 CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2017-05-21 06:25:11 CTS FIX Historical Data: Disconnected. | 2017-05-21 06:25:11 Canceling historical data download request for ES.20170600.CME_Eq Intraday data. | 2017-05-21 06:25:11 Removed historical data download ID 611 | 2017-05-21 06:25:11 Canceling historical data download request for 6S.20170600.CME_Fo Intraday data. | 2017-05-21 06:25:11 Removed historical data download ID 613 | 2017-05-21 06:25:11 Canceling historical data download request for HO.20170700.CME_NY Intraday data. | 2017-05-21 06:25:11 Removed historical data download ID 614 | 2017-05-21 06:25:11 Canceling historical data download request for 6C.20170600.CME_Fo Intraday data. | 2017-05-21 06:25:11 Removed historical data download ID 615 | 2017-05-21 06:25:11 Canceling historical data download request for HO.20171200.CME_NY Intraday data. | 2017-05-21 06:25:11 Removed historical data download ID 616 | 2017-05-21 06:25:11 Canceling historical data download request for CL.20170700.CME_NY Intraday data. | 2017-05-21 06:25:11 Removed historical data download ID 617 | 2017-05-21 06:25:11 Canceling historical data download request for 6N.20170600.CME_Fo Intraday data. | 2017-05-21 06:25:11 Removed historical data download ID 618 | 2017-05-21 06:25:11 Canceling historical data download request for RB.20171200.CME_NY Intraday data. | 2017-05-21 06:25:11 Removed historical data download ID 619 | 2017-05-21 06:25:11 Canceling historical data download request for NQ.20170600.CME_Eq Intraday data. | 2017-05-21 06:25:11 Removed historical data download ID 620 | 2017-05-21 06:25:11 Canceling historical data download request for ZB.20170600.CME_F Intraday data. | 2017-05-21 06:25:11 Removed historical data download ID 621 | 2017-05-21 06:25:11 Canceling historical data download request for 6A.20170600.CME_Fo Intraday data. | 2017-05-21 06:25:11 Removed historical data download ID 622 | 2017-05-21 06:25:11 Canceling historical data download request for GC.20170600.CME_CO Intraday data. | 2017-05-21 06:25:11 Removed historical data download ID 623 | 2017-05-21 06:25:11 Canceling historical data download request for ZN.20170600.CME_F Intraday data. | 2017-05-21 06:25:11 Removed historical data download ID 624 | 2017-05-21 06:25:11 Canceling historical data download request for 6J.20170600.CME_Fo Intraday data. | 2017-05-21 06:25:11 Removed historical data download ID 625 | 2017-05-21 06:25:11 Canceling historical data download request for CL.20171200.CME_NY Intraday data. | 2017-05-21 06:25:11 Removed historical data download ID 626 | 2017-05-21 06:25:11 Canceling historical data download request for ZT.20170600.CME_F Intraday data. | 2017-05-21 06:25:11 Removed historical data download ID 627 | 2017-05-21 06:25:11 CTS T4 FIX | Disconnected. | 2017-05-21 06:25:11 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-21 06:25:11 SC DTC Data | Connecting to the server ds4.sierracharts.com. Port 443 | 2017-05-21 06:25:13 DTC Client (0) | Resolved address ds4.sierracharts.com to IP 192.81.56.146. | 2017-05-21 06:25:13 DTC Client (2149) | Connected. | 2017-05-21 06:25:13 SC DTC Data | Connected to server. | 2017-05-21 06:25:13 SC DTC Data | Sending Encoding Request to server | 2017-05-21 06:25:13 SC DTC Data | Setting DTC encoding to Binary VLS | 2017-05-21 06:25:13 SC DTC Data | Sending logon request message. | 2017-05-21 06:25:13 SC DTC Data | Received logon response. | 2017-05-21 06:25:14 SC DTC Data | Server Name: SC Realtime Server. | 2017-05-21 06:25:14 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2017-05-21 06:25:14 SC DTC Data | Successfully connected. | 2017-05-21 06:25:14 SC DTC Data | Trading is not supported. | 2017-05-21 06:25:14 Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2017-05-21 06:25:14 SC DTC Data | Restarting real-time data updates for symbol: AUDJPY | 2017-05-21 06:25:14 HD Request # 365 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-05-21 06:25:14 HD Request # 365 | Download start date-time: 2017-05-19 16:57:58.000 | 2017-05-21 06:25:14 HD Request # 365 | Using server: ds4.sierracharts.com port 10149 | 2017-05-21 06:25:14 Socket (0) | Resolved address ds4.sierracharts.com to IP 192.81.56.146. | 2017-05-21 06:25:14 Socket (2150) | Connected. | 2017-05-21 06:25:14 HD Request # 365 | Setting DTC encoding to Binary VLS | 2017-05-21 06:25:14 HD Request # 365 | Sending historical data logon request message. | 2017-05-21 06:25:14 SC DTC Data | Received security definition for symbol AUDJPY | 2017-05-21 06:25:14 HD Request # 365 | Requesting Intraday data. Start date-time: 2017-05-19 16:57:58. Record interval: 1. Symbol: AUDJPY | 2017-05-21 06:25:14 HD Request # 365 | Decompressing data. | 2017-05-21 06:25:14 HD Request # 365 | Receiving Intraday data for AUDJPY starting at 2017-05-19 16:57:58 | 2017-05-21 06:25:14 HD Request # 365 | Timestamp of first Intraday data file record written: 2017-05-19 16:57:58 | 2017-05-21 06:25:14 Socket (2150) | Shutdown and closed. | 2017-05-21 06:25:14 The network socket for historical data has been closed. | 2017-05-21 06:25:14 HD Request # 365 | Historical data for AUDJPY is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-05-21 06:25:14 HD Request # 365 | Received 1 record from 2017-05-19 16:57:58 to 2017-05-19 16:57:58 (0.0 seconds) and wrote 1 record for AUDJPY | 2017-05-21 06:25:14 HD Request # 365 | Intraday download COMPLETE for AUDJPY. Completion time: 0s. Unique request ID: 628 | 2017-05-21 06:25:14 Removed historical data download ID 628 | 2017-05-21 06:25:14 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2017-05-21 06:25:16 CTS T4 FIX | Firm: PTP | 2017-05-21 06:25:16 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199. | 2017-05-21 06:25:16 CTS FIX socket (2151) | Connected. | 2017-05-21 06:25:17 CTS FIX socket (2151) | Starting TLS 1.0 connection. | 2017-05-21 06:25:17 CTS FIX socket (2151) | SSL connection established. | 2017-05-21 06:25:17 CTS FIX: Sending the Logon message. | 2017-05-21 06:25:19 CTS T4 FIX | FIX version: 4.3.74.0 | 2017-05-21 06:25:19 CTS T4 FIX | Connected to data and trading server. | 2017-05-21 06:25:19 DTC Client (2149) | Shutdown and closed. | 2017-05-21 06:25:19 SC DTC Data | Disconnected from the server. | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: ZB.20160900.CME_F. ID: 1 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: ZB.20160900.CME_F. ID: 1 | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: 6E.20160900.CME_Fo. ID: 2 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: 6E.20160900.CME_Fo. ID: 2 | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6J.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: 6J.20160900.CME_Fo. ID: 3 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: 6J.20160900.CME_Fo. ID: 3 | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6B.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: 6B.20160900.CME_Fo. ID: 4 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: 6B.20160900.CME_Fo. ID: 4 | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6C.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: 6C.20160900.CME_Fo. ID: 5 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: 6C.20160900.CME_Fo. ID: 5 | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: CL.20160800.CME_NY. ID: 6 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: CL.20160800.CME_NY. ID: 6 | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6A.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: 6A.20160900.CME_Fo. ID: 7 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: 6A.20160900.CME_Fo. ID: 7 | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: NQ.20160900.CME_Eq. ID: 8 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: NQ.20160900.CME_Eq. ID: 8 | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM.######00.CME_E pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: YM.20160900.CME_E. ID: 9 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: YM.20160900.CME_E. ID: 9 | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: GC.20160800.CME_CO. ID: 10 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: GC.20160800.CME_CO. ID: 10 | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: ES.20160900.CME_Eq. ID: 11 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: ES.20160900.CME_Eq. ID: 11 | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: ZB.20170300.CME_F. ID: 12 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: ZB.20170300.CME_F. ID: 12 | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: CL.20170100.CME_NY. ID: 13 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: CL.20170100.CME_NY. ID: 13 | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: GC.20170400.CME_CO. ID: 14 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: GC.20170400.CME_CO. ID: 14 | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: ZB.20170600.CME_F. ID: 15 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: ZB.20170600.CME_F. ID: 15 | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6B.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: 6B.20170600.CME_Fo. ID: 16 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: 6B.20170600.CME_Fo. ID: 16 | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: CL.20170600.CME_NY. ID: 17 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: CL.20170600.CME_NY. ID: 17 | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6N.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: 6N.20170600.CME_Fo. ID: 18 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: 6N.20170600.CME_Fo. ID: 18 | 2017-05-21 06:25:19 CTS T4 FIX | Using primary service for historical data for 6N.20170600.CME_Fo | 2017-05-21 06:25:19 Intraday data recording state for symbol 6N.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:25:19 Delaying start of download for 6N.20170600.CME_Fo | 2017-05-21 06:25:19 CTS T4 FIX | Using primary service for historical data for ZB.20170600.CME_F | 2017-05-21 06:25:19 Intraday data recording state for symbol ZB.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The RB.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: RB.20171200.CME_NY. ID: 19 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: RB.20171200.CME_NY. ID: 19 | 2017-05-21 06:25:19 CTS T4 FIX | Using primary service for historical data for RB.20171200.CME_NY | 2017-05-21 06:25:19 Intraday data recording state for symbol RB.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZN.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: ZN.20170600.CME_F. ID: 20 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: ZN.20170600.CME_F. ID: 20 | 2017-05-21 06:25:19 CTS T4 FIX | Using primary service for historical data for ZN.20170600.CME_F | 2017-05-21 06:25:19 Intraday data recording state for symbol ZN.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6J.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: 6J.20170600.CME_Fo. ID: 21 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: 6J.20170600.CME_Fo. ID: 21 | 2017-05-21 06:25:19 CTS T4 FIX | Using primary service for historical data for 6J.20170600.CME_Fo | 2017-05-21 06:25:19 Intraday data recording state for symbol 6J.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:25:19 CTS T4 FIX | Received Account List collateral report. | 2017-05-21 06:25:19 CTS T4 FIX | Subscribing to account: May* | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6S.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: 6S.20170600.CME_Fo. ID: 22 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: 6S.20170600.CME_Fo. ID: 22 | 2017-05-21 06:25:19 CTS T4 FIX | Using primary service for historical data for 6S.20170600.CME_Fo | 2017-05-21 06:25:19 Intraday data recording state for symbol 6S.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The RB.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: RB.20170700.CME_NY. ID: 23 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: RB.20170700.CME_NY. ID: 23 | 2017-05-21 06:25:19 CTS T4 FIX | Using primary service for historical data for RB.20170700.CME_NY | 2017-05-21 06:25:19 Intraday data recording state for symbol RB.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: CL.20171200.CME_NY. ID: 24 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: CL.20171200.CME_NY. ID: 24 | 2017-05-21 06:25:19 CTS T4 FIX | Using primary service for historical data for CL.20171200.CME_NY | 2017-05-21 06:25:19 Intraday data recording state for symbol CL.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: GC.20170600.CME_CO. ID: 25 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: GC.20170600.CME_CO. ID: 25 | 2017-05-21 06:25:19 CTS T4 FIX | Using primary service for historical data for GC.20170600.CME_CO | 2017-05-21 06:25:19 Intraday data recording state for symbol GC.20170600.CME_CO is set to download 'Pending'. | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM.######00.CME_E pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: YM.20170600.CME_E. ID: 26 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: YM.20170600.CME_E. ID: 26 | 2017-05-21 06:25:19 CTS T4 FIX | Using primary service for historical data for YM.20170600.CME_E | 2017-05-21 06:25:19 Intraday data recording state for symbol YM.20170600.CME_E is set to download 'Pending'. | 2017-05-21 06:25:19 Supported exchange: CME_CO (SIM:COMEX Futures) | 2017-05-21 06:25:19 Requesting market depth updates for: 6J.20170600.CME_Fo if supported. | 2017-05-21 06:25:19 Supported exchange: CME_EqOp (SIM:CME Equity Options) | 2017-05-21 06:25:19 Supported exchange: CME_NYOp (SIM:NYMEX Options) | 2017-05-21 06:25:19 Supported exchange: CME_AgOp (SIM:CME Agricultural Options) | 2017-05-21 06:25:19 Supported exchange: CME_Eq (SIM:CME Equity Futures) | 2017-05-21 06:25:19 Supported exchange: CME_In (SIM:CME Interest Rate Futures) | 2017-05-21 06:25:19 Supported exchange: CME_C (SIM:CBOT Commodity Futures) | 2017-05-21 06:25:19 Supported exchange: CME_KOp (SIM:KCBT Options) | 2017-05-21 06:25:19 Supported exchange: CME_F (SIM:CBOT Financial Futures) | 2017-05-21 06:25:19 Supported exchange: CME_E (SIM:CBOT Equity Futures) | 2017-05-21 06:25:19 Supported exchange: CME_COp (SIM:CBOT Commodity Options) | 2017-05-21 06:25:19 Supported exchange: CME_K (SIM:KCBT Futures) | 2017-05-21 06:25:19 Supported exchange: CME_EOp (SIM:CBOT Equity Options) | 2017-05-21 06:25:19 Supported exchange: CME_NY (SIM:NYMEX Futures) | 2017-05-21 06:25:19 Supported exchange: CME_Fo (SIM:CME Foreign Exchange Futures) | 2017-05-21 06:25:19 Supported exchange: CME_Ag (SIM:CME Agricultural Futures) | 2017-05-21 06:25:19 Supported exchange: CME_FoOp (SIM:CME Foreign Exchange Options) | 2017-05-21 06:25:19 Supported exchange: CME_FOp (SIM:CBOT Financial Options) | 2017-05-21 06:25:19 Supported exchange: CME_InOp (SIM:CME Interest Rate Options) | 2017-05-21 06:25:19 Supported exchange: CME_COOp (SIM:COMEX Options) | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: CL.20170700.CME_NY. ID: 27 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: CL.20170700.CME_NY. ID: 27 | 2017-05-21 06:25:19 CTS T4 FIX | Using primary service for historical data for CL.20170700.CME_NY | 2017-05-21 06:25:19 Intraday data recording state for symbol CL.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:25:19 HD Request # 366 | Downloading Intraday chart data for 6N.20170600.CME_Fo to the file 6N.20170600.CME_Fo.scid. Service: cts | 2017-05-21 06:25:19 HD Request # 366 | Download start date-time: 2017-05-19 16:59:58.000 | 2017-05-21 06:25:19 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2017-05-21 06:25:19 CTS FIX Historical Data socket (0) | Resolved address fix-chart-sim.t4login.com to IP 74.201.6.229. | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: 6E.20170600.CME_Fo. ID: 28 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: 6E.20170600.CME_Fo. ID: 28 | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6A.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: 6A.20170600.CME_Fo. ID: 29 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: 6A.20170600.CME_Fo. ID: 29 | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6C.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: 6C.20170600.CME_Fo. ID: 30 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: 6C.20170600.CME_Fo. ID: 30 | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: ES.20170600.CME_Eq. ID: 31 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: ES.20170600.CME_Eq. ID: 31 | 2017-05-21 06:25:19 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:19 CTS T4 FIX | Starting real-time market data updates for: NQ.20170600.CME_Eq. ID: 32 | 2017-05-21 06:25:19 CTS T4 FIX | Requesting security definition data for: NQ.20170600.CME_Eq. ID: 32 | 2017-05-21 06:25:19 Requesting market depth updates for: NQ.20170600.CME_Eq if supported. | 2017-05-21 06:25:23 CTS T4 FIX | Using primary service for historical data for NQ.20170600.CME_Eq | 2017-05-21 06:25:23 Intraday data recording state for symbol NQ.20170600.CME_Eq is set to download 'Pending'. | 2017-05-21 06:25:23 CTS FIX Historical Data socket (2152) | Connected. | 2017-05-21 06:25:23 CTS FIX Historical Data socket (2152) | Starting TLS 1.0 connection. | 2017-05-21 06:25:23 CTS T4 FIX | Using primary service for historical data for 6A.20170600.CME_Fo | 2017-05-21 06:25:23 Intraday data recording state for symbol 6A.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:25:23 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZT.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:23 CTS T4 FIX | Starting real-time market data updates for: ZT.20170600.CME_F. ID: 33 | 2017-05-21 06:25:23 CTS T4 FIX | Requesting security definition data for: ZT.20170600.CME_F. ID: 33 | 2017-05-21 06:25:23 CTS T4 FIX | Using primary service for historical data for ZT.20170600.CME_F | 2017-05-21 06:25:23 Intraday data recording state for symbol ZT.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:25:23 'Allow Support for Sierra Chart Data Feeds' is disabled. The HO.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:23 CTS T4 FIX | Starting real-time market data updates for: HO.20170700.CME_NY. ID: 34 | 2017-05-21 06:25:23 CTS T4 FIX | Requesting security definition data for: HO.20170700.CME_NY. ID: 34 | 2017-05-21 06:25:23 CTS T4 FIX | Using primary service for historical data for HO.20170700.CME_NY | 2017-05-21 06:25:23 Intraday data recording state for symbol HO.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:25:23 Requesting market depth updates for: GC.20170600.CME_CO if supported. | 2017-05-21 06:25:23 CTS FIX Historical Data socket (2152) | SSL connection established. | 2017-05-21 06:25:23 Requesting market depth updates for: CL.20170700.CME_NY if supported. | 2017-05-21 06:25:23 Requesting market depth updates for: ZB.20170600.CME_F if supported. | 2017-05-21 06:25:23 CTS T4 FIX | Using primary service for historical data for 6B.20170600.CME_Fo | 2017-05-21 06:25:23 Intraday data recording state for symbol 6B.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:25:23 CTS T4 FIX | Using primary service for historical data for 6C.20170600.CME_Fo | 2017-05-21 06:25:23 Intraday data recording state for symbol 6C.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:25:23 Requesting market depth updates for: ES.20170600.CME_Eq if supported. | 2017-05-21 06:25:23 CTS T4 FIX | Using primary service for historical data for ES.20170600.CME_Eq | 2017-05-21 06:25:23 Intraday data recording state for symbol ES.20170600.CME_Eq is set to download 'Pending'. | 2017-05-21 06:25:23 CTS T4 FIX | Sending security definition request for symbol 6A.20160900.CME_Fo | 2017-05-21 06:25:23 CTS T4 FIX | Using primary service for historical data for 6E.20170600.CME_Fo | 2017-05-21 06:25:23 Intraday data recording state for symbol 6E.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:25:23 Using Bid/Ask average for last trade price for AUDJPY | 2017-05-21 06:25:23 SC DTC Data | Starting real-time market data updates for: AUDJPY. ID: 35 | 2017-05-21 06:25:23 SC DTC Data | Connecting to the server ds3.sierracharts.com. Port 10048 | 2017-05-21 06:25:23 SC DTC Data | Requesting security definition data for: AUDJPY. ID: 35 | 2017-05-21 06:25:23 Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2017-05-21 06:25:23 DTC Client (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2017-05-21 06:25:23 Delaying start of download for AUDJPY | 2017-05-21 06:25:23 Requesting market depth updates for: 6E.20170600.CME_Fo if supported. | 2017-05-21 06:25:23 DTC Client (2153) | Connected. | 2017-05-21 06:25:23 SC DTC Data | Connected to server. | 2017-05-21 06:25:23 SC DTC Data | Sending Encoding Request to server | 2017-05-21 06:25:23 Symbol Error - 6A.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:25:23 CTS T4 FIX | Received 0 security definitions for underlying symbol 6A | 2017-05-21 06:25:23 'Allow Support for Sierra Chart Data Feeds' is disabled. The HO.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:25:23 CTS T4 FIX | Starting real-time market data updates for: HO.20171200.CME_NY. ID: 36 | 2017-05-21 06:25:23 CTS T4 FIX | Requesting security definition data for: HO.20171200.CME_NY. ID: 36 | 2017-05-21 06:25:23 CTS T4 FIX | Using primary service for historical data for HO.20171200.CME_NY | 2017-05-21 06:25:23 Intraday data recording state for symbol HO.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:25:23 SC DTC Data | Setting DTC encoding to Binary VLS | 2017-05-21 06:25:23 SC DTC Data | Sending logon request message. | 2017-05-21 06:25:23 Requesting market depth updates for: 6B.20170600.CME_Fo if supported. | 2017-05-21 06:25:23 SC DTC Data | Received logon response. | 2017-05-21 06:25:23 SC DTC Data | Server Name: SC Realtime Server. | 2017-05-21 06:25:23 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2017-05-21 06:25:23 SC DTC Data | Successfully connected. | 2017-05-21 06:25:23 SC DTC Data | Trading is not supported. | 2017-05-21 06:25:23 SC DTC Data | Restarting real-time data updates for symbol: AUDJPY | 2017-05-21 06:25:23 Requesting market depth updates for: YM.20170600.CME_E if supported. | 2017-05-21 06:25:23 SC DTC Data | Received security definition for symbol AUDJPY | 2017-05-21 06:25:23 CTS FIX Historical Data: Sending the Logon message. | 2017-05-21 06:25:25 CTS T4 FIX | Received 'Account Update/Balance Data' collateral report. | 2017-05-21 06:25:25 CTS FIX Historical Data: Connected to Historical data server. | 2017-05-21 06:25:25 CTS T4 FIX | Sending security definition request for symbol 6A.20170600.CME_Fo | 2017-05-21 06:25:25 CTS T4 FIX | Received matching security definition for symbol 6A.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:25:25 CTS T4 FIX | Received 1 security definitions for underlying symbol 6A | 2017-05-21 06:25:25 Contract specifications for 6A.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:25:25 Delaying start of download for AUDJPY | 2017-05-21 06:25:25 CTS T4 FIX | Sending security definition request for symbol 6B.20160900.CME_Fo | 2017-05-21 06:25:27 Symbol Error - 6B.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:25:29 CTS T4 FIX | Received 0 security definitions for underlying symbol 6B | 2017-05-21 06:25:29 CTS T4 FIX | Requesting Open Orders for account: May*. Request ID: 9498645 | 2017-05-21 06:25:29 Requesting market depth updates for: 6B.20160900.CME_Fo if supported. | 2017-05-21 06:25:29 Requesting market depth updates for: 6E.20160900.CME_Fo if supported. | 2017-05-21 06:25:29 Requesting market depth updates for: 6J.20160900.CME_Fo if supported. | 2017-05-21 06:25:29 Requesting market depth updates for: 6N.20170600.CME_Fo if supported. | 2017-05-21 06:25:29 Requesting market depth updates for: CL.20160800.CME_NY if supported. | 2017-05-21 06:25:29 Requesting market depth updates for: CL.20170100.CME_NY if supported. | 2017-05-21 06:25:29 Requesting market depth updates for: CL.20170600.CME_NY if supported. | 2017-05-21 06:25:29 Requesting market depth updates for: CL.20171200.CME_NY if supported. | 2017-05-21 06:25:29 Requesting market depth updates for: ES.20160900.CME_Eq if supported. | 2017-05-21 06:25:29 Requesting market depth updates for: GC.20160800.CME_CO if supported. | 2017-05-21 06:25:29 Requesting market depth updates for: GC.20170400.CME_CO if supported. | 2017-05-21 06:25:29 Requesting market depth updates for: NQ.20160900.CME_Eq if supported. | 2017-05-21 06:25:29 Requesting market depth updates for: YM.20160900.CME_E if supported. | 2017-05-21 06:25:29 Requesting market depth updates for: ZB.20160900.CME_F if supported. | 2017-05-21 06:25:29 Requesting market depth updates for: ZB.20170300.CME_F if supported. | 2017-05-21 06:25:29 CTS T4 FIX | No open orders for account May18CCwmitchel | 2017-05-21 06:25:29 CTS T4 FIX | Sending security definition request for symbol 6B.20170600.CME_Fo | 2017-05-21 06:25:29 CTS T4 FIX | Received matching security definition for symbol 6B.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:25:30 CTS T4 FIX | Received 1 security definitions for underlying symbol 6B | 2017-05-21 06:25:30 HD Request # 367 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-05-21 06:25:30 HD Request # 367 | Download start date-time: 2017-05-19 16:57:58.000 | 2017-05-21 06:25:30 HD Request # 367 | Using server: ds3.sierracharts.com port 10149 | 2017-05-21 06:25:30 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2017-05-21 06:25:30 Socket (2154) | Connected. | 2017-05-21 06:25:30 HD Request # 367 | Setting DTC encoding to Binary VLS | 2017-05-21 06:25:30 HD Request # 367 | Sending historical data logon request message. | 2017-05-21 06:25:30 Contract specifications for 6B.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 6.25 | 2017-05-21 06:25:30 HD Request # 367 | Requesting Intraday data. Start date-time: 2017-05-19 16:57:58. Record interval: 1. Symbol: AUDJPY | 2017-05-21 06:25:30 HD Request # 367 | Decompressing data. | 2017-05-21 06:25:30 HD Request # 367 | Receiving Intraday data for AUDJPY starting at 2017-05-19 16:57:58 | 2017-05-21 06:25:30 HD Request # 367 | Timestamp of first Intraday data file record written: 2017-05-19 16:57:58 | 2017-05-21 06:25:30 Socket (2154) | Shutdown and closed. | 2017-05-21 06:25:30 The network socket for historical data has been closed. | 2017-05-21 06:25:30 HD Request # 367 | Received 1 record from 2017-05-19 16:57:58 to 2017-05-19 16:57:58 (0.0 seconds) and wrote 1 record for AUDJPY | 2017-05-21 06:25:30 HD Request # 367 | Intraday download COMPLETE for AUDJPY. Completion time: 1s. Unique request ID: 648 | 2017-05-21 06:25:30 Removed historical data download ID 648 | 2017-05-21 06:25:30 Real-time Intraday chart data file updates started for AUDJPY | 2017-05-21 06:25:30 Opened cached Intraday file: C:\SierraChart1\Data\AUDJPY.scid | 2017-05-21 06:25:30 Intraday chart data file opened for AUDJPY | 2017-05-21 06:25:30 CTS T4 FIX | Sending security definition request for symbol 6C.20160900.CME_Fo | 2017-05-21 06:25:30 Symbol Error - 6C.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:25:32 CTS T4 FIX | Received 0 security definitions for underlying symbol 6C | 2017-05-21 06:25:32 CTS T4 FIX | Sending security definition request for symbol 6C.20170600.CME_Fo | 2017-05-21 06:25:32 CTS T4 FIX | Received matching security definition for symbol 6C.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:25:33 CTS T4 FIX | Received 1 security definitions for underlying symbol 6C | 2017-05-21 06:25:33 Contract specifications for 6C.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 5 | 2017-05-21 06:25:33 CTS T4 FIX | Sending security definition request for symbol 6E.20160900.CME_Fo | 2017-05-21 06:25:33 Symbol Error - 6E.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:25:34 CTS T4 FIX | Received 0 security definitions for underlying symbol 6E | 2017-05-21 06:25:34 CTS T4 FIX | Sending security definition request for symbol 6E.20170600.CME_Fo | 2017-05-21 06:25:34 CTS T4 FIX | Received matching security definition for symbol 6E.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:25:36 CTS T4 FIX | Received 1 security definitions for underlying symbol 6E | 2017-05-21 06:25:36 Contract specifications for 6E.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-05-21 06:25:36 CTS T4 FIX | Sending security definition request for symbol 6J.20160900.CME_Fo | 2017-05-21 06:25:37 Symbol Error - 6J.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:25:37 CTS T4 FIX | Received 0 security definitions for underlying symbol 6J | 2017-05-21 06:25:37 CTS T4 FIX | Requesting historical Fills for account: May*. Request ID: 9498649 | 2017-05-21 06:25:39 CTS T4 FIX | Sending security definition request for symbol 6J.20170600.CME_Fo | 2017-05-21 06:25:39 CTS T4 FIX | Received Account List collateral report. | 2017-05-21 06:25:39 CTS T4 FIX | Server provided no historical order fills for account 1A297B51-A416-42D4-A1C8-C9B1B4125155 | 2017-05-21 06:25:39 CTS T4 FIX | Received matching security definition for symbol 6J.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:25:39 CTS T4 FIX | Received 1 security definitions for underlying symbol 6J | 2017-05-21 06:25:39 Contract specifications for 6J.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-05-21 06:25:39 CTS T4 FIX | Sending security definition request for symbol 6N.20170600.CME_Fo | 2017-05-21 06:25:40 CTS T4 FIX | Received matching security definition for symbol 6N.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:25:40 CTS T4 FIX | Received matching security definition for symbol 6N.20170600.CME_Fo. Requesting historical data. | 2017-05-21 06:25:40 HD Request # 366 | Requesting historical Second data for 6N.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:25:40 CTS T4 FIX | Received 1 security definitions for underlying symbol 6N | 2017-05-21 06:25:40 Contract specifications for 6N.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:25:40 HD Request # 366 | Receiving Intraday data for 6N.20170600.CME_Fo starting at 2017-05-18 18:00:03 | 2017-05-21 06:25:40 HD Request # 366 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:58 | 2017-05-21 06:25:40 HD Request # 366 | Total records received: 3666 | 2017-05-21 06:25:40 HD Request # 366 | Requesting historical Second data for 6N.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:25:40 HD Request # 366 | Total records received: 3666 | 2017-05-21 06:25:41 HD Request # 366 | Requesting historical Second data for 6N.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:25:41 HD Request # 366 | Total records received: 3666 | 2017-05-21 06:25:41 HD Request # 366 | Requesting historical Second data for 6N.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:25:41 CTS T4 FIX | Sending security definition request for symbol 6S.20170600.CME_Fo | 2017-05-21 06:25:41 CTS T4 FIX | Received matching security definition for symbol 6S.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:25:41 CTS T4 FIX | Received 1 security definitions for underlying symbol 6S | 2017-05-21 06:25:41 HD Request # 366 | Total records received: 3666 | 2017-05-21 06:25:41 HD Request # 366 | Requesting historical Second data for 6N.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:25:41 Contract specifications for 6S.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 12.5 | 2017-05-21 06:25:41 HD Request # 366 | Received 3666 records from 2017-05-18 18:00:03 to 2017-05-19 16:59:58 (23.0 hours) and wrote 1 record for 6N.20170600.CME_Fo | 2017-05-21 06:25:41 HD Request # 366 | Intraday download COMPLETE for 6N.20170600.CME_Fo. Completion time: 20s. Unique request ID: 629 | 2017-05-21 06:25:41 Removed historical data download ID 629 | 2017-05-21 06:25:41 Real-time Intraday chart data file updates started for 6N.20170600.CME_Fo | 2017-05-21 06:25:41 Opened cached Intraday file: C:\SierraChart1\Data\6N.20170600.CME_Fo.scid | 2017-05-21 06:25:41 Intraday chart data file opened for 6N.20170600.CME_Fo | 2017-05-21 06:25:41 Delaying start of download for ZB.20170600.CME_F | 2017-05-21 06:25:41 Chart #6 has tagged chart #19 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:25:41 Chart #6 has tagged chart #9 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:25:41 CTS T4 FIX | Sending security definition request for symbol CL.20160800.CME_NY | 2017-05-21 06:25:43 ZT.20170600.CME_F 3 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:25:43 Chart #9 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:25:43 Chart #9 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:25:43 Chart #9 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:25:43 Symbol Error - CL.20160800.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:25:43 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2017-05-21 06:25:43 ZN.20170600.CME_F 3 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:25:43 Chart #19 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:25:43 Chart #19 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:25:43 Chart #19 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:25:43 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:25:43 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:25:43 ZB.20170600.CME_F 3 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:25:43 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:25:43 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:25:43 CTS T4 FIX | Sending security definition request for symbol CL.20170100.CME_NY | 2017-05-21 06:25:45 Symbol Error - CL.20170100.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:25:45 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2017-05-21 06:25:45 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:25:45 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:25:45 CTS T4 FIX | Sending security definition request for symbol CL.20170600.CME_NY | 2017-05-21 06:25:47 CTS T4 FIX | Received matching security definition for symbol CL.20170600.CME_NY. Subscribing to data. | 2017-05-21 06:25:48 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:25:48 Contract specifications for CL.20170600.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:25:48 CTS T4 FIX | Sending security definition request for symbol CL.20170700.CME_NY | 2017-05-21 06:25:48 CTS T4 FIX | Received matching security definition for symbol CL.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:25:49 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:25:49 Contract specifications for CL.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:25:49 CTS T4 FIX | Sending security definition request for symbol CL.20171200.CME_NY | 2017-05-21 06:25:51 CTS T4 FIX | Received matching security definition for symbol CL.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:25:51 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:25:51 Contract specifications for CL.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:25:51 CTS T4 FIX | Sending security definition request for symbol ES.20160900.CME_Eq | 2017-05-21 06:25:52 Symbol Error - ES.20160900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:25:52 CTS T4 FIX | Received 0 security definitions for underlying symbol ES | 2017-05-21 06:25:52 CTS T4 FIX | Sending security definition request for symbol ES.20170600.CME_Eq | 2017-05-21 06:25:53 CTS T4 FIX | Received matching security definition for symbol ES.20170600.CME_Eq. Subscribing to data. | 2017-05-21 06:25:53 CTS T4 FIX | Received 1 security definitions for underlying symbol ES | 2017-05-21 06:25:53 Contract specifications for ES.20170600.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 12.5 | 2017-05-21 06:25:53 CTS T4 FIX | Sending security definition request for symbol GC.20160800.CME_CO | 2017-05-21 06:25:55 Symbol Error - GC.20160800.CME_CO is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:25:55 CTS T4 FIX | Received 0 security definitions for underlying symbol GC | 2017-05-21 06:25:55 CTS T4 FIX | Sending security definition request for symbol GC.20170400.CME_CO | 2017-05-21 06:25:56 Symbol Error - GC.20170400.CME_CO is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:25:56 CTS T4 FIX | Received 0 security definitions for underlying symbol GC | 2017-05-21 06:25:56 CTS T4 FIX | Sending security definition request for symbol GC.20170600.CME_CO | 2017-05-21 06:25:57 CTS T4 FIX | Received matching security definition for symbol GC.20170600.CME_CO. Subscribing to data. | 2017-05-21 06:25:57 CTS T4 FIX | Received 1 security definitions for underlying symbol GC | 2017-05-21 06:25:57 Contract specifications for GC.20170600.CME_CO. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:25:57 CTS T4 FIX | Sending security definition request for symbol HO.20170700.CME_NY | 2017-05-21 06:25:59 CTS T4 FIX | Received matching security definition for symbol HO.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:25:59 CTS T4 FIX | Received 1 security definitions for underlying symbol HO | 2017-05-21 06:25:59 Contract specifications for HO.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:26:00 CTS T4 FIX | Sending security definition request for symbol HO.20171200.CME_NY | 2017-05-21 06:26:00 CTS T4 FIX | Received matching security definition for symbol HO.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:26:00 CTS T4 FIX | Received 1 security definitions for underlying symbol HO | 2017-05-21 06:26:00 Contract specifications for HO.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:26:02 CTS T4 FIX | Sending security definition request for symbol NQ.20160900.CME_Eq | 2017-05-21 06:26:02 Symbol Error - NQ.20160900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:26:03 CTS T4 FIX | Received 0 security definitions for underlying symbol NQ | 2017-05-21 06:26:03 CTS T4 FIX | Sending security definition request for symbol NQ.20170600.CME_Eq | 2017-05-21 06:26:03 CTS T4 FIX | Received matching security definition for symbol NQ.20170600.CME_Eq. Subscribing to data. | 2017-05-21 06:26:05 CTS T4 FIX | Received 1 security definitions for underlying symbol NQ | 2017-05-21 06:26:05 Contract specifications for NQ.20170600.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 5 | 2017-05-21 06:26:05 HD Request # 368 | Downloading Intraday chart data for ZB.20170600.CME_F to the file ZB.20170600.CME_F.scid. Service: cts | 2017-05-21 06:26:05 HD Request # 368 | Download start date-time: 2017-05-19 16:59:56.000 | 2017-05-21 06:26:05 CTS T4 FIX | Sending security definition request for symbol RB.20170700.CME_NY | 2017-05-21 06:26:05 CTS T4 FIX | Received matching security definition for symbol RB.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:26:06 CTS T4 FIX | Received 1 security definitions for underlying symbol RB | 2017-05-21 06:26:06 Contract specifications for RB.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:26:06 CTS T4 FIX | Sending security definition request for symbol RB.20171200.CME_NY | 2017-05-21 06:26:06 CTS T4 FIX | Received matching security definition for symbol RB.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:26:08 CTS T4 FIX | Received 1 security definitions for underlying symbol RB | 2017-05-21 06:26:08 Contract specifications for RB.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:26:08 CTS T4 FIX | Sending security definition request for symbol YM.20160900.CME_E | 2017-05-21 06:26:08 Symbol Error - YM.20160900.CME_E is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:26:09 CTS T4 FIX | Received 0 security definitions for underlying symbol YM | 2017-05-21 06:26:09 CTS T4 FIX | Sending security definition request for symbol YM.20170600.CME_E | 2017-05-21 06:26:09 CTS T4 FIX | Received matching security definition for symbol YM.20170600.CME_E. Subscribing to data. | 2017-05-21 06:26:11 CTS T4 FIX | Received 1 security definitions for underlying symbol YM | 2017-05-21 06:26:11 Contract specifications for YM.20170600.CME_E. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 5 | 2017-05-21 06:26:11 CTS T4 FIX | Sending security definition request for symbol ZB.20160900.CME_F | 2017-05-21 06:26:11 Symbol Error - ZB.20160900.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:26:12 CTS T4 FIX | Received 0 security definitions for underlying symbol ZB | 2017-05-21 06:26:12 CTS T4 FIX | Sending security definition request for symbol ZB.20170300.CME_F | 2017-05-21 06:26:12 Symbol Error - ZB.20170300.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:26:14 CTS T4 FIX | Received 0 security definitions for underlying symbol ZB | 2017-05-21 06:26:14 CTS T4 FIX | Sending security definition request for symbol ZB.20170600.CME_F | 2017-05-21 06:26:16 CTS T4 FIX | Received matching security definition for symbol ZB.20170600.CME_F. Subscribing to data. | 2017-05-21 06:26:16 CTS T4 FIX | Received matching security definition for symbol ZB.20170600.CME_F. Requesting historical data. | 2017-05-21 06:26:16 HD Request # 368 | Requesting historical Second data for ZB.20170600.CME_F from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:26:16 CTS T4 FIX | Received 1 security definitions for underlying symbol ZB | 2017-05-21 06:26:16 Contract specifications for ZB.20170600.CME_F. Multiplier: 0.00001000. Tick Size: 0.03125. Value Format: 132. Currency Value per Tick: 31.25 | 2017-05-21 06:26:16 HD Request # 368 | Receiving Intraday data for ZB.20170600.CME_F starting at 2017-05-18 18:00:00 | 2017-05-21 06:26:16 HD Request # 368 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:56 | 2017-05-21 06:26:16 HD Request # 368 | Total records received: 6509 | 2017-05-21 06:26:16 HD Request # 368 | Requesting historical Second data for ZB.20170600.CME_F from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:26:16 HD Request # 368 | Total records received: 6509 | 2017-05-21 06:26:18 HD Request # 368 | Requesting historical Second data for ZB.20170600.CME_F from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:26:18 HD Request # 368 | Total records received: 6509 | 2017-05-21 06:26:18 HD Request # 368 | Requesting historical Second data for ZB.20170600.CME_F from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:26:18 CTS T4 FIX | Sending security definition request for symbol ZN.20170600.CME_F | 2017-05-21 06:26:18 CTS T4 FIX | Received matching security definition for symbol ZN.20170600.CME_F. Subscribing to data. | 2017-05-21 06:26:18 CTS T4 FIX | Received 1 security definitions for underlying symbol ZN | 2017-05-21 06:26:18 HD Request # 368 | Total records received: 6509 | 2017-05-21 06:26:18 HD Request # 368 | Requesting historical Second data for ZB.20170600.CME_F from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:26:18 Contract specifications for ZN.20170600.CME_F. Multiplier: 0.00000100. Tick Size: 0.015625. Value Format: 132. Currency Value per Tick: 15.625 | 2017-05-21 06:26:18 HD Request # 368 | Received 6509 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:56 (23.0 hours) and wrote 1 record for ZB.20170600.CME_F | 2017-05-21 06:26:18 HD Request # 368 | Intraday download COMPLETE for ZB.20170600.CME_F. Completion time: 13s. Unique request ID: 630 | 2017-05-21 06:26:18 Removed historical data download ID 630 | 2017-05-21 06:26:18 Real-time Intraday chart data file updates started for ZB.20170600.CME_F | 2017-05-21 06:26:18 Opened cached Intraday file: C:\SierraChart1\Data\ZB.20170600.CME_F.scid | 2017-05-21 06:26:18 Intraday chart data file opened for ZB.20170600.CME_F | 2017-05-21 06:26:18 Delaying start of download for RB.20171200.CME_NY | 2017-05-21 06:26:18 Chart #13 has tagged chart #1 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:26:18 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:26:18 Chart #13 has tagged chart #14 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:26:18 Chart #13 has tagged chart #17 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:26:18 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:26:18 Chart #13 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:26:19 Chart #13 has tagged chart #14 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:26:19 Chart #13 has tagged chart #17 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:26:19 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:26:19 Chart #15 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:26:19 Chart #15 has tagged chart #13 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:26:19 Chart #15 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:26:19 Chart #15 has tagged chart #26 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:26:19 Chart #15 has tagged chart #5 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:26:19 6J.20170600.CME_Fo [C] 30 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:26:19 Chart #5 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:26:19 Chart #5 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:26:19 ES.20170600.CME_Eq 30 Sec #17 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:26:19 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:26:19 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:26:19 Chart #17 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:26:19 ES.20170600.CME_Eq 3 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:26:19 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:26:19 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:26:19 Chart #17 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:26:19 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:26:19 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:26:19 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:26:19 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:26:19 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:26:19 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:26:19 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:26:19 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:26:19 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:26:19 GC.20170600.CME_CO 3 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:26:19 Chart #1 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:26:19 Chart #1 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:26:19 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:26:19 ZB.20170600.CME_F [C] 15 Min #26 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:26:19 6J.20170600.CME_Fo 3 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:26:19 Chart #14 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:26:19 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:26:19 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:26:19 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:26:19 6J.20170600.CME_Fo 30 Sec #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:26:19 CTS T4 FIX | Sending security definition request for symbol ZT.20170600.CME_F | 2017-05-21 06:26:19 NQ.20170600.CME_Eq 30 Sec #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:26:26 CTS T4 FIX | Received matching security definition for symbol ZT.20170600.CME_F. Subscribing to data. | 2017-05-21 06:26:26 CTS T4 FIX | Received 1 security definitions for underlying symbol ZT | 2017-05-21 06:26:26 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:26:26 Contract specifications for ZT.20170600.CME_F. Multiplier: 0.00000010. Tick Size: 0.0078125. Value Format: 228. Currency Value per Tick: 15.625 | 2017-05-21 06:26:26 GC.20170600.CME_CO 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:26:26 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:26:26 GC.20170600.CME_CO [C] 30 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:26:26 Chart #13 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:26:26 Chart #13 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:26:26 Chart #13 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:26:26 Chart #13 has tagged chart #4 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:26:26 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:26:26 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:26:26 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:26:26 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:26:26 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:26:26 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:26:26 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:26:26 6C.20170600.CME_Fo [C] 30 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:26:26 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:26:26 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:26:26 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:26:26 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:26:26 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:26:26 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:26:26 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:26:31 HD Request # 369 | Downloading Intraday chart data for RB.20171200.CME_NY to the file RB.20171200.CME_NY.scid. Service: cts | 2017-05-21 06:26:50 HD Request # 369 | Download start date-time: 2017-05-19 16:18:13.000 | 2017-05-21 06:26:50 HD Request # 369 | Requesting historical Second data for RB.20171200.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:26:50 HD Request # 369 | Receiving Intraday data for RB.20171200.CME_NY starting at 2017-05-18 21:53:54 | 2017-05-21 06:26:50 HD Request # 369 | Timestamp of first Intraday data file record written: 2017-05-19 16:18:13 | 2017-05-21 06:26:50 HD Request # 369 | Total records received: 758 | 2017-05-21 06:26:50 HD Request # 369 | Requesting historical Second data for RB.20171200.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:26:50 HD Request # 369 | Total records received: 758 | 2017-05-21 06:26:52 HD Request # 369 | Requesting historical Second data for RB.20171200.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:26:52 HD Request # 369 | Total records received: 758 | 2017-05-21 06:26:52 HD Request # 369 | Requesting historical Second data for RB.20171200.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:26:52 HD Request # 369 | Total records received: 758 | 2017-05-21 06:26:52 HD Request # 369 | Requesting historical Second data for RB.20171200.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:26:52 HD Request # 369 | Received 758 records from 2017-05-18 21:53:54 to 2017-05-19 16:18:13 (18.4 hours) and wrote 1 record for RB.20171200.CME_NY | 2017-05-21 06:26:52 HD Request # 369 | Intraday download COMPLETE for RB.20171200.CME_NY. Completion time: 1s. Unique request ID: 631 | 2017-05-21 06:26:52 Removed historical data download ID 631 | 2017-05-21 06:26:52 Real-time Intraday chart data file updates started for RB.20171200.CME_NY | 2017-05-21 06:26:52 Opened cached Intraday file: C:\SierraChart1\Data\RB.20171200.CME_NY.scid | 2017-05-21 06:26:52 Intraday chart data file opened for RB.20171200.CME_NY | 2017-05-21 06:26:52 Delaying start of download for ZN.20170600.CME_F | 2017-05-21 06:26:52 Chart #23 has tagged chart #16 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:26:52 CL.20170700.CME_NY 3 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:26:53 Chart #16 has tagged chart #15 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:26:53 6C.20170600.CME_Fo 3 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:26:55 HD Request # 370 | Downloading Intraday chart data for ZN.20170600.CME_F to the file ZN.20170600.CME_F.scid. Service: cts | 2017-05-21 06:27:17 HD Request # 370 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:27:17 HD Request # 370 | Requesting historical Second data for ZN.20170600.CME_F from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:27:17 HD Request # 370 | Receiving Intraday data for ZN.20170600.CME_F starting at 2017-05-18 18:00:00 | 2017-05-21 06:27:17 HD Request # 370 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:27:17 HD Request # 370 | Total records received: 10370 | 2017-05-21 06:27:17 HD Request # 370 | Requesting historical Second data for ZN.20170600.CME_F from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:27:17 HD Request # 370 | Total records received: 10370 | 2017-05-21 06:27:19 HD Request # 370 | Requesting historical Second data for ZN.20170600.CME_F from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:27:19 HD Request # 370 | Total records received: 10370 | 2017-05-21 06:27:19 HD Request # 370 | Requesting historical Second data for ZN.20170600.CME_F from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:27:19 HD Request # 370 | Total records received: 10370 | 2017-05-21 06:27:19 HD Request # 370 | Requesting historical Second data for ZN.20170600.CME_F from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:27:19 HD Request # 370 | Received 10370 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for ZN.20170600.CME_F | 2017-05-21 06:27:19 HD Request # 370 | Intraday download COMPLETE for ZN.20170600.CME_F. Completion time: 2s. Unique request ID: 632 | 2017-05-21 06:27:19 Removed historical data download ID 632 | 2017-05-21 06:27:19 Real-time Intraday chart data file updates started for ZN.20170600.CME_F | 2017-05-21 06:27:19 Opened cached Intraday file: C:\SierraChart1\Data\ZN.20170600.CME_F.scid | 2017-05-21 06:27:19 Intraday chart data file opened for ZN.20170600.CME_F | 2017-05-21 06:27:19 Delaying start of download for 6J.20170600.CME_Fo | 2017-05-21 06:27:19 Chart #19 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:27:19 Chart #19 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:27:19 Chart #16 has tagged chart #13 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:19 Chart #16 has tagged chart #15 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:19 Chart #16 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:19 Chart #16 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:19 Chart #16 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:19 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:27:19 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:19 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:27:19 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:27:21 GC.20170600.CME_CO 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:27:21 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:27:21 GC.20170600.CME_CO [C] 30 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:27:21 Chart #13 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:21 Chart #13 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:21 Chart #13 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:21 Chart #13 has tagged chart #4 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:21 ZB.20170600.CME_F 30 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:27:21 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:27:21 ZB.20170600.CME_F [C] 30 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:27:21 Chart #15 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:21 Chart #15 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:21 Chart #15 has tagged chart #26 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:21 Chart #19 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:27:21 Chart #19 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:27:21 Chart #19 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:27:21 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:27:21 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:27:21 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:21 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:21 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:21 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:21 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:27:21 6C.20170600.CME_Fo [C] 30 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:27:21 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:27:21 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:27:21 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:27:21 ZB.20170600.CME_F [C] 15 Min #26 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:27:21 ZB.20170600.CME_F 3 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:27:21 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:27:21 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:27:21 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:27:21 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:21 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:27:21 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:27:28 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:27:28 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:27:28 HD Request # 371 | Downloading Intraday chart data for 6J.20170600.CME_Fo to the file 6J.20170600.CME_Fo.scid. Service: cts | 2017-05-21 06:27:51 HD Request # 371 | Download start date-time: 2017-05-19 16:59:51.000 | 2017-05-21 06:27:51 HD Request # 371 | Requesting historical Second data for 6J.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:27:51 HD Request # 371 | Receiving Intraday data for 6J.20170600.CME_Fo starting at 2017-05-18 18:00:00 | 2017-05-21 06:27:52 HD Request # 371 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:51 | 2017-05-21 06:27:52 HD Request # 371 | Total records received: 19164 | 2017-05-21 06:27:52 HD Request # 371 | Requesting historical Second data for 6J.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:27:52 HD Request # 371 | Total records received: 19164 | 2017-05-21 06:27:52 HD Request # 371 | Requesting historical Second data for 6J.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:27:52 HD Request # 371 | Total records received: 19164 | 2017-05-21 06:27:52 HD Request # 371 | Requesting historical Second data for 6J.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:27:52 HD Request # 371 | Total records received: 19164 | 2017-05-21 06:27:52 HD Request # 371 | Requesting historical Second data for 6J.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:27:52 HD Request # 371 | Received 19164 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:51 (23.0 hours) and wrote 1 record for 6J.20170600.CME_Fo | 2017-05-21 06:27:52 HD Request # 371 | Intraday download COMPLETE for 6J.20170600.CME_Fo. Completion time: 2s. Unique request ID: 633 | 2017-05-21 06:27:52 Removed historical data download ID 633 | 2017-05-21 06:27:52 Real-time Intraday chart data file updates started for 6J.20170600.CME_Fo | 2017-05-21 06:27:52 Opened cached Intraday file: C:\SierraChart1\Data\6J.20170600.CME_Fo.scid | 2017-05-21 06:27:52 Intraday chart data file opened for 6J.20170600.CME_Fo | 2017-05-21 06:27:52 Delaying start of download for 6S.20170600.CME_Fo | 2017-05-21 06:27:52 Chart #5 has tagged chart #13 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:54 Chart #5 has tagged chart #15 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:54 Chart #5 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:54 Chart #5 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:54 Chart #14 has tagged chart #1 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:27:54 Chart #14 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:27:54 Chart #14 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:27:54 ZB.20170600.CME_F 3 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:27:54 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:27:54 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:27:54 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:27:54 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:54 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:27:54 Chart #14 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:27:54 Chart #14 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:27:54 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:27:56 GC.20170600.CME_CO 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:27:56 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:27:56 GC.20170600.CME_CO [C] 30 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:27:56 Chart #13 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:56 Chart #13 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:56 Chart #13 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:56 Chart #13 has tagged chart #4 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:56 ZB.20170600.CME_F 30 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:27:56 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:27:56 ZB.20170600.CME_F [C] 30 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:27:56 Chart #15 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:56 Chart #15 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:56 Chart #15 has tagged chart #26 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:56 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:27:56 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:27:56 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:56 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:56 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:56 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:56 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:27:56 6C.20170600.CME_Fo [C] 30 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:27:56 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:27:56 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:27:56 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:27:56 GC.20170600.CME_CO 3 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:27:56 Chart #1 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:27:56 Chart #1 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:27:56 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:27:56 ZB.20170600.CME_F [C] 15 Min #26 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:27:56 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:27:56 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:27:56 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:27:56 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:28:04 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:28:04 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:28:04 HD Request # 372 | Downloading Intraday chart data for 6S.20170600.CME_Fo to the file 6S.20170600.CME_Fo.scid. Service: cts | 2017-05-21 06:28:23 HD Request # 372 | Download start date-time: 2017-05-19 16:59:35.000 | 2017-05-21 06:28:23 HD Request # 372 | Requesting historical Second data for 6S.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:28:23 HD Request # 372 | Receiving Intraday data for 6S.20170600.CME_Fo starting at 2017-05-18 18:00:00 | 2017-05-21 06:28:25 HD Request # 372 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:35 | 2017-05-21 06:28:25 HD Request # 372 | Total records received: 4884 | 2017-05-21 06:28:25 HD Request # 372 | Requesting historical Second data for 6S.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:28:25 HD Request # 372 | Total records received: 4884 | 2017-05-21 06:28:25 HD Request # 372 | Requesting historical Second data for 6S.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:28:25 HD Request # 372 | Total records received: 4884 | 2017-05-21 06:28:25 HD Request # 372 | Requesting historical Second data for 6S.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:28:25 HD Request # 372 | Total records received: 4884 | 2017-05-21 06:28:25 HD Request # 372 | Requesting historical Second data for 6S.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:28:25 HD Request # 372 | Received 4884 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:35 (23.0 hours) and wrote 1 record for 6S.20170600.CME_Fo | 2017-05-21 06:28:27 HD Request # 372 | Intraday download COMPLETE for 6S.20170600.CME_Fo. Completion time: 2s. Unique request ID: 634 | 2017-05-21 06:28:27 Removed historical data download ID 634 | 2017-05-21 06:28:27 Real-time Intraday chart data file updates started for 6S.20170600.CME_Fo | 2017-05-21 06:28:27 Opened cached Intraday file: C:\SierraChart1\Data\6S.20170600.CME_Fo.scid | 2017-05-21 06:28:27 Intraday chart data file opened for 6S.20170600.CME_Fo | 2017-05-21 06:28:27 Delaying start of download for RB.20170700.CME_NY | 2017-05-21 06:28:27 HD Request # 373 | Downloading Intraday chart data for RB.20170700.CME_NY to the file RB.20170700.CME_NY.scid. Service: cts | 2017-05-21 06:28:51 HD Request # 373 | Download start date-time: 2017-05-19 16:59:53.000 | 2017-05-21 06:28:51 HD Request # 373 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:28:51 HD Request # 373 | Receiving Intraday data for RB.20170700.CME_NY starting at 2017-05-18 18:00:00 | 2017-05-21 06:28:52 HD Request # 373 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:53 | 2017-05-21 06:28:52 HD Request # 373 | Total records received: 7454 | 2017-05-21 06:28:52 HD Request # 373 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:28:52 HD Request # 373 | Total records received: 7454 | 2017-05-21 06:28:52 HD Request # 373 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:28:52 HD Request # 373 | Total records received: 7454 | 2017-05-21 06:28:52 HD Request # 373 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:28:52 HD Request # 373 | Total records received: 7454 | 2017-05-21 06:28:52 HD Request # 373 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:28:52 HD Request # 373 | Received 7454 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:53 (23.0 hours) and wrote 1 record for RB.20170700.CME_NY | 2017-05-21 06:28:52 HD Request # 373 | Intraday download COMPLETE for RB.20170700.CME_NY. Completion time: 2s. Unique request ID: 635 | 2017-05-21 06:28:52 Removed historical data download ID 635 | 2017-05-21 06:28:52 Real-time Intraday chart data file updates started for RB.20170700.CME_NY | 2017-05-21 06:28:52 Opened cached Intraday file: C:\SierraChart1\Data\RB.20170700.CME_NY.scid | 2017-05-21 06:28:52 Intraday chart data file opened for RB.20170700.CME_NY | 2017-05-21 06:28:52 Delaying start of download for CL.20171200.CME_NY | 2017-05-21 06:28:52 Chart #18 has tagged chart #16 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:28:54 Chart #21 has tagged chart #9 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:28:54 Chart #22 has tagged chart #16 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:28:54 CL.20170700.CME_NY 30 Sec #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:28:55 CL.20170700.CME_NY [C] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:28:55 Chart #9 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:28:55 CL.20170700.CME_NY 3 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:28:55 Chart #16 has tagged chart #15 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:28:55 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:28:55 6C.20170600.CME_Fo 3 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:28:58 HD Request # 374 | Downloading Intraday chart data for CL.20171200.CME_NY to the file CL.20171200.CME_NY.scid. Service: cts | 2017-05-21 06:29:18 HD Request # 374 | Download start date-time: 2017-05-19 16:59:47.000 | 2017-05-21 06:29:18 HD Request # 374 | Requesting historical Second data for CL.20171200.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:29:18 HD Request # 374 | Receiving Intraday data for CL.20171200.CME_NY starting at 2017-05-18 18:00:18 | 2017-05-21 06:29:18 HD Request # 374 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:47 | 2017-05-21 06:29:18 HD Request # 374 | Total records received: 2449 | 2017-05-21 06:29:18 HD Request # 374 | Requesting historical Second data for CL.20171200.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:29:18 HD Request # 374 | Total records received: 2449 | 2017-05-21 06:29:18 HD Request # 374 | Requesting historical Second data for CL.20171200.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:29:18 HD Request # 374 | Total records received: 2449 | 2017-05-21 06:29:20 HD Request # 374 | Requesting historical Second data for CL.20171200.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:29:20 HD Request # 374 | Total records received: 2449 | 2017-05-21 06:29:20 HD Request # 374 | Requesting historical Second data for CL.20171200.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:29:20 HD Request # 374 | Received 2449 records from 2017-05-18 18:00:18 to 2017-05-19 16:59:47 (23.0 hours) and wrote 1 record for CL.20171200.CME_NY | 2017-05-21 06:29:20 HD Request # 374 | Intraday download COMPLETE for CL.20171200.CME_NY. Completion time: 1s. Unique request ID: 636 | 2017-05-21 06:29:20 Removed historical data download ID 636 | 2017-05-21 06:29:20 Real-time Intraday chart data file updates started for CL.20171200.CME_NY | 2017-05-21 06:29:20 Opened cached Intraday file: C:\SierraChart1\Data\CL.20171200.CME_NY.scid | 2017-05-21 06:29:20 Intraday chart data file opened for CL.20171200.CME_NY | 2017-05-21 06:29:20 Delaying start of download for GC.20170600.CME_CO | 2017-05-21 06:29:20 Chart #17 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:29:20 Chart #17 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:29:20 Chart #17 has tagged chart #9 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:29:20 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:29:20 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:29:20 Chart #21 has tagged chart #16 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:29:20 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:29:21 CL.20170700.CME_NY [C] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:29:21 Chart #9 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:29:21 Chart #6 has tagged chart #19 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:29:21 Chart #6 has tagged chart #9 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:29:21 CL.20170700.CME_NY 3 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:29:21 Chart #16 has tagged chart #15 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:29:21 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:29:21 ZN.20170600.CME_F 30 Sec #19 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:29:21 Chart #19 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:29:21 Chart #19 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:29:21 ZT.20170600.CME_F 30 Sec #9 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:29:24 Chart #9 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:29:24 Chart #9 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:29:24 GC.20170600.CME_CO 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:29:24 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:29:24 ZB.20170600.CME_F 30 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:29:24 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:29:24 6C.20170600.CME_Fo 3 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:29:24 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:29:24 HD Request # 375 | Downloading Intraday chart data for GC.20170600.CME_CO to the file GC.20170600.CME_CO.scid. Service: cts | 2017-05-21 06:29:47 HD Request # 375 | Download start date-time: 2017-05-19 16:59:57.000 | 2017-05-21 06:29:47 HD Request # 375 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:29:47 HD Request # 375 | Receiving Intraday data for GC.20170600.CME_CO starting at 2017-05-18 18:00:00 | 2017-05-21 06:29:50 HD Request # 375 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:57 | 2017-05-21 06:29:50 HD Request # 375 | Total records received: 26821 | 2017-05-21 06:29:50 HD Request # 375 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:29:50 HD Request # 375 | Total records received: 26821 | 2017-05-21 06:29:50 HD Request # 375 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:29:50 HD Request # 375 | Total records received: 26821 | 2017-05-21 06:29:50 HD Request # 375 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:29:50 HD Request # 375 | Total records received: 26821 | 2017-05-21 06:29:50 HD Request # 375 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:29:50 HD Request # 375 | Received 26821 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:57 (23.0 hours) and wrote 1 record for GC.20170600.CME_CO | 2017-05-21 06:29:50 HD Request # 375 | Intraday download COMPLETE for GC.20170600.CME_CO. Completion time: 3s. Unique request ID: 637 | 2017-05-21 06:29:50 Removed historical data download ID 637 | 2017-05-21 06:29:50 Real-time Intraday chart data file updates started for GC.20170600.CME_CO | 2017-05-21 06:29:50 Opened cached Intraday file: C:\SierraChart1\Data\GC.20170600.CME_CO.scid | 2017-05-21 06:29:50 Intraday chart data file opened for GC.20170600.CME_CO | 2017-05-21 06:29:50 Delaying start of download for YM.20170600.CME_E | 2017-05-21 06:29:50 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:29:50 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:29:52 Chart #1 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:29:52 Chart #1 has tagged chart #14 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:29:52 Chart #1 has tagged chart #17 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:29:52 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:29:52 Chart #13 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:29:52 Chart #13 has tagged chart #15 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:29:52 Chart #13 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:29:52 Chart #13 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:29:52 Chart #13 has tagged chart #4 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:29:52 Chart #13 has tagged chart #5 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:29:52 ZB.20170600.CME_F 30 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:29:52 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:29:52 ZB.20170600.CME_F [C] 30 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:29:52 Chart #15 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:29:52 Chart #15 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:29:52 Chart #15 has tagged chart #26 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:29:52 6J.20170600.CME_Fo [C] 30 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:29:52 Chart #5 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:29:52 Chart #5 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:29:52 ES.20170600.CME_Eq 30 Sec #17 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:29:52 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:29:52 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:29:52 Chart #17 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:29:52 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:29:52 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:29:52 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:29:52 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:29:52 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:29:52 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:29:52 6C.20170600.CME_Fo [C] 30 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:29:52 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:29:52 Chart #1 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:29:52 Chart #1 has tagged chart #14 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:29:52 Chart #1 has tagged chart #17 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:29:52 Chart #1 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:29:52 Chart #1 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:29:52 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:29:52 ZB.20170600.CME_F [C] 15 Min #26 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:29:52 6J.20170600.CME_Fo 3 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:29:52 Chart #14 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:29:52 ZB.20170600.CME_F 3 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:29:52 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:29:52 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:29:52 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:29:52 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:29:52 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:29:52 6J.20170600.CME_Fo 30 Sec #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:29:52 NQ.20170600.CME_Eq 30 Sec #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:29:59 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:29:59 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:29:59 ES.20170600.CME_Eq 3 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:29:59 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:29:59 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:29:59 Chart #17 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:29:59 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:29:59 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:29:59 6J.20170600.CME_Fo 3 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:29:59 Chart #14 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:29:59 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:30:02 HD Request # 376 | Downloading Intraday chart data for YM.20170600.CME_E to the file YM.20170600.CME_E.scid. Service: cts | 2017-05-21 06:30:23 HD Request # 376 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:30:23 HD Request # 376 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:30:23 HD Request # 376 | Receiving Intraday data for YM.20170600.CME_E starting at 2017-05-18 18:00:00 | 2017-05-21 06:30:24 HD Request # 376 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:30:24 HD Request # 376 | Total records received: 19680 | 2017-05-21 06:30:24 HD Request # 376 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:30:24 HD Request # 376 | Total records received: 19680 | 2017-05-21 06:30:24 HD Request # 376 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:30:24 HD Request # 376 | Total records received: 19680 | 2017-05-21 06:30:24 HD Request # 376 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:30:24 HD Request # 376 | Total records received: 19680 | 2017-05-21 06:30:24 HD Request # 376 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:30:24 HD Request # 376 | Received 19680 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for YM.20170600.CME_E | 2017-05-21 06:30:24 HD Request # 376 | Intraday download COMPLETE for YM.20170600.CME_E. Completion time: 2s. Unique request ID: 638 | 2017-05-21 06:30:24 Removed historical data download ID 638 | 2017-05-21 06:30:24 Real-time Intraday chart data file updates started for YM.20170600.CME_E | 2017-05-21 06:30:24 Opened cached Intraday file: C:\SierraChart1\Data\YM.20170600.CME_E.scid | 2017-05-21 06:30:24 Intraday chart data file opened for YM.20170600.CME_E | 2017-05-21 06:30:24 Delaying start of download for CL.20170700.CME_NY | 2017-05-21 06:30:24 Chart #3 has tagged chart #4 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:30:26 ZB.20170600.CME_F 3 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:30:27 CTS FIX socket (2151) | Closed. No error. | 2017-05-21 06:30:27 CTS FIX socket (2151) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-21 06:30:27 CTS FIX socket (2151) | SSL has been shut down. | 2017-05-21 06:30:27 CTS FIX socket (2151) | SSL object has been freed. SSL state is now disconnected. | 2017-05-21 06:30:27 CTS FIX socket (2151) | Shutdown and closed. | 2017-05-21 06:30:27 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2017-05-21 06:30:27 Connection to the external service has been lost. | 2017-05-21 06:30:27 DTC Client (2153) | Closed. No error. | 2017-05-21 06:30:27 DTC Client (2153) | Shutdown and closed. | 2017-05-21 06:30:27 SC DTC Data | Disconnected from the server. | 2017-05-21 06:30:27 SC DTC Data | Data feed disconnected. Will reconnect in 2 seconds. | 2017-05-21 06:30:27 CTS FIX Historical Data socket (2152) | Closed. No error. | 2017-05-21 06:30:27 CTS FIX Historical Data: Received a Logout message. Text = Timed out. No valid messages received within the heartbeat interval of 30 seconds | 2017-05-21 06:30:27 CTS FIX Historical Data: Sending a Logout message. Text = Received Logout message. | 2017-05-21 06:30:27 CTS FIX Historical Data socket (2152) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-21 06:30:27 CTS FIX Historical Data socket (2152) | SSL has been shut down. | 2017-05-21 06:30:27 CTS FIX Historical Data socket (2152) | SSL object has been freed. SSL state is now disconnected. | 2017-05-21 06:30:27 CTS FIX Historical Data socket (2152) | Shutdown and closed. | 2017-05-21 06:30:27 CTS FIX Historical Data: Disconnected. | 2017-05-21 06:30:27 Canceling historical data download request for CL.20170700.CME_NY Intraday data. | 2017-05-21 06:31:34 Removed historical data download ID 639 | 2017-05-21 06:31:34 Canceling historical data download request for NQ.20170600.CME_Eq Intraday data. | 2017-05-21 06:31:34 Removed historical data download ID 640 | 2017-05-21 06:31:34 Canceling historical data download request for 6A.20170600.CME_Fo Intraday data. | 2017-05-21 06:31:34 Removed historical data download ID 641 | 2017-05-21 06:31:34 Canceling historical data download request for ZT.20170600.CME_F Intraday data. | 2017-05-21 06:31:34 Removed historical data download ID 642 | 2017-05-21 06:31:34 Canceling historical data download request for HO.20170700.CME_NY Intraday data. | 2017-05-21 06:31:34 Removed historical data download ID 643 | 2017-05-21 06:31:34 Canceling historical data download request for 6B.20170600.CME_Fo Intraday data. | 2017-05-21 06:31:34 Removed historical data download ID 644 | 2017-05-21 06:31:34 Canceling historical data download request for 6C.20170600.CME_Fo Intraday data. | 2017-05-21 06:31:34 Removed historical data download ID 645 | 2017-05-21 06:31:34 Canceling historical data download request for ES.20170600.CME_Eq Intraday data. | 2017-05-21 06:31:34 Removed historical data download ID 646 | 2017-05-21 06:31:34 Canceling historical data download request for 6E.20170600.CME_Fo Intraday data. | 2017-05-21 06:31:34 Removed historical data download ID 647 | 2017-05-21 06:31:34 Canceling historical data download request for HO.20171200.CME_NY Intraday data. | 2017-05-21 06:31:34 Removed historical data download ID 649 | 2017-05-21 06:31:34 CTS T4 FIX | Disconnected. | 2017-05-21 06:31:34 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-21 06:31:34 SC DTC Data | Connecting to the server ds4.sierracharts.com. Port 443 | 2017-05-21 06:31:36 DTC Client (0) | Resolved address ds4.sierracharts.com to IP 192.81.56.146. | 2017-05-21 06:31:36 DTC Client (2158) | Connected. | 2017-05-21 06:31:36 SC DTC Data | Connected to server. | 2017-05-21 06:31:36 SC DTC Data | Sending Encoding Request to server | 2017-05-21 06:31:36 SC DTC Data | Setting DTC encoding to Binary VLS | 2017-05-21 06:31:36 SC DTC Data | Sending logon request message. | 2017-05-21 06:31:36 SC DTC Data | Received logon response. | 2017-05-21 06:31:36 SC DTC Data | Server Name: SC Realtime Server. | 2017-05-21 06:31:36 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2017-05-21 06:31:36 SC DTC Data | Successfully connected. | 2017-05-21 06:31:36 SC DTC Data | Trading is not supported. | 2017-05-21 06:31:36 Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2017-05-21 06:31:36 SC DTC Data | Restarting real-time data updates for symbol: AUDJPY | 2017-05-21 06:31:36 HD Request # 377 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-05-21 06:31:36 HD Request # 377 | Download start date-time: 2017-05-19 16:57:58.000 | 2017-05-21 06:31:36 HD Request # 377 | Using server: ds4.sierracharts.com port 10149 | 2017-05-21 06:31:36 Socket (0) | Resolved address ds4.sierracharts.com to IP 192.81.56.146. | 2017-05-21 06:31:38 Socket (2159) | Connected. | 2017-05-21 06:31:38 HD Request # 377 | Setting DTC encoding to Binary VLS | 2017-05-21 06:31:38 HD Request # 377 | Sending historical data logon request message. | 2017-05-21 06:31:38 HD Request # 377 | Requesting Intraday data. Start date-time: 2017-05-19 16:57:58. Record interval: 1. Symbol: AUDJPY | 2017-05-21 06:31:38 HD Request # 377 | Decompressing data. | 2017-05-21 06:31:38 HD Request # 377 | Receiving Intraday data for AUDJPY starting at 2017-05-19 16:57:58 | 2017-05-21 06:31:38 HD Request # 377 | Timestamp of first Intraday data file record written: 2017-05-19 16:57:58 | 2017-05-21 06:31:38 Socket (2159) | Shutdown and closed. | 2017-05-21 06:31:38 The network socket for historical data has been closed. | 2017-05-21 06:31:38 SC DTC Data | Received security definition for symbol AUDJPY | 2017-05-21 06:31:38 HD Request # 377 | Historical data for AUDJPY is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-05-21 06:31:38 HD Request # 377 | Received 1 record from 2017-05-19 16:57:58 to 2017-05-19 16:57:58 (0.0 seconds) and wrote 1 record for AUDJPY | 2017-05-21 06:31:38 HD Request # 377 | Intraday download COMPLETE for AUDJPY. Completion time: 1s. Unique request ID: 650 | 2017-05-21 06:31:38 Removed historical data download ID 650 | 2017-05-21 06:31:38 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2017-05-21 06:31:39 CTS T4 FIX | Firm: PTP | 2017-05-21 06:31:39 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 69.44.110.200. | 2017-05-21 06:31:39 CTS FIX socket (2160) | Connected. | 2017-05-21 06:31:41 CTS FIX socket (2160) | Starting TLS 1.0 connection. | 2017-05-21 06:31:41 CTS FIX socket (2160) | SSL connection established. | 2017-05-21 06:31:41 CTS FIX: Sending the Logon message. | 2017-05-21 06:31:42 CTS T4 FIX | FIX version: 4.3.74.0 | 2017-05-21 06:31:42 CTS T4 FIX | Connected to data and trading server. | 2017-05-21 06:31:42 DTC Client (2158) | Shutdown and closed. | 2017-05-21 06:31:42 SC DTC Data | Disconnected from the server. | 2017-05-21 06:31:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:42 CTS T4 FIX | Starting real-time market data updates for: ZB.20160900.CME_F. ID: 1 | 2017-05-21 06:31:42 CTS T4 FIX | Requesting security definition data for: ZB.20160900.CME_F. ID: 1 | 2017-05-21 06:31:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:42 CTS T4 FIX | Starting real-time market data updates for: 6E.20160900.CME_Fo. ID: 2 | 2017-05-21 06:31:42 CTS T4 FIX | Requesting security definition data for: 6E.20160900.CME_Fo. ID: 2 | 2017-05-21 06:31:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6J.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:42 CTS T4 FIX | Starting real-time market data updates for: 6J.20160900.CME_Fo. ID: 3 | 2017-05-21 06:31:42 CTS T4 FIX | Requesting security definition data for: 6J.20160900.CME_Fo. ID: 3 | 2017-05-21 06:31:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6B.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:42 CTS T4 FIX | Starting real-time market data updates for: 6B.20160900.CME_Fo. ID: 4 | 2017-05-21 06:31:42 CTS T4 FIX | Requesting security definition data for: 6B.20160900.CME_Fo. ID: 4 | 2017-05-21 06:31:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6C.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:42 CTS T4 FIX | Starting real-time market data updates for: 6C.20160900.CME_Fo. ID: 5 | 2017-05-21 06:31:42 CTS T4 FIX | Requesting security definition data for: 6C.20160900.CME_Fo. ID: 5 | 2017-05-21 06:31:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:42 CTS T4 FIX | Starting real-time market data updates for: CL.20160800.CME_NY. ID: 6 | 2017-05-21 06:31:42 CTS T4 FIX | Requesting security definition data for: CL.20160800.CME_NY. ID: 6 | 2017-05-21 06:31:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6A.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:42 CTS T4 FIX | Starting real-time market data updates for: 6A.20160900.CME_Fo. ID: 7 | 2017-05-21 06:31:42 CTS T4 FIX | Requesting security definition data for: 6A.20160900.CME_Fo. ID: 7 | 2017-05-21 06:31:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:42 CTS T4 FIX | Starting real-time market data updates for: NQ.20160900.CME_Eq. ID: 8 | 2017-05-21 06:31:42 CTS T4 FIX | Requesting security definition data for: NQ.20160900.CME_Eq. ID: 8 | 2017-05-21 06:31:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM.######00.CME_E pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:42 CTS T4 FIX | Starting real-time market data updates for: YM.20160900.CME_E. ID: 9 | 2017-05-21 06:31:42 CTS T4 FIX | Requesting security definition data for: YM.20160900.CME_E. ID: 9 | 2017-05-21 06:31:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:42 CTS T4 FIX | Starting real-time market data updates for: GC.20160800.CME_CO. ID: 10 | 2017-05-21 06:31:42 CTS T4 FIX | Requesting security definition data for: GC.20160800.CME_CO. ID: 10 | 2017-05-21 06:31:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:42 CTS T4 FIX | Starting real-time market data updates for: ES.20160900.CME_Eq. ID: 11 | 2017-05-21 06:31:42 CTS T4 FIX | Requesting security definition data for: ES.20160900.CME_Eq. ID: 11 | 2017-05-21 06:31:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:42 CTS T4 FIX | Starting real-time market data updates for: ZB.20170300.CME_F. ID: 12 | 2017-05-21 06:31:42 CTS T4 FIX | Requesting security definition data for: ZB.20170300.CME_F. ID: 12 | 2017-05-21 06:31:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:42 CTS T4 FIX | Starting real-time market data updates for: CL.20170100.CME_NY. ID: 13 | 2017-05-21 06:31:42 CTS T4 FIX | Requesting security definition data for: CL.20170100.CME_NY. ID: 13 | 2017-05-21 06:31:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:42 CTS T4 FIX | Starting real-time market data updates for: GC.20170400.CME_CO. ID: 14 | 2017-05-21 06:31:42 CTS T4 FIX | Requesting security definition data for: GC.20170400.CME_CO. ID: 14 | 2017-05-21 06:31:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:42 CTS T4 FIX | Starting real-time market data updates for: ZB.20170600.CME_F. ID: 15 | 2017-05-21 06:31:42 CTS T4 FIX | Requesting security definition data for: ZB.20170600.CME_F. ID: 15 | 2017-05-21 06:31:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6B.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:42 CTS T4 FIX | Starting real-time market data updates for: 6B.20170600.CME_Fo. ID: 16 | 2017-05-21 06:31:42 CTS T4 FIX | Requesting security definition data for: 6B.20170600.CME_Fo. ID: 16 | 2017-05-21 06:31:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:42 CTS T4 FIX | Starting real-time market data updates for: CL.20170600.CME_NY. ID: 17 | 2017-05-21 06:31:42 CTS T4 FIX | Requesting security definition data for: CL.20170600.CME_NY. ID: 17 | 2017-05-21 06:31:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6N.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:42 CTS T4 FIX | Starting real-time market data updates for: 6N.20170600.CME_Fo. ID: 18 | 2017-05-21 06:31:42 CTS T4 FIX | Requesting security definition data for: 6N.20170600.CME_Fo. ID: 18 | 2017-05-21 06:31:42 CTS T4 FIX | Using primary service for historical data for 6N.20170600.CME_Fo | 2017-05-21 06:31:42 Intraday data recording state for symbol 6N.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:31:42 Delaying start of download for 6N.20170600.CME_Fo | 2017-05-21 06:31:42 CTS T4 FIX | Using primary service for historical data for ZB.20170600.CME_F | 2017-05-21 06:31:42 Intraday data recording state for symbol ZB.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:31:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The RB.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:42 CTS T4 FIX | Starting real-time market data updates for: RB.20171200.CME_NY. ID: 19 | 2017-05-21 06:31:42 CTS T4 FIX | Requesting security definition data for: RB.20171200.CME_NY. ID: 19 | 2017-05-21 06:31:42 CTS T4 FIX | Using primary service for historical data for RB.20171200.CME_NY | 2017-05-21 06:31:42 Intraday data recording state for symbol RB.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:31:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZN.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:42 CTS T4 FIX | Starting real-time market data updates for: ZN.20170600.CME_F. ID: 20 | 2017-05-21 06:31:42 CTS T4 FIX | Requesting security definition data for: ZN.20170600.CME_F. ID: 20 | 2017-05-21 06:31:42 CTS T4 FIX | Using primary service for historical data for ZN.20170600.CME_F | 2017-05-21 06:31:42 Intraday data recording state for symbol ZN.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:31:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6J.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:42 CTS T4 FIX | Starting real-time market data updates for: 6J.20170600.CME_Fo. ID: 21 | 2017-05-21 06:31:42 CTS T4 FIX | Requesting security definition data for: 6J.20170600.CME_Fo. ID: 21 | 2017-05-21 06:31:42 CTS T4 FIX | Using primary service for historical data for 6J.20170600.CME_Fo | 2017-05-21 06:31:42 Intraday data recording state for symbol 6J.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:31:42 CTS T4 FIX | Received Account List collateral report. | 2017-05-21 06:31:42 CTS T4 FIX | Subscribing to account: May* | 2017-05-21 06:31:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6S.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:42 CTS T4 FIX | Starting real-time market data updates for: 6S.20170600.CME_Fo. ID: 22 | 2017-05-21 06:31:42 CTS T4 FIX | Requesting security definition data for: 6S.20170600.CME_Fo. ID: 22 | 2017-05-21 06:31:42 CTS T4 FIX | Using primary service for historical data for 6S.20170600.CME_Fo | 2017-05-21 06:31:42 Intraday data recording state for symbol 6S.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:31:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The RB.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:42 CTS T4 FIX | Starting real-time market data updates for: RB.20170700.CME_NY. ID: 23 | 2017-05-21 06:31:42 CTS T4 FIX | Requesting security definition data for: RB.20170700.CME_NY. ID: 23 | 2017-05-21 06:31:42 CTS T4 FIX | Using primary service for historical data for RB.20170700.CME_NY | 2017-05-21 06:31:42 Intraday data recording state for symbol RB.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:31:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:42 CTS T4 FIX | Starting real-time market data updates for: CL.20171200.CME_NY. ID: 24 | 2017-05-21 06:31:42 CTS T4 FIX | Requesting security definition data for: CL.20171200.CME_NY. ID: 24 | 2017-05-21 06:31:42 CTS T4 FIX | Using primary service for historical data for CL.20171200.CME_NY | 2017-05-21 06:31:42 Intraday data recording state for symbol CL.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:31:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:42 CTS T4 FIX | Starting real-time market data updates for: GC.20170600.CME_CO. ID: 25 | 2017-05-21 06:31:42 CTS T4 FIX | Requesting security definition data for: GC.20170600.CME_CO. ID: 25 | 2017-05-21 06:31:42 CTS T4 FIX | Using primary service for historical data for GC.20170600.CME_CO | 2017-05-21 06:31:42 Intraday data recording state for symbol GC.20170600.CME_CO is set to download 'Pending'. | 2017-05-21 06:31:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM.######00.CME_E pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:42 CTS T4 FIX | Starting real-time market data updates for: YM.20170600.CME_E. ID: 26 | 2017-05-21 06:31:42 CTS T4 FIX | Requesting security definition data for: YM.20170600.CME_E. ID: 26 | 2017-05-21 06:31:42 CTS T4 FIX | Using primary service for historical data for YM.20170600.CME_E | 2017-05-21 06:31:42 Intraday data recording state for symbol YM.20170600.CME_E is set to download 'Pending'. | 2017-05-21 06:31:42 Supported exchange: CME_CO (SIM:COMEX Futures) | 2017-05-21 06:31:42 Supported exchange: CME_EqOp (SIM:CME Equity Options) | 2017-05-21 06:31:42 Requesting market depth updates for: 6J.20170600.CME_Fo if supported. | 2017-05-21 06:31:42 Supported exchange: CME_NYOp (SIM:NYMEX Options) | 2017-05-21 06:31:42 Supported exchange: CME_AgOp (SIM:CME Agricultural Options) | 2017-05-21 06:31:42 Supported exchange: CME_Eq (SIM:CME Equity Futures) | 2017-05-21 06:31:42 Supported exchange: CME_In (SIM:CME Interest Rate Futures) | 2017-05-21 06:31:42 Supported exchange: CME_C (SIM:CBOT Commodity Futures) | 2017-05-21 06:31:42 Supported exchange: CME_KOp (SIM:KCBT Options) | 2017-05-21 06:31:42 Supported exchange: CME_F (SIM:CBOT Financial Futures) | 2017-05-21 06:31:42 Supported exchange: CME_E (SIM:CBOT Equity Futures) | 2017-05-21 06:31:42 Supported exchange: CME_COp (SIM:CBOT Commodity Options) | 2017-05-21 06:31:42 Supported exchange: CME_K (SIM:KCBT Futures) | 2017-05-21 06:31:42 Supported exchange: CME_EOp (SIM:CBOT Equity Options) | 2017-05-21 06:31:42 Supported exchange: CME_NY (SIM:NYMEX Futures) | 2017-05-21 06:31:42 Supported exchange: CME_Fo (SIM:CME Foreign Exchange Futures) | 2017-05-21 06:31:42 Supported exchange: CME_Ag (SIM:CME Agricultural Futures) | 2017-05-21 06:31:42 Supported exchange: CME_FoOp (SIM:CME Foreign Exchange Options) | 2017-05-21 06:31:42 Supported exchange: CME_FOp (SIM:CBOT Financial Options) | 2017-05-21 06:31:42 Supported exchange: CME_InOp (SIM:CME Interest Rate Options) | 2017-05-21 06:31:42 Supported exchange: CME_COOp (SIM:COMEX Options) | 2017-05-21 06:31:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:42 CTS T4 FIX | Starting real-time market data updates for: CL.20170700.CME_NY. ID: 27 | 2017-05-21 06:31:42 CTS T4 FIX | Requesting security definition data for: CL.20170700.CME_NY. ID: 27 | 2017-05-21 06:31:42 CTS T4 FIX | Using primary service for historical data for CL.20170700.CME_NY | 2017-05-21 06:31:42 Intraday data recording state for symbol CL.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:31:42 HD Request # 378 | Downloading Intraday chart data for 6N.20170600.CME_Fo to the file 6N.20170600.CME_Fo.scid. Service: cts | 2017-05-21 06:31:42 HD Request # 378 | Download start date-time: 2017-05-19 16:59:58.000 | 2017-05-21 06:31:42 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2017-05-21 06:31:42 CTS FIX Historical Data socket (0) | Resolved address fix-chart-sim.t4login.com to IP 74.201.6.229. | 2017-05-21 06:31:42 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:47 CTS T4 FIX | Starting real-time market data updates for: NQ.20170600.CME_Eq. ID: 28 | 2017-05-21 06:31:47 CTS T4 FIX | Requesting security definition data for: NQ.20170600.CME_Eq. ID: 28 | 2017-05-21 06:31:47 Requesting market depth updates for: NQ.20170600.CME_Eq if supported. | 2017-05-21 06:31:47 CTS T4 FIX | Using primary service for historical data for NQ.20170600.CME_Eq | 2017-05-21 06:31:47 Intraday data recording state for symbol NQ.20170600.CME_Eq is set to download 'Pending'. | 2017-05-21 06:31:47 CTS FIX Historical Data socket (2161) | Connected. | 2017-05-21 06:31:47 CTS FIX Historical Data socket (2161) | Starting TLS 1.0 connection. | 2017-05-21 06:31:47 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6A.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:47 CTS T4 FIX | Starting real-time market data updates for: 6A.20170600.CME_Fo. ID: 29 | 2017-05-21 06:31:47 CTS T4 FIX | Requesting security definition data for: 6A.20170600.CME_Fo. ID: 29 | 2017-05-21 06:31:47 CTS T4 FIX | Using primary service for historical data for 6A.20170600.CME_Fo | 2017-05-21 06:31:47 Intraday data recording state for symbol 6A.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:31:47 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZT.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:47 CTS T4 FIX | Starting real-time market data updates for: ZT.20170600.CME_F. ID: 30 | 2017-05-21 06:31:47 CTS T4 FIX | Requesting security definition data for: ZT.20170600.CME_F. ID: 30 | 2017-05-21 06:31:47 CTS T4 FIX | Using primary service for historical data for ZT.20170600.CME_F | 2017-05-21 06:31:47 Intraday data recording state for symbol ZT.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:31:47 'Allow Support for Sierra Chart Data Feeds' is disabled. The HO.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:47 CTS T4 FIX | Starting real-time market data updates for: HO.20170700.CME_NY. ID: 31 | 2017-05-21 06:31:47 CTS T4 FIX | Requesting security definition data for: HO.20170700.CME_NY. ID: 31 | 2017-05-21 06:31:47 CTS T4 FIX | Using primary service for historical data for HO.20170700.CME_NY | 2017-05-21 06:31:47 Intraday data recording state for symbol HO.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:31:47 Requesting market depth updates for: GC.20170600.CME_CO if supported. | 2017-05-21 06:31:47 CTS FIX Historical Data socket (2161) | SSL connection established. | 2017-05-21 06:31:47 Requesting market depth updates for: CL.20170700.CME_NY if supported. | 2017-05-21 06:31:47 Requesting market depth updates for: ZB.20170600.CME_F if supported. | 2017-05-21 06:31:47 CTS T4 FIX | Using primary service for historical data for 6B.20170600.CME_Fo | 2017-05-21 06:31:47 Intraday data recording state for symbol 6B.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:31:47 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6C.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:47 CTS T4 FIX | Starting real-time market data updates for: 6C.20170600.CME_Fo. ID: 32 | 2017-05-21 06:31:47 CTS T4 FIX | Requesting security definition data for: 6C.20170600.CME_Fo. ID: 32 | 2017-05-21 06:31:47 CTS T4 FIX | Using primary service for historical data for 6C.20170600.CME_Fo | 2017-05-21 06:31:47 Intraday data recording state for symbol 6C.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:31:47 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:47 CTS T4 FIX | Starting real-time market data updates for: ES.20170600.CME_Eq. ID: 33 | 2017-05-21 06:31:47 CTS T4 FIX | Requesting security definition data for: ES.20170600.CME_Eq. ID: 33 | 2017-05-21 06:31:47 Requesting market depth updates for: ES.20170600.CME_Eq if supported. | 2017-05-21 06:31:47 CTS T4 FIX | Using primary service for historical data for ES.20170600.CME_Eq | 2017-05-21 06:31:47 Intraday data recording state for symbol ES.20170600.CME_Eq is set to download 'Pending'. | 2017-05-21 06:31:47 CTS T4 FIX | Sending security definition request for symbol 6A.20160900.CME_Fo | 2017-05-21 06:31:47 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:47 CTS T4 FIX | Starting real-time market data updates for: 6E.20170600.CME_Fo. ID: 34 | 2017-05-21 06:31:47 CTS T4 FIX | Requesting security definition data for: 6E.20170600.CME_Fo. ID: 34 | 2017-05-21 06:31:47 CTS T4 FIX | Using primary service for historical data for 6E.20170600.CME_Fo | 2017-05-21 06:31:47 Intraday data recording state for symbol 6E.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:31:47 Using Bid/Ask average for last trade price for AUDJPY | 2017-05-21 06:31:47 SC DTC Data | Starting real-time market data updates for: AUDJPY. ID: 35 | 2017-05-21 06:31:47 SC DTC Data | Connecting to the server ds3.sierracharts.com. Port 10048 | 2017-05-21 06:31:47 SC DTC Data | Requesting security definition data for: AUDJPY. ID: 35 | 2017-05-21 06:31:47 Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2017-05-21 06:31:47 DTC Client (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2017-05-21 06:31:47 Delaying start of download for AUDJPY | 2017-05-21 06:31:47 Symbol Error - 6A.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:31:47 CTS T4 FIX | Received 0 security definitions for underlying symbol 6A | 2017-05-21 06:31:47 Requesting market depth updates for: 6E.20170600.CME_Fo if supported. | 2017-05-21 06:31:47 DTC Client (2162) | Connected. | 2017-05-21 06:31:47 SC DTC Data | Connected to server. | 2017-05-21 06:31:47 SC DTC Data | Sending Encoding Request to server | 2017-05-21 06:31:47 'Allow Support for Sierra Chart Data Feeds' is disabled. The HO.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:31:47 CTS T4 FIX | Starting real-time market data updates for: HO.20171200.CME_NY. ID: 36 | 2017-05-21 06:31:47 CTS T4 FIX | Requesting security definition data for: HO.20171200.CME_NY. ID: 36 | 2017-05-21 06:31:47 CTS T4 FIX | Using primary service for historical data for HO.20171200.CME_NY | 2017-05-21 06:31:47 Intraday data recording state for symbol HO.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:31:47 SC DTC Data | Setting DTC encoding to Binary VLS | 2017-05-21 06:31:47 SC DTC Data | Sending logon request message. | 2017-05-21 06:31:47 Requesting market depth updates for: 6B.20170600.CME_Fo if supported. | 2017-05-21 06:31:47 SC DTC Data | Received logon response. | 2017-05-21 06:31:47 SC DTC Data | Server Name: SC Realtime Server. | 2017-05-21 06:31:47 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2017-05-21 06:31:47 SC DTC Data | Successfully connected. | 2017-05-21 06:31:47 SC DTC Data | Trading is not supported. | 2017-05-21 06:31:47 SC DTC Data | Restarting real-time data updates for symbol: AUDJPY | 2017-05-21 06:31:47 Requesting market depth updates for: YM.20170600.CME_E if supported. | 2017-05-21 06:31:47 SC DTC Data | Received security definition for symbol AUDJPY | 2017-05-21 06:31:47 CTS FIX Historical Data: Sending the Logon message. | 2017-05-21 06:31:50 CTS T4 FIX | Sending security definition request for symbol 6A.20170600.CME_Fo | 2017-05-21 06:31:50 Delaying start of download for AUDJPY | 2017-05-21 06:31:52 CTS FIX Historical Data: Connected to Historical data server. | 2017-05-21 06:31:52 CTS T4 FIX | Received 'Account Update/Balance Data' collateral report. | 2017-05-21 06:31:52 CTS T4 FIX | Received matching security definition for symbol 6A.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:31:52 CTS T4 FIX | Received 1 security definitions for underlying symbol 6A | 2017-05-21 06:31:52 CTS T4 FIX | Sending security definition request for symbol 6B.20160900.CME_Fo | 2017-05-21 06:31:52 Contract specifications for 6A.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:31:52 Symbol Error - 6B.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:31:52 CTS T4 FIX | Received 0 security definitions for underlying symbol 6B | 2017-05-21 06:31:52 Requesting market depth updates for: 6B.20160900.CME_Fo if supported. | 2017-05-21 06:31:53 Requesting market depth updates for: 6E.20160900.CME_Fo if supported. | 2017-05-21 06:31:53 Requesting market depth updates for: 6J.20160900.CME_Fo if supported. | 2017-05-21 06:31:53 Requesting market depth updates for: 6N.20170600.CME_Fo if supported. | 2017-05-21 06:31:53 Requesting market depth updates for: CL.20160800.CME_NY if supported. | 2017-05-21 06:31:53 Requesting market depth updates for: CL.20170100.CME_NY if supported. | 2017-05-21 06:31:53 Requesting market depth updates for: CL.20170600.CME_NY if supported. | 2017-05-21 06:31:53 Requesting market depth updates for: CL.20171200.CME_NY if supported. | 2017-05-21 06:31:53 Requesting market depth updates for: ES.20160900.CME_Eq if supported. | 2017-05-21 06:31:53 Requesting market depth updates for: GC.20160800.CME_CO if supported. | 2017-05-21 06:31:53 Requesting market depth updates for: GC.20170400.CME_CO if supported. | 2017-05-21 06:31:53 Requesting market depth updates for: NQ.20160900.CME_Eq if supported. | 2017-05-21 06:31:53 Requesting market depth updates for: YM.20160900.CME_E if supported. | 2017-05-21 06:31:53 Requesting market depth updates for: ZB.20160900.CME_F if supported. | 2017-05-21 06:31:53 Requesting market depth updates for: ZB.20170300.CME_F if supported. | 2017-05-21 06:31:53 CTS T4 FIX | Requesting Open Orders for account: May*. Request ID: 9498706 | 2017-05-21 06:31:53 CTS T4 FIX | No open orders for account May18CCwmitchel | 2017-05-21 06:31:53 HD Request # 379 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-05-21 06:31:53 HD Request # 379 | Download start date-time: 2017-05-19 16:57:58.000 | 2017-05-21 06:31:53 HD Request # 379 | Using server: ds3.sierracharts.com port 10149 | 2017-05-21 06:31:53 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2017-05-21 06:31:53 Socket (2163) | Connected. | 2017-05-21 06:31:53 HD Request # 379 | Setting DTC encoding to Binary VLS | 2017-05-21 06:31:53 HD Request # 379 | Sending historical data logon request message. | 2017-05-21 06:31:53 HD Request # 379 | Requesting Intraday data. Start date-time: 2017-05-19 16:57:58. Record interval: 1. Symbol: AUDJPY | 2017-05-21 06:31:55 HD Request # 379 | Decompressing data. | 2017-05-21 06:31:55 HD Request # 379 | Receiving Intraday data for AUDJPY starting at 2017-05-19 16:57:58 | 2017-05-21 06:31:55 HD Request # 379 | Timestamp of first Intraday data file record written: 2017-05-19 16:57:58 | 2017-05-21 06:31:55 Socket (2163) | Shutdown and closed. | 2017-05-21 06:31:55 The network socket for historical data has been closed. | 2017-05-21 06:31:55 HD Request # 379 | Received 1 record from 2017-05-19 16:57:58 to 2017-05-19 16:57:58 (0.0 seconds) and wrote 1 record for AUDJPY | 2017-05-21 06:31:55 HD Request # 379 | Intraday download COMPLETE for AUDJPY. Completion time: 0s. Unique request ID: 670 | 2017-05-21 06:31:55 Removed historical data download ID 670 | 2017-05-21 06:31:55 Real-time Intraday chart data file updates started for AUDJPY | 2017-05-21 06:31:55 Opened cached Intraday file: C:\SierraChart1\Data\AUDJPY.scid | 2017-05-21 06:31:55 Intraday chart data file opened for AUDJPY | 2017-05-21 06:31:55 CTS T4 FIX | Sending security definition request for symbol 6B.20170600.CME_Fo | 2017-05-21 06:31:55 CTS T4 FIX | Received matching security definition for symbol 6B.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:31:55 CTS T4 FIX | Received 1 security definitions for underlying symbol 6B | 2017-05-21 06:31:55 Contract specifications for 6B.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 6.25 | 2017-05-21 06:31:55 CTS T4 FIX | Sending security definition request for symbol 6C.20160900.CME_Fo | 2017-05-21 06:31:58 Symbol Error - 6C.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:31:58 CTS T4 FIX | Received 0 security definitions for underlying symbol 6C | 2017-05-21 06:31:58 CTS T4 FIX | Sending security definition request for symbol 6C.20170600.CME_Fo | 2017-05-21 06:31:59 CTS T4 FIX | Received matching security definition for symbol 6C.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:31:59 CTS T4 FIX | Received 1 security definitions for underlying symbol 6C | 2017-05-21 06:31:59 Contract specifications for 6C.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 5 | 2017-05-21 06:31:59 CTS T4 FIX | Sending security definition request for symbol 6E.20160900.CME_Fo | 2017-05-21 06:32:01 Symbol Error - 6E.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:32:01 CTS T4 FIX | Received 0 security definitions for underlying symbol 6E | 2017-05-21 06:32:01 CTS T4 FIX | Sending security definition request for symbol 6E.20170600.CME_Fo | 2017-05-21 06:32:02 CTS T4 FIX | Requesting historical Fills for account: May*. Request ID: 9498709 | 2017-05-21 06:32:02 CTS T4 FIX | Received matching security definition for symbol 6E.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:32:02 CTS T4 FIX | Received 1 security definitions for underlying symbol 6E | 2017-05-21 06:32:02 CTS T4 FIX | Received Account List collateral report. | 2017-05-21 06:32:02 CTS T4 FIX | Server provided no historical order fills for account 1A297B51-A416-42D4-A1C8-C9B1B4125155 | 2017-05-21 06:32:02 Contract specifications for 6E.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-05-21 06:32:02 CTS T4 FIX | Sending security definition request for symbol 6J.20160900.CME_Fo | 2017-05-21 06:32:04 Symbol Error - 6J.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:32:04 CTS T4 FIX | Received 0 security definitions for underlying symbol 6J | 2017-05-21 06:32:04 CTS T4 FIX | Sending security definition request for symbol 6J.20170600.CME_Fo | 2017-05-21 06:32:05 CTS T4 FIX | Received matching security definition for symbol 6J.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:32:05 CTS T4 FIX | Received 1 security definitions for underlying symbol 6J | 2017-05-21 06:32:05 Contract specifications for 6J.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-05-21 06:32:05 CTS T4 FIX | Sending security definition request for symbol 6N.20170600.CME_Fo | 2017-05-21 06:32:08 CTS T4 FIX | Received matching security definition for symbol 6N.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:32:08 CTS T4 FIX | Received matching security definition for symbol 6N.20170600.CME_Fo. Requesting historical data. | 2017-05-21 06:32:08 HD Request # 378 | Requesting historical Second data for 6N.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:32:08 CTS T4 FIX | Received 1 security definitions for underlying symbol 6N | 2017-05-21 06:32:08 Contract specifications for 6N.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:32:08 HD Request # 378 | Receiving Intraday data for 6N.20170600.CME_Fo starting at 2017-05-18 18:00:03 | 2017-05-21 06:32:08 HD Request # 378 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:58 | 2017-05-21 06:32:08 HD Request # 378 | Total records received: 3666 | 2017-05-21 06:32:08 HD Request # 378 | Requesting historical Second data for 6N.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:32:08 HD Request # 378 | Total records received: 3666 | 2017-05-21 06:32:10 HD Request # 378 | Requesting historical Second data for 6N.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:32:10 HD Request # 378 | Total records received: 3666 | 2017-05-21 06:32:10 HD Request # 378 | Requesting historical Second data for 6N.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:32:10 HD Request # 378 | Total records received: 3666 | 2017-05-21 06:32:10 HD Request # 378 | Requesting historical Second data for 6N.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:32:10 HD Request # 378 | Received 3666 records from 2017-05-18 18:00:03 to 2017-05-19 16:59:58 (23.0 hours) and wrote 1 record for 6N.20170600.CME_Fo | 2017-05-21 06:32:10 HD Request # 378 | Intraday download COMPLETE for 6N.20170600.CME_Fo. Completion time: 24s. Unique request ID: 651 | 2017-05-21 06:32:10 Removed historical data download ID 651 | 2017-05-21 06:32:10 Real-time Intraday chart data file updates started for 6N.20170600.CME_Fo | 2017-05-21 06:32:10 Opened cached Intraday file: C:\SierraChart1\Data\6N.20170600.CME_Fo.scid | 2017-05-21 06:32:10 Intraday chart data file opened for 6N.20170600.CME_Fo | 2017-05-21 06:32:10 Delaying start of download for ZB.20170600.CME_F | 2017-05-21 06:32:10 Chart #6 has tagged chart #19 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:32:11 Chart #6 has tagged chart #9 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:32:11 CTS T4 FIX | Sending security definition request for symbol 6S.20170600.CME_Fo | 2017-05-21 06:32:11 CTS T4 FIX | Received matching security definition for symbol 6S.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:32:11 CTS T4 FIX | Received 1 security definitions for underlying symbol 6S | 2017-05-21 06:32:11 Contract specifications for 6S.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 12.5 | 2017-05-21 06:32:11 ZT.20170600.CME_F 3 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:32:11 Chart #9 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:32:11 Chart #9 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:32:11 Chart #9 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:32:11 ZN.20170600.CME_F 3 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:32:11 Chart #19 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:32:11 Chart #19 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:32:11 Chart #19 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:32:11 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:32:11 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:32:11 ZB.20170600.CME_F 3 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:32:14 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:32:14 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:32:14 CTS T4 FIX | Sending security definition request for symbol CL.20160800.CME_NY | 2017-05-21 06:32:14 Symbol Error - CL.20160800.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:32:14 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2017-05-21 06:32:14 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:32:14 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:32:14 CTS T4 FIX | Sending security definition request for symbol CL.20170100.CME_NY | 2017-05-21 06:32:16 Symbol Error - CL.20170100.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:32:16 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2017-05-21 06:32:16 CTS T4 FIX | Sending security definition request for symbol CL.20170600.CME_NY | 2017-05-21 06:32:19 CTS T4 FIX | Received matching security definition for symbol CL.20170600.CME_NY. Subscribing to data. | 2017-05-21 06:32:19 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:32:19 Contract specifications for CL.20170600.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:32:19 CTS T4 FIX | Sending security definition request for symbol CL.20170700.CME_NY | 2017-05-21 06:32:20 CTS T4 FIX | Received matching security definition for symbol CL.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:32:20 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:32:20 Contract specifications for CL.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:32:20 CTS T4 FIX | Sending security definition request for symbol CL.20171200.CME_NY | 2017-05-21 06:32:22 CTS T4 FIX | Received matching security definition for symbol CL.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:32:22 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:32:22 Contract specifications for CL.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:32:22 CTS T4 FIX | Sending security definition request for symbol ES.20160900.CME_Eq | 2017-05-21 06:32:24 Symbol Error - ES.20160900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:32:24 CTS T4 FIX | Received 0 security definitions for underlying symbol ES | 2017-05-21 06:32:24 CTS T4 FIX | Sending security definition request for symbol ES.20170600.CME_Eq | 2017-05-21 06:32:25 CTS T4 FIX | Received matching security definition for symbol ES.20170600.CME_Eq. Subscribing to data. | 2017-05-21 06:32:25 CTS T4 FIX | Received 1 security definitions for underlying symbol ES | 2017-05-21 06:32:25 Contract specifications for ES.20170600.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 12.5 | 2017-05-21 06:32:25 CTS T4 FIX | Sending security definition request for symbol GC.20160800.CME_CO | 2017-05-21 06:32:27 Symbol Error - GC.20160800.CME_CO is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:32:27 CTS T4 FIX | Received 0 security definitions for underlying symbol GC | 2017-05-21 06:32:27 CTS T4 FIX | Sending security definition request for symbol GC.20170400.CME_CO | 2017-05-21 06:32:30 Symbol Error - GC.20170400.CME_CO is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:32:30 CTS T4 FIX | Received 0 security definitions for underlying symbol GC | 2017-05-21 06:32:30 CTS T4 FIX | Sending security definition request for symbol GC.20170600.CME_CO | 2017-05-21 06:32:31 CTS T4 FIX | Received matching security definition for symbol GC.20170600.CME_CO. Subscribing to data. | 2017-05-21 06:32:31 CTS T4 FIX | Received 1 security definitions for underlying symbol GC | 2017-05-21 06:32:31 Contract specifications for GC.20170600.CME_CO. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:32:31 CTS T4 FIX | Sending security definition request for symbol HO.20170700.CME_NY | 2017-05-21 06:32:33 CTS T4 FIX | Received matching security definition for symbol HO.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:32:33 CTS T4 FIX | Received 1 security definitions for underlying symbol HO | 2017-05-21 06:32:33 Contract specifications for HO.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:32:33 CTS T4 FIX | Sending security definition request for symbol HO.20171200.CME_NY | 2017-05-21 06:32:34 CTS T4 FIX | Received matching security definition for symbol HO.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:32:34 CTS T4 FIX | Received 1 security definitions for underlying symbol HO | 2017-05-21 06:32:34 Contract specifications for HO.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:32:34 CTS T4 FIX | Sending security definition request for symbol NQ.20160900.CME_Eq | 2017-05-21 06:32:36 Symbol Error - NQ.20160900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:32:36 CTS T4 FIX | Received 0 security definitions for underlying symbol NQ | 2017-05-21 06:32:36 HD Request # 380 | Downloading Intraday chart data for ZB.20170600.CME_F to the file ZB.20170600.CME_F.scid. Service: cts | 2017-05-21 06:32:36 HD Request # 380 | Download start date-time: 2017-05-19 16:59:56.000 | 2017-05-21 06:32:36 CTS T4 FIX | Sending security definition request for symbol NQ.20170600.CME_Eq | 2017-05-21 06:32:37 CTS T4 FIX | Received matching security definition for symbol NQ.20170600.CME_Eq. Subscribing to data. | 2017-05-21 06:32:39 CTS T4 FIX | Received 1 security definitions for underlying symbol NQ | 2017-05-21 06:32:39 Contract specifications for NQ.20170600.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 5 | 2017-05-21 06:32:39 CTS T4 FIX | Sending security definition request for symbol RB.20170700.CME_NY | 2017-05-21 06:32:39 CTS T4 FIX | Received matching security definition for symbol RB.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:32:41 CTS T4 FIX | Received 1 security definitions for underlying symbol RB | 2017-05-21 06:32:41 Contract specifications for RB.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:32:41 CTS T4 FIX | Sending security definition request for symbol RB.20171200.CME_NY | 2017-05-21 06:32:41 CTS T4 FIX | Received matching security definition for symbol RB.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:32:41 CTS T4 FIX | Received 1 security definitions for underlying symbol RB | 2017-05-21 06:32:41 Contract specifications for RB.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:32:42 CTS T4 FIX | Sending security definition request for symbol YM.20160900.CME_E | 2017-05-21 06:32:42 Symbol Error - YM.20160900.CME_E is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:32:42 CTS T4 FIX | Received 0 security definitions for underlying symbol YM | 2017-05-21 06:32:42 CTS T4 FIX | Sending security definition request for symbol YM.20170600.CME_E | 2017-05-21 06:32:44 CTS T4 FIX | Received matching security definition for symbol YM.20170600.CME_E. Subscribing to data. | 2017-05-21 06:32:45 CTS T4 FIX | Received 1 security definitions for underlying symbol YM | 2017-05-21 06:32:45 Contract specifications for YM.20170600.CME_E. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 5 | 2017-05-21 06:32:45 CTS T4 FIX | Sending security definition request for symbol ZB.20160900.CME_F | 2017-05-21 06:32:45 Symbol Error - ZB.20160900.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:32:45 CTS T4 FIX | Received 0 security definitions for underlying symbol ZB | 2017-05-21 06:32:45 CTS T4 FIX | Sending security definition request for symbol ZB.20170300.CME_F | 2017-05-21 06:32:47 Symbol Error - ZB.20170300.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:32:47 CTS T4 FIX | Received 0 security definitions for underlying symbol ZB | 2017-05-21 06:32:47 CTS T4 FIX | Sending security definition request for symbol ZB.20170600.CME_F | 2017-05-21 06:32:48 CTS T4 FIX | Received matching security definition for symbol ZB.20170600.CME_F. Subscribing to data. | 2017-05-21 06:32:48 CTS T4 FIX | Received matching security definition for symbol ZB.20170600.CME_F. Requesting historical data. | 2017-05-21 06:32:48 HD Request # 380 | Requesting historical Second data for ZB.20170600.CME_F from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:32:48 CTS T4 FIX | Received 1 security definitions for underlying symbol ZB | 2017-05-21 06:32:48 Contract specifications for ZB.20170600.CME_F. Multiplier: 0.00001000. Tick Size: 0.03125. Value Format: 132. Currency Value per Tick: 31.25 | 2017-05-21 06:32:48 CTS T4 FIX | Sending security definition request for symbol ZN.20170600.CME_F | 2017-05-21 06:32:50 CTS T4 FIX | Received matching security definition for symbol ZN.20170600.CME_F. Subscribing to data. | 2017-05-21 06:32:50 CTS T4 FIX | Received 1 security definitions for underlying symbol ZN | 2017-05-21 06:32:50 Contract specifications for ZN.20170600.CME_F. Multiplier: 0.00000100. Tick Size: 0.015625. Value Format: 132. Currency Value per Tick: 15.625 | 2017-05-21 06:32:50 HD Request # 380 | Receiving Intraday data for ZB.20170600.CME_F starting at 2017-05-18 18:00:00 | 2017-05-21 06:32:51 HD Request # 380 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:56 | 2017-05-21 06:32:51 HD Request # 380 | Total records received: 6509 | 2017-05-21 06:32:51 HD Request # 380 | Requesting historical Second data for ZB.20170600.CME_F from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:32:51 HD Request # 380 | Total records received: 6509 | 2017-05-21 06:32:51 HD Request # 380 | Requesting historical Second data for ZB.20170600.CME_F from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:32:51 HD Request # 380 | Total records received: 6509 | 2017-05-21 06:32:51 HD Request # 380 | Requesting historical Second data for ZB.20170600.CME_F from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:32:51 HD Request # 380 | Total records received: 6509 | 2017-05-21 06:32:51 HD Request # 380 | Requesting historical Second data for ZB.20170600.CME_F from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:32:51 CTS T4 FIX | Sending security definition request for symbol ZT.20170600.CME_F | 2017-05-21 06:32:51 CTS T4 FIX | Received matching security definition for symbol ZT.20170600.CME_F. Subscribing to data. | 2017-05-21 06:32:51 CTS T4 FIX | Received 1 security definitions for underlying symbol ZT | 2017-05-21 06:32:51 HD Request # 380 | Received 6509 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:56 (23.0 hours) and wrote 1 record for ZB.20170600.CME_F | 2017-05-21 06:32:51 HD Request # 380 | Intraday download COMPLETE for ZB.20170600.CME_F. Completion time: 15s. Unique request ID: 652 | 2017-05-21 06:32:51 Removed historical data download ID 652 | 2017-05-21 06:32:51 Real-time Intraday chart data file updates started for ZB.20170600.CME_F | 2017-05-21 06:32:51 Opened cached Intraday file: C:\SierraChart1\Data\ZB.20170600.CME_F.scid | 2017-05-21 06:32:51 Intraday chart data file opened for ZB.20170600.CME_F | 2017-05-21 06:32:51 Delaying start of download for RB.20171200.CME_NY | 2017-05-21 06:32:51 Contract specifications for ZT.20170600.CME_F. Multiplier: 0.00000010. Tick Size: 0.0078125. Value Format: 228. Currency Value per Tick: 15.625 | 2017-05-21 06:32:51 Chart #13 has tagged chart #1 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:32:53 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:32:53 Chart #13 has tagged chart #14 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:32:53 Chart #13 has tagged chart #17 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:32:53 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:32:53 Chart #13 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:32:53 Chart #13 has tagged chart #14 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:32:53 Chart #13 has tagged chart #17 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:32:53 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:32:53 Chart #15 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:32:53 Chart #15 has tagged chart #13 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:32:53 Chart #15 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:32:53 Chart #15 has tagged chart #26 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:32:53 Chart #15 has tagged chart #5 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:32:53 6J.20170600.CME_Fo [C] 30 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:32:53 Chart #5 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:32:53 Chart #5 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:32:53 ES.20170600.CME_Eq 30 Sec #17 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:32:53 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:32:53 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:32:53 Chart #17 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:32:53 ES.20170600.CME_Eq 3 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:32:53 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:32:53 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:32:53 Chart #17 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:32:53 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:32:53 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:32:53 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:32:53 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:32:53 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:32:53 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:32:53 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:32:53 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:32:53 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:32:56 GC.20170600.CME_CO 3 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:32:56 Chart #1 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:32:56 Chart #1 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:32:56 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:32:56 ZB.20170600.CME_F [C] 15 Min #26 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:32:56 6J.20170600.CME_Fo 3 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:32:56 Chart #14 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:32:56 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:32:56 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:32:56 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:32:56 6J.20170600.CME_Fo 30 Sec #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:32:56 NQ.20170600.CME_Eq 30 Sec #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:32:56 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:32:56 GC.20170600.CME_CO 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:32:56 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:32:56 GC.20170600.CME_CO [C] 30 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:32:56 Chart #13 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:32:56 Chart #13 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:32:56 Chart #13 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:32:56 Chart #13 has tagged chart #4 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:32:56 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:32:56 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:32:56 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:32:56 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:32:56 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:32:56 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:32:56 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:32:56 6C.20170600.CME_Fo [C] 30 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:32:56 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:32:56 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:33:04 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:33:04 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:33:04 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:33:04 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:33:04 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:33:04 HD Request # 381 | Downloading Intraday chart data for RB.20171200.CME_NY to the file RB.20171200.CME_NY.scid. Service: cts | 2017-05-21 06:33:25 HD Request # 381 | Download start date-time: 2017-05-19 16:18:13.000 | 2017-05-21 06:33:25 HD Request # 381 | Requesting historical Second data for RB.20171200.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:33:25 HD Request # 381 | Receiving Intraday data for RB.20171200.CME_NY starting at 2017-05-18 21:53:54 | 2017-05-21 06:33:25 HD Request # 381 | Timestamp of first Intraday data file record written: 2017-05-19 16:18:13 | 2017-05-21 06:33:25 HD Request # 381 | Total records received: 758 | 2017-05-21 06:33:25 HD Request # 381 | Requesting historical Second data for RB.20171200.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:33:25 HD Request # 381 | Total records received: 758 | 2017-05-21 06:33:25 HD Request # 381 | Requesting historical Second data for RB.20171200.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:33:25 HD Request # 381 | Total records received: 758 | 2017-05-21 06:33:26 HD Request # 381 | Requesting historical Second data for RB.20171200.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:33:26 HD Request # 381 | Total records received: 758 | 2017-05-21 06:33:26 HD Request # 381 | Requesting historical Second data for RB.20171200.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:33:26 HD Request # 381 | Received 758 records from 2017-05-18 21:53:54 to 2017-05-19 16:18:13 (18.4 hours) and wrote 1 record for RB.20171200.CME_NY | 2017-05-21 06:33:26 HD Request # 381 | Intraday download COMPLETE for RB.20171200.CME_NY. Completion time: 1s. Unique request ID: 653 | 2017-05-21 06:33:26 Removed historical data download ID 653 | 2017-05-21 06:33:26 Real-time Intraday chart data file updates started for RB.20171200.CME_NY | 2017-05-21 06:33:26 Opened cached Intraday file: C:\SierraChart1\Data\RB.20171200.CME_NY.scid | 2017-05-21 06:33:26 Intraday chart data file opened for RB.20171200.CME_NY | 2017-05-21 06:33:26 Delaying start of download for ZN.20170600.CME_F | 2017-05-21 06:33:26 Chart #23 has tagged chart #16 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:33:28 CL.20170700.CME_NY 3 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:33:28 Chart #16 has tagged chart #15 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:33:28 6C.20170600.CME_Fo 3 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:33:30 HD Request # 382 | Downloading Intraday chart data for ZN.20170600.CME_F to the file ZN.20170600.CME_F.scid. Service: cts | 2017-05-21 06:33:49 HD Request # 382 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:33:49 HD Request # 382 | Requesting historical Second data for ZN.20170600.CME_F from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:33:49 HD Request # 382 | Receiving Intraday data for ZN.20170600.CME_F starting at 2017-05-18 18:00:00 | 2017-05-21 06:33:51 HD Request # 382 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:33:51 HD Request # 382 | Total records received: 10370 | 2017-05-21 06:33:51 HD Request # 382 | Requesting historical Second data for ZN.20170600.CME_F from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:33:51 HD Request # 382 | Total records received: 10370 | 2017-05-21 06:33:51 HD Request # 382 | Requesting historical Second data for ZN.20170600.CME_F from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:33:51 HD Request # 382 | Total records received: 10370 | 2017-05-21 06:33:51 HD Request # 382 | Requesting historical Second data for ZN.20170600.CME_F from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:33:51 HD Request # 382 | Total records received: 10370 | 2017-05-21 06:33:52 HD Request # 382 | Requesting historical Second data for ZN.20170600.CME_F from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:33:52 HD Request # 382 | Received 10370 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for ZN.20170600.CME_F | 2017-05-21 06:33:52 HD Request # 382 | Intraday download COMPLETE for ZN.20170600.CME_F. Completion time: 3s. Unique request ID: 654 | 2017-05-21 06:33:52 Removed historical data download ID 654 | 2017-05-21 06:33:52 Real-time Intraday chart data file updates started for ZN.20170600.CME_F | 2017-05-21 06:33:52 Opened cached Intraday file: C:\SierraChart1\Data\ZN.20170600.CME_F.scid | 2017-05-21 06:33:52 Intraday chart data file opened for ZN.20170600.CME_F | 2017-05-21 06:33:52 Delaying start of download for 6J.20170600.CME_Fo | 2017-05-21 06:33:52 Chart #19 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:33:52 Chart #19 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:33:52 Chart #19 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:33:52 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:33:52 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:33:52 Chart #19 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:33:54 Chart #19 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:33:54 Chart #16 has tagged chart #13 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:33:54 Chart #16 has tagged chart #15 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:33:54 Chart #16 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:33:54 Chart #16 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:33:54 Chart #16 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:33:54 ZB.20170600.CME_F 3 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:33:54 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:33:54 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:33:54 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:33:54 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:33:54 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:33:54 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:33:54 GC.20170600.CME_CO 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:33:54 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:33:54 GC.20170600.CME_CO [C] 30 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:33:54 Chart #13 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:33:54 Chart #13 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:33:54 Chart #13 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:33:54 Chart #13 has tagged chart #4 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:33:54 ZB.20170600.CME_F 30 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:33:54 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:33:54 ZB.20170600.CME_F [C] 30 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:33:54 Chart #15 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:33:54 Chart #15 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:33:54 Chart #15 has tagged chart #26 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:33:54 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:33:54 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:33:54 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:33:54 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:33:54 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:33:54 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:33:54 6C.20170600.CME_Fo [C] 30 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:33:54 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:33:54 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:33:54 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:33:59 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:33:59 ZB.20170600.CME_F [C] 15 Min #26 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:33:59 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:33:59 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:33:59 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:33:59 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:33:59 HD Request # 383 | Downloading Intraday chart data for 6J.20170600.CME_Fo to the file 6J.20170600.CME_Fo.scid. Service: cts | 2017-05-21 06:34:20 HD Request # 383 | Download start date-time: 2017-05-19 16:59:51.000 | 2017-05-21 06:34:20 HD Request # 383 | Requesting historical Second data for 6J.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:34:20 HD Request # 383 | Receiving Intraday data for 6J.20170600.CME_Fo starting at 2017-05-18 18:00:00 | 2017-05-21 06:34:22 HD Request # 383 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:51 | 2017-05-21 06:34:22 HD Request # 383 | Total records received: 19164 | 2017-05-21 06:34:22 HD Request # 383 | Requesting historical Second data for 6J.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:34:22 HD Request # 383 | Total records received: 19164 | 2017-05-21 06:34:22 HD Request # 383 | Requesting historical Second data for 6J.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:34:22 HD Request # 383 | Total records received: 19164 | 2017-05-21 06:34:22 HD Request # 383 | Requesting historical Second data for 6J.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:34:22 HD Request # 383 | Total records received: 19164 | 2017-05-21 06:34:24 HD Request # 383 | Requesting historical Second data for 6J.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:34:24 HD Request # 383 | Received 19164 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:51 (23.0 hours) and wrote 1 record for 6J.20170600.CME_Fo | 2017-05-21 06:34:24 HD Request # 383 | Intraday download COMPLETE for 6J.20170600.CME_Fo. Completion time: 3s. Unique request ID: 655 | 2017-05-21 06:34:24 Removed historical data download ID 655 | 2017-05-21 06:34:24 Real-time Intraday chart data file updates started for 6J.20170600.CME_Fo | 2017-05-21 06:34:24 Opened cached Intraday file: C:\SierraChart1\Data\6J.20170600.CME_Fo.scid | 2017-05-21 06:34:24 Intraday chart data file opened for 6J.20170600.CME_Fo | 2017-05-21 06:34:24 Delaying start of download for 6S.20170600.CME_Fo | 2017-05-21 06:34:24 Chart #5 has tagged chart #13 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:34:24 Chart #5 has tagged chart #15 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:34:24 Chart #5 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:34:24 Chart #5 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:34:24 Chart #14 has tagged chart #1 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:34:25 Chart #14 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:34:25 Chart #14 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:34:25 ZB.20170600.CME_F 3 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:34:25 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:34:25 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:34:25 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:34:25 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:34:25 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:34:25 Chart #14 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:34:25 Chart #14 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:34:25 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:34:25 GC.20170600.CME_CO 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:34:25 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:34:25 GC.20170600.CME_CO [C] 30 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:34:25 Chart #13 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:34:25 Chart #13 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:34:25 Chart #13 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:34:25 Chart #13 has tagged chart #4 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:34:25 ZB.20170600.CME_F 30 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:34:25 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:34:25 ZB.20170600.CME_F [C] 30 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:34:25 Chart #15 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:34:25 Chart #15 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:34:25 Chart #15 has tagged chart #26 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:34:25 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:34:25 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:34:25 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:34:25 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:34:25 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:34:25 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:34:25 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:34:25 6C.20170600.CME_Fo [C] 30 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:34:25 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:34:25 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:34:25 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:34:31 GC.20170600.CME_CO 3 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:34:31 Chart #1 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:34:31 Chart #1 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:34:31 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:34:31 ZB.20170600.CME_F [C] 15 Min #26 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:34:31 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:34:31 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:34:31 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:34:31 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:34:31 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:34:31 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:34:31 HD Request # 384 | Downloading Intraday chart data for 6S.20170600.CME_Fo to the file 6S.20170600.CME_Fo.scid. Service: cts | 2017-05-21 06:34:53 HD Request # 384 | Download start date-time: 2017-05-19 16:59:35.000 | 2017-05-21 06:34:53 HD Request # 384 | Requesting historical Second data for 6S.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:34:53 HD Request # 384 | Receiving Intraday data for 6S.20170600.CME_Fo starting at 2017-05-18 18:00:00 | 2017-05-21 06:34:53 HD Request # 384 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:35 | 2017-05-21 06:34:53 HD Request # 384 | Total records received: 4884 | 2017-05-21 06:34:53 HD Request # 384 | Requesting historical Second data for 6S.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:34:53 HD Request # 384 | Total records received: 4884 | 2017-05-21 06:34:53 HD Request # 384 | Requesting historical Second data for 6S.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:34:53 HD Request # 384 | Total records received: 4884 | 2017-05-21 06:34:53 HD Request # 384 | Requesting historical Second data for 6S.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:34:53 HD Request # 384 | Total records received: 4884 | 2017-05-21 06:34:54 HD Request # 384 | Requesting historical Second data for 6S.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:34:54 HD Request # 384 | Received 4884 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:35 (23.0 hours) and wrote 1 record for 6S.20170600.CME_Fo | 2017-05-21 06:34:54 HD Request # 384 | Intraday download COMPLETE for 6S.20170600.CME_Fo. Completion time: 1s. Unique request ID: 656 | 2017-05-21 06:34:54 Removed historical data download ID 656 | 2017-05-21 06:34:54 Real-time Intraday chart data file updates started for 6S.20170600.CME_Fo | 2017-05-21 06:34:54 Opened cached Intraday file: C:\SierraChart1\Data\6S.20170600.CME_Fo.scid | 2017-05-21 06:34:54 Intraday chart data file opened for 6S.20170600.CME_Fo | 2017-05-21 06:34:54 Delaying start of download for RB.20170700.CME_NY | 2017-05-21 06:34:54 HD Request # 385 | Downloading Intraday chart data for RB.20170700.CME_NY to the file RB.20170700.CME_NY.scid. Service: cts | 2017-05-21 06:35:17 HD Request # 385 | Download start date-time: 2017-05-19 16:59:53.000 | 2017-05-21 06:35:17 HD Request # 385 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:35:17 HD Request # 385 | Receiving Intraday data for RB.20170700.CME_NY starting at 2017-05-18 18:00:00 | 2017-05-21 06:35:17 HD Request # 385 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:53 | 2017-05-21 06:35:17 HD Request # 385 | Total records received: 7454 | 2017-05-21 06:35:17 HD Request # 385 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:35:17 HD Request # 385 | Total records received: 7454 | 2017-05-21 06:35:18 HD Request # 385 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:35:18 HD Request # 385 | Total records received: 7454 | 2017-05-21 06:35:18 HD Request # 385 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:35:18 HD Request # 385 | Total records received: 7454 | 2017-05-21 06:35:18 HD Request # 385 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:35:18 HD Request # 385 | Received 7454 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:53 (23.0 hours) and wrote 1 record for RB.20170700.CME_NY | 2017-05-21 06:35:18 HD Request # 385 | Intraday download COMPLETE for RB.20170700.CME_NY. Completion time: 2s. Unique request ID: 657 | 2017-05-21 06:35:18 Removed historical data download ID 657 | 2017-05-21 06:35:18 Real-time Intraday chart data file updates started for RB.20170700.CME_NY | 2017-05-21 06:35:18 Opened cached Intraday file: C:\SierraChart1\Data\RB.20170700.CME_NY.scid | 2017-05-21 06:35:18 Intraday chart data file opened for RB.20170700.CME_NY | 2017-05-21 06:35:18 Delaying start of download for CL.20171200.CME_NY | 2017-05-21 06:35:18 Chart #18 has tagged chart #16 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:35:18 Chart #21 has tagged chart #9 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:35:18 Chart #22 has tagged chart #16 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:35:20 CL.20170700.CME_NY 30 Sec #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:35:20 CL.20170700.CME_NY [C] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:35:20 Chart #9 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:35:20 CL.20170700.CME_NY 3 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:35:20 Chart #16 has tagged chart #15 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:35:20 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:35:22 6C.20170600.CME_Fo 3 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:35:22 HD Request # 386 | Downloading Intraday chart data for CL.20171200.CME_NY to the file CL.20171200.CME_NY.scid. Service: cts | 2017-05-21 06:35:44 HD Request # 386 | Download start date-time: 2017-05-19 16:59:47.000 | 2017-05-21 06:35:44 HD Request # 386 | Requesting historical Second data for CL.20171200.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:35:44 HD Request # 386 | Receiving Intraday data for CL.20171200.CME_NY starting at 2017-05-18 18:00:18 | 2017-05-21 06:35:44 HD Request # 386 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:47 | 2017-05-21 06:35:44 HD Request # 386 | Total records received: 2449 | 2017-05-21 06:35:44 HD Request # 386 | Requesting historical Second data for CL.20171200.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:35:44 HD Request # 386 | Total records received: 2449 | 2017-05-21 06:35:44 HD Request # 386 | Requesting historical Second data for CL.20171200.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:35:44 HD Request # 386 | Total records received: 2449 | 2017-05-21 06:35:44 HD Request # 386 | Requesting historical Second data for CL.20171200.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:35:44 HD Request # 386 | Total records received: 2449 | 2017-05-21 06:35:44 HD Request # 386 | Requesting historical Second data for CL.20171200.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:35:44 HD Request # 386 | Received 2449 records from 2017-05-18 18:00:18 to 2017-05-19 16:59:47 (23.0 hours) and wrote 1 record for CL.20171200.CME_NY | 2017-05-21 06:35:45 HD Request # 386 | Intraday download COMPLETE for CL.20171200.CME_NY. Completion time: 2s. Unique request ID: 658 | 2017-05-21 06:35:45 Removed historical data download ID 658 | 2017-05-21 06:35:45 Real-time Intraday chart data file updates started for CL.20171200.CME_NY | 2017-05-21 06:35:45 Opened cached Intraday file: C:\SierraChart1\Data\CL.20171200.CME_NY.scid | 2017-05-21 06:35:45 Intraday chart data file opened for CL.20171200.CME_NY | 2017-05-21 06:35:45 Delaying start of download for GC.20170600.CME_CO | 2017-05-21 06:35:45 Chart #17 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:35:45 Chart #17 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:35:45 Chart #17 has tagged chart #9 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:35:45 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:35:45 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:35:45 Chart #21 has tagged chart #16 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:35:45 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:35:45 CL.20170700.CME_NY [C] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:35:45 Chart #9 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:35:45 Chart #6 has tagged chart #19 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:35:45 Chart #6 has tagged chart #9 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:35:45 CL.20170700.CME_NY 3 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:35:45 Chart #16 has tagged chart #15 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:35:45 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:35:47 ZN.20170600.CME_F 30 Sec #19 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:35:47 Chart #19 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:35:47 Chart #19 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:35:47 ZT.20170600.CME_F 30 Sec #9 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:35:47 Chart #9 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:35:47 Chart #9 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:35:47 GC.20170600.CME_CO 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:35:47 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:35:47 ZB.20170600.CME_F 30 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:35:47 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:35:47 6C.20170600.CME_Fo 3 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:35:47 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:35:51 HD Request # 387 | Downloading Intraday chart data for GC.20170600.CME_CO to the file GC.20170600.CME_CO.scid. Service: cts | 2017-05-21 06:36:10 HD Request # 387 | Download start date-time: 2017-05-19 16:59:57.000 | 2017-05-21 06:36:10 HD Request # 387 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:36:10 HD Request # 387 | Receiving Intraday data for GC.20170600.CME_CO starting at 2017-05-18 18:00:00 | 2017-05-21 06:36:13 HD Request # 387 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:57 | 2017-05-21 06:36:13 HD Request # 387 | Total records received: 26821 | 2017-05-21 06:36:13 HD Request # 387 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:36:13 HD Request # 387 | Total records received: 26821 | 2017-05-21 06:36:13 HD Request # 387 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:36:13 HD Request # 387 | Total records received: 26821 | 2017-05-21 06:36:13 HD Request # 387 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:36:13 HD Request # 387 | Total records received: 26821 | 2017-05-21 06:36:13 HD Request # 387 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:36:13 HD Request # 387 | Received 26821 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:57 (23.0 hours) and wrote 1 record for GC.20170600.CME_CO | 2017-05-21 06:36:15 HD Request # 387 | Intraday download COMPLETE for GC.20170600.CME_CO. Completion time: 3s. Unique request ID: 659 | 2017-05-21 06:36:15 Removed historical data download ID 659 | 2017-05-21 06:36:15 Real-time Intraday chart data file updates started for GC.20170600.CME_CO | 2017-05-21 06:36:15 Opened cached Intraday file: C:\SierraChart1\Data\GC.20170600.CME_CO.scid | 2017-05-21 06:36:15 Intraday chart data file opened for GC.20170600.CME_CO | 2017-05-21 06:36:15 Delaying start of download for YM.20170600.CME_E | 2017-05-21 06:36:15 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:36:15 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:36:15 Chart #1 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:36:15 Chart #1 has tagged chart #14 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:36:15 Chart #1 has tagged chart #17 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:36:15 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:36:15 Chart #13 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:36:15 Chart #13 has tagged chart #15 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:36:15 Chart #13 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:36:15 Chart #13 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:36:15 Chart #13 has tagged chart #4 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:36:15 Chart #13 has tagged chart #5 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:36:15 ZB.20170600.CME_F 30 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:36:15 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:36:15 ZB.20170600.CME_F [C] 30 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:36:15 Chart #15 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:36:15 Chart #15 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:36:15 Chart #15 has tagged chart #26 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:36:15 6J.20170600.CME_Fo [C] 30 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:36:15 Chart #5 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:36:15 Chart #5 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:36:15 ES.20170600.CME_Eq 30 Sec #17 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:36:15 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:36:15 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:36:15 Chart #17 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:36:15 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:36:15 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:36:15 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:36:15 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:36:15 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:36:15 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:36:15 6C.20170600.CME_Fo [C] 30 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:36:15 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:36:19 Chart #1 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:36:19 Chart #1 has tagged chart #14 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:36:19 Chart #1 has tagged chart #17 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:36:19 Chart #1 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:36:19 Chart #1 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:36:19 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:36:19 ZB.20170600.CME_F [C] 15 Min #26 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:36:19 6J.20170600.CME_Fo 3 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:36:19 Chart #14 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:36:19 ZB.20170600.CME_F 3 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:36:19 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:36:19 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:36:19 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:36:19 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:36:19 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:36:19 6J.20170600.CME_Fo 30 Sec #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:36:19 NQ.20170600.CME_Eq 30 Sec #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:36:19 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:36:19 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:36:19 ES.20170600.CME_Eq 3 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:36:19 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:36:19 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:36:19 Chart #17 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:36:19 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:36:19 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:36:19 6J.20170600.CME_Fo 3 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:36:24 Chart #14 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:36:24 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:36:24 HD Request # 388 | Downloading Intraday chart data for YM.20170600.CME_E to the file YM.20170600.CME_E.scid. Service: cts | 2017-05-21 06:36:45 HD Request # 388 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:36:45 HD Request # 388 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:36:45 HD Request # 388 | Receiving Intraday data for YM.20170600.CME_E starting at 2017-05-18 18:00:00 | 2017-05-21 06:36:46 HD Request # 388 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:36:46 HD Request # 388 | Total records received: 19680 | 2017-05-21 06:36:46 HD Request # 388 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:36:46 HD Request # 388 | Total records received: 19680 | 2017-05-21 06:36:46 HD Request # 388 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:36:46 HD Request # 388 | Total records received: 19680 | 2017-05-21 06:36:46 HD Request # 388 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:36:46 HD Request # 388 | Total records received: 19680 | 2017-05-21 06:36:48 HD Request # 388 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:36:48 HD Request # 388 | Received 19680 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for YM.20170600.CME_E | 2017-05-21 06:36:48 HD Request # 388 | Intraday download COMPLETE for YM.20170600.CME_E. Completion time: 3s. Unique request ID: 660 | 2017-05-21 06:36:48 Removed historical data download ID 660 | 2017-05-21 06:36:48 Real-time Intraday chart data file updates started for YM.20170600.CME_E | 2017-05-21 06:36:48 Opened cached Intraday file: C:\SierraChart1\Data\YM.20170600.CME_E.scid | 2017-05-21 06:36:48 Intraday chart data file opened for YM.20170600.CME_E | 2017-05-21 06:36:48 Delaying start of download for CL.20170700.CME_NY | 2017-05-21 06:36:48 Chart #3 has tagged chart #4 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:36:49 ZB.20170600.CME_F 3 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:36:51 HD Request # 389 | Downloading Intraday chart data for CL.20170700.CME_NY to the file CL.20170700.CME_NY.scid. Service: cts | 2017-05-21 06:38:04 HD Request # 389 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:38:04 HD Request # 389 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:38:04 HD Request # 389 | Receiving Intraday data for CL.20170700.CME_NY starting at 2017-05-18 18:00:00 | 2017-05-21 06:38:06 HD Request # 389 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:38:06 HD Request # 389 | Total records received: 33722 | 2017-05-21 06:38:06 HD Request # 389 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:38:06 HD Request # 389 | Total records received: 33722 | 2017-05-21 06:38:06 HD Request # 389 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:38:06 HD Request # 389 | Total records received: 33722 | 2017-05-21 06:38:06 HD Request # 389 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:38:06 HD Request # 389 | Total records received: 33722 | 2017-05-21 06:38:07 HD Request # 389 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:38:07 HD Request # 389 | Received 33722 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for CL.20170700.CME_NY | 2017-05-21 06:38:07 HD Request # 389 | Intraday download COMPLETE for CL.20170700.CME_NY. Completion time: 3s. Unique request ID: 661 | 2017-05-21 06:38:07 Removed historical data download ID 661 | 2017-05-21 06:38:07 Real-time Intraday chart data file updates started for CL.20170700.CME_NY | 2017-05-21 06:38:07 Opened cached Intraday file: C:\SierraChart1\Data\CL.20170700.CME_NY.scid | 2017-05-21 06:38:07 Intraday chart data file opened for CL.20170700.CME_NY | 2017-05-21 06:38:07 Delaying start of download for NQ.20170600.CME_Eq | 2017-05-21 06:38:07 Chart #3 has tagged chart #1 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:38:07 Chart #3 has tagged chart #4 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:38:07 Chart #3 has tagged chart #5 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:38:07 Chart #3 has tagged chart #8 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:38:07 CL.20170700.CME_NY 30 Sec #4 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:38:07 CL.20170700.CME_NY 3 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:38:07 CTS FIX socket (2160) | Closed. No error. | 2017-05-21 06:38:07 CTS FIX: Received a Logout message. Text = Timed out. No valid messages received within the heartbeat interval of 30 seconds | 2017-05-21 06:38:07 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2017-05-21 06:38:07 CTS FIX socket (2160) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-21 06:38:07 CTS FIX socket (2160) | SSL has been shut down. | 2017-05-21 06:38:07 CTS FIX socket (2160) | SSL object has been freed. SSL state is now disconnected. | 2017-05-21 06:38:07 CTS FIX socket (2160) | Shutdown and closed. | 2017-05-21 06:38:07 Connection to the external service has been lost. | 2017-05-21 06:38:07 Chart #9 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:38:07 Chart #16 has tagged chart #15 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:38:07 CL.20170700.CME_NY 3 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:38:07 6C.20170600.CME_Fo 3 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:38:07 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:39:04 CL.20170700.CME_NY 3 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:39:04 Canceling historical data download request for NQ.20170600.CME_Eq Intraday data. | 2017-05-21 06:39:04 Removed historical data download ID 662 | 2017-05-21 06:39:04 Canceling historical data download request for 6A.20170600.CME_Fo Intraday data. | 2017-05-21 06:39:04 Removed historical data download ID 663 | 2017-05-21 06:39:04 Canceling historical data download request for ZT.20170600.CME_F Intraday data. | 2017-05-21 06:39:04 Removed historical data download ID 664 | 2017-05-21 06:39:04 Canceling historical data download request for HO.20170700.CME_NY Intraday data. | 2017-05-21 06:39:04 Removed historical data download ID 665 | 2017-05-21 06:39:04 Canceling historical data download request for 6B.20170600.CME_Fo Intraday data. | 2017-05-21 06:39:04 Removed historical data download ID 666 | 2017-05-21 06:39:04 Canceling historical data download request for 6C.20170600.CME_Fo Intraday data. | 2017-05-21 06:39:04 Removed historical data download ID 667 | 2017-05-21 06:39:04 Canceling historical data download request for ES.20170600.CME_Eq Intraday data. | 2017-05-21 06:39:04 Removed historical data download ID 668 | 2017-05-21 06:39:04 Canceling historical data download request for 6E.20170600.CME_Fo Intraday data. | 2017-05-21 06:39:04 Removed historical data download ID 669 | 2017-05-21 06:39:04 Canceling historical data download request for HO.20171200.CME_NY Intraday data. | 2017-05-21 06:39:04 Removed historical data download ID 671 | 2017-05-21 06:39:04 CTS FIX Historical Data: DisconnectFIX called. | 2017-05-21 06:39:04 CTS FIX Historical Data: Sending a Logout message. | 2017-05-21 06:39:04 CTS T4 FIX | Disconnected. | 2017-05-21 06:39:04 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-21 06:39:04 CTS FIX Historical Data socket (2161) | Closed. No error. | 2017-05-21 06:39:04 CTS FIX Historical Data: Received a Logout message. Text = Successful logout upon request | 2017-05-21 06:39:04 CTS FIX Historical Data socket (2161) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-21 06:39:04 CTS FIX Historical Data socket (2161) | SSL has been shut down. | 2017-05-21 06:39:04 CTS FIX Historical Data socket (2161) | SSL object has been freed. SSL state is now disconnected. | 2017-05-21 06:39:04 CTS FIX Historical Data socket (2161) | Shutdown and closed. | 2017-05-21 06:39:04 CTS FIX Historical Data: Disconnected. | 2017-05-21 06:39:04 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2017-05-21 06:39:09 CTS T4 FIX | Firm: PTP | 2017-05-21 06:39:09 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199. | 2017-05-21 06:39:09 CTS FIX socket (2168) | Connected. | 2017-05-21 06:39:09 CTS FIX socket (2168) | Starting TLS 1.0 connection. | 2017-05-21 06:39:09 CTS FIX socket (2168) | SSL connection established. | 2017-05-21 06:39:09 CTS FIX: Sending the Logon message. | 2017-05-21 06:39:12 CTS T4 FIX | FIX version: 4.3.74.0 | 2017-05-21 06:39:12 CTS T4 FIX | Connected to data and trading server. | 2017-05-21 06:39:12 DTC Client (2162) | Shutdown and closed. | 2017-05-21 06:39:12 SC DTC Data | Disconnected from the server. | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: ZB.20160900.CME_F. ID: 1 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: ZB.20160900.CME_F. ID: 1 | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: 6E.20160900.CME_Fo. ID: 2 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: 6E.20160900.CME_Fo. ID: 2 | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6J.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: 6J.20160900.CME_Fo. ID: 3 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: 6J.20160900.CME_Fo. ID: 3 | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6B.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: 6B.20160900.CME_Fo. ID: 4 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: 6B.20160900.CME_Fo. ID: 4 | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6C.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: 6C.20160900.CME_Fo. ID: 5 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: 6C.20160900.CME_Fo. ID: 5 | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: CL.20160800.CME_NY. ID: 6 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: CL.20160800.CME_NY. ID: 6 | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6A.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: 6A.20160900.CME_Fo. ID: 7 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: 6A.20160900.CME_Fo. ID: 7 | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: NQ.20160900.CME_Eq. ID: 8 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: NQ.20160900.CME_Eq. ID: 8 | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM.######00.CME_E pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: YM.20160900.CME_E. ID: 9 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: YM.20160900.CME_E. ID: 9 | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: GC.20160800.CME_CO. ID: 10 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: GC.20160800.CME_CO. ID: 10 | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: ES.20160900.CME_Eq. ID: 11 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: ES.20160900.CME_Eq. ID: 11 | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: ZB.20170300.CME_F. ID: 12 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: ZB.20170300.CME_F. ID: 12 | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: CL.20170100.CME_NY. ID: 13 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: CL.20170100.CME_NY. ID: 13 | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: GC.20170400.CME_CO. ID: 14 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: GC.20170400.CME_CO. ID: 14 | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: ZB.20170600.CME_F. ID: 15 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: ZB.20170600.CME_F. ID: 15 | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6B.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: 6B.20170600.CME_Fo. ID: 16 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: 6B.20170600.CME_Fo. ID: 16 | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: CL.20170600.CME_NY. ID: 17 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: CL.20170600.CME_NY. ID: 17 | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: NQ.20170600.CME_Eq. ID: 18 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: NQ.20170600.CME_Eq. ID: 18 | 2017-05-21 06:39:12 Requesting market depth updates for: NQ.20170600.CME_Eq if supported. | 2017-05-21 06:39:12 CTS T4 FIX | Using primary service for historical data for NQ.20170600.CME_Eq | 2017-05-21 06:39:12 Intraday data recording state for symbol NQ.20170600.CME_Eq is set to download 'Pending'. | 2017-05-21 06:39:12 Delaying start of download for NQ.20170600.CME_Eq | 2017-05-21 06:39:12 CTS T4 FIX | Received Account List collateral report. | 2017-05-21 06:39:12 CTS T4 FIX | Subscribing to account: May* | 2017-05-21 06:39:12 Supported exchange: CME_CO (SIM:COMEX Futures) | 2017-05-21 06:39:12 Supported exchange: CME_EqOp (SIM:CME Equity Options) | 2017-05-21 06:39:12 Supported exchange: CME_NYOp (SIM:NYMEX Options) | 2017-05-21 06:39:12 Supported exchange: CME_AgOp (SIM:CME Agricultural Options) | 2017-05-21 06:39:12 Supported exchange: CME_Eq (SIM:CME Equity Futures) | 2017-05-21 06:39:12 Supported exchange: CME_In (SIM:CME Interest Rate Futures) | 2017-05-21 06:39:12 Supported exchange: CME_C (SIM:CBOT Commodity Futures) | 2017-05-21 06:39:12 Supported exchange: CME_KOp (SIM:KCBT Options) | 2017-05-21 06:39:12 Supported exchange: CME_F (SIM:CBOT Financial Futures) | 2017-05-21 06:39:12 Supported exchange: CME_E (SIM:CBOT Equity Futures) | 2017-05-21 06:39:12 Supported exchange: CME_COp (SIM:CBOT Commodity Options) | 2017-05-21 06:39:12 Supported exchange: CME_K (SIM:KCBT Futures) | 2017-05-21 06:39:12 Supported exchange: CME_EOp (SIM:CBOT Equity Options) | 2017-05-21 06:39:12 Supported exchange: CME_NY (SIM:NYMEX Futures) | 2017-05-21 06:39:12 Supported exchange: CME_Fo (SIM:CME Foreign Exchange Futures) | 2017-05-21 06:39:12 Supported exchange: CME_Ag (SIM:CME Agricultural Futures) | 2017-05-21 06:39:12 Supported exchange: CME_FoOp (SIM:CME Foreign Exchange Options) | 2017-05-21 06:39:12 Supported exchange: CME_FOp (SIM:CBOT Financial Options) | 2017-05-21 06:39:12 Supported exchange: CME_InOp (SIM:CME Interest Rate Options) | 2017-05-21 06:39:12 Supported exchange: CME_COOp (SIM:COMEX Options) | 2017-05-21 06:39:12 CTS T4 FIX | Sending security definition request for symbol 6A.20160900.CME_Fo | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6A.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: 6A.20170600.CME_Fo. ID: 19 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: 6A.20170600.CME_Fo. ID: 19 | 2017-05-21 06:39:12 CTS T4 FIX | Using primary service for historical data for 6A.20170600.CME_Fo | 2017-05-21 06:39:12 Intraday data recording state for symbol 6A.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: GC.20170600.CME_CO. ID: 20 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: GC.20170600.CME_CO. ID: 20 | 2017-05-21 06:39:12 CTS T4 FIX | Using primary service for historical data for GC.20170600.CME_CO | 2017-05-21 06:39:12 Intraday data recording state for symbol GC.20170600.CME_CO is set to download 'Pending'. | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZT.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: ZT.20170600.CME_F. ID: 21 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: ZT.20170600.CME_F. ID: 21 | 2017-05-21 06:39:12 CTS T4 FIX | Using primary service for historical data for ZT.20170600.CME_F | 2017-05-21 06:39:12 Intraday data recording state for symbol ZT.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The HO.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: HO.20170700.CME_NY. ID: 22 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: HO.20170700.CME_NY. ID: 22 | 2017-05-21 06:39:12 CTS T4 FIX | Using primary service for historical data for HO.20170700.CME_NY | 2017-05-21 06:39:12 Intraday data recording state for symbol HO.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:39:12 Requesting market depth updates for: GC.20170600.CME_CO if supported. | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: CL.20170700.CME_NY. ID: 23 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: CL.20170700.CME_NY. ID: 23 | 2017-05-21 06:39:12 CTS T4 FIX | Using primary service for historical data for CL.20170700.CME_NY | 2017-05-21 06:39:12 Intraday data recording state for symbol CL.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:39:12 Symbol Error - 6A.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:39:12 CTS T4 FIX | Received 0 security definitions for underlying symbol 6A | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: 6E.20170600.CME_Fo. ID: 24 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: 6E.20170600.CME_Fo. ID: 24 | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6C.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: 6C.20170600.CME_Fo. ID: 25 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: 6C.20170600.CME_Fo. ID: 25 | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6J.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: 6J.20170600.CME_Fo. ID: 26 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: 6J.20170600.CME_Fo. ID: 26 | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6S.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: 6S.20170600.CME_Fo. ID: 27 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: 6S.20170600.CME_Fo. ID: 27 | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: ES.20170600.CME_Eq. ID: 28 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: ES.20170600.CME_Eq. ID: 28 | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM.######00.CME_E pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: YM.20170600.CME_E. ID: 29 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: YM.20170600.CME_E. ID: 29 | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6N.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: 6N.20170600.CME_Fo. ID: 30 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: 6N.20170600.CME_Fo. ID: 30 | 2017-05-21 06:39:12 Requesting market depth updates for: CL.20170700.CME_NY if supported. | 2017-05-21 06:39:12 Requesting market depth updates for: ZB.20170600.CME_F if supported. | 2017-05-21 06:39:12 CTS T4 FIX | Using primary service for historical data for ZB.20170600.CME_F | 2017-05-21 06:39:12 Intraday data recording state for symbol ZB.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:39:12 CTS T4 FIX | Using primary service for historical data for 6B.20170600.CME_Fo | 2017-05-21 06:39:12 Intraday data recording state for symbol 6B.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:39:12 CTS T4 FIX | Using primary service for historical data for 6C.20170600.CME_Fo | 2017-05-21 06:39:12 Intraday data recording state for symbol 6C.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:39:12 CTS T4 FIX | Using primary service for historical data for 6J.20170600.CME_Fo | 2017-05-21 06:39:12 Intraday data recording state for symbol 6J.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZN.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: ZN.20170600.CME_F. ID: 31 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: ZN.20170600.CME_F. ID: 31 | 2017-05-21 06:39:12 CTS T4 FIX | Using primary service for historical data for ZN.20170600.CME_F | 2017-05-21 06:39:12 Intraday data recording state for symbol ZN.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:39:12 HD Request # 390 | Downloading Intraday chart data for NQ.20170600.CME_Eq to the file NQ.20170600.CME_Eq.scid. Service: cts | 2017-05-21 06:39:12 HD Request # 390 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:39:12 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: CL.20171200.CME_NY. ID: 32 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: CL.20171200.CME_NY. ID: 32 | 2017-05-21 06:39:12 CTS T4 FIX | Using primary service for historical data for CL.20171200.CME_NY | 2017-05-21 06:39:12 Intraday data recording state for symbol CL.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:39:12 Requesting market depth updates for: ES.20170600.CME_Eq if supported. | 2017-05-21 06:39:12 CTS T4 FIX | Using primary service for historical data for ES.20170600.CME_Eq | 2017-05-21 06:39:12 Intraday data recording state for symbol ES.20170600.CME_Eq is set to download 'Pending'. | 2017-05-21 06:39:12 CTS FIX Historical Data socket (0) | Resolved address fix-chart-sim.t4login.com to IP 74.201.6.229. | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The RB.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: RB.20170700.CME_NY. ID: 33 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: RB.20170700.CME_NY. ID: 33 | 2017-05-21 06:39:12 CTS T4 FIX | Using primary service for historical data for RB.20170700.CME_NY | 2017-05-21 06:39:12 Intraday data recording state for symbol RB.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:39:12 CTS T4 FIX | Using primary service for historical data for 6E.20170600.CME_Fo | 2017-05-21 06:39:12 Intraday data recording state for symbol 6E.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:39:12 CTS T4 FIX | Using primary service for historical data for YM.20170600.CME_E | 2017-05-21 06:39:12 Intraday data recording state for symbol YM.20170600.CME_E is set to download 'Pending'. | 2017-05-21 06:39:12 Using Bid/Ask average for last trade price for AUDJPY | 2017-05-21 06:39:12 SC DTC Data | Starting real-time market data updates for: AUDJPY. ID: 34 | 2017-05-21 06:39:12 SC DTC Data | Connecting to the server ds4.sierracharts.com. Port 443 | 2017-05-21 06:39:12 SC DTC Data | Requesting security definition data for: AUDJPY. ID: 34 | 2017-05-21 06:39:12 Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2017-05-21 06:39:12 DTC Client (0) | Resolved address ds4.sierracharts.com to IP 192.81.56.146. | 2017-05-21 06:39:12 Delaying start of download for AUDJPY | 2017-05-21 06:39:12 CTS T4 FIX | Using primary service for historical data for 6S.20170600.CME_Fo | 2017-05-21 06:39:12 Intraday data recording state for symbol 6S.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:39:12 CTS FIX Historical Data socket (2169) | Connected. | 2017-05-21 06:39:12 CTS FIX Historical Data socket (2169) | Starting TLS 1.0 connection. | 2017-05-21 06:39:12 Requesting market depth updates for: 6E.20170600.CME_Fo if supported. | 2017-05-21 06:39:12 DTC Client (2170) | Connected. | 2017-05-21 06:39:12 SC DTC Data | Connected to server. | 2017-05-21 06:39:12 SC DTC Data | Sending Encoding Request to server | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The HO.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: HO.20171200.CME_NY. ID: 35 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: HO.20171200.CME_NY. ID: 35 | 2017-05-21 06:39:12 CTS T4 FIX | Using primary service for historical data for HO.20171200.CME_NY | 2017-05-21 06:39:12 Intraday data recording state for symbol HO.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:39:12 CTS T4 FIX | Using primary service for historical data for 6N.20170600.CME_Fo | 2017-05-21 06:39:12 Intraday data recording state for symbol 6N.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:39:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The RB.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:39:12 CTS T4 FIX | Starting real-time market data updates for: RB.20171200.CME_NY. ID: 36 | 2017-05-21 06:39:12 CTS T4 FIX | Requesting security definition data for: RB.20171200.CME_NY. ID: 36 | 2017-05-21 06:39:12 CTS T4 FIX | Using primary service for historical data for RB.20171200.CME_NY | 2017-05-21 06:39:12 Intraday data recording state for symbol RB.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:39:12 SC DTC Data | Setting DTC encoding to Binary VLS | 2017-05-21 06:39:12 SC DTC Data | Sending logon request message. | 2017-05-21 06:39:12 CTS FIX Historical Data socket (2169) | SSL connection established. | 2017-05-21 06:39:12 Requesting market depth updates for: 6B.20170600.CME_Fo if supported. | 2017-05-21 06:39:16 SC DTC Data | Received logon response. | 2017-05-21 06:39:16 SC DTC Data | Server Name: SC Realtime Server. | 2017-05-21 06:39:16 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2017-05-21 06:39:16 SC DTC Data | Successfully connected. | 2017-05-21 06:39:16 SC DTC Data | Trading is not supported. | 2017-05-21 06:39:16 SC DTC Data | Restarting real-time data updates for symbol: AUDJPY | 2017-05-21 06:39:16 CTS T4 FIX | Received 'Account Update/Balance Data' collateral report. | 2017-05-21 06:39:16 SC DTC Data | Received security definition for symbol AUDJPY | 2017-05-21 06:39:16 Requesting market depth updates for: YM.20170600.CME_E if supported. | 2017-05-21 06:39:16 Requesting market depth updates for: 6J.20170600.CME_Fo if supported. | 2017-05-21 06:39:16 CTS T4 FIX | Sending security definition request for symbol 6A.20170600.CME_Fo | 2017-05-21 06:39:16 CTS T4 FIX | Received matching security definition for symbol 6A.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:39:16 CTS T4 FIX | Received 1 security definitions for underlying symbol 6A | 2017-05-21 06:39:16 Contract specifications for 6A.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:39:16 CTS FIX Historical Data: Sending the Logon message. | 2017-05-21 06:39:16 CTS FIX Historical Data: Connected to Historical data server. | 2017-05-21 06:39:19 Delaying start of download for AUDJPY | 2017-05-21 06:39:19 CTS T4 FIX | Sending security definition request for symbol 6B.20160900.CME_Fo | 2017-05-21 06:39:19 Symbol Error - 6B.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:39:19 CTS T4 FIX | Received 0 security definitions for underlying symbol 6B | 2017-05-21 06:39:19 Requesting market depth updates for: 6B.20160900.CME_Fo if supported. | 2017-05-21 06:39:20 Requesting market depth updates for: 6E.20160900.CME_Fo if supported. | 2017-05-21 06:39:20 Requesting market depth updates for: 6J.20160900.CME_Fo if supported. | 2017-05-21 06:39:20 Requesting market depth updates for: 6N.20170600.CME_Fo if supported. | 2017-05-21 06:39:20 Requesting market depth updates for: CL.20160800.CME_NY if supported. | 2017-05-21 06:39:20 Requesting market depth updates for: CL.20170100.CME_NY if supported. | 2017-05-21 06:39:20 Requesting market depth updates for: CL.20170600.CME_NY if supported. | 2017-05-21 06:39:20 Requesting market depth updates for: CL.20171200.CME_NY if supported. | 2017-05-21 06:39:20 Requesting market depth updates for: ES.20160900.CME_Eq if supported. | 2017-05-21 06:39:20 Requesting market depth updates for: GC.20160800.CME_CO if supported. | 2017-05-21 06:39:20 Requesting market depth updates for: GC.20170400.CME_CO if supported. | 2017-05-21 06:39:20 Requesting market depth updates for: NQ.20160900.CME_Eq if supported. | 2017-05-21 06:39:20 Requesting market depth updates for: YM.20160900.CME_E if supported. | 2017-05-21 06:39:20 Requesting market depth updates for: ZB.20160900.CME_F if supported. | 2017-05-21 06:39:20 Requesting market depth updates for: ZB.20170300.CME_F if supported. | 2017-05-21 06:39:20 CTS T4 FIX | Requesting Open Orders for account: May*. Request ID: 9498767 | 2017-05-21 06:39:20 CTS T4 FIX | No open orders for account May18CCwmitchel | 2017-05-21 06:39:20 CTS T4 FIX | Sending security definition request for symbol 6B.20170600.CME_Fo | 2017-05-21 06:39:22 HD Request # 391 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-05-21 06:39:22 HD Request # 391 | Download start date-time: 2017-05-19 16:57:58.000 | 2017-05-21 06:39:22 HD Request # 391 | Using server: ds4.sierracharts.com port 10149 | 2017-05-21 06:39:22 Socket (0) | Resolved address ds4.sierracharts.com to IP 192.81.56.146. | 2017-05-21 06:39:22 Socket (2171) | Connected. | 2017-05-21 06:39:22 HD Request # 391 | Setting DTC encoding to Binary VLS | 2017-05-21 06:39:22 HD Request # 391 | Sending historical data logon request message. | 2017-05-21 06:39:22 CTS T4 FIX | Received matching security definition for symbol 6B.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:39:22 CTS T4 FIX | Received 1 security definitions for underlying symbol 6B | 2017-05-21 06:39:22 Contract specifications for 6B.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 6.25 | 2017-05-21 06:39:22 HD Request # 391 | Requesting Intraday data. Start date-time: 2017-05-19 16:57:58. Record interval: 1. Symbol: AUDJPY | 2017-05-21 06:39:23 HD Request # 391 | Decompressing data. | 2017-05-21 06:39:23 HD Request # 391 | Receiving Intraday data for AUDJPY starting at 2017-05-19 16:57:58 | 2017-05-21 06:39:23 HD Request # 391 | Timestamp of first Intraday data file record written: 2017-05-19 16:57:58 | 2017-05-21 06:39:23 Socket (2171) | Shutdown and closed. | 2017-05-21 06:39:23 The network socket for historical data has been closed. | 2017-05-21 06:39:23 HD Request # 391 | Received 1 record from 2017-05-19 16:57:58 to 2017-05-19 16:57:58 (0.0 seconds) and wrote 1 record for AUDJPY | 2017-05-21 06:39:23 HD Request # 391 | Intraday download COMPLETE for AUDJPY. Completion time: 0s. Unique request ID: 688 | 2017-05-21 06:39:23 Removed historical data download ID 688 | 2017-05-21 06:39:23 Real-time Intraday chart data file updates started for AUDJPY | 2017-05-21 06:39:23 Opened cached Intraday file: C:\SierraChart1\Data\AUDJPY.scid | 2017-05-21 06:39:23 Intraday chart data file opened for AUDJPY | 2017-05-21 06:39:23 CTS T4 FIX | Sending security definition request for symbol 6C.20160900.CME_Fo | 2017-05-21 06:39:25 Symbol Error - 6C.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:39:25 CTS T4 FIX | Received 0 security definitions for underlying symbol 6C | 2017-05-21 06:39:25 CTS T4 FIX | Sending security definition request for symbol 6C.20170600.CME_Fo | 2017-05-21 06:39:28 CTS T4 FIX | Received matching security definition for symbol 6C.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:39:28 CTS T4 FIX | Received 1 security definitions for underlying symbol 6C | 2017-05-21 06:39:28 Contract specifications for 6C.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 5 | 2017-05-21 06:39:28 CTS T4 FIX | Requesting historical Fills for account: May*. Request ID: 9498770 | 2017-05-21 06:39:30 CTS T4 FIX | Received Account List collateral report. | 2017-05-21 06:39:30 CTS T4 FIX | Server provided no historical order fills for account 1A297B51-A416-42D4-A1C8-C9B1B4125155 | 2017-05-21 06:39:30 CTS T4 FIX | Sending security definition request for symbol 6E.20160900.CME_Fo | 2017-05-21 06:39:31 Symbol Error - 6E.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:39:31 CTS T4 FIX | Received 0 security definitions for underlying symbol 6E | 2017-05-21 06:39:31 CTS T4 FIX | Sending security definition request for symbol 6E.20170600.CME_Fo | 2017-05-21 06:39:34 CTS T4 FIX | Received matching security definition for symbol 6E.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:39:34 CTS T4 FIX | Received 1 security definitions for underlying symbol 6E | 2017-05-21 06:39:34 Contract specifications for 6E.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-05-21 06:39:34 CTS T4 FIX | Sending security definition request for symbol 6J.20160900.CME_Fo | 2017-05-21 06:39:37 Symbol Error - 6J.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:39:37 CTS T4 FIX | Received 0 security definitions for underlying symbol 6J | 2017-05-21 06:39:37 CTS T4 FIX | Sending security definition request for symbol 6J.20170600.CME_Fo | 2017-05-21 06:39:41 CTS T4 FIX | Received matching security definition for symbol 6J.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:39:41 CTS T4 FIX | Received 1 security definitions for underlying symbol 6J | 2017-05-21 06:39:41 Contract specifications for 6J.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-05-21 06:39:41 CTS T4 FIX | Sending security definition request for symbol 6N.20170600.CME_Fo | 2017-05-21 06:39:44 CTS T4 FIX | Received matching security definition for symbol 6N.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:39:44 CTS T4 FIX | Received 1 security definitions for underlying symbol 6N | 2017-05-21 06:39:44 Contract specifications for 6N.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:39:44 CTS T4 FIX | Sending security definition request for symbol 6S.20170600.CME_Fo | 2017-05-21 06:39:45 CTS T4 FIX | Received matching security definition for symbol 6S.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:39:45 CTS T4 FIX | Received 1 security definitions for underlying symbol 6S | 2017-05-21 06:39:45 Contract specifications for 6S.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 12.5 | 2017-05-21 06:39:45 CTS T4 FIX | Sending security definition request for symbol CL.20160800.CME_NY | 2017-05-21 06:39:47 Symbol Error - CL.20160800.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:39:47 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2017-05-21 06:39:47 CTS T4 FIX | Sending security definition request for symbol CL.20170100.CME_NY | 2017-05-21 06:39:49 Symbol Error - CL.20170100.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:39:49 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2017-05-21 06:39:49 CTS T4 FIX | Sending security definition request for symbol CL.20170600.CME_NY | 2017-05-21 06:39:52 CTS T4 FIX | Received matching security definition for symbol CL.20170600.CME_NY. Subscribing to data. | 2017-05-21 06:39:52 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:39:52 Contract specifications for CL.20170600.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:39:52 CTS T4 FIX | Sending security definition request for symbol CL.20170700.CME_NY | 2017-05-21 06:39:55 CTS T4 FIX | Received matching security definition for symbol CL.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:39:55 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:39:55 Contract specifications for CL.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:39:55 CTS T4 FIX | Sending security definition request for symbol CL.20171200.CME_NY | 2017-05-21 06:39:57 CTS T4 FIX | Received matching security definition for symbol CL.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:39:57 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:39:57 Contract specifications for CL.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:39:57 CTS T4 FIX | Sending security definition request for symbol ES.20160900.CME_Eq | 2017-05-21 06:40:00 Symbol Error - ES.20160900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:40:00 CTS T4 FIX | Received 0 security definitions for underlying symbol ES | 2017-05-21 06:40:00 CTS T4 FIX | Sending security definition request for symbol ES.20170600.CME_Eq | 2017-05-21 06:40:03 CTS T4 FIX | Received matching security definition for symbol ES.20170600.CME_Eq. Subscribing to data. | 2017-05-21 06:40:03 CTS T4 FIX | Received 1 security definitions for underlying symbol ES | 2017-05-21 06:40:03 Contract specifications for ES.20170600.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 12.5 | 2017-05-21 06:40:03 CTS T4 FIX | Sending security definition request for symbol GC.20160800.CME_CO | 2017-05-21 06:40:04 Symbol Error - GC.20160800.CME_CO is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:40:04 CTS T4 FIX | Received 0 security definitions for underlying symbol GC | 2017-05-21 06:40:04 CTS T4 FIX | Sending security definition request for symbol GC.20170400.CME_CO | 2017-05-21 06:40:07 Symbol Error - GC.20170400.CME_CO is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:40:07 CTS T4 FIX | Received 0 security definitions for underlying symbol GC | 2017-05-21 06:40:07 CTS T4 FIX | Sending security definition request for symbol GC.20170600.CME_CO | 2017-05-21 06:40:10 CTS T4 FIX | Received matching security definition for symbol GC.20170600.CME_CO. Subscribing to data. | 2017-05-21 06:40:10 CTS T4 FIX | Received 1 security definitions for underlying symbol GC | 2017-05-21 06:40:10 Contract specifications for GC.20170600.CME_CO. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:40:10 CTS T4 FIX | Sending security definition request for symbol HO.20170700.CME_NY | 2017-05-21 06:40:13 CTS T4 FIX | Received matching security definition for symbol HO.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:40:13 CTS T4 FIX | Received 1 security definitions for underlying symbol HO | 2017-05-21 06:40:13 Contract specifications for HO.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:40:13 CTS T4 FIX | Sending security definition request for symbol HO.20171200.CME_NY | 2017-05-21 06:40:16 CTS T4 FIX | Received matching security definition for symbol HO.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:40:16 CTS T4 FIX | Received 1 security definitions for underlying symbol HO | 2017-05-21 06:40:16 Contract specifications for HO.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:40:16 CTS T4 FIX | Sending security definition request for symbol NQ.20160900.CME_Eq | 2017-05-21 06:40:20 Symbol Error - NQ.20160900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:40:20 CTS T4 FIX | Received 0 security definitions for underlying symbol NQ | 2017-05-21 06:40:20 CTS T4 FIX | Sending security definition request for symbol NQ.20170600.CME_Eq | 2017-05-21 06:40:23 CTS T4 FIX | Received matching security definition for symbol NQ.20170600.CME_Eq. Subscribing to data. | 2017-05-21 06:40:23 CTS T4 FIX | Received matching security definition for symbol NQ.20170600.CME_Eq. Requesting historical data. | 2017-05-21 06:40:23 HD Request # 390 | Requesting historical Second data for NQ.20170600.CME_Eq from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:40:23 CTS T4 FIX | Received 1 security definitions for underlying symbol NQ | 2017-05-21 06:40:23 Contract specifications for NQ.20170600.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 5 | 2017-05-21 06:40:23 HD Request # 390 | Receiving Intraday data for NQ.20170600.CME_Eq starting at 2017-05-18 18:00:00 | 2017-05-21 06:40:24 HD Request # 390 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:40:24 HD Request # 390 | Total records received: 24898 | 2017-05-21 06:40:24 HD Request # 390 | Requesting historical Second data for NQ.20170600.CME_Eq from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:40:24 HD Request # 390 | Total records received: 24898 | 2017-05-21 06:40:24 HD Request # 390 | Requesting historical Second data for NQ.20170600.CME_Eq from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:40:24 HD Request # 390 | Total records received: 24898 | 2017-05-21 06:40:24 HD Request # 390 | Requesting historical Second data for NQ.20170600.CME_Eq from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:40:24 HD Request # 390 | Total records received: 24898 | 2017-05-21 06:40:24 HD Request # 390 | Requesting historical Second data for NQ.20170600.CME_Eq from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:40:24 HD Request # 390 | Received 24898 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for NQ.20170600.CME_Eq | 2017-05-21 06:40:26 HD Request # 390 | Intraday download COMPLETE for NQ.20170600.CME_Eq. Completion time: 1m 10s. Unique request ID: 672 | 2017-05-21 06:40:26 Removed historical data download ID 672 | 2017-05-21 06:40:26 Real-time Intraday chart data file updates started for NQ.20170600.CME_Eq | 2017-05-21 06:40:26 Opened cached Intraday file: C:\SierraChart1\Data\NQ.20170600.CME_Eq.scid | 2017-05-21 06:40:26 Intraday chart data file opened for NQ.20170600.CME_Eq | 2017-05-21 06:40:26 Delaying start of download for 6A.20170600.CME_Fo | 2017-05-21 06:40:26 CTS T4 FIX | Sending security definition request for symbol RB.20170700.CME_NY | 2017-05-21 06:40:26 CTS T4 FIX | Received matching security definition for symbol RB.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:40:26 CTS T4 FIX | Received 1 security definitions for underlying symbol RB | 2017-05-21 06:40:26 Contract specifications for RB.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:40:26 CTS T4 FIX | Sending security definition request for symbol RB.20171200.CME_NY | 2017-05-21 06:40:29 CTS T4 FIX | Received matching security definition for symbol RB.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:40:29 CTS T4 FIX | Received 1 security definitions for underlying symbol RB | 2017-05-21 06:40:29 Contract specifications for RB.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:40:29 CTS T4 FIX | Sending security definition request for symbol YM.20160900.CME_E | 2017-05-21 06:40:30 Symbol Error - YM.20160900.CME_E is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:40:30 CTS T4 FIX | Received 0 security definitions for underlying symbol YM | 2017-05-21 06:40:30 CTS T4 FIX | Sending security definition request for symbol YM.20170600.CME_E | 2017-05-21 06:40:33 CTS T4 FIX | Received matching security definition for symbol YM.20170600.CME_E. Subscribing to data. | 2017-05-21 06:40:33 CTS T4 FIX | Received 1 security definitions for underlying symbol YM | 2017-05-21 06:40:33 Contract specifications for YM.20170600.CME_E. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 5 | 2017-05-21 06:40:33 CTS T4 FIX | Sending security definition request for symbol ZB.20160900.CME_F | 2017-05-21 06:40:36 Symbol Error - ZB.20160900.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:40:36 CTS T4 FIX | Received 0 security definitions for underlying symbol ZB | 2017-05-21 06:40:36 CTS T4 FIX | Sending security definition request for symbol ZB.20170300.CME_F | 2017-05-21 06:40:39 Symbol Error - ZB.20170300.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:40:39 CTS T4 FIX | Received 0 security definitions for underlying symbol ZB | 2017-05-21 06:40:39 CTS T4 FIX | Sending security definition request for symbol ZB.20170600.CME_F | 2017-05-21 06:40:42 CTS T4 FIX | Received matching security definition for symbol ZB.20170600.CME_F. Subscribing to data. | 2017-05-21 06:40:42 CTS T4 FIX | Received 1 security definitions for underlying symbol ZB | 2017-05-21 06:40:42 Contract specifications for ZB.20170600.CME_F. Multiplier: 0.00001000. Tick Size: 0.03125. Value Format: 132. Currency Value per Tick: 31.25 | 2017-05-21 06:40:42 CTS T4 FIX | Sending security definition request for symbol ZN.20170600.CME_F | 2017-05-21 06:40:45 CTS T4 FIX | Received matching security definition for symbol ZN.20170600.CME_F. Subscribing to data. | 2017-05-21 06:40:45 CTS T4 FIX | Received 1 security definitions for underlying symbol ZN | 2017-05-21 06:40:45 Contract specifications for ZN.20170600.CME_F. Multiplier: 0.00000100. Tick Size: 0.015625. Value Format: 132. Currency Value per Tick: 15.625 | 2017-05-21 06:40:45 CTS T4 FIX | Sending security definition request for symbol ZT.20170600.CME_F | 2017-05-21 06:40:47 CTS T4 FIX | Received matching security definition for symbol ZT.20170600.CME_F. Subscribing to data. | 2017-05-21 06:40:48 CTS T4 FIX | Received 1 security definitions for underlying symbol ZT | 2017-05-21 06:40:48 Contract specifications for ZT.20170600.CME_F. Multiplier: 0.00000010. Tick Size: 0.0078125. Value Format: 228. Currency Value per Tick: 15.625 | 2017-05-21 06:40:48 HD Request # 392 | Downloading Intraday chart data for 6A.20170600.CME_Fo to the file 6A.20170600.CME_Fo.scid. Service: cts | 2017-05-21 06:40:48 HD Request # 392 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:40:48 HD Request # 392 | Requesting historical Second data for 6A.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:40:48 HD Request # 392 | Receiving Intraday data for 6A.20170600.CME_Fo starting at 2017-05-18 18:00:00 | 2017-05-21 06:40:50 HD Request # 392 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:40:50 HD Request # 392 | Total records received: 6413 | 2017-05-21 06:40:50 HD Request # 392 | Requesting historical Second data for 6A.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:40:50 HD Request # 392 | Total records received: 6413 | 2017-05-21 06:40:50 HD Request # 392 | Requesting historical Second data for 6A.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:40:50 HD Request # 392 | Total records received: 6413 | 2017-05-21 06:40:50 HD Request # 392 | Requesting historical Second data for 6A.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:40:50 HD Request # 392 | Total records received: 6413 | 2017-05-21 06:40:50 HD Request # 392 | Requesting historical Second data for 6A.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:40:50 HD Request # 392 | Received 6413 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for 6A.20170600.CME_Fo | 2017-05-21 06:40:50 HD Request # 392 | Intraday download COMPLETE for 6A.20170600.CME_Fo. Completion time: 2s. Unique request ID: 673 | 2017-05-21 06:40:50 Removed historical data download ID 673 | 2017-05-21 06:40:50 Real-time Intraday chart data file updates started for 6A.20170600.CME_Fo | 2017-05-21 06:40:50 Opened cached Intraday file: C:\SierraChart1\Data\6A.20170600.CME_Fo.scid | 2017-05-21 06:40:50 Intraday chart data file opened for 6A.20170600.CME_Fo | 2017-05-21 06:40:50 Delaying start of download for GC.20170600.CME_CO | 2017-05-21 06:40:50 HD Request # 393 | Downloading Intraday chart data for GC.20170600.CME_CO to the file GC.20170600.CME_CO.scid. Service: cts | 2017-05-21 06:41:16 HD Request # 393 | Download start date-time: 2017-05-19 16:59:57.000 | 2017-05-21 06:41:16 HD Request # 393 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:41:16 HD Request # 393 | Receiving Intraday data for GC.20170600.CME_CO starting at 2017-05-18 18:00:00 | 2017-05-21 06:41:17 HD Request # 393 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:57 | 2017-05-21 06:41:17 HD Request # 393 | Total records received: 26821 | 2017-05-21 06:41:17 HD Request # 393 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:41:17 HD Request # 393 | Total records received: 26821 | 2017-05-21 06:41:17 HD Request # 393 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:41:17 HD Request # 393 | Total records received: 26821 | 2017-05-21 06:41:17 HD Request # 393 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:41:17 HD Request # 393 | Total records received: 26821 | 2017-05-21 06:41:19 HD Request # 393 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:41:19 HD Request # 393 | Received 26821 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:57 (23.0 hours) and wrote 1 record for GC.20170600.CME_CO | 2017-05-21 06:41:19 HD Request # 393 | Intraday download COMPLETE for GC.20170600.CME_CO. Completion time: 4s. Unique request ID: 674 | 2017-05-21 06:41:19 Removed historical data download ID 674 | 2017-05-21 06:41:19 Real-time Intraday chart data file updates started for GC.20170600.CME_CO | 2017-05-21 06:41:19 Opened cached Intraday file: C:\SierraChart1\Data\GC.20170600.CME_CO.scid | 2017-05-21 06:41:19 Intraday chart data file opened for GC.20170600.CME_CO | 2017-05-21 06:41:19 Delaying start of download for ZT.20170600.CME_F | 2017-05-21 06:41:19 Chart #1 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:41:19 Chart #1 has tagged chart #14 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:41:19 Chart #1 has tagged chart #17 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:41:19 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:41:19 Chart #13 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:19 Chart #13 has tagged chart #15 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:19 Chart #13 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:19 Chart #13 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:19 Chart #13 has tagged chart #4 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:19 Chart #13 has tagged chart #5 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:19 ZB.20170600.CME_F 30 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:41:19 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:41:19 ZB.20170600.CME_F [C] 30 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:41:19 Chart #15 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:19 Chart #15 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:19 Chart #15 has tagged chart #26 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:19 6J.20170600.CME_Fo [C] 30 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:41:19 Chart #5 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:19 Chart #5 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:19 ES.20170600.CME_Eq 30 Sec #17 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:41:19 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:41:19 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:41:19 Chart #17 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:41:19 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:41:19 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:19 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:19 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:19 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:19 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:41:19 6C.20170600.CME_Fo [C] 30 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:41:19 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:41:23 Chart #1 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:41:23 Chart #1 has tagged chart #14 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:41:23 Chart #1 has tagged chart #17 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:41:23 Chart #1 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:41:23 Chart #1 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:41:23 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:41:23 ZB.20170600.CME_F [C] 15 Min #26 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:41:23 6J.20170600.CME_Fo 3 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:41:23 Chart #14 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:41:23 ZB.20170600.CME_F 3 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:41:23 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:41:23 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:41:23 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:41:23 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:23 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:23 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:41:23 6J.20170600.CME_Fo 30 Sec #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:41:23 NQ.20170600.CME_Eq 30 Sec #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:41:23 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:41:23 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:41:23 ES.20170600.CME_Eq 3 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:41:23 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:41:23 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:41:23 Chart #17 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:41:23 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:41:23 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:41:23 6J.20170600.CME_Fo 3 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:41:29 Chart #14 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:41:29 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:41:29 HD Request # 394 | Downloading Intraday chart data for ZT.20170600.CME_F to the file ZT.20170600.CME_F.scid. Service: cts | 2017-05-21 06:41:51 HD Request # 394 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:41:51 HD Request # 394 | Requesting historical Second data for ZT.20170600.CME_F from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:41:51 HD Request # 394 | Receiving Intraday data for ZT.20170600.CME_F starting at 2017-05-18 18:00:00 | 2017-05-21 06:41:51 HD Request # 394 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:41:51 HD Request # 394 | Total records received: 3447 | 2017-05-21 06:41:51 HD Request # 394 | Requesting historical Second data for ZT.20170600.CME_F from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:41:51 HD Request # 394 | Total records received: 3447 | 2017-05-21 06:41:51 HD Request # 394 | Requesting historical Second data for ZT.20170600.CME_F from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:41:51 HD Request # 394 | Total records received: 3447 | 2017-05-21 06:41:51 HD Request # 394 | Requesting historical Second data for ZT.20170600.CME_F from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:41:51 HD Request # 394 | Total records received: 3447 | 2017-05-21 06:41:52 HD Request # 394 | Requesting historical Second data for ZT.20170600.CME_F from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:41:52 HD Request # 394 | Received 3447 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for ZT.20170600.CME_F | 2017-05-21 06:41:52 HD Request # 394 | Intraday download COMPLETE for ZT.20170600.CME_F. Completion time: 0s. Unique request ID: 675 | 2017-05-21 06:41:52 Removed historical data download ID 675 | 2017-05-21 06:41:52 Real-time Intraday chart data file updates started for ZT.20170600.CME_F | 2017-05-21 06:41:52 Opened cached Intraday file: C:\SierraChart1\Data\ZT.20170600.CME_F.scid | 2017-05-21 06:41:52 Intraday chart data file opened for ZT.20170600.CME_F | 2017-05-21 06:41:52 Delaying start of download for HO.20170700.CME_NY | 2017-05-21 06:41:52 Chart #9 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:41:52 Chart #9 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:41:52 GC.20170600.CME_CO 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:41:52 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:41:52 Chart #9 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:41:52 Chart #9 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:41:52 Chart #9 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:41:52 ZB.20170600.CME_F 30 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:41:52 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:41:52 Chart #12 has tagged chart #13 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:52 Chart #12 has tagged chart #15 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:52 Chart #12 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:52 Chart #12 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:52 ZB.20170600.CME_F [C] 30 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:41:52 Chart #15 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:52 Chart #15 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:52 Chart #15 has tagged chart #26 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:52 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:41:52 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:41:52 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:52 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:52 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:52 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:52 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:41:52 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:41:52 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:41:57 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:41:57 ZB.20170600.CME_F [C] 15 Min #26 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:41:57 ZB.20170600.CME_F 3 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:41:57 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:41:57 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:41:57 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:41:57 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:57 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:41:57 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:41:57 GC.20170600.CME_CO [C] 30 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:41:57 Chart #13 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:57 Chart #13 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:57 Chart #13 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:57 Chart #13 has tagged chart #4 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:57 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:41:57 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:57 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:57 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:57 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:41:57 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:41:57 6C.20170600.CME_Fo [C] 30 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:41:57 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:41:57 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:41:57 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:42:02 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:42:02 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:42:02 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:42:02 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:42:02 HD Request # 395 | Downloading Intraday chart data for HO.20170700.CME_NY to the file HO.20170700.CME_NY.scid. Service: cts | 2017-05-21 06:42:21 HD Request # 395 | Download start date-time: 2017-05-19 16:59:53.000 | 2017-05-21 06:42:21 HD Request # 395 | Requesting historical Second data for HO.20170700.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:42:21 HD Request # 395 | Receiving Intraday data for HO.20170700.CME_NY starting at 2017-05-18 18:00:00 | 2017-05-21 06:42:23 HD Request # 395 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:53 | 2017-05-21 06:42:23 HD Request # 395 | Total records received: 7519 | 2017-05-21 06:42:23 HD Request # 395 | Requesting historical Second data for HO.20170700.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:42:23 HD Request # 395 | Total records received: 7519 | 2017-05-21 06:42:23 HD Request # 395 | Requesting historical Second data for HO.20170700.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:42:23 HD Request # 395 | Total records received: 7519 | 2017-05-21 06:42:23 HD Request # 395 | Requesting historical Second data for HO.20170700.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:42:23 HD Request # 395 | Total records received: 7519 | 2017-05-21 06:42:24 HD Request # 395 | Requesting historical Second data for HO.20170700.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:42:24 HD Request # 395 | Received 7519 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:53 (23.0 hours) and wrote 1 record for HO.20170700.CME_NY | 2017-05-21 06:42:24 HD Request # 395 | Intraday download COMPLETE for HO.20170700.CME_NY. Completion time: 2s. Unique request ID: 676 | 2017-05-21 06:42:24 Removed historical data download ID 676 | 2017-05-21 06:42:24 Real-time Intraday chart data file updates started for HO.20170700.CME_NY | 2017-05-21 06:42:24 Opened cached Intraday file: C:\SierraChart1\Data\HO.20170700.CME_NY.scid | 2017-05-21 06:42:24 Intraday chart data file opened for HO.20170700.CME_NY | 2017-05-21 06:42:24 Delaying start of download for CL.20170700.CME_NY | 2017-05-21 06:42:24 Chart #20 has tagged chart #16 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:42:24 Chart #20 has tagged chart #9 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:42:24 CL.20170700.CME_NY [C] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:42:24 Chart #9 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:42:24 Chart #5 has tagged chart #16 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:42:24 CL.20170700.CME_NY 3 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:42:24 Chart #16 has tagged chart #15 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:42:24 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:42:26 CL.20170700.CME_NY 30 Sec #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:42:26 6C.20170600.CME_Fo 3 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:42:26 HD Request # 396 | Downloading Intraday chart data for CL.20170700.CME_NY to the file CL.20170700.CME_NY.scid. Service: cts | 2017-05-21 06:42:48 HD Request # 396 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:42:48 HD Request # 396 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:42:48 HD Request # 396 | Receiving Intraday data for CL.20170700.CME_NY starting at 2017-05-18 18:00:00 | 2017-05-21 06:42:50 HD Request # 396 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:42:50 HD Request # 396 | Total records received: 33722 | 2017-05-21 06:42:50 HD Request # 396 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:42:50 HD Request # 396 | Total records received: 33722 | 2017-05-21 06:42:50 HD Request # 396 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:42:50 HD Request # 396 | Total records received: 33722 | 2017-05-21 06:42:51 HD Request # 396 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:42:51 HD Request # 396 | Total records received: 33722 | 2017-05-21 06:42:51 HD Request # 396 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:42:51 HD Request # 396 | Received 33722 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for CL.20170700.CME_NY | 2017-05-21 06:42:51 HD Request # 396 | Intraday download COMPLETE for CL.20170700.CME_NY. Completion time: 3s. Unique request ID: 677 | 2017-05-21 06:42:51 Removed historical data download ID 677 | 2017-05-21 06:42:51 Real-time Intraday chart data file updates started for CL.20170700.CME_NY | 2017-05-21 06:42:51 Opened cached Intraday file: C:\SierraChart1\Data\CL.20170700.CME_NY.scid | 2017-05-21 06:42:51 Intraday chart data file opened for CL.20170700.CME_NY | 2017-05-21 06:42:51 Delaying start of download for ZB.20170600.CME_F | 2017-05-21 06:42:51 Chart #9 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:42:51 Chart #16 has tagged chart #15 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:42:51 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:42:53 Chart #3 has tagged chart #1 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:42:53 Chart #3 has tagged chart #4 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:42:53 Chart #3 has tagged chart #5 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:42:53 Chart #3 has tagged chart #8 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:42:53 CL.20170700.CME_NY 30 Sec #4 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:42:53 CL.20170700.CME_NY 3 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:42:53 DTC Client (2170) | Closed. No error. | 2017-05-21 06:42:53 DTC Client (2170) | Shutdown and closed. | 2017-05-21 06:42:53 SC DTC Data | Disconnected from the server. | 2017-05-21 06:42:53 SC DTC Data | Data feed disconnected. Will reconnect in 2 seconds. | 2017-05-21 06:42:53 CTS FIX socket (2168) | Closed. No error. | 2017-05-21 06:42:53 CTS FIX socket (2168) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-21 06:42:53 CTS FIX socket (2168) | SSL has been shut down. | 2017-05-21 06:42:53 CTS FIX socket (2168) | SSL object has been freed. SSL state is now disconnected. | 2017-05-21 06:42:53 CTS FIX socket (2168) | Shutdown and closed. | 2017-05-21 06:42:53 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2017-05-21 06:42:53 Connection to the external service has been lost. | 2017-05-21 06:42:53 CL.20170700.CME_NY 3 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:42:53 6C.20170600.CME_Fo 3 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:42:53 CL.20170700.CME_NY 3 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:43:52 SC DTC Data | Connecting to the server ds3.sierracharts.com. Port 10048 | 2017-05-21 06:43:52 Canceling historical data download request for ZB.20170600.CME_F Intraday data. | 2017-05-21 06:43:52 Removed historical data download ID 678 | 2017-05-21 06:43:52 Canceling historical data download request for 6B.20170600.CME_Fo Intraday data. | 2017-05-21 06:43:52 Removed historical data download ID 679 | 2017-05-21 06:43:52 Canceling historical data download request for 6C.20170600.CME_Fo Intraday data. | 2017-05-21 06:43:52 Removed historical data download ID 680 | 2017-05-21 06:43:52 Canceling historical data download request for 6J.20170600.CME_Fo Intraday data. | 2017-05-21 06:43:52 Removed historical data download ID 681 | 2017-05-21 06:43:52 Canceling historical data download request for ZN.20170600.CME_F Intraday data. | 2017-05-21 06:43:52 Removed historical data download ID 682 | 2017-05-21 06:43:52 Canceling historical data download request for CL.20171200.CME_NY Intraday data. | 2017-05-21 06:43:52 Removed historical data download ID 683 | 2017-05-21 06:43:52 Canceling historical data download request for ES.20170600.CME_Eq Intraday data. | 2017-05-21 06:43:52 Removed historical data download ID 684 | 2017-05-21 06:43:52 Canceling historical data download request for RB.20170700.CME_NY Intraday data. | 2017-05-21 06:43:52 Removed historical data download ID 685 | 2017-05-21 06:43:52 Canceling historical data download request for 6E.20170600.CME_Fo Intraday data. | 2017-05-21 06:43:52 Removed historical data download ID 686 | 2017-05-21 06:43:52 Canceling historical data download request for YM.20170600.CME_E Intraday data. | 2017-05-21 06:43:52 Removed historical data download ID 687 | 2017-05-21 06:43:52 Canceling historical data download request for 6S.20170600.CME_Fo Intraday data. | 2017-05-21 06:43:52 Removed historical data download ID 689 | 2017-05-21 06:43:52 Canceling historical data download request for HO.20171200.CME_NY Intraday data. | 2017-05-21 06:43:52 Removed historical data download ID 690 | 2017-05-21 06:43:52 Canceling historical data download request for 6N.20170600.CME_Fo Intraday data. | 2017-05-21 06:43:52 Removed historical data download ID 691 | 2017-05-21 06:43:52 Canceling historical data download request for RB.20171200.CME_NY Intraday data. | 2017-05-21 06:43:52 Removed historical data download ID 692 | 2017-05-21 06:43:52 CTS FIX Historical Data: DisconnectFIX called. | 2017-05-21 06:43:52 CTS FIX Historical Data: Sending a Logout message. | 2017-05-21 06:43:52 CTS T4 FIX | Disconnected. | 2017-05-21 06:43:52 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-21 06:43:52 DTC Client (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2017-05-21 06:43:52 DTC Client (2174) | Connected. | 2017-05-21 06:43:52 SC DTC Data | Connected to server. | 2017-05-21 06:43:52 SC DTC Data | Sending Encoding Request to server | 2017-05-21 06:43:52 CTS FIX Historical Data socket (2169) | Closed. No error. | 2017-05-21 06:43:52 CTS FIX Historical Data: Received a Logout message. Text = Successful logout upon request | 2017-05-21 06:43:52 CTS FIX Historical Data socket (2169) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-21 06:43:52 CTS FIX Historical Data socket (2169) | SSL has been shut down. | 2017-05-21 06:43:52 CTS FIX Historical Data socket (2169) | SSL object has been freed. SSL state is now disconnected. | 2017-05-21 06:43:52 CTS FIX Historical Data socket (2169) | Shutdown and closed. | 2017-05-21 06:43:52 CTS FIX Historical Data: Disconnected. | 2017-05-21 06:43:52 SC DTC Data | Setting DTC encoding to Binary VLS | 2017-05-21 06:43:52 SC DTC Data | Sending logon request message. | 2017-05-21 06:43:52 SC DTC Data | Received logon response. | 2017-05-21 06:43:54 SC DTC Data | Server Name: SC Realtime Server. | 2017-05-21 06:43:54 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2017-05-21 06:43:54 SC DTC Data | Successfully connected. | 2017-05-21 06:43:54 SC DTC Data | Trading is not supported. | 2017-05-21 06:43:54 Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2017-05-21 06:43:54 SC DTC Data | Restarting real-time data updates for symbol: AUDJPY | 2017-05-21 06:43:54 HD Request # 397 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-05-21 06:43:54 HD Request # 397 | Download start date-time: 2017-05-19 16:57:58.000 | 2017-05-21 06:43:54 HD Request # 397 | Using server: ds3.sierracharts.com port 10149 | 2017-05-21 06:43:54 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2017-05-21 06:43:54 Socket (2175) | Connected. | 2017-05-21 06:43:54 HD Request # 397 | Setting DTC encoding to Binary VLS | 2017-05-21 06:43:54 HD Request # 397 | Sending historical data logon request message. | 2017-05-21 06:43:54 SC DTC Data | Received security definition for symbol AUDJPY | 2017-05-21 06:43:54 HD Request # 397 | Requesting Intraday data. Start date-time: 2017-05-19 16:57:58. Record interval: 1. Symbol: AUDJPY | 2017-05-21 06:43:54 HD Request # 397 | Decompressing data. | 2017-05-21 06:43:54 HD Request # 397 | Receiving Intraday data for AUDJPY starting at 2017-05-19 16:57:58 | 2017-05-21 06:43:54 HD Request # 397 | Timestamp of first Intraday data file record written: 2017-05-19 16:57:58 | 2017-05-21 06:43:54 Socket (2175) | Shutdown and closed. | 2017-05-21 06:43:54 The network socket for historical data has been closed. | 2017-05-21 06:43:54 HD Request # 397 | Historical data for AUDJPY is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-05-21 06:43:54 HD Request # 397 | Received 1 record from 2017-05-19 16:57:58 to 2017-05-19 16:57:58 (0.0 seconds) and wrote 1 record for AUDJPY | 2017-05-21 06:43:54 HD Request # 397 | Intraday download COMPLETE for AUDJPY. Completion time: 0s. Unique request ID: 693 | 2017-05-21 06:43:54 Removed historical data download ID 693 | 2017-05-21 06:43:54 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2017-05-21 06:43:57 CTS T4 FIX | Firm: PTP | 2017-05-21 06:43:57 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199. | 2017-05-21 06:43:57 CTS FIX socket (2176) | Connected. | 2017-05-21 06:43:57 CTS FIX socket (2176) | Starting TLS 1.0 connection. | 2017-05-21 06:43:57 CTS FIX socket (2176) | SSL connection established. | 2017-05-21 06:43:58 CTS FIX: Sending the Logon message. | 2017-05-21 06:44:00 CTS T4 FIX | FIX version: 4.3.74.0 | 2017-05-21 06:44:00 CTS T4 FIX | Connected to data and trading server. | 2017-05-21 06:44:00 DTC Client (2174) | Shutdown and closed. | 2017-05-21 06:44:00 SC DTC Data | Disconnected from the server. | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: ZB.20160900.CME_F. ID: 1 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: ZB.20160900.CME_F. ID: 1 | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: 6E.20160900.CME_Fo. ID: 2 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: 6E.20160900.CME_Fo. ID: 2 | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6J.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: 6J.20160900.CME_Fo. ID: 3 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: 6J.20160900.CME_Fo. ID: 3 | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6B.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: 6B.20160900.CME_Fo. ID: 4 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: 6B.20160900.CME_Fo. ID: 4 | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6C.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: 6C.20160900.CME_Fo. ID: 5 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: 6C.20160900.CME_Fo. ID: 5 | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: CL.20160800.CME_NY. ID: 6 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: CL.20160800.CME_NY. ID: 6 | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6A.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: 6A.20160900.CME_Fo. ID: 7 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: 6A.20160900.CME_Fo. ID: 7 | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: NQ.20160900.CME_Eq. ID: 8 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: NQ.20160900.CME_Eq. ID: 8 | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM.######00.CME_E pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: YM.20160900.CME_E. ID: 9 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: YM.20160900.CME_E. ID: 9 | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: GC.20160800.CME_CO. ID: 10 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: GC.20160800.CME_CO. ID: 10 | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: ES.20160900.CME_Eq. ID: 11 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: ES.20160900.CME_Eq. ID: 11 | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: ZB.20170300.CME_F. ID: 12 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: ZB.20170300.CME_F. ID: 12 | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: CL.20170100.CME_NY. ID: 13 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: CL.20170100.CME_NY. ID: 13 | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: GC.20170400.CME_CO. ID: 14 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: GC.20170400.CME_CO. ID: 14 | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: ZB.20170600.CME_F. ID: 15 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: ZB.20170600.CME_F. ID: 15 | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6B.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: 6B.20170600.CME_Fo. ID: 16 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: 6B.20170600.CME_Fo. ID: 16 | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: CL.20170600.CME_NY. ID: 17 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: CL.20170600.CME_NY. ID: 17 | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: CL.20170700.CME_NY. ID: 18 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: CL.20170700.CME_NY. ID: 18 | 2017-05-21 06:44:00 Requesting market depth updates for: CL.20170700.CME_NY if supported. | 2017-05-21 06:44:00 CTS T4 FIX | Using primary service for historical data for CL.20170700.CME_NY | 2017-05-21 06:44:00 Intraday data recording state for symbol CL.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:44:00 Delaying start of download for CL.20170700.CME_NY | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6A.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: 6A.20170600.CME_Fo. ID: 19 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: 6A.20170600.CME_Fo. ID: 19 | 2017-05-21 06:44:00 CTS T4 FIX | Using primary service for historical data for 6A.20170600.CME_Fo | 2017-05-21 06:44:00 Intraday data recording state for symbol 6A.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZT.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: ZT.20170600.CME_F. ID: 20 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: ZT.20170600.CME_F. ID: 20 | 2017-05-21 06:44:00 CTS T4 FIX | Using primary service for historical data for ZT.20170600.CME_F | 2017-05-21 06:44:00 Intraday data recording state for symbol ZT.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:44:00 CTS T4 FIX | Received Account List collateral report. | 2017-05-21 06:44:00 CTS T4 FIX | Subscribing to account: May* | 2017-05-21 06:44:00 Supported exchange: CME_CO (SIM:COMEX Futures) | 2017-05-21 06:44:00 Supported exchange: CME_EqOp (SIM:CME Equity Options) | 2017-05-21 06:44:00 Supported exchange: CME_NYOp (SIM:NYMEX Options) | 2017-05-21 06:44:00 Supported exchange: CME_AgOp (SIM:CME Agricultural Options) | 2017-05-21 06:44:00 Supported exchange: CME_Eq (SIM:CME Equity Futures) | 2017-05-21 06:44:00 Supported exchange: CME_In (SIM:CME Interest Rate Futures) | 2017-05-21 06:44:00 Supported exchange: CME_C (SIM:CBOT Commodity Futures) | 2017-05-21 06:44:00 Supported exchange: CME_KOp (SIM:KCBT Options) | 2017-05-21 06:44:00 Supported exchange: CME_F (SIM:CBOT Financial Futures) | 2017-05-21 06:44:00 Supported exchange: CME_E (SIM:CBOT Equity Futures) | 2017-05-21 06:44:00 Supported exchange: CME_COp (SIM:CBOT Commodity Options) | 2017-05-21 06:44:00 Supported exchange: CME_K (SIM:KCBT Futures) | 2017-05-21 06:44:00 Supported exchange: CME_EOp (SIM:CBOT Equity Options) | 2017-05-21 06:44:00 Supported exchange: CME_NY (SIM:NYMEX Futures) | 2017-05-21 06:44:00 Supported exchange: CME_Fo (SIM:CME Foreign Exchange Futures) | 2017-05-21 06:44:00 Supported exchange: CME_Ag (SIM:CME Agricultural Futures) | 2017-05-21 06:44:00 Supported exchange: CME_FoOp (SIM:CME Foreign Exchange Options) | 2017-05-21 06:44:00 Supported exchange: CME_FOp (SIM:CBOT Financial Options) | 2017-05-21 06:44:00 Supported exchange: CME_InOp (SIM:CME Interest Rate Options) | 2017-05-21 06:44:00 Supported exchange: CME_COOp (SIM:COMEX Options) | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: GC.20170600.CME_CO. ID: 21 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: GC.20170600.CME_CO. ID: 21 | 2017-05-21 06:44:00 CTS T4 FIX | Using primary service for historical data for GC.20170600.CME_CO | 2017-05-21 06:44:00 Intraday data recording state for symbol GC.20170600.CME_CO is set to download 'Pending'. | 2017-05-21 06:44:00 Requesting market depth updates for: ZB.20170600.CME_F if supported. | 2017-05-21 06:44:00 CTS T4 FIX | Using primary service for historical data for ZB.20170600.CME_F | 2017-05-21 06:44:00 Intraday data recording state for symbol ZB.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:44:00 CTS T4 FIX | Using primary service for historical data for 6B.20170600.CME_Fo | 2017-05-21 06:44:00 Intraday data recording state for symbol 6B.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The HO.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: HO.20170700.CME_NY. ID: 22 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: HO.20170700.CME_NY. ID: 22 | 2017-05-21 06:44:00 CTS T4 FIX | Using primary service for historical data for HO.20170700.CME_NY | 2017-05-21 06:44:00 Intraday data recording state for symbol HO.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6C.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: 6C.20170600.CME_Fo. ID: 23 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: 6C.20170600.CME_Fo. ID: 23 | 2017-05-21 06:44:00 CTS T4 FIX | Using primary service for historical data for 6C.20170600.CME_Fo | 2017-05-21 06:44:00 Intraday data recording state for symbol 6C.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6J.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: 6J.20170600.CME_Fo. ID: 24 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: 6J.20170600.CME_Fo. ID: 24 | 2017-05-21 06:44:00 CTS T4 FIX | Using primary service for historical data for 6J.20170600.CME_Fo | 2017-05-21 06:44:00 Intraday data recording state for symbol 6J.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZN.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: ZN.20170600.CME_F. ID: 25 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: ZN.20170600.CME_F. ID: 25 | 2017-05-21 06:44:00 CTS T4 FIX | Using primary service for historical data for ZN.20170600.CME_F | 2017-05-21 06:44:00 Intraday data recording state for symbol ZN.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: CL.20171200.CME_NY. ID: 26 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: CL.20171200.CME_NY. ID: 26 | 2017-05-21 06:44:00 CTS T4 FIX | Using primary service for historical data for CL.20171200.CME_NY | 2017-05-21 06:44:00 Intraday data recording state for symbol CL.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:44:00 HD Request # 398 | Downloading Intraday chart data for CL.20170700.CME_NY to the file CL.20170700.CME_NY.scid. Service: cts | 2017-05-21 06:44:00 HD Request # 398 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:44:00 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: ES.20170600.CME_Eq. ID: 27 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: ES.20170600.CME_Eq. ID: 27 | 2017-05-21 06:44:00 Requesting market depth updates for: ES.20170600.CME_Eq if supported. | 2017-05-21 06:44:00 CTS T4 FIX | Using primary service for historical data for ES.20170600.CME_Eq | 2017-05-21 06:44:00 Intraday data recording state for symbol ES.20170600.CME_Eq is set to download 'Pending'. | 2017-05-21 06:44:00 CTS FIX Historical Data socket (0) | Resolved address fix-chart-sim.t4login.com to IP 74.201.6.229. | 2017-05-21 06:44:00 CTS FIX Historical Data socket (2177) | Connected. | 2017-05-21 06:44:00 CTS FIX Historical Data socket (2177) | Starting TLS 1.0 connection. | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The RB.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: RB.20170700.CME_NY. ID: 28 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: RB.20170700.CME_NY. ID: 28 | 2017-05-21 06:44:00 CTS T4 FIX | Using primary service for historical data for RB.20170700.CME_NY | 2017-05-21 06:44:00 Intraday data recording state for symbol RB.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: 6E.20170600.CME_Fo. ID: 29 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: 6E.20170600.CME_Fo. ID: 29 | 2017-05-21 06:44:00 CTS T4 FIX | Using primary service for historical data for 6E.20170600.CME_Fo | 2017-05-21 06:44:00 Intraday data recording state for symbol 6E.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM.######00.CME_E pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: YM.20170600.CME_E. ID: 30 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: YM.20170600.CME_E. ID: 30 | 2017-05-21 06:44:00 CTS T4 FIX | Using primary service for historical data for YM.20170600.CME_E | 2017-05-21 06:44:00 Intraday data recording state for symbol YM.20170600.CME_E is set to download 'Pending'. | 2017-05-21 06:44:00 Using Bid/Ask average for last trade price for AUDJPY | 2017-05-21 06:44:00 SC DTC Data | Starting real-time market data updates for: AUDJPY. ID: 31 | 2017-05-21 06:44:00 SC DTC Data | Connecting to the server ds4.sierracharts.com. Port 443 | 2017-05-21 06:44:00 SC DTC Data | Requesting security definition data for: AUDJPY. ID: 31 | 2017-05-21 06:44:00 Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2017-05-21 06:44:00 DTC Client (0) | Resolved address ds4.sierracharts.com to IP 192.81.56.146. | 2017-05-21 06:44:00 Delaying start of download for AUDJPY | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6S.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: 6S.20170600.CME_Fo. ID: 32 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: 6S.20170600.CME_Fo. ID: 32 | 2017-05-21 06:44:00 CTS T4 FIX | Using primary service for historical data for 6S.20170600.CME_Fo | 2017-05-21 06:44:00 Intraday data recording state for symbol 6S.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:44:00 Requesting market depth updates for: 6E.20170600.CME_Fo if supported. | 2017-05-21 06:44:00 DTC Client (2178) | Connected. | 2017-05-21 06:44:00 SC DTC Data | Connected to server. | 2017-05-21 06:44:00 SC DTC Data | Sending Encoding Request to server | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The HO.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: HO.20171200.CME_NY. ID: 33 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: HO.20171200.CME_NY. ID: 33 | 2017-05-21 06:44:00 CTS T4 FIX | Using primary service for historical data for HO.20171200.CME_NY | 2017-05-21 06:44:00 Intraday data recording state for symbol HO.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6N.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: 6N.20170600.CME_Fo. ID: 34 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: 6N.20170600.CME_Fo. ID: 34 | 2017-05-21 06:44:00 CTS T4 FIX | Using primary service for historical data for 6N.20170600.CME_Fo | 2017-05-21 06:44:00 Intraday data recording state for symbol 6N.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The RB.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: RB.20171200.CME_NY. ID: 35 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: RB.20171200.CME_NY. ID: 35 | 2017-05-21 06:44:00 CTS T4 FIX | Using primary service for historical data for RB.20171200.CME_NY | 2017-05-21 06:44:00 Intraday data recording state for symbol RB.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:44:00 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:44:00 CTS T4 FIX | Starting real-time market data updates for: NQ.20170600.CME_Eq. ID: 36 | 2017-05-21 06:44:00 CTS T4 FIX | Requesting security definition data for: NQ.20170600.CME_Eq. ID: 36 | 2017-05-21 06:44:00 CTS T4 FIX | Using primary service for historical data for NQ.20170600.CME_Eq | 2017-05-21 06:44:00 Intraday data recording state for symbol NQ.20170600.CME_Eq is set to download 'Pending'. | 2017-05-21 06:44:00 CTS FIX Historical Data socket (2177) | SSL connection established. | 2017-05-21 06:44:00 Requesting market depth updates for: 6B.20170600.CME_Fo if supported. | 2017-05-21 06:44:04 SC DTC Data | Setting DTC encoding to Binary VLS | 2017-05-21 06:44:04 SC DTC Data | Sending logon request message. | 2017-05-21 06:44:04 Requesting market depth updates for: YM.20170600.CME_E if supported. | 2017-05-21 06:44:04 Requesting market depth updates for: 6J.20170600.CME_Fo if supported. | 2017-05-21 06:44:04 SC DTC Data | Received logon response. | 2017-05-21 06:44:04 SC DTC Data | Server Name: SC Realtime Server. | 2017-05-21 06:44:04 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2017-05-21 06:44:04 SC DTC Data | Successfully connected. | 2017-05-21 06:44:04 SC DTC Data | Trading is not supported. | 2017-05-21 06:44:04 SC DTC Data | Restarting real-time data updates for symbol: AUDJPY | 2017-05-21 06:44:04 Requesting market depth updates for: NQ.20170600.CME_Eq if supported. | 2017-05-21 06:44:04 SC DTC Data | Received security definition for symbol AUDJPY | 2017-05-21 06:44:04 Requesting market depth updates for: GC.20170600.CME_CO if supported. | 2017-05-21 06:44:04 CTS T4 FIX | Sending security definition request for symbol 6A.20160900.CME_Fo | 2017-05-21 06:44:04 Symbol Error - 6A.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:44:04 CTS T4 FIX | Received 0 security definitions for underlying symbol 6A | 2017-05-21 06:44:04 CTS FIX Historical Data: Sending the Logon message. | 2017-05-21 06:44:04 CTS T4 FIX | Sending security definition request for symbol 6A.20170600.CME_Fo | 2017-05-21 06:44:07 Delaying start of download for AUDJPY | 2017-05-21 06:44:07 CTS FIX Historical Data: Connected to Historical data server. | 2017-05-21 06:44:07 CTS T4 FIX | Received 'Account Update/Balance Data' collateral report. | 2017-05-21 06:44:07 CTS T4 FIX | Received matching security definition for symbol 6A.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:44:07 CTS T4 FIX | Received 1 security definitions for underlying symbol 6A | 2017-05-21 06:44:07 Contract specifications for 6A.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:44:07 CTS T4 FIX | Sending security definition request for symbol 6B.20160900.CME_Fo | 2017-05-21 06:44:08 Symbol Error - 6B.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:44:08 CTS T4 FIX | Received 0 security definitions for underlying symbol 6B | 2017-05-21 06:44:08 Requesting market depth updates for: 6B.20160900.CME_Fo if supported. | 2017-05-21 06:44:10 Requesting market depth updates for: 6E.20160900.CME_Fo if supported. | 2017-05-21 06:44:10 Requesting market depth updates for: 6J.20160900.CME_Fo if supported. | 2017-05-21 06:44:10 Requesting market depth updates for: 6N.20170600.CME_Fo if supported. | 2017-05-21 06:44:10 Requesting market depth updates for: CL.20160800.CME_NY if supported. | 2017-05-21 06:44:10 Requesting market depth updates for: CL.20170100.CME_NY if supported. | 2017-05-21 06:44:10 Requesting market depth updates for: CL.20170600.CME_NY if supported. | 2017-05-21 06:44:10 Requesting market depth updates for: CL.20171200.CME_NY if supported. | 2017-05-21 06:44:10 Requesting market depth updates for: ES.20160900.CME_Eq if supported. | 2017-05-21 06:44:10 Requesting market depth updates for: GC.20160800.CME_CO if supported. | 2017-05-21 06:44:10 Requesting market depth updates for: GC.20170400.CME_CO if supported. | 2017-05-21 06:44:10 Requesting market depth updates for: NQ.20160900.CME_Eq if supported. | 2017-05-21 06:44:10 Requesting market depth updates for: YM.20160900.CME_E if supported. | 2017-05-21 06:44:10 Requesting market depth updates for: ZB.20160900.CME_F if supported. | 2017-05-21 06:44:10 Requesting market depth updates for: ZB.20170300.CME_F if supported. | 2017-05-21 06:44:10 CTS T4 FIX | Requesting Open Orders for account: May*. Request ID: 9498828 | 2017-05-21 06:44:10 CTS T4 FIX | No open orders for account May18CCwmitchel | 2017-05-21 06:44:10 HD Request # 399 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-05-21 06:44:11 HD Request # 399 | Download start date-time: 2017-05-19 16:57:58.000 | 2017-05-21 06:44:11 HD Request # 399 | Using server: ds4.sierracharts.com port 10149 | 2017-05-21 06:44:11 Socket (0) | Resolved address ds4.sierracharts.com to IP 192.81.56.146. | 2017-05-21 06:44:11 Socket (2179) | Connected. | 2017-05-21 06:44:11 HD Request # 399 | Setting DTC encoding to Binary VLS | 2017-05-21 06:44:11 HD Request # 399 | Sending historical data logon request message. | 2017-05-21 06:44:11 HD Request # 399 | Requesting Intraday data. Start date-time: 2017-05-19 16:57:58. Record interval: 1. Symbol: AUDJPY | 2017-05-21 06:44:11 HD Request # 399 | Decompressing data. | 2017-05-21 06:44:11 HD Request # 399 | Receiving Intraday data for AUDJPY starting at 2017-05-19 16:57:58 | 2017-05-21 06:44:11 HD Request # 399 | Timestamp of first Intraday data file record written: 2017-05-19 16:57:58 | 2017-05-21 06:44:11 Socket (2179) | Shutdown and closed. | 2017-05-21 06:44:11 The network socket for historical data has been closed. | 2017-05-21 06:44:11 HD Request # 399 | Received 1 record from 2017-05-19 16:57:58 to 2017-05-19 16:57:58 (0.0 seconds) and wrote 1 record for AUDJPY | 2017-05-21 06:44:11 HD Request # 399 | Intraday download COMPLETE for AUDJPY. Completion time: 0s. Unique request ID: 709 | 2017-05-21 06:44:11 Removed historical data download ID 709 | 2017-05-21 06:44:11 Real-time Intraday chart data file updates started for AUDJPY | 2017-05-21 06:44:11 Opened cached Intraday file: C:\SierraChart1\Data\AUDJPY.scid | 2017-05-21 06:44:11 Intraday chart data file opened for AUDJPY | 2017-05-21 06:44:11 CTS T4 FIX | Sending security definition request for symbol 6B.20170600.CME_Fo | 2017-05-21 06:44:11 CTS T4 FIX | Received matching security definition for symbol 6B.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:44:11 CTS T4 FIX | Received 1 security definitions for underlying symbol 6B | 2017-05-21 06:44:11 Contract specifications for 6B.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 6.25 | 2017-05-21 06:44:13 CTS T4 FIX | Sending security definition request for symbol 6C.20160900.CME_Fo | 2017-05-21 06:44:14 Symbol Error - 6C.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:44:14 CTS T4 FIX | Received 0 security definitions for underlying symbol 6C | 2017-05-21 06:44:14 CTS T4 FIX | Sending security definition request for symbol 6C.20170600.CME_Fo | 2017-05-21 06:44:16 CTS T4 FIX | Received matching security definition for symbol 6C.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:44:17 CTS T4 FIX | Received 1 security definitions for underlying symbol 6C | 2017-05-21 06:44:17 Contract specifications for 6C.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 5 | 2017-05-21 06:44:17 CTS T4 FIX | Sending security definition request for symbol 6E.20160900.CME_Fo | 2017-05-21 06:44:18 CTS T4 FIX | Requesting historical Fills for account: May*. Request ID: 9498831 | 2017-05-21 06:44:18 Symbol Error - 6E.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:44:20 CTS T4 FIX | Received 0 security definitions for underlying symbol 6E | 2017-05-21 06:44:20 CTS T4 FIX | Received Account List collateral report. | 2017-05-21 06:44:20 CTS T4 FIX | Server provided no historical order fills for account 1A297B51-A416-42D4-A1C8-C9B1B4125155 | 2017-05-21 06:44:20 CTS T4 FIX | Sending security definition request for symbol 6E.20170600.CME_Fo | 2017-05-21 06:44:21 CTS T4 FIX | Received matching security definition for symbol 6E.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:44:21 CTS T4 FIX | Received 1 security definitions for underlying symbol 6E | 2017-05-21 06:44:21 Contract specifications for 6E.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-05-21 06:44:21 CTS T4 FIX | Sending security definition request for symbol 6J.20160900.CME_Fo | 2017-05-21 06:44:24 Symbol Error - 6J.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:44:24 CTS T4 FIX | Received 0 security definitions for underlying symbol 6J | 2017-05-21 06:44:24 CTS T4 FIX | Sending security definition request for symbol 6J.20170600.CME_Fo | 2017-05-21 06:44:27 CTS T4 FIX | Received matching security definition for symbol 6J.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:44:27 CTS T4 FIX | Received 1 security definitions for underlying symbol 6J | 2017-05-21 06:44:27 Contract specifications for 6J.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-05-21 06:44:27 CTS T4 FIX | Sending security definition request for symbol 6N.20170600.CME_Fo | 2017-05-21 06:44:28 CTS T4 FIX | Received matching security definition for symbol 6N.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:44:28 CTS T4 FIX | Received 1 security definitions for underlying symbol 6N | 2017-05-21 06:44:28 Contract specifications for 6N.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:44:29 CTS T4 FIX | Sending security definition request for symbol 6S.20170600.CME_Fo | 2017-05-21 06:44:31 CTS T4 FIX | Received matching security definition for symbol 6S.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:44:31 CTS T4 FIX | Received 1 security definitions for underlying symbol 6S | 2017-05-21 06:44:31 Contract specifications for 6S.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 12.5 | 2017-05-21 06:44:32 CTS T4 FIX | Sending security definition request for symbol CL.20160800.CME_NY | 2017-05-21 06:44:32 Symbol Error - CL.20160800.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:44:34 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2017-05-21 06:44:34 CTS T4 FIX | Sending security definition request for symbol CL.20170100.CME_NY | 2017-05-21 06:44:35 Symbol Error - CL.20170100.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:44:36 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2017-05-21 06:44:36 CTS T4 FIX | Sending security definition request for symbol CL.20170600.CME_NY | 2017-05-21 06:44:36 CTS T4 FIX | Received matching security definition for symbol CL.20170600.CME_NY. Subscribing to data. | 2017-05-21 06:44:38 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:44:38 Contract specifications for CL.20170600.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:44:38 CTS T4 FIX | Sending security definition request for symbol CL.20170700.CME_NY | 2017-05-21 06:44:39 CTS T4 FIX | Received matching security definition for symbol CL.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:44:39 CTS T4 FIX | Received matching security definition for symbol CL.20170700.CME_NY. Requesting historical data. | 2017-05-21 06:44:39 HD Request # 398 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:44:39 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:44:39 Contract specifications for CL.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:44:39 CTS T4 FIX | Sending security definition request for symbol CL.20171200.CME_NY | 2017-05-21 06:44:41 CTS T4 FIX | Received matching security definition for symbol CL.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:44:41 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:44:41 Contract specifications for CL.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:44:41 HD Request # 398 | Receiving Intraday data for CL.20170700.CME_NY starting at 2017-05-18 18:00:00 | 2017-05-21 06:44:41 HD Request # 398 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:44:41 HD Request # 398 | Total records received: 33722 | 2017-05-21 06:44:41 HD Request # 398 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:44:41 HD Request # 398 | Total records received: 33722 | 2017-05-21 06:44:41 HD Request # 398 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:44:41 HD Request # 398 | Total records received: 33722 | 2017-05-21 06:44:42 HD Request # 398 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:44:42 HD Request # 398 | Total records received: 33722 | 2017-05-21 06:44:42 HD Request # 398 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:44:42 HD Request # 398 | Received 33722 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for CL.20170700.CME_NY | 2017-05-21 06:44:42 HD Request # 398 | Intraday download COMPLETE for CL.20170700.CME_NY. Completion time: 39s. Unique request ID: 694 | 2017-05-21 06:44:42 Removed historical data download ID 694 | 2017-05-21 06:44:42 Real-time Intraday chart data file updates started for CL.20170700.CME_NY | 2017-05-21 06:44:42 Opened cached Intraday file: C:\SierraChart1\Data\CL.20170700.CME_NY.scid | 2017-05-21 06:44:42 Intraday chart data file opened for CL.20170700.CME_NY | 2017-05-21 06:44:42 Delaying start of download for 6A.20170600.CME_Fo | 2017-05-21 06:44:42 CTS T4 FIX | Sending security definition request for symbol ES.20160900.CME_Eq | 2017-05-21 06:44:42 Symbol Error - ES.20160900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:44:42 CTS T4 FIX | Received 0 security definitions for underlying symbol ES | 2017-05-21 06:44:42 Chart #9 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:44:42 Chart #16 has tagged chart #15 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:44:42 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:44:44 Chart #3 has tagged chart #1 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:44:44 Chart #3 has tagged chart #4 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:44:44 Chart #3 has tagged chart #5 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:44:44 Chart #3 has tagged chart #8 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:44:44 CL.20170700.CME_NY 30 Sec #4 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:44:44 CL.20170700.CME_NY 3 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:44:44 CL.20170700.CME_NY 3 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:44:44 6C.20170600.CME_Fo 3 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:44:44 CTS T4 FIX | Sending security definition request for symbol ES.20170600.CME_Eq | 2017-05-21 06:45:38 CTS T4 FIX | Received matching security definition for symbol ES.20170600.CME_Eq. Subscribing to data. | 2017-05-21 06:45:38 CTS T4 FIX | Received 1 security definitions for underlying symbol ES | 2017-05-21 06:45:38 CL.20170700.CME_NY 3 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:45:38 Contract specifications for ES.20170600.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 12.5 | 2017-05-21 06:45:38 CTS T4 FIX | Sending security definition request for symbol GC.20160800.CME_CO | 2017-05-21 06:45:39 Symbol Error - GC.20160800.CME_CO is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:45:41 CTS T4 FIX | Received 0 security definitions for underlying symbol GC | 2017-05-21 06:45:41 CTS T4 FIX | Sending security definition request for symbol GC.20170400.CME_CO | 2017-05-21 06:45:42 CTS FIX Historical Data socket (2177) | Closed. No error. | 2017-05-21 06:45:42 CTS FIX Historical Data socket (2177) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-21 06:45:42 CTS FIX Historical Data socket (2177) | SSL has been shut down. | 2017-05-21 06:45:42 CTS FIX Historical Data socket (2177) | SSL object has been freed. SSL state is now disconnected. | 2017-05-21 06:45:42 CTS FIX Historical Data socket (2177) | Shutdown and closed. | 2017-05-21 06:45:42 CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2017-05-21 06:45:42 CTS FIX Historical Data: Disconnected. | 2017-05-21 06:45:42 Symbol Error - GC.20170400.CME_CO is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:45:42 CTS T4 FIX | Received 0 security definitions for underlying symbol GC | 2017-05-21 06:45:42 CTS T4 FIX | Sending security definition request for symbol GC.20170600.CME_CO | 2017-05-21 06:45:45 CTS T4 FIX | Received matching security definition for symbol GC.20170600.CME_CO. Subscribing to data. | 2017-05-21 06:45:45 CTS T4 FIX | Received 1 security definitions for underlying symbol GC | 2017-05-21 06:45:45 Contract specifications for GC.20170600.CME_CO. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:45:45 CTS T4 FIX | Sending security definition request for symbol HO.20170700.CME_NY | 2017-05-21 06:45:48 CTS T4 FIX | Received matching security definition for symbol HO.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:45:48 CTS T4 FIX | Received 1 security definitions for underlying symbol HO | 2017-05-21 06:45:48 Contract specifications for HO.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:45:48 CTS T4 FIX | Sending security definition request for symbol HO.20171200.CME_NY | 2017-05-21 06:45:49 CTS T4 FIX | Received matching security definition for symbol HO.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:45:49 CTS T4 FIX | Received 1 security definitions for underlying symbol HO | 2017-05-21 06:45:49 Contract specifications for HO.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:45:49 CTS T4 FIX | Sending security definition request for symbol NQ.20160900.CME_Eq | 2017-05-21 06:45:52 Symbol Error - NQ.20160900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:45:52 CTS T4 FIX | Received 0 security definitions for underlying symbol NQ | 2017-05-21 06:45:52 CTS T4 FIX | Sending security definition request for symbol NQ.20170600.CME_Eq | 2017-05-21 06:45:55 CTS T4 FIX | Received matching security definition for symbol NQ.20170600.CME_Eq. Subscribing to data. | 2017-05-21 06:45:55 CTS T4 FIX | Received 1 security definitions for underlying symbol NQ | 2017-05-21 06:45:55 Contract specifications for NQ.20170600.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 5 | 2017-05-21 06:45:56 CTS T4 FIX | Sending security definition request for symbol RB.20170700.CME_NY | 2017-05-21 06:45:56 CTS T4 FIX | Received matching security definition for symbol RB.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:45:58 CTS T4 FIX | Received 1 security definitions for underlying symbol RB | 2017-05-21 06:45:58 Contract specifications for RB.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:45:58 HD Request # 400 | Downloading Intraday chart data for 6A.20170600.CME_Fo to the file 6A.20170600.CME_Fo.scid. Service: cts | 2017-05-21 06:45:58 HD Request # 400 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:45:58 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2017-05-21 06:45:58 CTS FIX Historical Data socket (0) | Resolved address fix-chart-sim.t4login.com to IP 74.201.6.229. | 2017-05-21 06:45:59 CTS FIX Historical Data socket (2181) | Connected. | 2017-05-21 06:45:59 CTS FIX Historical Data socket (2181) | Starting TLS 1.0 connection. | 2017-05-21 06:45:59 CTS FIX Historical Data socket (2181) | SSL connection established. | 2017-05-21 06:45:59 CTS T4 FIX | Sending security definition request for symbol RB.20171200.CME_NY | 2017-05-21 06:46:00 CTS T4 FIX | Received matching security definition for symbol RB.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:46:00 CTS T4 FIX | Received 1 security definitions for underlying symbol RB | 2017-05-21 06:46:00 Contract specifications for RB.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:46:00 CTS FIX Historical Data: Sending the Logon message. | 2017-05-21 06:46:00 CTS FIX Historical Data: Connected to Historical data server. | 2017-05-21 06:46:00 HD Request # 400 | Requesting historical Second data for 6A.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:46:00 HD Request # 400 | Receiving Intraday data for 6A.20170600.CME_Fo starting at 2017-05-18 18:00:00 | 2017-05-21 06:46:02 HD Request # 400 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:46:02 HD Request # 400 | Total records received: 6413 | 2017-05-21 06:46:02 HD Request # 400 | Requesting historical Second data for 6A.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:46:02 CTS T4 FIX | Sending security definition request for symbol YM.20160900.CME_E | 2017-05-21 06:46:02 HD Request # 400 | Total records received: 6413 | 2017-05-21 06:46:02 HD Request # 400 | Requesting historical Second data for 6A.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:46:02 Symbol Error - YM.20160900.CME_E is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:46:02 CTS T4 FIX | Received 0 security definitions for underlying symbol YM | 2017-05-21 06:46:02 HD Request # 400 | Total records received: 6413 | 2017-05-21 06:46:02 HD Request # 400 | Requesting historical Second data for 6A.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:46:02 HD Request # 400 | Total records received: 6413 | 2017-05-21 06:46:02 HD Request # 400 | Requesting historical Second data for 6A.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:46:02 HD Request # 400 | Received 6413 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for 6A.20170600.CME_Fo | 2017-05-21 06:46:02 HD Request # 400 | Intraday download COMPLETE for 6A.20170600.CME_Fo. Completion time: 5s. Unique request ID: 695 | 2017-05-21 06:46:02 Removed historical data download ID 695 | 2017-05-21 06:46:02 Real-time Intraday chart data file updates started for 6A.20170600.CME_Fo | 2017-05-21 06:46:02 Opened cached Intraday file: C:\SierraChart1\Data\6A.20170600.CME_Fo.scid | 2017-05-21 06:46:02 Intraday chart data file opened for 6A.20170600.CME_Fo | 2017-05-21 06:46:02 Delaying start of download for ZT.20170600.CME_F | 2017-05-21 06:46:02 CTS T4 FIX | Sending security definition request for symbol YM.20170600.CME_E | 2017-05-21 06:46:05 CTS T4 FIX | Received matching security definition for symbol YM.20170600.CME_E. Subscribing to data. | 2017-05-21 06:46:05 CTS T4 FIX | Received 1 security definitions for underlying symbol YM | 2017-05-21 06:46:05 Contract specifications for YM.20170600.CME_E. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 5 | 2017-05-21 06:46:05 CTS T4 FIX | Sending security definition request for symbol ZB.20160900.CME_F | 2017-05-21 06:46:06 Symbol Error - ZB.20160900.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:46:06 CTS T4 FIX | Received 0 security definitions for underlying symbol ZB | 2017-05-21 06:46:06 CTS T4 FIX | Sending security definition request for symbol ZB.20170300.CME_F | 2017-05-21 06:46:09 Symbol Error - ZB.20170300.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:46:09 CTS T4 FIX | Received 0 security definitions for underlying symbol ZB | 2017-05-21 06:46:09 CTS T4 FIX | Sending security definition request for symbol ZB.20170600.CME_F | 2017-05-21 06:46:11 CTS T4 FIX | Received matching security definition for symbol ZB.20170600.CME_F. Subscribing to data. | 2017-05-21 06:46:11 CTS T4 FIX | Received 1 security definitions for underlying symbol ZB | 2017-05-21 06:46:11 Contract specifications for ZB.20170600.CME_F. Multiplier: 0.00001000. Tick Size: 0.03125. Value Format: 132. Currency Value per Tick: 31.25 | 2017-05-21 06:46:11 CTS T4 FIX | Sending security definition request for symbol ZN.20170600.CME_F | 2017-05-21 06:46:13 CTS T4 FIX | Received matching security definition for symbol ZN.20170600.CME_F. Subscribing to data. | 2017-05-21 06:46:13 CTS T4 FIX | Received 1 security definitions for underlying symbol ZN | 2017-05-21 06:46:13 Contract specifications for ZN.20170600.CME_F. Multiplier: 0.00000100. Tick Size: 0.015625. Value Format: 132. Currency Value per Tick: 15.625 | 2017-05-21 06:46:14 CTS T4 FIX | Sending security definition request for symbol ZT.20170600.CME_F | 2017-05-21 06:46:16 CTS T4 FIX | Received matching security definition for symbol ZT.20170600.CME_F. Subscribing to data. | 2017-05-21 06:46:16 CTS T4 FIX | Received 1 security definitions for underlying symbol ZT | 2017-05-21 06:46:16 Contract specifications for ZT.20170600.CME_F. Multiplier: 0.00000010. Tick Size: 0.0078125. Value Format: 228. Currency Value per Tick: 15.625 | 2017-05-21 06:46:16 HD Request # 401 | Downloading Intraday chart data for ZT.20170600.CME_F to the file ZT.20170600.CME_F.scid. Service: cts | 2017-05-21 06:46:24 HD Request # 401 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:46:24 HD Request # 401 | Requesting historical Second data for ZT.20170600.CME_F from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:46:24 HD Request # 401 | Receiving Intraday data for ZT.20170600.CME_F starting at 2017-05-18 18:00:00 | 2017-05-21 06:46:26 HD Request # 401 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:46:26 HD Request # 401 | Total records received: 3447 | 2017-05-21 06:46:26 HD Request # 401 | Requesting historical Second data for ZT.20170600.CME_F from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:46:26 HD Request # 401 | Total records received: 3447 | 2017-05-21 06:46:26 HD Request # 401 | Requesting historical Second data for ZT.20170600.CME_F from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:46:26 HD Request # 401 | Total records received: 3447 | 2017-05-21 06:46:26 HD Request # 401 | Requesting historical Second data for ZT.20170600.CME_F from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:46:26 HD Request # 401 | Total records received: 3447 | 2017-05-21 06:46:26 HD Request # 401 | Requesting historical Second data for ZT.20170600.CME_F from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:46:26 HD Request # 401 | Received 3447 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for ZT.20170600.CME_F | 2017-05-21 06:46:26 HD Request # 401 | Intraday download COMPLETE for ZT.20170600.CME_F. Completion time: 2s. Unique request ID: 696 | 2017-05-21 06:46:26 Removed historical data download ID 696 | 2017-05-21 06:46:26 Real-time Intraday chart data file updates started for ZT.20170600.CME_F | 2017-05-21 06:46:26 Opened cached Intraday file: C:\SierraChart1\Data\ZT.20170600.CME_F.scid | 2017-05-21 06:46:26 Intraday chart data file opened for ZT.20170600.CME_F | 2017-05-21 06:46:26 Delaying start of download for GC.20170600.CME_CO | 2017-05-21 06:46:26 Chart #9 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:46:27 Chart #9 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:46:27 GC.20170600.CME_CO 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:46:27 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:46:27 Chart #9 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:46:27 Chart #9 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:46:27 Chart #9 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:46:27 ZB.20170600.CME_F 30 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:46:27 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:46:27 Chart #12 has tagged chart #13 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:27 Chart #12 has tagged chart #15 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:27 Chart #12 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:27 Chart #12 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:27 ZB.20170600.CME_F [C] 30 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:46:27 Chart #15 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:27 Chart #15 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:27 Chart #15 has tagged chart #26 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:27 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:46:27 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:46:27 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:27 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:27 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:27 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:27 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:46:27 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:46:31 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:46:31 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:46:31 ZB.20170600.CME_F [C] 15 Min #26 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:46:31 ZB.20170600.CME_F 3 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:46:31 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:46:31 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:46:31 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:46:31 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:31 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:46:31 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:46:31 GC.20170600.CME_CO [C] 30 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:46:31 Chart #13 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:31 Chart #13 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:31 Chart #13 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:31 Chart #13 has tagged chart #4 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:31 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:46:31 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:31 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:31 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:31 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:31 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:46:31 6C.20170600.CME_Fo [C] 30 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:46:31 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:46:31 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:46:36 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:46:36 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:46:36 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:36 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:46:36 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:46:36 HD Request # 402 | Downloading Intraday chart data for GC.20170600.CME_CO to the file GC.20170600.CME_CO.scid. Service: cts | 2017-05-21 06:46:55 HD Request # 402 | Download start date-time: 2017-05-19 16:59:57.000 | 2017-05-21 06:46:55 HD Request # 402 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:46:55 HD Request # 402 | Receiving Intraday data for GC.20170600.CME_CO starting at 2017-05-18 18:00:00 | 2017-05-21 06:46:57 HD Request # 402 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:57 | 2017-05-21 06:46:57 HD Request # 402 | Total records received: 26821 | 2017-05-21 06:46:57 HD Request # 402 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:46:57 HD Request # 402 | Total records received: 26821 | 2017-05-21 06:46:57 HD Request # 402 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:46:57 HD Request # 402 | Total records received: 26821 | 2017-05-21 06:46:57 HD Request # 402 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:46:57 HD Request # 402 | Total records received: 26821 | 2017-05-21 06:46:58 HD Request # 402 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:46:58 HD Request # 402 | Received 26821 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:57 (23.0 hours) and wrote 1 record for GC.20170600.CME_CO | 2017-05-21 06:46:58 HD Request # 402 | Intraday download COMPLETE for GC.20170600.CME_CO. Completion time: 3s. Unique request ID: 697 | 2017-05-21 06:46:58 Removed historical data download ID 697 | 2017-05-21 06:46:58 Real-time Intraday chart data file updates started for GC.20170600.CME_CO | 2017-05-21 06:46:58 Opened cached Intraday file: C:\SierraChart1\Data\GC.20170600.CME_CO.scid | 2017-05-21 06:46:58 Intraday chart data file opened for GC.20170600.CME_CO | 2017-05-21 06:46:58 Delaying start of download for ZB.20170600.CME_F | 2017-05-21 06:46:58 Chart #1 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:46:58 Chart #1 has tagged chart #14 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:46:58 Chart #1 has tagged chart #17 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:46:58 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:46:58 Chart #13 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:58 Chart #13 has tagged chart #15 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:58 Chart #13 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:58 Chart #13 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:58 Chart #13 has tagged chart #4 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:58 Chart #13 has tagged chart #5 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:58 ZB.20170600.CME_F 30 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:46:58 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:46:58 ZB.20170600.CME_F [C] 30 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:46:58 Chart #15 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:58 Chart #15 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:58 Chart #15 has tagged chart #26 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:58 6J.20170600.CME_Fo [C] 30 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:46:58 Chart #5 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:58 Chart #5 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:58 ES.20170600.CME_Eq 30 Sec #17 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:46:58 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:46:58 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:46:58 Chart #17 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:46:58 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:46:58 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:58 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:58 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:58 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:46:58 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:46:58 6C.20170600.CME_Fo [C] 30 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:46:58 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:47:02 Chart #1 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:47:02 Chart #1 has tagged chart #14 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:47:02 Chart #1 has tagged chart #17 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:47:02 Chart #1 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:47:02 Chart #1 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:47:02 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:47:02 ZB.20170600.CME_F [C] 15 Min #26 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:47:02 6J.20170600.CME_Fo 3 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:47:02 Chart #14 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:47:02 ZB.20170600.CME_F 3 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:47:02 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:47:02 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:47:02 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:47:02 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:47:02 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:47:02 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:47:02 6J.20170600.CME_Fo 30 Sec #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:47:02 NQ.20170600.CME_Eq 30 Sec #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:47:02 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:47:02 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:47:02 ES.20170600.CME_Eq 3 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:47:02 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:47:02 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:47:02 Chart #17 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:47:02 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:47:02 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:47:08 6J.20170600.CME_Fo 3 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:47:08 Chart #14 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:47:08 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:47:08 HD Request # 403 | Downloading Intraday chart data for ZB.20170600.CME_F to the file ZB.20170600.CME_F.scid. Service: cts | 2017-05-21 06:47:27 HD Request # 403 | Download start date-time: 2017-05-19 16:59:56.000 | 2017-05-21 06:47:27 HD Request # 403 | Requesting historical Second data for ZB.20170600.CME_F from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:47:27 HD Request # 403 | Receiving Intraday data for ZB.20170600.CME_F starting at 2017-05-18 18:00:00 | 2017-05-21 06:47:28 HD Request # 403 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:56 | 2017-05-21 06:47:28 HD Request # 403 | Total records received: 6509 | 2017-05-21 06:47:28 HD Request # 403 | Requesting historical Second data for ZB.20170600.CME_F from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:47:28 HD Request # 403 | Total records received: 6509 | 2017-05-21 06:47:28 HD Request # 403 | Requesting historical Second data for ZB.20170600.CME_F from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:47:28 HD Request # 403 | Total records received: 6509 | 2017-05-21 06:47:28 HD Request # 403 | Requesting historical Second data for ZB.20170600.CME_F from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:47:28 HD Request # 403 | Total records received: 6509 | 2017-05-21 06:47:28 HD Request # 403 | Requesting historical Second data for ZB.20170600.CME_F from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:47:28 HD Request # 403 | Received 6509 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:56 (23.0 hours) and wrote 1 record for ZB.20170600.CME_F | 2017-05-21 06:47:29 HD Request # 403 | Intraday download COMPLETE for ZB.20170600.CME_F. Completion time: 2s. Unique request ID: 698 | 2017-05-21 06:47:29 Removed historical data download ID 698 | 2017-05-21 06:47:29 Real-time Intraday chart data file updates started for ZB.20170600.CME_F | 2017-05-21 06:47:29 Opened cached Intraday file: C:\SierraChart1\Data\ZB.20170600.CME_F.scid | 2017-05-21 06:47:29 Intraday chart data file opened for ZB.20170600.CME_F | 2017-05-21 06:47:29 Delaying start of download for 6B.20170600.CME_Fo | 2017-05-21 06:47:29 Chart #13 has tagged chart #1 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:47:29 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:47:29 Chart #13 has tagged chart #14 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:47:29 Chart #13 has tagged chart #17 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:47:29 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:47:29 Chart #13 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:47:29 Chart #13 has tagged chart #14 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:47:29 Chart #13 has tagged chart #17 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:47:29 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:47:29 Chart #15 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:47:29 Chart #15 has tagged chart #13 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:47:29 Chart #15 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:47:29 Chart #15 has tagged chart #26 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:47:29 Chart #15 has tagged chart #5 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:47:29 6J.20170600.CME_Fo [C] 30 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:47:29 Chart #5 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:47:29 Chart #5 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:47:29 ES.20170600.CME_Eq 30 Sec #17 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:47:29 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:47:29 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:47:29 Chart #17 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:47:29 ES.20170600.CME_Eq 3 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:47:29 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:47:29 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:47:29 Chart #17 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:47:29 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:47:29 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:47:29 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:47:29 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:47:29 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:47:29 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:47:29 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:47:29 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:47:32 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:47:32 GC.20170600.CME_CO 3 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:47:32 Chart #1 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:47:32 Chart #1 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:47:32 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:47:32 ZB.20170600.CME_F [C] 15 Min #26 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:47:32 6J.20170600.CME_Fo 3 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:47:32 Chart #14 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:47:32 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:47:32 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:47:32 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:47:32 6J.20170600.CME_Fo 30 Sec #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:47:32 NQ.20170600.CME_Eq 30 Sec #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:47:32 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:47:32 GC.20170600.CME_CO 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:47:32 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:47:32 GC.20170600.CME_CO [C] 30 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:47:32 Chart #13 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:47:32 Chart #13 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:47:32 Chart #13 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:47:32 Chart #13 has tagged chart #4 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:47:32 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:47:32 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:47:32 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:47:32 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:47:32 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:47:32 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:47:32 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:47:32 6C.20170600.CME_Fo [C] 30 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:47:32 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:47:32 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:47:39 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:47:39 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:47:39 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:47:39 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:47:39 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:47:39 HD Request # 404 | Downloading Intraday chart data for 6B.20170600.CME_Fo to the file 6B.20170600.CME_Fo.scid. Service: cts | 2017-05-21 06:47:56 HD Request # 404 | Download start date-time: 2017-05-19 16:59:54.000 | 2017-05-21 06:47:56 HD Request # 404 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:47:56 HD Request # 404 | Receiving Intraday data for 6B.20170600.CME_Fo starting at 2017-05-18 18:00:00 | 2017-05-21 06:47:57 HD Request # 404 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:54 | 2017-05-21 06:47:57 HD Request # 404 | Total records received: 8374 | 2017-05-21 06:47:57 HD Request # 404 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:47:57 HD Request # 404 | Total records received: 8374 | 2017-05-21 06:47:57 HD Request # 404 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:47:57 HD Request # 404 | Total records received: 8374 | 2017-05-21 06:47:57 HD Request # 404 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:47:57 HD Request # 404 | Total records received: 8374 | 2017-05-21 06:47:57 HD Request # 404 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:47:57 HD Request # 404 | Received 8374 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:54 (23.0 hours) and wrote 1 record for 6B.20170600.CME_Fo | 2017-05-21 06:47:59 HD Request # 404 | Intraday download COMPLETE for 6B.20170600.CME_Fo. Completion time: 2s. Unique request ID: 699 | 2017-05-21 06:47:59 Removed historical data download ID 699 | 2017-05-21 06:47:59 Real-time Intraday chart data file updates started for 6B.20170600.CME_Fo | 2017-05-21 06:47:59 Opened cached Intraday file: C:\SierraChart1\Data\6B.20170600.CME_Fo.scid | 2017-05-21 06:47:59 Intraday chart data file opened for 6B.20170600.CME_Fo | 2017-05-21 06:47:59 Delaying start of download for HO.20170700.CME_NY | 2017-05-21 06:47:59 Chart #12 has tagged chart #8 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:47:59 Chart #12 has tagged chart #8 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:47:59 6A.20170600.CME_Fo 3 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:48:00 6A.20170600.CME_Fo 3 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:48:00 HD Request # 405 | Downloading Intraday chart data for HO.20170700.CME_NY to the file HO.20170700.CME_NY.scid. Service: cts | 2017-05-21 06:48:21 HD Request # 405 | Download start date-time: 2017-05-19 16:59:53.000 | 2017-05-21 06:48:21 HD Request # 405 | Requesting historical Second data for HO.20170700.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:48:21 HD Request # 405 | Receiving Intraday data for HO.20170700.CME_NY starting at 2017-05-18 18:00:00 | 2017-05-21 06:48:21 HD Request # 405 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:53 | 2017-05-21 06:48:21 HD Request # 405 | Total records received: 7519 | 2017-05-21 06:48:21 HD Request # 405 | Requesting historical Second data for HO.20170700.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:48:21 HD Request # 405 | Total records received: 7519 | 2017-05-21 06:48:21 HD Request # 405 | Requesting historical Second data for HO.20170700.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:48:21 HD Request # 405 | Total records received: 7519 | 2017-05-21 06:48:22 HD Request # 405 | Requesting historical Second data for HO.20170700.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:48:22 HD Request # 405 | Total records received: 7519 | 2017-05-21 06:48:22 HD Request # 405 | Requesting historical Second data for HO.20170700.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:48:22 HD Request # 405 | Received 7519 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:53 (23.0 hours) and wrote 1 record for HO.20170700.CME_NY | 2017-05-21 06:48:22 HD Request # 405 | Intraday download COMPLETE for HO.20170700.CME_NY. Completion time: 2s. Unique request ID: 700 | 2017-05-21 06:48:22 Removed historical data download ID 700 | 2017-05-21 06:48:22 Real-time Intraday chart data file updates started for HO.20170700.CME_NY | 2017-05-21 06:48:22 Opened cached Intraday file: C:\SierraChart1\Data\HO.20170700.CME_NY.scid | 2017-05-21 06:48:22 Intraday chart data file opened for HO.20170700.CME_NY | 2017-05-21 06:48:22 Delaying start of download for 6C.20170600.CME_Fo | 2017-05-21 06:48:22 Chart #20 has tagged chart #16 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:48:22 Chart #20 has tagged chart #9 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:48:22 CL.20170700.CME_NY [C] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:48:22 Chart #9 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:48:22 Chart #5 has tagged chart #16 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:48:22 CL.20170700.CME_NY 3 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:48:22 Chart #16 has tagged chart #15 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:48:22 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:48:24 CL.20170700.CME_NY 30 Sec #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:48:24 6C.20170600.CME_Fo 3 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:48:24 HD Request # 406 | Downloading Intraday chart data for 6C.20170600.CME_Fo to the file 6C.20170600.CME_Fo.scid. Service: cts | 2017-05-21 06:48:48 HD Request # 406 | Download start date-time: 2017-05-19 16:59:56.000 | 2017-05-21 06:48:48 HD Request # 406 | Requesting historical Second data for 6C.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:48:48 HD Request # 406 | Receiving Intraday data for 6C.20170600.CME_Fo starting at 2017-05-18 18:00:00 | 2017-05-21 06:48:50 HD Request # 406 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:56 | 2017-05-21 06:48:50 HD Request # 406 | Total records received: 8488 | 2017-05-21 06:48:50 HD Request # 406 | Requesting historical Second data for 6C.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:48:50 HD Request # 406 | Total records received: 8488 | 2017-05-21 06:48:50 HD Request # 406 | Requesting historical Second data for 6C.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:48:50 HD Request # 406 | Total records received: 8488 | 2017-05-21 06:48:50 HD Request # 406 | Requesting historical Second data for 6C.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:48:50 HD Request # 406 | Total records received: 8488 | 2017-05-21 06:48:50 HD Request # 406 | Requesting historical Second data for 6C.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:48:50 HD Request # 406 | Received 8488 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:56 (23.0 hours) and wrote 1 record for 6C.20170600.CME_Fo | 2017-05-21 06:48:50 HD Request # 406 | Intraday download COMPLETE for 6C.20170600.CME_Fo. Completion time: 2s. Unique request ID: 701 | 2017-05-21 06:48:50 Removed historical data download ID 701 | 2017-05-21 06:48:50 Real-time Intraday chart data file updates started for 6C.20170600.CME_Fo | 2017-05-21 06:48:50 Opened cached Intraday file: C:\SierraChart1\Data\6C.20170600.CME_Fo.scid | 2017-05-21 06:48:50 Intraday chart data file opened for 6C.20170600.CME_Fo | 2017-05-21 06:48:50 Delaying start of download for 6J.20170600.CME_Fo | 2017-05-21 06:48:50 HD Request # 407 | Downloading Intraday chart data for 6J.20170600.CME_Fo to the file 6J.20170600.CME_Fo.scid. Service: cts | 2017-05-21 06:49:15 HD Request # 407 | Download start date-time: 2017-05-19 16:59:51.000 | 2017-05-21 06:49:15 HD Request # 407 | Requesting historical Second data for 6J.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:49:15 HD Request # 407 | Receiving Intraday data for 6J.20170600.CME_Fo starting at 2017-05-18 18:00:00 | 2017-05-21 06:49:17 HD Request # 407 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:51 | 2017-05-21 06:49:17 HD Request # 407 | Total records received: 19164 | 2017-05-21 06:49:17 HD Request # 407 | Requesting historical Second data for 6J.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:49:17 HD Request # 407 | Total records received: 19164 | 2017-05-21 06:49:17 HD Request # 407 | Requesting historical Second data for 6J.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:49:17 HD Request # 407 | Total records received: 19164 | 2017-05-21 06:49:17 HD Request # 407 | Requesting historical Second data for 6J.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:49:17 HD Request # 407 | Total records received: 19164 | 2017-05-21 06:49:17 HD Request # 407 | Requesting historical Second data for 6J.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:49:17 HD Request # 407 | Received 19164 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:51 (23.0 hours) and wrote 1 record for 6J.20170600.CME_Fo | 2017-05-21 06:49:17 HD Request # 407 | Intraday download COMPLETE for 6J.20170600.CME_Fo. Completion time: 3s. Unique request ID: 702 | 2017-05-21 06:49:17 Removed historical data download ID 702 | 2017-05-21 06:49:17 Real-time Intraday chart data file updates started for 6J.20170600.CME_Fo | 2017-05-21 06:49:17 Opened cached Intraday file: C:\SierraChart1\Data\6J.20170600.CME_Fo.scid | 2017-05-21 06:49:17 Intraday chart data file opened for 6J.20170600.CME_Fo | 2017-05-21 06:49:17 Delaying start of download for ZN.20170600.CME_F | 2017-05-21 06:49:17 Chart #14 has tagged chart #1 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:49:19 Chart #14 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:49:19 Chart #14 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:49:19 ZB.20170600.CME_F 3 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:49:19 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:49:19 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:49:19 Chart #14 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:49:19 Chart #14 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:49:19 GC.20170600.CME_CO 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:49:19 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:49:19 ZB.20170600.CME_F 30 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:49:19 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:49:19 Chart #5 has tagged chart #13 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:19 Chart #5 has tagged chart #15 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:19 Chart #5 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:19 Chart #5 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:19 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:49:19 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:49:19 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:49:23 GC.20170600.CME_CO 3 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:49:23 Chart #1 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:49:23 Chart #1 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:49:23 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:49:23 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:49:23 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:23 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:49:23 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:49:23 GC.20170600.CME_CO [C] 30 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:49:23 Chart #13 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:23 Chart #13 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:23 Chart #13 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:23 Chart #13 has tagged chart #4 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:23 ZB.20170600.CME_F [C] 30 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:49:23 Chart #15 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:23 Chart #15 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:23 Chart #15 has tagged chart #26 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:23 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:49:23 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:49:23 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:23 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:23 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:23 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:23 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:49:23 6C.20170600.CME_Fo [C] 30 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:49:23 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:49:23 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:49:27 ZB.20170600.CME_F [C] 15 Min #26 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:49:27 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:49:27 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:27 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:49:27 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:49:27 HD Request # 408 | Downloading Intraday chart data for ZN.20170600.CME_F to the file ZN.20170600.CME_F.scid. Service: cts | 2017-05-21 06:49:49 HD Request # 408 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:49:49 HD Request # 408 | Requesting historical Second data for ZN.20170600.CME_F from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:49:49 HD Request # 408 | Receiving Intraday data for ZN.20170600.CME_F starting at 2017-05-18 18:00:00 | 2017-05-21 06:49:49 HD Request # 408 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:49:49 HD Request # 408 | Total records received: 10370 | 2017-05-21 06:49:49 HD Request # 408 | Requesting historical Second data for ZN.20170600.CME_F from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:49:49 HD Request # 408 | Total records received: 10370 | 2017-05-21 06:49:49 HD Request # 408 | Requesting historical Second data for ZN.20170600.CME_F from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:49:49 HD Request # 408 | Total records received: 10370 | 2017-05-21 06:49:49 HD Request # 408 | Requesting historical Second data for ZN.20170600.CME_F from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:49:49 HD Request # 408 | Total records received: 10370 | 2017-05-21 06:49:50 HD Request # 408 | Requesting historical Second data for ZN.20170600.CME_F from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:49:50 HD Request # 408 | Received 10370 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for ZN.20170600.CME_F | 2017-05-21 06:49:50 HD Request # 408 | Intraday download COMPLETE for ZN.20170600.CME_F. Completion time: 2s. Unique request ID: 703 | 2017-05-21 06:49:50 Removed historical data download ID 703 | 2017-05-21 06:49:50 Real-time Intraday chart data file updates started for ZN.20170600.CME_F | 2017-05-21 06:49:50 Opened cached Intraday file: C:\SierraChart1\Data\ZN.20170600.CME_F.scid | 2017-05-21 06:49:50 Intraday chart data file opened for ZN.20170600.CME_F | 2017-05-21 06:49:50 Delaying start of download for CL.20171200.CME_NY | 2017-05-21 06:49:50 Chart #19 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:49:50 Chart #19 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:49:50 Chart #19 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:49:50 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:49:50 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:49:52 Chart #19 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:49:52 Chart #19 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:49:52 Chart #16 has tagged chart #13 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:52 Chart #16 has tagged chart #15 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:52 Chart #16 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:52 Chart #16 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:52 Chart #16 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:52 ZB.20170600.CME_F 3 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:49:52 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:49:52 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:49:52 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:49:52 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:52 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:49:52 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:49:52 GC.20170600.CME_CO 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:49:52 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:49:52 GC.20170600.CME_CO [C] 30 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:49:52 Chart #13 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:52 Chart #13 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:52 Chart #13 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:52 Chart #13 has tagged chart #4 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:52 ZB.20170600.CME_F 30 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:49:52 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:49:52 ZB.20170600.CME_F [C] 30 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:49:52 Chart #15 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:52 Chart #15 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:52 Chart #15 has tagged chart #26 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:52 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:49:52 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:52 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:52 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:52 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:52 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:49:52 6C.20170600.CME_Fo [C] 30 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:49:52 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:49:52 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:49:58 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:49:58 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:49:58 ZB.20170600.CME_F [C] 15 Min #26 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:49:58 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:49:58 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:49:58 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:49:58 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:49:58 HD Request # 409 | Downloading Intraday chart data for CL.20171200.CME_NY to the file CL.20171200.CME_NY.scid. Service: cts | 2017-05-21 06:50:21 HD Request # 409 | Download start date-time: 2017-05-19 16:59:47.000 | 2017-05-21 06:50:21 HD Request # 409 | Requesting historical Second data for CL.20171200.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:50:21 HD Request # 409 | Receiving Intraday data for CL.20171200.CME_NY starting at 2017-05-18 18:00:18 | 2017-05-21 06:50:21 HD Request # 409 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:47 | 2017-05-21 06:50:21 HD Request # 409 | Total records received: 2449 | 2017-05-21 06:50:21 HD Request # 409 | Requesting historical Second data for CL.20171200.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:50:21 HD Request # 409 | Total records received: 2449 | 2017-05-21 06:50:21 HD Request # 409 | Requesting historical Second data for CL.20171200.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:50:21 HD Request # 409 | Total records received: 2449 | 2017-05-21 06:50:23 HD Request # 409 | Requesting historical Second data for CL.20171200.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:50:23 HD Request # 409 | Total records received: 2449 | 2017-05-21 06:50:23 HD Request # 409 | Requesting historical Second data for CL.20171200.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:50:23 HD Request # 409 | Received 2449 records from 2017-05-18 18:00:18 to 2017-05-19 16:59:47 (23.0 hours) and wrote 1 record for CL.20171200.CME_NY | 2017-05-21 06:50:23 HD Request # 409 | Intraday download COMPLETE for CL.20171200.CME_NY. Completion time: 2s. Unique request ID: 704 | 2017-05-21 06:50:23 Removed historical data download ID 704 | 2017-05-21 06:50:23 Real-time Intraday chart data file updates started for CL.20171200.CME_NY | 2017-05-21 06:50:23 Opened cached Intraday file: C:\SierraChart1\Data\CL.20171200.CME_NY.scid | 2017-05-21 06:50:23 Intraday chart data file opened for CL.20171200.CME_NY | 2017-05-21 06:50:23 Delaying start of download for ES.20170600.CME_Eq | 2017-05-21 06:50:23 Chart #6 has tagged chart #19 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:50:23 Chart #6 has tagged chart #9 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:50:23 ZN.20170600.CME_F 30 Sec #19 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:50:24 Chart #19 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:50:24 Chart #19 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:50:24 Chart #17 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:50:24 Chart #17 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:50:24 Chart #17 has tagged chart #9 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:50:24 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:50:24 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:50:24 Chart #21 has tagged chart #16 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:50:24 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:50:24 ZT.20170600.CME_F 30 Sec #9 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:50:24 Chart #9 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:50:24 Chart #9 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:50:24 GC.20170600.CME_CO 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:50:24 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:50:24 ZB.20170600.CME_F 30 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:50:24 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:50:24 CL.20170700.CME_NY [C] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:50:24 Chart #9 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:50:24 CL.20170700.CME_NY 3 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:50:24 Chart #16 has tagged chart #15 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:50:24 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:50:29 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:50:29 6C.20170600.CME_Fo 3 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:50:29 HD Request # 410 | Downloading Intraday chart data for ES.20170600.CME_Eq to the file ES.20170600.CME_Eq.scid. Service: cts | 2017-05-21 06:50:49 HD Request # 410 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:50:49 HD Request # 410 | Requesting historical Second data for ES.20170600.CME_Eq from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:50:49 HD Request # 410 | Receiving Intraday data for ES.20170600.CME_Eq starting at 2017-05-18 18:00:00 | 2017-05-21 06:50:50 HD Request # 410 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:50:50 HD Request # 410 | Total records received: 27907 | 2017-05-21 06:50:50 HD Request # 410 | Requesting historical Second data for ES.20170600.CME_Eq from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:50:50 HD Request # 410 | Total records received: 27907 | 2017-05-21 06:50:50 HD Request # 410 | Requesting historical Second data for ES.20170600.CME_Eq from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:50:50 HD Request # 410 | Total records received: 27907 | 2017-05-21 06:50:52 HD Request # 410 | Requesting historical Second data for ES.20170600.CME_Eq from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:50:52 HD Request # 410 | Total records received: 27907 | 2017-05-21 06:50:52 HD Request # 410 | Requesting historical Second data for ES.20170600.CME_Eq from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:50:52 HD Request # 410 | Received 27907 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for ES.20170600.CME_Eq | 2017-05-21 06:50:52 HD Request # 410 | Intraday download COMPLETE for ES.20170600.CME_Eq. Completion time: 3s. Unique request ID: 705 | 2017-05-21 06:50:52 Removed historical data download ID 705 | 2017-05-21 06:50:52 Real-time Intraday chart data file updates started for ES.20170600.CME_Eq | 2017-05-21 06:50:52 Opened cached Intraday file: C:\SierraChart1\Data\ES.20170600.CME_Eq.scid | 2017-05-21 06:50:52 Intraday chart data file opened for ES.20170600.CME_Eq | 2017-05-21 06:50:52 Delaying start of download for RB.20170700.CME_NY | 2017-05-21 06:50:52 Chart #17 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:50:52 Chart #17 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:50:52 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:50:52 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:50:52 Chart #17 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:50:52 Chart #17 has tagged chart #1 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:50:52 Chart #17 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:50:52 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:50:52 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:50:52 Chart #17 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:50:52 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:50:52 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:50:52 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:50:52 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:50:52 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:50:52 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:50:52 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:50:53 GC.20170600.CME_CO 3 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:50:53 Chart #1 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:50:53 Chart #1 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:50:53 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:50:53 6J.20170600.CME_Fo 3 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:50:53 Chart #14 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:50:53 ZB.20170600.CME_F 3 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:50:53 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:50:53 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:50:53 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:50:53 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:50:53 6J.20170600.CME_Fo 30 Sec #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:50:53 NQ.20170600.CME_Eq 30 Sec #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:50:53 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:50:53 GC.20170600.CME_CO 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:50:53 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:50:53 ZB.20170600.CME_F 30 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:50:53 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:50:53 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:50:53 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:50:53 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:51:00 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:51:00 HD Request # 411 | Downloading Intraday chart data for RB.20170700.CME_NY to the file RB.20170700.CME_NY.scid. Service: cts | 2017-05-21 06:51:20 HD Request # 411 | Download start date-time: 2017-05-19 16:59:53.000 | 2017-05-21 06:51:20 HD Request # 411 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:51:20 HD Request # 411 | Receiving Intraday data for RB.20170700.CME_NY starting at 2017-05-18 18:00:00 | 2017-05-21 06:51:21 HD Request # 411 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:53 | 2017-05-21 06:51:21 HD Request # 411 | Total records received: 7454 | 2017-05-21 06:51:21 HD Request # 411 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:51:21 HD Request # 411 | Total records received: 7454 | 2017-05-21 06:51:21 HD Request # 411 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:51:21 HD Request # 411 | Total records received: 7454 | 2017-05-21 06:51:21 HD Request # 411 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:51:21 HD Request # 411 | Total records received: 7454 | 2017-05-21 06:51:21 HD Request # 411 | Requesting historical Second data for RB.20170700.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:51:21 HD Request # 411 | Received 7454 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:53 (23.0 hours) and wrote 1 record for RB.20170700.CME_NY | 2017-05-21 06:51:23 HD Request # 411 | Intraday download COMPLETE for RB.20170700.CME_NY. Completion time: 2s. Unique request ID: 706 | 2017-05-21 06:51:23 Removed historical data download ID 706 | 2017-05-21 06:51:23 Real-time Intraday chart data file updates started for RB.20170700.CME_NY | 2017-05-21 06:51:23 Opened cached Intraday file: C:\SierraChart1\Data\RB.20170700.CME_NY.scid | 2017-05-21 06:51:23 Intraday chart data file opened for RB.20170700.CME_NY | 2017-05-21 06:51:23 Delaying start of download for 6E.20170600.CME_Fo | 2017-05-21 06:51:23 Chart #22 has tagged chart #16 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:51:23 Chart #18 has tagged chart #16 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:51:23 CL.20170700.CME_NY 3 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:51:23 Chart #16 has tagged chart #15 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:51:23 Chart #21 has tagged chart #9 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:51:23 CL.20170700.CME_NY 30 Sec #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:51:25 6C.20170600.CME_Fo 3 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:51:25 CL.20170700.CME_NY [C] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:51:25 Chart #9 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:51:25 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:51:27 HD Request # 412 | Downloading Intraday chart data for 6E.20170600.CME_Fo to the file 6E.20170600.CME_Fo.scid. Service: cts | 2017-05-21 06:51:45 HD Request # 412 | Download start date-time: 2017-05-19 16:59:58.000 | 2017-05-21 06:51:45 HD Request # 412 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:51:45 HD Request # 412 | Receiving Intraday data for 6E.20170600.CME_Fo starting at 2017-05-18 18:00:00 | 2017-05-21 06:51:46 HD Request # 412 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:58 | 2017-05-21 06:51:46 HD Request # 412 | Total records received: 17398 | 2017-05-21 06:51:46 HD Request # 412 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:51:46 HD Request # 412 | Total records received: 17398 | 2017-05-21 06:51:46 HD Request # 412 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:51:46 HD Request # 412 | Total records received: 17398 | 2017-05-21 06:51:46 HD Request # 412 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:51:46 HD Request # 412 | Total records received: 17398 | 2017-05-21 06:51:46 HD Request # 412 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:51:46 HD Request # 412 | Received 17398 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:58 (23.0 hours) and wrote 1 record for 6E.20170600.CME_Fo | 2017-05-21 06:51:48 HD Request # 412 | Intraday download COMPLETE for 6E.20170600.CME_Fo. Completion time: 2s. Unique request ID: 707 | 2017-05-21 06:51:48 Removed historical data download ID 707 | 2017-05-21 06:51:48 Real-time Intraday chart data file updates started for 6E.20170600.CME_Fo | 2017-05-21 06:51:48 Opened cached Intraday file: C:\SierraChart1\Data\6E.20170600.CME_Fo.scid | 2017-05-21 06:51:48 Intraday chart data file opened for 6E.20170600.CME_Fo | 2017-05-21 06:51:48 Delaying start of download for YM.20170600.CME_E | 2017-05-21 06:51:48 Chart #15 has tagged chart #4 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:51:48 6B.20170600.CME_Fo 30 Sec #4 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:51:49 HD Request # 413 | Downloading Intraday chart data for YM.20170600.CME_E to the file YM.20170600.CME_E.scid. Service: cts | 2017-05-21 06:52:11 HD Request # 413 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:52:11 HD Request # 413 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:52:11 HD Request # 413 | Receiving Intraday data for YM.20170600.CME_E starting at 2017-05-18 18:00:00 | 2017-05-21 06:52:12 HD Request # 413 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:52:12 HD Request # 413 | Total records received: 19680 | 2017-05-21 06:52:12 HD Request # 413 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:52:12 HD Request # 413 | Total records received: 19680 | 2017-05-21 06:52:12 HD Request # 413 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:52:12 HD Request # 413 | Total records received: 19680 | 2017-05-21 06:52:12 HD Request # 413 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:52:12 HD Request # 413 | Total records received: 19680 | 2017-05-21 06:52:14 HD Request # 413 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:52:14 HD Request # 413 | Received 19680 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for YM.20170600.CME_E | 2017-05-21 06:52:14 HD Request # 413 | Intraday download COMPLETE for YM.20170600.CME_E. Completion time: 3s. Unique request ID: 708 | 2017-05-21 06:52:14 Removed historical data download ID 708 | 2017-05-21 06:52:14 Real-time Intraday chart data file updates started for YM.20170600.CME_E | 2017-05-21 06:52:14 Opened cached Intraday file: C:\SierraChart1\Data\YM.20170600.CME_E.scid | 2017-05-21 06:52:14 Intraday chart data file opened for YM.20170600.CME_E | 2017-05-21 06:52:14 Delaying start of download for 6S.20170600.CME_Fo | 2017-05-21 06:52:14 Chart #3 has tagged chart #4 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:52:15 ZB.20170600.CME_F 3 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:52:16 CTS FIX socket (2176) | Closed. No error. | 2017-05-21 06:52:16 CTS FIX socket (2176) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-21 06:52:16 CTS FIX socket (2176) | SSL has been shut down. | 2017-05-21 06:52:16 CTS FIX socket (2176) | SSL object has been freed. SSL state is now disconnected. | 2017-05-21 06:52:16 CTS FIX socket (2176) | Shutdown and closed. | 2017-05-21 06:52:16 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2017-05-21 06:52:16 Connection to the external service has been lost. | 2017-05-21 06:52:16 Canceling historical data download request for 6S.20170600.CME_Fo Intraday data. | 2017-05-21 06:53:12 Removed historical data download ID 710 | 2017-05-21 06:53:12 Canceling historical data download request for HO.20171200.CME_NY Intraday data. | 2017-05-21 06:53:12 Removed historical data download ID 711 | 2017-05-21 06:53:12 Canceling historical data download request for 6N.20170600.CME_Fo Intraday data. | 2017-05-21 06:53:12 Removed historical data download ID 712 | 2017-05-21 06:53:12 Canceling historical data download request for RB.20171200.CME_NY Intraday data. | 2017-05-21 06:53:12 Removed historical data download ID 713 | 2017-05-21 06:53:12 Canceling historical data download request for NQ.20170600.CME_Eq Intraday data. | 2017-05-21 06:53:12 Removed historical data download ID 714 | 2017-05-21 06:53:12 CTS FIX Historical Data: DisconnectFIX called. | 2017-05-21 06:53:12 CTS FIX Historical Data: Sending a Logout message. | 2017-05-21 06:53:12 CTS T4 FIX | Disconnected. | 2017-05-21 06:53:12 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-21 06:53:12 CTS FIX Historical Data socket (2181) | Closed. No error. | 2017-05-21 06:53:12 CTS FIX Historical Data: Received a Logout message. Text = Successful logout upon request | 2017-05-21 06:53:12 CTS FIX Historical Data socket (2181) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-21 06:53:12 CTS FIX Historical Data socket (2181) | SSL has been shut down. | 2017-05-21 06:53:12 CTS FIX Historical Data socket (2181) | SSL object has been freed. SSL state is now disconnected. | 2017-05-21 06:53:12 CTS FIX Historical Data socket (2181) | Shutdown and closed. | 2017-05-21 06:53:12 CTS FIX Historical Data: Disconnected. | 2017-05-21 06:53:12 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2017-05-21 06:53:17 CTS T4 FIX | Firm: PTP | 2017-05-21 06:53:17 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199. | 2017-05-21 06:53:17 CTS FIX socket (2186) | Connected. | 2017-05-21 06:53:17 CTS FIX socket (2186) | Starting TLS 1.0 connection. | 2017-05-21 06:53:17 CTS FIX socket (2186) | SSL connection established. | 2017-05-21 06:53:17 CTS FIX: Sending the Logon message. | 2017-05-21 06:53:18 CTS T4 FIX | FIX version: 4.3.74.0 | 2017-05-21 06:53:18 CTS T4 FIX | Connected to data and trading server. | 2017-05-21 06:53:18 DTC Client (2178) | Shutdown and closed. | 2017-05-21 06:53:18 SC DTC Data | Disconnected from the server. | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: ZB.20160900.CME_F. ID: 1 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: ZB.20160900.CME_F. ID: 1 | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: 6E.20160900.CME_Fo. ID: 2 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: 6E.20160900.CME_Fo. ID: 2 | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6J.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: 6J.20160900.CME_Fo. ID: 3 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: 6J.20160900.CME_Fo. ID: 3 | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6B.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: 6B.20160900.CME_Fo. ID: 4 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: 6B.20160900.CME_Fo. ID: 4 | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6C.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: 6C.20160900.CME_Fo. ID: 5 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: 6C.20160900.CME_Fo. ID: 5 | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: CL.20160800.CME_NY. ID: 6 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: CL.20160800.CME_NY. ID: 6 | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6A.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: 6A.20160900.CME_Fo. ID: 7 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: 6A.20160900.CME_Fo. ID: 7 | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: NQ.20160900.CME_Eq. ID: 8 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: NQ.20160900.CME_Eq. ID: 8 | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM.######00.CME_E pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: YM.20160900.CME_E. ID: 9 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: YM.20160900.CME_E. ID: 9 | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: GC.20160800.CME_CO. ID: 10 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: GC.20160800.CME_CO. ID: 10 | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: ES.20160900.CME_Eq. ID: 11 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: ES.20160900.CME_Eq. ID: 11 | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: ZB.20170300.CME_F. ID: 12 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: ZB.20170300.CME_F. ID: 12 | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: CL.20170100.CME_NY. ID: 13 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: CL.20170100.CME_NY. ID: 13 | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: GC.20170400.CME_CO. ID: 14 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: GC.20170400.CME_CO. ID: 14 | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: ZB.20170600.CME_F. ID: 15 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: ZB.20170600.CME_F. ID: 15 | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6B.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: 6B.20170600.CME_Fo. ID: 16 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: 6B.20170600.CME_Fo. ID: 16 | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: CL.20170600.CME_NY. ID: 17 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: CL.20170600.CME_NY. ID: 17 | 2017-05-21 06:53:18 CTS T4 FIX | Using primary service for historical data for 6B.20170600.CME_Fo | 2017-05-21 06:53:18 Intraday data recording state for symbol 6B.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:53:18 Delaying start of download for 6B.20170600.CME_Fo | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: 6E.20170600.CME_Fo. ID: 18 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: 6E.20170600.CME_Fo. ID: 18 | 2017-05-21 06:53:18 CTS T4 FIX | Using primary service for historical data for 6E.20170600.CME_Fo | 2017-05-21 06:53:18 Intraday data recording state for symbol 6E.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM.######00.CME_E pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: YM.20170600.CME_E. ID: 19 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: YM.20170600.CME_E. ID: 19 | 2017-05-21 06:53:18 CTS T4 FIX | Using primary service for historical data for YM.20170600.CME_E | 2017-05-21 06:53:18 Intraday data recording state for symbol YM.20170600.CME_E is set to download 'Pending'. | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: ES.20170600.CME_Eq. ID: 20 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: ES.20170600.CME_Eq. ID: 20 | 2017-05-21 06:53:18 CTS T4 FIX | Using primary service for historical data for ES.20170600.CME_Eq | 2017-05-21 06:53:18 Intraday data recording state for symbol ES.20170600.CME_Eq is set to download 'Pending'. | 2017-05-21 06:53:18 CTS T4 FIX | Received Account List collateral report. | 2017-05-21 06:53:18 CTS T4 FIX | Subscribing to account: May* | 2017-05-21 06:53:18 Using Bid/Ask average for last trade price for AUDJPY | 2017-05-21 06:53:18 SC DTC Data | Starting real-time market data updates for: AUDJPY. ID: 21 | 2017-05-21 06:53:18 SC DTC Data | Connecting to the server ds3.sierracharts.com. Port 10048 | 2017-05-21 06:53:18 SC DTC Data | Requesting security definition data for: AUDJPY. ID: 21 | 2017-05-21 06:53:18 Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2017-05-21 06:53:18 DTC Client (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2017-05-21 06:53:18 Delaying start of download for AUDJPY | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6S.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: 6S.20170600.CME_Fo. ID: 22 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: 6S.20170600.CME_Fo. ID: 22 | 2017-05-21 06:53:18 CTS T4 FIX | Using primary service for historical data for 6S.20170600.CME_Fo | 2017-05-21 06:53:18 Intraday data recording state for symbol 6S.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:53:18 Requesting market depth updates for: 6E.20170600.CME_Fo if supported. | 2017-05-21 06:53:18 DTC Client (2187) | Connected. | 2017-05-21 06:53:18 SC DTC Data | Connected to server. | 2017-05-21 06:53:18 SC DTC Data | Sending Encoding Request to server | 2017-05-21 06:53:18 Supported exchange: CME_CO (SIM:COMEX Futures) | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The HO.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: HO.20170700.CME_NY. ID: 23 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: HO.20170700.CME_NY. ID: 23 | 2017-05-21 06:53:18 CTS T4 FIX | Using primary service for historical data for HO.20170700.CME_NY | 2017-05-21 06:53:18 Intraday data recording state for symbol HO.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:53:18 Supported exchange: CME_EqOp (SIM:CME Equity Options) | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6C.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: 6C.20170600.CME_Fo. ID: 24 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: 6C.20170600.CME_Fo. ID: 24 | 2017-05-21 06:53:18 CTS T4 FIX | Using primary service for historical data for 6C.20170600.CME_Fo | 2017-05-21 06:53:18 Intraday data recording state for symbol 6C.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:53:18 Supported exchange: CME_NYOp (SIM:NYMEX Options) | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The HO.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: HO.20171200.CME_NY. ID: 25 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: HO.20171200.CME_NY. ID: 25 | 2017-05-21 06:53:18 CTS T4 FIX | Using primary service for historical data for HO.20171200.CME_NY | 2017-05-21 06:53:18 Intraday data recording state for symbol HO.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:53:18 Supported exchange: CME_AgOp (SIM:CME Agricultural Options) | 2017-05-21 06:53:18 Supported exchange: CME_Eq (SIM:CME Equity Futures) | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: CL.20170700.CME_NY. ID: 26 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: CL.20170700.CME_NY. ID: 26 | 2017-05-21 06:53:18 CTS T4 FIX | Using primary service for historical data for CL.20170700.CME_NY | 2017-05-21 06:53:18 Intraday data recording state for symbol CL.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:53:18 Supported exchange: CME_In (SIM:CME Interest Rate Futures) | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6N.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: 6N.20170600.CME_Fo. ID: 27 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: 6N.20170600.CME_Fo. ID: 27 | 2017-05-21 06:53:18 CTS T4 FIX | Using primary service for historical data for 6N.20170600.CME_Fo | 2017-05-21 06:53:18 Intraday data recording state for symbol 6N.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:53:18 Supported exchange: CME_C (SIM:CBOT Commodity Futures) | 2017-05-21 06:53:18 Supported exchange: CME_KOp (SIM:KCBT Options) | 2017-05-21 06:53:18 Supported exchange: CME_F (SIM:CBOT Financial Futures) | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The RB.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: RB.20170700.CME_NY. ID: 28 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: RB.20170700.CME_NY. ID: 28 | 2017-05-21 06:53:18 CTS T4 FIX | Using primary service for historical data for RB.20170700.CME_NY | 2017-05-21 06:53:18 Intraday data recording state for symbol RB.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:53:18 Supported exchange: CME_E (SIM:CBOT Equity Futures) | 2017-05-21 06:53:18 HD Request # 414 | Downloading Intraday chart data for 6B.20170600.CME_Fo to the file 6B.20170600.CME_Fo.scid. Service: cts | 2017-05-21 06:53:18 HD Request # 414 | Download start date-time: 2017-05-19 16:59:54.000 | 2017-05-21 06:53:18 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2017-05-21 06:53:18 Supported exchange: CME_COp (SIM:CBOT Commodity Options) | 2017-05-21 06:53:18 Supported exchange: CME_K (SIM:KCBT Futures) | 2017-05-21 06:53:18 Supported exchange: CME_EOp (SIM:CBOT Equity Options) | 2017-05-21 06:53:18 Supported exchange: CME_NY (SIM:NYMEX Futures) | 2017-05-21 06:53:18 Supported exchange: CME_Fo (SIM:CME Foreign Exchange Futures) | 2017-05-21 06:53:18 Supported exchange: CME_Ag (SIM:CME Agricultural Futures) | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The RB.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: RB.20171200.CME_NY. ID: 29 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: RB.20171200.CME_NY. ID: 29 | 2017-05-21 06:53:18 CTS T4 FIX | Using primary service for historical data for RB.20171200.CME_NY | 2017-05-21 06:53:18 Intraday data recording state for symbol RB.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:53:18 Supported exchange: CME_FoOp (SIM:CME Foreign Exchange Options) | 2017-05-21 06:53:18 Supported exchange: CME_FOp (SIM:CBOT Financial Options) | 2017-05-21 06:53:18 Supported exchange: CME_InOp (SIM:CME Interest Rate Options) | 2017-05-21 06:53:18 Supported exchange: CME_COOp (SIM:COMEX Options) | 2017-05-21 06:53:18 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:18 CTS T4 FIX | Starting real-time market data updates for: NQ.20170600.CME_Eq. ID: 30 | 2017-05-21 06:53:18 CTS T4 FIX | Requesting security definition data for: NQ.20170600.CME_Eq. ID: 30 | 2017-05-21 06:53:18 CTS T4 FIX | Using primary service for historical data for NQ.20170600.CME_Eq | 2017-05-21 06:53:18 Intraday data recording state for symbol NQ.20170600.CME_Eq is set to download 'Pending'. | 2017-05-21 06:53:18 SC DTC Data | Setting DTC encoding to Binary VLS | 2017-05-21 06:53:18 SC DTC Data | Sending logon request message. | 2017-05-21 06:53:18 CTS T4 FIX | Using primary service for historical data for ZB.20170600.CME_F | 2017-05-21 06:53:22 Intraday data recording state for symbol ZB.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:53:22 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6A.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:22 CTS T4 FIX | Starting real-time market data updates for: 6A.20170600.CME_Fo. ID: 31 | 2017-05-21 06:53:22 CTS T4 FIX | Requesting security definition data for: 6A.20170600.CME_Fo. ID: 31 | 2017-05-21 06:53:22 CTS T4 FIX | Using primary service for historical data for 6A.20170600.CME_Fo | 2017-05-21 06:53:22 Intraday data recording state for symbol 6A.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:53:22 Requesting market depth updates for: 6B.20170600.CME_Fo if supported. | 2017-05-21 06:53:22 CTS FIX Historical Data socket (0) | Resolved address fix-chart-sim.t4login.com to IP 74.201.6.229. | 2017-05-21 06:53:22 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:22 CTS T4 FIX | Starting real-time market data updates for: GC.20170600.CME_CO. ID: 32 | 2017-05-21 06:53:22 CTS T4 FIX | Requesting security definition data for: GC.20170600.CME_CO. ID: 32 | 2017-05-21 06:53:22 CTS T4 FIX | Using primary service for historical data for GC.20170600.CME_CO | 2017-05-21 06:53:22 Intraday data recording state for symbol GC.20170600.CME_CO is set to download 'Pending'. | 2017-05-21 06:53:22 SC DTC Data | Received logon response. | 2017-05-21 06:53:22 SC DTC Data | Server Name: SC Realtime Server. | 2017-05-21 06:53:22 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2017-05-21 06:53:22 SC DTC Data | Successfully connected. | 2017-05-21 06:53:22 SC DTC Data | Trading is not supported. | 2017-05-21 06:53:22 SC DTC Data | Restarting real-time data updates for symbol: AUDJPY | 2017-05-21 06:53:22 Requesting market depth updates for: YM.20170600.CME_E if supported. | 2017-05-21 06:53:22 SC DTC Data | Received security definition for symbol AUDJPY | 2017-05-21 06:53:22 CTS FIX Historical Data socket (2188) | Connected. | 2017-05-21 06:53:22 CTS FIX Historical Data socket (2188) | Starting TLS 1.0 connection. | 2017-05-21 06:53:22 CTS T4 FIX | Received 'Account Update/Balance Data' collateral report. | 2017-05-21 06:53:22 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZN.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:22 CTS T4 FIX | Starting real-time market data updates for: ZN.20170600.CME_F. ID: 33 | 2017-05-21 06:53:22 CTS T4 FIX | Requesting security definition data for: ZN.20170600.CME_F. ID: 33 | 2017-05-21 06:53:22 CTS T4 FIX | Using primary service for historical data for ZN.20170600.CME_F | 2017-05-21 06:53:22 Intraday data recording state for symbol ZN.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:53:22 CTS FIX Historical Data socket (2188) | SSL connection established. | 2017-05-21 06:53:22 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6J.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:22 CTS T4 FIX | Starting real-time market data updates for: 6J.20170600.CME_Fo. ID: 34 | 2017-05-21 06:53:22 CTS T4 FIX | Requesting security definition data for: 6J.20170600.CME_Fo. ID: 34 | 2017-05-21 06:53:22 CTS T4 FIX | Using primary service for historical data for 6J.20170600.CME_Fo | 2017-05-21 06:53:22 Intraday data recording state for symbol 6J.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:53:22 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:22 CTS T4 FIX | Starting real-time market data updates for: CL.20171200.CME_NY. ID: 35 | 2017-05-21 06:53:22 CTS T4 FIX | Requesting security definition data for: CL.20171200.CME_NY. ID: 35 | 2017-05-21 06:53:22 CTS T4 FIX | Using primary service for historical data for CL.20171200.CME_NY | 2017-05-21 06:53:22 Intraday data recording state for symbol CL.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:53:22 Requesting market depth updates for: 6J.20170600.CME_Fo if supported. | 2017-05-21 06:53:22 Requesting market depth updates for: NQ.20170600.CME_Eq if supported. | 2017-05-21 06:53:22 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZT.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:53:22 CTS T4 FIX | Starting real-time market data updates for: ZT.20170600.CME_F. ID: 36 | 2017-05-21 06:53:22 CTS T4 FIX | Requesting security definition data for: ZT.20170600.CME_F. ID: 36 | 2017-05-21 06:53:22 CTS T4 FIX | Using primary service for historical data for ZT.20170600.CME_F | 2017-05-21 06:53:22 Intraday data recording state for symbol ZT.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:53:22 Requesting market depth updates for: GC.20170600.CME_CO if supported. | 2017-05-21 06:53:22 Requesting market depth updates for: CL.20170700.CME_NY if supported. | 2017-05-21 06:53:22 Requesting market depth updates for: ZB.20170600.CME_F if supported. | 2017-05-21 06:53:22 Requesting market depth updates for: ES.20170600.CME_Eq if supported. | 2017-05-21 06:53:22 CTS T4 FIX | Sending security definition request for symbol 6A.20160900.CME_Fo | 2017-05-21 06:53:22 Symbol Error - 6A.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:53:22 CTS T4 FIX | Received 0 security definitions for underlying symbol 6A | 2017-05-21 06:53:22 Delaying start of download for AUDJPY | 2017-05-21 06:53:25 CTS FIX Historical Data: Sending the Logon message. | 2017-05-21 06:53:25 CTS FIX Historical Data: Connected to Historical data server. | 2017-05-21 06:53:25 CTS T4 FIX | Sending security definition request for symbol 6A.20170600.CME_Fo | 2017-05-21 06:53:26 CTS T4 FIX | Received matching security definition for symbol 6A.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:53:26 CTS T4 FIX | Received 1 security definitions for underlying symbol 6A | 2017-05-21 06:53:26 Contract specifications for 6A.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:53:26 CTS T4 FIX | Requesting Open Orders for account: May*. Request ID: 9498889 | 2017-05-21 06:53:28 Requesting market depth updates for: 6B.20160900.CME_Fo if supported. | 2017-05-21 06:53:28 Requesting market depth updates for: 6E.20160900.CME_Fo if supported. | 2017-05-21 06:53:28 Requesting market depth updates for: 6J.20160900.CME_Fo if supported. | 2017-05-21 06:53:28 Requesting market depth updates for: 6N.20170600.CME_Fo if supported. | 2017-05-21 06:53:28 Requesting market depth updates for: CL.20160800.CME_NY if supported. | 2017-05-21 06:53:28 Requesting market depth updates for: CL.20170100.CME_NY if supported. | 2017-05-21 06:53:28 Requesting market depth updates for: CL.20170600.CME_NY if supported. | 2017-05-21 06:53:28 Requesting market depth updates for: CL.20171200.CME_NY if supported. | 2017-05-21 06:53:28 Requesting market depth updates for: ES.20160900.CME_Eq if supported. | 2017-05-21 06:53:28 Requesting market depth updates for: GC.20160800.CME_CO if supported. | 2017-05-21 06:53:28 Requesting market depth updates for: GC.20170400.CME_CO if supported. | 2017-05-21 06:53:28 Requesting market depth updates for: NQ.20160900.CME_Eq if supported. | 2017-05-21 06:53:28 Requesting market depth updates for: YM.20160900.CME_E if supported. | 2017-05-21 06:53:28 Requesting market depth updates for: ZB.20160900.CME_F if supported. | 2017-05-21 06:53:28 Requesting market depth updates for: ZB.20170300.CME_F if supported. | 2017-05-21 06:53:28 CTS T4 FIX | Sending security definition request for symbol 6B.20160900.CME_Fo | 2017-05-21 06:53:28 CTS T4 FIX | No open orders for account May18CCwmitchel | 2017-05-21 06:53:28 Symbol Error - 6B.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:53:28 CTS T4 FIX | Received 0 security definitions for underlying symbol 6B | 2017-05-21 06:53:28 HD Request # 415 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-05-21 06:53:28 HD Request # 415 | Download start date-time: 2017-05-19 16:57:58.000 | 2017-05-21 06:53:28 HD Request # 415 | Using server: ds3.sierracharts.com port 10149 | 2017-05-21 06:53:28 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2017-05-21 06:53:28 Socket (2189) | Connected. | 2017-05-21 06:53:28 HD Request # 415 | Setting DTC encoding to Binary VLS | 2017-05-21 06:53:29 HD Request # 415 | Sending historical data logon request message. | 2017-05-21 06:53:29 HD Request # 415 | Requesting Intraday data. Start date-time: 2017-05-19 16:57:58. Record interval: 1. Symbol: AUDJPY | 2017-05-21 06:53:29 HD Request # 415 | Decompressing data. | 2017-05-21 06:53:29 HD Request # 415 | Receiving Intraday data for AUDJPY starting at 2017-05-19 16:57:58 | 2017-05-21 06:53:29 HD Request # 415 | Timestamp of first Intraday data file record written: 2017-05-19 16:57:58 | 2017-05-21 06:53:29 Socket (2189) | Shutdown and closed. | 2017-05-21 06:53:29 The network socket for historical data has been closed. | 2017-05-21 06:53:29 HD Request # 415 | Received 1 record from 2017-05-19 16:57:58 to 2017-05-19 16:57:58 (0.0 seconds) and wrote 1 record for AUDJPY | 2017-05-21 06:53:29 HD Request # 415 | Intraday download COMPLETE for AUDJPY. Completion time: 1s. Unique request ID: 719 | 2017-05-21 06:53:29 Removed historical data download ID 719 | 2017-05-21 06:53:29 Real-time Intraday chart data file updates started for AUDJPY | 2017-05-21 06:53:29 Opened cached Intraday file: C:\SierraChart1\Data\AUDJPY.scid | 2017-05-21 06:53:29 Intraday chart data file opened for AUDJPY | 2017-05-21 06:53:29 CTS T4 FIX | Sending security definition request for symbol 6B.20170600.CME_Fo | 2017-05-21 06:53:29 CTS T4 FIX | Received matching security definition for symbol 6B.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:53:29 CTS T4 FIX | Received matching security definition for symbol 6B.20170600.CME_Fo. Requesting historical data. | 2017-05-21 06:53:29 HD Request # 414 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:53:29 CTS T4 FIX | Received 1 security definitions for underlying symbol 6B | 2017-05-21 06:53:29 Contract specifications for 6B.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 6.25 | 2017-05-21 06:53:29 HD Request # 414 | Receiving Intraday data for 6B.20170600.CME_Fo starting at 2017-05-18 18:00:00 | 2017-05-21 06:53:31 HD Request # 414 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:54 | 2017-05-21 06:53:31 HD Request # 414 | Total records received: 8374 | 2017-05-21 06:53:31 HD Request # 414 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:53:31 HD Request # 414 | Total records received: 8374 | 2017-05-21 06:53:31 HD Request # 414 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:53:31 CTS T4 FIX | Sending security definition request for symbol 6C.20160900.CME_Fo | 2017-05-21 06:53:31 HD Request # 414 | Total records received: 8374 | 2017-05-21 06:53:31 HD Request # 414 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:53:31 Symbol Error - 6C.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:53:31 CTS T4 FIX | Received 0 security definitions for underlying symbol 6C | 2017-05-21 06:53:31 HD Request # 414 | Total records received: 8374 | 2017-05-21 06:53:31 HD Request # 414 | Requesting historical Second data for 6B.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:53:31 HD Request # 414 | Received 8374 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:54 (23.0 hours) and wrote 1 record for 6B.20170600.CME_Fo | 2017-05-21 06:53:32 HD Request # 414 | Intraday download COMPLETE for 6B.20170600.CME_Fo. Completion time: 9s. Unique request ID: 715 | 2017-05-21 06:53:32 Removed historical data download ID 715 | 2017-05-21 06:53:32 Real-time Intraday chart data file updates started for 6B.20170600.CME_Fo | 2017-05-21 06:53:32 Opened cached Intraday file: C:\SierraChart1\Data\6B.20170600.CME_Fo.scid | 2017-05-21 06:53:32 Intraday chart data file opened for 6B.20170600.CME_Fo | 2017-05-21 06:53:32 Delaying start of download for 6E.20170600.CME_Fo | 2017-05-21 06:53:32 CTS T4 FIX | Sending security definition request for symbol 6C.20170600.CME_Fo | 2017-05-21 06:53:32 Chart #12 has tagged chart #8 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:53:32 CTS T4 FIX | Received matching security definition for symbol 6C.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:53:32 CTS T4 FIX | Received 1 security definitions for underlying symbol 6C | 2017-05-21 06:53:32 Chart #12 has tagged chart #8 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:53:32 Contract specifications for 6C.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 5 | 2017-05-21 06:53:32 6A.20170600.CME_Fo 3 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:53:33 6A.20170600.CME_Fo 3 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:53:33 CTS T4 FIX | Sending security definition request for symbol 6E.20160900.CME_Fo | 2017-05-21 06:53:33 Symbol Error - 6E.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:53:33 CTS T4 FIX | Received 0 security definitions for underlying symbol 6E | 2017-05-21 06:53:33 CTS T4 FIX | Sending security definition request for symbol 6E.20170600.CME_Fo | 2017-05-21 06:53:37 CTS T4 FIX | Received matching security definition for symbol 6E.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:53:37 CTS T4 FIX | Received 1 security definitions for underlying symbol 6E | 2017-05-21 06:53:37 Contract specifications for 6E.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-05-21 06:53:37 CTS T4 FIX | Requesting historical Fills for account: May*. Request ID: 9498893 | 2017-05-21 06:53:38 CTS T4 FIX | Received Account List collateral report. | 2017-05-21 06:53:38 CTS T4 FIX | Server provided no historical order fills for account 1A297B51-A416-42D4-A1C8-C9B1B4125155 | 2017-05-21 06:53:38 CTS T4 FIX | Sending security definition request for symbol 6J.20160900.CME_Fo | 2017-05-21 06:53:38 Symbol Error - 6J.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:53:38 CTS T4 FIX | Received 0 security definitions for underlying symbol 6J | 2017-05-21 06:53:38 CTS T4 FIX | Sending security definition request for symbol 6J.20170600.CME_Fo | 2017-05-21 06:53:39 CTS T4 FIX | Received matching security definition for symbol 6J.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:53:39 CTS T4 FIX | Received 1 security definitions for underlying symbol 6J | 2017-05-21 06:53:39 Contract specifications for 6J.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-05-21 06:53:41 CTS T4 FIX | Sending security definition request for symbol 6N.20170600.CME_Fo | 2017-05-21 06:53:41 CTS T4 FIX | Received matching security definition for symbol 6N.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:53:41 CTS T4 FIX | Received 1 security definitions for underlying symbol 6N | 2017-05-21 06:53:41 Contract specifications for 6N.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:53:42 CTS T4 FIX | Sending security definition request for symbol 6S.20170600.CME_Fo | 2017-05-21 06:53:42 CTS T4 FIX | Received matching security definition for symbol 6S.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:53:43 CTS T4 FIX | Received 1 security definitions for underlying symbol 6S | 2017-05-21 06:53:43 Contract specifications for 6S.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 12.5 | 2017-05-21 06:53:43 CTS T4 FIX | Sending security definition request for symbol CL.20160800.CME_NY | 2017-05-21 06:53:45 Symbol Error - CL.20160800.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:53:45 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2017-05-21 06:53:45 CTS T4 FIX | Sending security definition request for symbol CL.20170100.CME_NY | 2017-05-21 06:53:46 Symbol Error - CL.20170100.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:53:46 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2017-05-21 06:53:46 CTS T4 FIX | Sending security definition request for symbol CL.20170600.CME_NY | 2017-05-21 06:53:47 CTS T4 FIX | Received matching security definition for symbol CL.20170600.CME_NY. Subscribing to data. | 2017-05-21 06:53:47 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:53:47 Contract specifications for CL.20170600.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:53:47 CTS T4 FIX | Sending security definition request for symbol CL.20170700.CME_NY | 2017-05-21 06:53:49 CTS T4 FIX | Received matching security definition for symbol CL.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:53:49 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:53:49 Contract specifications for CL.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:53:49 CTS T4 FIX | Sending security definition request for symbol CL.20171200.CME_NY | 2017-05-21 06:53:50 CTS T4 FIX | Received matching security definition for symbol CL.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:53:50 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:53:50 Contract specifications for CL.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:53:50 CTS T4 FIX | Sending security definition request for symbol ES.20160900.CME_Eq | 2017-05-21 06:53:52 Symbol Error - ES.20160900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:53:52 CTS T4 FIX | Received 0 security definitions for underlying symbol ES | 2017-05-21 06:53:52 CTS T4 FIX | Sending security definition request for symbol ES.20170600.CME_Eq | 2017-05-21 06:53:53 CTS T4 FIX | Received matching security definition for symbol ES.20170600.CME_Eq. Subscribing to data. | 2017-05-21 06:53:53 CTS T4 FIX | Received 1 security definitions for underlying symbol ES | 2017-05-21 06:53:53 Contract specifications for ES.20170600.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 12.5 | 2017-05-21 06:53:54 HD Request # 416 | Downloading Intraday chart data for 6E.20170600.CME_Fo to the file 6E.20170600.CME_Fo.scid. Service: cts | 2017-05-21 06:53:54 HD Request # 416 | Download start date-time: 2017-05-19 16:59:58.000 | 2017-05-21 06:53:54 HD Request # 416 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:53:54 CTS T4 FIX | Sending security definition request for symbol GC.20160800.CME_CO | 2017-05-21 06:53:54 Symbol Error - GC.20160800.CME_CO is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:53:54 CTS T4 FIX | Received 0 security definitions for underlying symbol GC | 2017-05-21 06:53:54 HD Request # 416 | Receiving Intraday data for 6E.20170600.CME_Fo starting at 2017-05-18 18:00:00 | 2017-05-21 06:53:56 HD Request # 416 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:58 | 2017-05-21 06:53:56 HD Request # 416 | Total records received: 17398 | 2017-05-21 06:53:56 HD Request # 416 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:53:56 HD Request # 416 | Total records received: 17398 | 2017-05-21 06:53:56 HD Request # 416 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:53:56 HD Request # 416 | Total records received: 17398 | 2017-05-21 06:53:56 HD Request # 416 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:53:56 CTS T4 FIX | Sending security definition request for symbol GC.20170400.CME_CO | 2017-05-21 06:53:56 Symbol Error - GC.20170400.CME_CO is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:53:57 CTS T4 FIX | Received 0 security definitions for underlying symbol GC | 2017-05-21 06:53:57 HD Request # 416 | Total records received: 17398 | 2017-05-21 06:53:57 HD Request # 416 | Requesting historical Second data for 6E.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:53:57 HD Request # 416 | Received 17398 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:58 (23.0 hours) and wrote 1 record for 6E.20170600.CME_Fo | 2017-05-21 06:53:57 HD Request # 416 | Intraday download COMPLETE for 6E.20170600.CME_Fo. Completion time: 3s. Unique request ID: 716 | 2017-05-21 06:53:57 Removed historical data download ID 716 | 2017-05-21 06:53:57 Real-time Intraday chart data file updates started for 6E.20170600.CME_Fo | 2017-05-21 06:53:57 Opened cached Intraday file: C:\SierraChart1\Data\6E.20170600.CME_Fo.scid | 2017-05-21 06:53:57 Intraday chart data file opened for 6E.20170600.CME_Fo | 2017-05-21 06:53:57 Delaying start of download for YM.20170600.CME_E | 2017-05-21 06:53:57 CTS T4 FIX | Sending security definition request for symbol GC.20170600.CME_CO | 2017-05-21 06:53:57 Chart #15 has tagged chart #4 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:53:57 CTS T4 FIX | Received matching security definition for symbol GC.20170600.CME_CO. Subscribing to data. | 2017-05-21 06:53:57 CTS T4 FIX | Received 1 security definitions for underlying symbol GC | 2017-05-21 06:53:57 6B.20170600.CME_Fo 30 Sec #4 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:53:59 Contract specifications for GC.20170600.CME_CO. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:53:59 CTS T4 FIX | Sending security definition request for symbol HO.20170700.CME_NY | 2017-05-21 06:53:59 CTS T4 FIX | Received matching security definition for symbol HO.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:54:01 CTS T4 FIX | Received 1 security definitions for underlying symbol HO | 2017-05-21 06:54:01 Contract specifications for HO.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:54:01 CTS T4 FIX | Sending security definition request for symbol HO.20171200.CME_NY | 2017-05-21 06:54:02 CTS T4 FIX | Received matching security definition for symbol HO.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:54:02 CTS T4 FIX | Received 1 security definitions for underlying symbol HO | 2017-05-21 06:54:02 Contract specifications for HO.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:54:03 CTS T4 FIX | Sending security definition request for symbol NQ.20160900.CME_Eq | 2017-05-21 06:54:03 Symbol Error - NQ.20160900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:54:03 CTS T4 FIX | Received 0 security definitions for underlying symbol NQ | 2017-05-21 06:54:03 CTS T4 FIX | Sending security definition request for symbol NQ.20170600.CME_Eq | 2017-05-21 06:54:05 CTS T4 FIX | Received matching security definition for symbol NQ.20170600.CME_Eq. Subscribing to data. | 2017-05-21 06:54:05 CTS T4 FIX | Received 1 security definitions for underlying symbol NQ | 2017-05-21 06:54:05 Contract specifications for NQ.20170600.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 5 | 2017-05-21 06:54:06 CTS T4 FIX | Sending security definition request for symbol RB.20170700.CME_NY | 2017-05-21 06:54:06 CTS T4 FIX | Received matching security definition for symbol RB.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:54:07 CTS T4 FIX | Received 1 security definitions for underlying symbol RB | 2017-05-21 06:54:07 Contract specifications for RB.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:54:07 CTS T4 FIX | Sending security definition request for symbol RB.20171200.CME_NY | 2017-05-21 06:54:09 CTS T4 FIX | Received matching security definition for symbol RB.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:54:09 CTS T4 FIX | Received 1 security definitions for underlying symbol RB | 2017-05-21 06:54:09 Contract specifications for RB.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 06:54:09 CTS T4 FIX | Sending security definition request for symbol YM.20160900.CME_E | 2017-05-21 06:54:10 Symbol Error - YM.20160900.CME_E is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:54:10 CTS T4 FIX | Received 0 security definitions for underlying symbol YM | 2017-05-21 06:54:10 CTS T4 FIX | Sending security definition request for symbol YM.20170600.CME_E | 2017-05-21 06:54:11 CTS T4 FIX | Received matching security definition for symbol YM.20170600.CME_E. Subscribing to data. | 2017-05-21 06:54:11 CTS T4 FIX | Received 1 security definitions for underlying symbol YM | 2017-05-21 06:54:11 Contract specifications for YM.20170600.CME_E. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 5 | 2017-05-21 06:54:11 CTS T4 FIX | Sending security definition request for symbol ZB.20160900.CME_F | 2017-05-21 06:54:13 Symbol Error - ZB.20160900.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:54:13 CTS T4 FIX | Received 0 security definitions for underlying symbol ZB | 2017-05-21 06:54:13 CTS T4 FIX | Sending security definition request for symbol ZB.20170300.CME_F | 2017-05-21 06:54:14 Symbol Error - ZB.20170300.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:54:14 CTS T4 FIX | Received 0 security definitions for underlying symbol ZB | 2017-05-21 06:54:14 CTS T4 FIX | Sending security definition request for symbol ZB.20170600.CME_F | 2017-05-21 06:54:15 CTS T4 FIX | Received matching security definition for symbol ZB.20170600.CME_F. Subscribing to data. | 2017-05-21 06:54:15 CTS T4 FIX | Received 1 security definitions for underlying symbol ZB | 2017-05-21 06:54:15 Contract specifications for ZB.20170600.CME_F. Multiplier: 0.00001000. Tick Size: 0.03125. Value Format: 132. Currency Value per Tick: 31.25 | 2017-05-21 06:54:17 CTS T4 FIX | Sending security definition request for symbol ZN.20170600.CME_F | 2017-05-21 06:54:17 CTS T4 FIX | Received matching security definition for symbol ZN.20170600.CME_F. Subscribing to data. | 2017-05-21 06:54:17 CTS T4 FIX | Received 1 security definitions for underlying symbol ZN | 2017-05-21 06:54:17 Contract specifications for ZN.20170600.CME_F. Multiplier: 0.00000100. Tick Size: 0.015625. Value Format: 132. Currency Value per Tick: 15.625 | 2017-05-21 06:54:17 CTS T4 FIX | Sending security definition request for symbol ZT.20170600.CME_F | 2017-05-21 06:54:18 CTS T4 FIX | Received matching security definition for symbol ZT.20170600.CME_F. Subscribing to data. | 2017-05-21 06:54:18 CTS T4 FIX | Received 1 security definitions for underlying symbol ZT | 2017-05-21 06:54:18 Contract specifications for ZT.20170600.CME_F. Multiplier: 0.00000010. Tick Size: 0.0078125. Value Format: 228. Currency Value per Tick: 15.625 | 2017-05-21 06:54:19 HD Request # 417 | Downloading Intraday chart data for YM.20170600.CME_E to the file YM.20170600.CME_E.scid. Service: cts | 2017-05-21 06:54:19 HD Request # 417 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:54:19 HD Request # 417 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:54:19 HD Request # 417 | Receiving Intraday data for YM.20170600.CME_E starting at 2017-05-18 18:00:00 | 2017-05-21 06:54:21 HD Request # 417 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:54:21 HD Request # 417 | Total records received: 19680 | 2017-05-21 06:54:21 HD Request # 417 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:54:21 HD Request # 417 | Total records received: 19680 | 2017-05-21 06:54:21 HD Request # 417 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:54:21 HD Request # 417 | Total records received: 19680 | 2017-05-21 06:54:21 HD Request # 417 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:54:21 HD Request # 417 | Total records received: 19680 | 2017-05-21 06:54:22 HD Request # 417 | Requesting historical Second data for YM.20170600.CME_E from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:54:22 HD Request # 417 | Received 19680 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for YM.20170600.CME_E | 2017-05-21 06:54:22 HD Request # 417 | Intraday download COMPLETE for YM.20170600.CME_E. Completion time: 3s. Unique request ID: 717 | 2017-05-21 06:54:22 Removed historical data download ID 717 | 2017-05-21 06:54:22 Real-time Intraday chart data file updates started for YM.20170600.CME_E | 2017-05-21 06:54:22 Opened cached Intraday file: C:\SierraChart1\Data\YM.20170600.CME_E.scid | 2017-05-21 06:54:22 Intraday chart data file opened for YM.20170600.CME_E | 2017-05-21 06:54:22 Delaying start of download for ES.20170600.CME_Eq | 2017-05-21 06:54:22 Chart #3 has tagged chart #4 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:54:24 ZB.20170600.CME_F 3 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:54:25 SC DTC Data | There has been no activity on the network socket for 40 seconds. Will reconnect. | 2017-05-21 06:55:23 DTC Client (2187) | Shutdown and closed. | 2017-05-21 06:55:23 SC DTC Data | Disconnected from the server. | 2017-05-21 06:55:23 SC DTC Data | Data feed disconnected. Will reconnect in 2 seconds. | 2017-05-21 06:55:23 SC DTC Data | Connecting to the server ds4.sierracharts.com. Port 443 | 2017-05-21 06:55:26 DTC Client (0) | Resolved address ds4.sierracharts.com to IP 192.81.56.146. | 2017-05-21 06:55:26 DTC Client (2191) | Connected. | 2017-05-21 06:55:26 SC DTC Data | Connected to server. | 2017-05-21 06:55:26 SC DTC Data | Sending Encoding Request to server | 2017-05-21 06:55:26 SC DTC Data | Setting DTC encoding to Binary VLS | 2017-05-21 06:55:26 SC DTC Data | Sending logon request message. | 2017-05-21 06:55:26 SC DTC Data | Received logon response. | 2017-05-21 06:55:27 SC DTC Data | Server Name: SC Realtime Server. | 2017-05-21 06:55:27 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2017-05-21 06:55:27 SC DTC Data | Successfully connected. | 2017-05-21 06:55:27 SC DTC Data | Trading is not supported. | 2017-05-21 06:55:27 Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2017-05-21 06:55:27 SC DTC Data | Restarting real-time data updates for symbol: AUDJPY | 2017-05-21 06:55:27 Delaying start of download for AUDJPY | 2017-05-21 06:55:27 SC DTC Data | Received security definition for symbol AUDJPY | 2017-05-21 06:55:27 HD Request # 418 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-05-21 06:55:33 HD Request # 418 | Download start date-time: 2017-05-19 16:57:58.000 | 2017-05-21 06:55:33 HD Request # 418 | Using server: ds4.sierracharts.com port 10149 | 2017-05-21 06:55:33 Socket (0) | Resolved address ds4.sierracharts.com to IP 192.81.56.146. | 2017-05-21 06:55:33 Socket (2192) | Connected. | 2017-05-21 06:55:33 HD Request # 418 | Setting DTC encoding to Binary VLS | 2017-05-21 06:55:33 HD Request # 418 | Sending historical data logon request message. | 2017-05-21 06:55:33 HD Request # 418 | Requesting Intraday data. Start date-time: 2017-05-19 16:57:58. Record interval: 1. Symbol: AUDJPY | 2017-05-21 06:55:34 HD Request # 418 | Decompressing data. | 2017-05-21 06:55:34 HD Request # 418 | Receiving Intraday data for AUDJPY starting at 2017-05-19 16:57:58 | 2017-05-21 06:55:34 HD Request # 418 | Timestamp of first Intraday data file record written: 2017-05-19 16:57:58 | 2017-05-21 06:55:34 Socket (2192) | Shutdown and closed. | 2017-05-21 06:55:34 The network socket for historical data has been closed. | 2017-05-21 06:55:34 HD Request # 418 | Received 1 record from 2017-05-19 16:57:58 to 2017-05-19 16:57:58 (0.0 seconds) and wrote 1 record for AUDJPY | 2017-05-21 06:55:34 HD Request # 418 | Intraday download COMPLETE for AUDJPY. Completion time: 1s. Unique request ID: 736 | 2017-05-21 06:55:34 Removed historical data download ID 736 | 2017-05-21 06:55:34 Real-time Intraday chart data file updates started for AUDJPY | 2017-05-21 06:55:34 Opened cached Intraday file: C:\SierraChart1\Data\AUDJPY.scid | 2017-05-21 06:55:34 Intraday chart data file opened for AUDJPY | 2017-05-21 06:55:34 HD Request # 419 | Downloading Intraday chart data for ES.20170600.CME_Eq to the file ES.20170600.CME_Eq.scid. Service: cts | 2017-05-21 06:55:36 HD Request # 419 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:55:36 HD Request # 419 | Requesting historical Second data for ES.20170600.CME_Eq from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:55:36 HD Request # 419 | Receiving Intraday data for ES.20170600.CME_Eq starting at 2017-05-18 18:00:00 | 2017-05-21 06:55:37 HD Request # 419 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:55:37 HD Request # 419 | Total records received: 27907 | 2017-05-21 06:55:37 HD Request # 419 | Requesting historical Second data for ES.20170600.CME_Eq from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:55:37 HD Request # 419 | Total records received: 27907 | 2017-05-21 06:55:37 HD Request # 419 | Requesting historical Second data for ES.20170600.CME_Eq from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:55:37 HD Request # 419 | Total records received: 27907 | 2017-05-21 06:55:37 HD Request # 419 | Requesting historical Second data for ES.20170600.CME_Eq from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:55:37 HD Request # 419 | Total records received: 27907 | 2017-05-21 06:55:37 HD Request # 419 | Requesting historical Second data for ES.20170600.CME_Eq from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:55:37 HD Request # 419 | Received 27907 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for ES.20170600.CME_Eq | 2017-05-21 06:55:39 HD Request # 419 | Intraday download COMPLETE for ES.20170600.CME_Eq. Completion time: 3s. Unique request ID: 718 | 2017-05-21 06:55:39 Removed historical data download ID 718 | 2017-05-21 06:55:39 Real-time Intraday chart data file updates started for ES.20170600.CME_Eq | 2017-05-21 06:55:39 Opened cached Intraday file: C:\SierraChart1\Data\ES.20170600.CME_Eq.scid | 2017-05-21 06:55:39 Intraday chart data file opened for ES.20170600.CME_Eq | 2017-05-21 06:55:39 Delaying start of download for 6S.20170600.CME_Fo | 2017-05-21 06:55:39 Chart #17 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:55:39 Chart #17 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:55:39 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:55:39 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:55:39 Chart #17 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:55:39 Chart #17 has tagged chart #1 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:55:39 Chart #17 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:55:39 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:55:39 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:55:39 Chart #17 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:55:39 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:55:39 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:55:39 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:55:39 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:55:39 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:55:39 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:55:39 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:55:40 GC.20170600.CME_CO 3 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:55:40 Chart #1 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:55:40 Chart #1 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:55:40 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:55:40 6J.20170600.CME_Fo 3 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:55:40 Chart #14 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:55:40 ZB.20170600.CME_F 3 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:55:40 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:55:40 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:55:40 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:55:40 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:55:40 6J.20170600.CME_Fo 30 Sec #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:55:40 NQ.20170600.CME_Eq 30 Sec #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:55:40 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:55:40 GC.20170600.CME_CO 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:55:40 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:55:40 ZB.20170600.CME_F 30 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:55:40 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:55:40 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:55:40 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:55:40 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:55:46 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:55:46 HD Request # 420 | Downloading Intraday chart data for 6S.20170600.CME_Fo to the file 6S.20170600.CME_Fo.scid. Service: cts | 2017-05-21 06:56:06 HD Request # 420 | Download start date-time: 2017-05-19 16:59:35.000 | 2017-05-21 06:56:06 HD Request # 420 | Requesting historical Second data for 6S.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:56:06 HD Request # 420 | Receiving Intraday data for 6S.20170600.CME_Fo starting at 2017-05-18 18:00:00 | 2017-05-21 06:56:06 HD Request # 420 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:35 | 2017-05-21 06:56:06 HD Request # 420 | Total records received: 4884 | 2017-05-21 06:56:06 HD Request # 420 | Requesting historical Second data for 6S.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:56:06 HD Request # 420 | Total records received: 4884 | 2017-05-21 06:56:06 HD Request # 420 | Requesting historical Second data for 6S.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:56:06 HD Request # 420 | Total records received: 4884 | 2017-05-21 06:56:06 HD Request # 420 | Requesting historical Second data for 6S.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:56:06 HD Request # 420 | Total records received: 4884 | 2017-05-21 06:56:08 HD Request # 420 | Requesting historical Second data for 6S.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:56:08 HD Request # 420 | Received 4884 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:35 (23.0 hours) and wrote 1 record for 6S.20170600.CME_Fo | 2017-05-21 06:56:08 HD Request # 420 | Intraday download COMPLETE for 6S.20170600.CME_Fo. Completion time: 2s. Unique request ID: 720 | 2017-05-21 06:56:08 Removed historical data download ID 720 | 2017-05-21 06:56:08 Real-time Intraday chart data file updates started for 6S.20170600.CME_Fo | 2017-05-21 06:56:08 Opened cached Intraday file: C:\SierraChart1\Data\6S.20170600.CME_Fo.scid | 2017-05-21 06:56:08 Intraday chart data file opened for 6S.20170600.CME_Fo | 2017-05-21 06:56:08 Delaying start of download for HO.20170700.CME_NY | 2017-05-21 06:56:08 HD Request # 421 | Downloading Intraday chart data for HO.20170700.CME_NY to the file HO.20170700.CME_NY.scid. Service: cts | 2017-05-21 06:56:28 HD Request # 421 | Download start date-time: 2017-05-19 16:59:53.000 | 2017-05-21 06:56:28 HD Request # 421 | Requesting historical Second data for HO.20170700.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:56:28 HD Request # 421 | Receiving Intraday data for HO.20170700.CME_NY starting at 2017-05-18 18:00:00 | 2017-05-21 06:56:30 HD Request # 421 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:53 | 2017-05-21 06:56:30 HD Request # 421 | Total records received: 7519 | 2017-05-21 06:56:30 HD Request # 421 | Requesting historical Second data for HO.20170700.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:56:30 HD Request # 421 | Total records received: 7519 | 2017-05-21 06:56:30 HD Request # 421 | Requesting historical Second data for HO.20170700.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:56:30 HD Request # 421 | Total records received: 7519 | 2017-05-21 06:56:30 HD Request # 421 | Requesting historical Second data for HO.20170700.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:56:30 HD Request # 421 | Total records received: 7519 | 2017-05-21 06:56:30 HD Request # 421 | Requesting historical Second data for HO.20170700.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:56:30 HD Request # 421 | Received 7519 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:53 (23.0 hours) and wrote 1 record for HO.20170700.CME_NY | 2017-05-21 06:56:30 HD Request # 421 | Intraday download COMPLETE for HO.20170700.CME_NY. Completion time: 2s. Unique request ID: 721 | 2017-05-21 06:56:30 Removed historical data download ID 721 | 2017-05-21 06:56:30 Real-time Intraday chart data file updates started for HO.20170700.CME_NY | 2017-05-21 06:56:30 Opened cached Intraday file: C:\SierraChart1\Data\HO.20170700.CME_NY.scid | 2017-05-21 06:56:30 Intraday chart data file opened for HO.20170700.CME_NY | 2017-05-21 06:56:30 Delaying start of download for 6C.20170600.CME_Fo | 2017-05-21 06:56:30 Chart #5 has tagged chart #16 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 06:56:30 Chart #20 has tagged chart #16 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:56:31 CL.20170700.CME_NY 30 Sec #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 06:56:31 Chart #20 has tagged chart #9 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:56:31 CL.20170700.CME_NY [C] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:56:31 Chart #9 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:56:31 CL.20170700.CME_NY 3 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:56:31 Chart #16 has tagged chart #15 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:56:31 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:56:33 6C.20170600.CME_Fo 3 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:56:33 HD Request # 422 | Downloading Intraday chart data for 6C.20170600.CME_Fo to the file 6C.20170600.CME_Fo.scid. Service: cts | 2017-05-21 06:56:54 HD Request # 422 | Download start date-time: 2017-05-19 16:59:56.000 | 2017-05-21 06:56:54 HD Request # 422 | Requesting historical Second data for 6C.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:56:54 HD Request # 422 | Receiving Intraday data for 6C.20170600.CME_Fo starting at 2017-05-18 18:00:00 | 2017-05-21 06:56:55 HD Request # 422 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:56 | 2017-05-21 06:56:55 HD Request # 422 | Total records received: 8488 | 2017-05-21 06:56:55 HD Request # 422 | Requesting historical Second data for 6C.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:56:55 HD Request # 422 | Total records received: 8488 | 2017-05-21 06:56:55 HD Request # 422 | Requesting historical Second data for 6C.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:56:55 HD Request # 422 | Total records received: 8488 | 2017-05-21 06:56:55 HD Request # 422 | Requesting historical Second data for 6C.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:56:55 HD Request # 422 | Total records received: 8488 | 2017-05-21 06:56:55 HD Request # 422 | Requesting historical Second data for 6C.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:56:55 HD Request # 422 | Received 8488 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:56 (23.0 hours) and wrote 1 record for 6C.20170600.CME_Fo | 2017-05-21 06:56:57 HD Request # 422 | Intraday download COMPLETE for 6C.20170600.CME_Fo. Completion time: 1s. Unique request ID: 722 | 2017-05-21 06:56:57 Removed historical data download ID 722 | 2017-05-21 06:56:57 Real-time Intraday chart data file updates started for 6C.20170600.CME_Fo | 2017-05-21 06:56:57 Opened cached Intraday file: C:\SierraChart1\Data\6C.20170600.CME_Fo.scid | 2017-05-21 06:56:57 Intraday chart data file opened for 6C.20170600.CME_Fo | 2017-05-21 06:56:57 Delaying start of download for HO.20171200.CME_NY | 2017-05-21 06:56:57 HD Request # 423 | Downloading Intraday chart data for HO.20171200.CME_NY to the file HO.20171200.CME_NY.scid. Service: cts | 2017-05-21 06:57:16 HD Request # 423 | Download start date-time: 2017-05-19 16:00:55.000 | 2017-05-21 06:57:16 HD Request # 423 | Requesting historical Second data for HO.20171200.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:57:16 HD Request # 423 | Receiving Intraday data for HO.20171200.CME_NY starting at 2017-05-18 19:20:47 | 2017-05-21 06:57:17 HD Request # 423 | Timestamp of first Intraday data file record written: 2017-05-19 16:00:55 | 2017-05-21 06:57:17 HD Request # 423 | Total records received: 1157 | 2017-05-21 06:57:17 HD Request # 423 | Requesting historical Second data for HO.20171200.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:57:17 HD Request # 423 | Total records received: 1157 | 2017-05-21 06:57:17 HD Request # 423 | Requesting historical Second data for HO.20171200.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:57:17 HD Request # 423 | Total records received: 1157 | 2017-05-21 06:57:17 HD Request # 423 | Requesting historical Second data for HO.20171200.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:57:17 HD Request # 423 | Total records received: 1157 | 2017-05-21 06:57:17 HD Request # 423 | Requesting historical Second data for HO.20171200.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:57:17 HD Request # 423 | Received 1157 records from 2017-05-18 19:20:47 to 2017-05-19 16:00:55 (20.7 hours) and wrote 1 record for HO.20171200.CME_NY | 2017-05-21 06:57:17 HD Request # 423 | Intraday download COMPLETE for HO.20171200.CME_NY. Completion time: 1s. Unique request ID: 723 | 2017-05-21 06:57:17 Removed historical data download ID 723 | 2017-05-21 06:57:17 Real-time Intraday chart data file updates started for HO.20171200.CME_NY | 2017-05-21 06:57:17 Opened cached Intraday file: C:\SierraChart1\Data\HO.20171200.CME_NY.scid | 2017-05-21 06:57:17 Intraday chart data file opened for HO.20171200.CME_NY | 2017-05-21 06:57:17 Delaying start of download for CL.20170700.CME_NY | 2017-05-21 06:57:17 HD Request # 424 | Downloading Intraday chart data for CL.20170700.CME_NY to the file CL.20170700.CME_NY.scid. Service: cts | 2017-05-21 06:57:38 HD Request # 424 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:57:38 HD Request # 424 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:57:38 HD Request # 424 | Receiving Intraday data for CL.20170700.CME_NY starting at 2017-05-18 18:00:00 | 2017-05-21 06:57:41 HD Request # 424 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:57:41 HD Request # 424 | Total records received: 33722 | 2017-05-21 06:57:41 HD Request # 424 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:57:41 HD Request # 424 | Total records received: 33722 | 2017-05-21 06:57:41 HD Request # 424 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:57:41 HD Request # 424 | Total records received: 33722 | 2017-05-21 06:57:41 HD Request # 424 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:57:41 HD Request # 424 | Total records received: 33722 | 2017-05-21 06:57:41 HD Request # 424 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:57:41 HD Request # 424 | Received 33722 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for CL.20170700.CME_NY | 2017-05-21 06:57:43 HD Request # 424 | Intraday download COMPLETE for CL.20170700.CME_NY. Completion time: 3s. Unique request ID: 724 | 2017-05-21 06:57:43 Removed historical data download ID 724 | 2017-05-21 06:57:43 Real-time Intraday chart data file updates started for CL.20170700.CME_NY | 2017-05-21 06:57:43 Opened cached Intraday file: C:\SierraChart1\Data\CL.20170700.CME_NY.scid | 2017-05-21 06:57:43 Intraday chart data file opened for CL.20170700.CME_NY | 2017-05-21 06:57:43 Delaying start of download for 6N.20170600.CME_Fo | 2017-05-21 06:57:43 Chart #3 has tagged chart #1 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:57:43 Chart #3 has tagged chart #4 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:57:43 Chart #3 has tagged chart #5 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:57:43 Chart #3 has tagged chart #8 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:57:43 CL.20170700.CME_NY 30 Sec #4 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:57:43 CL.20170700.CME_NY 3 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:57:43 CTS FIX socket (2186) | Closed. No error. | 2017-05-21 06:57:43 CTS FIX socket (2186) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-21 06:57:43 CTS FIX socket (2186) | SSL has been shut down. | 2017-05-21 06:57:43 CTS FIX socket (2186) | SSL object has been freed. SSL state is now disconnected. | 2017-05-21 06:57:43 CTS FIX socket (2186) | Shutdown and closed. | 2017-05-21 06:57:43 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2017-05-21 06:57:43 Connection to the external service has been lost. | 2017-05-21 06:57:43 Chart #9 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:57:43 Chart #16 has tagged chart #15 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:57:43 CL.20170700.CME_NY 3 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:57:43 6C.20170600.CME_Fo 3 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:57:43 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:58:34 CL.20170700.CME_NY 3 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:58:34 Canceling historical data download request for 6N.20170600.CME_Fo Intraday data. | 2017-05-21 06:58:34 Removed historical data download ID 725 | 2017-05-21 06:58:34 Canceling historical data download request for RB.20170700.CME_NY Intraday data. | 2017-05-21 06:58:34 Removed historical data download ID 726 | 2017-05-21 06:58:34 Canceling historical data download request for RB.20171200.CME_NY Intraday data. | 2017-05-21 06:58:34 Removed historical data download ID 727 | 2017-05-21 06:58:34 Canceling historical data download request for NQ.20170600.CME_Eq Intraday data. | 2017-05-21 06:58:34 Removed historical data download ID 728 | 2017-05-21 06:58:34 Canceling historical data download request for ZB.20170600.CME_F Intraday data. | 2017-05-21 06:58:34 Removed historical data download ID 729 | 2017-05-21 06:58:34 Canceling historical data download request for 6A.20170600.CME_Fo Intraday data. | 2017-05-21 06:58:34 Removed historical data download ID 730 | 2017-05-21 06:58:34 Canceling historical data download request for GC.20170600.CME_CO Intraday data. | 2017-05-21 06:58:34 Removed historical data download ID 731 | 2017-05-21 06:58:34 Canceling historical data download request for ZN.20170600.CME_F Intraday data. | 2017-05-21 06:58:34 Removed historical data download ID 732 | 2017-05-21 06:58:34 Canceling historical data download request for 6J.20170600.CME_Fo Intraday data. | 2017-05-21 06:58:34 Removed historical data download ID 733 | 2017-05-21 06:58:34 Canceling historical data download request for CL.20171200.CME_NY Intraday data. | 2017-05-21 06:58:34 Removed historical data download ID 734 | 2017-05-21 06:58:34 Canceling historical data download request for ZT.20170600.CME_F Intraday data. | 2017-05-21 06:58:34 Removed historical data download ID 735 | 2017-05-21 06:58:34 CTS FIX Historical Data: DisconnectFIX called. | 2017-05-21 06:58:34 CTS FIX Historical Data: Sending a Logout message. | 2017-05-21 06:58:34 CTS T4 FIX | Disconnected. | 2017-05-21 06:58:34 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-21 06:58:34 CTS FIX Historical Data socket (2188) | Closed. No error. | 2017-05-21 06:58:34 CTS FIX Historical Data: Received a Logout message. Text = Successful logout upon request | 2017-05-21 06:58:34 CTS FIX Historical Data socket (2188) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-21 06:58:34 CTS FIX Historical Data socket (2188) | SSL has been shut down. | 2017-05-21 06:58:34 CTS FIX Historical Data socket (2188) | SSL object has been freed. SSL state is now disconnected. | 2017-05-21 06:58:34 CTS FIX Historical Data socket (2188) | Shutdown and closed. | 2017-05-21 06:58:34 CTS FIX Historical Data: Disconnected. | 2017-05-21 06:58:34 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2017-05-21 06:58:39 CTS T4 FIX | Firm: PTP | 2017-05-21 06:58:39 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 69.44.110.200. | 2017-05-21 06:58:39 CTS FIX socket (2194) | Connected. | 2017-05-21 06:58:39 CTS FIX socket (2194) | Starting TLS 1.0 connection. | 2017-05-21 06:58:39 CTS FIX socket (2194) | SSL connection established. | 2017-05-21 06:58:40 CTS FIX: Sending the Logon message. | 2017-05-21 06:58:41 CTS T4 FIX | FIX version: 4.3.74.0 | 2017-05-21 06:58:41 CTS T4 FIX | Connected to data and trading server. | 2017-05-21 06:58:41 DTC Client (2191) | Shutdown and closed. | 2017-05-21 06:58:41 SC DTC Data | Disconnected from the server. | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: ZB.20160900.CME_F. ID: 1 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: ZB.20160900.CME_F. ID: 1 | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: 6E.20160900.CME_Fo. ID: 2 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: 6E.20160900.CME_Fo. ID: 2 | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6J.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: 6J.20160900.CME_Fo. ID: 3 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: 6J.20160900.CME_Fo. ID: 3 | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6B.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: 6B.20160900.CME_Fo. ID: 4 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: 6B.20160900.CME_Fo. ID: 4 | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6C.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: 6C.20160900.CME_Fo. ID: 5 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: 6C.20160900.CME_Fo. ID: 5 | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: CL.20160800.CME_NY. ID: 6 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: CL.20160800.CME_NY. ID: 6 | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6A.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: 6A.20160900.CME_Fo. ID: 7 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: 6A.20160900.CME_Fo. ID: 7 | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: NQ.20160900.CME_Eq. ID: 8 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: NQ.20160900.CME_Eq. ID: 8 | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM.######00.CME_E pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: YM.20160900.CME_E. ID: 9 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: YM.20160900.CME_E. ID: 9 | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: GC.20160800.CME_CO. ID: 10 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: GC.20160800.CME_CO. ID: 10 | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: ES.20160900.CME_Eq. ID: 11 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: ES.20160900.CME_Eq. ID: 11 | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: ZB.20170300.CME_F. ID: 12 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: ZB.20170300.CME_F. ID: 12 | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: CL.20170100.CME_NY. ID: 13 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: CL.20170100.CME_NY. ID: 13 | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: GC.20170400.CME_CO. ID: 14 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: GC.20170400.CME_CO. ID: 14 | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZB.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: ZB.20170600.CME_F. ID: 15 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: ZB.20170600.CME_F. ID: 15 | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6B.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: 6B.20170600.CME_Fo. ID: 16 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: 6B.20170600.CME_Fo. ID: 16 | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: CL.20170600.CME_NY. ID: 17 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: CL.20170600.CME_NY. ID: 17 | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: CL.20170700.CME_NY. ID: 18 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: CL.20170700.CME_NY. ID: 18 | 2017-05-21 06:58:41 CTS T4 FIX | Using primary service for historical data for CL.20170700.CME_NY | 2017-05-21 06:58:41 Intraday data recording state for symbol CL.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:58:41 Delaying start of download for CL.20170700.CME_NY | 2017-05-21 06:58:41 CTS T4 FIX | Sending security definition request for symbol 6A.20160900.CME_Fo | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6A.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: 6A.20170600.CME_Fo. ID: 19 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: 6A.20170600.CME_Fo. ID: 19 | 2017-05-21 06:58:41 CTS T4 FIX | Using primary service for historical data for 6A.20170600.CME_Fo | 2017-05-21 06:58:41 Intraday data recording state for symbol 6A.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: NQ.20170600.CME_Eq. ID: 20 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: NQ.20170600.CME_Eq. ID: 20 | 2017-05-21 06:58:41 CTS T4 FIX | Using primary service for historical data for NQ.20170600.CME_Eq | 2017-05-21 06:58:41 Intraday data recording state for symbol NQ.20170600.CME_Eq is set to download 'Pending'. | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The GC.######00.CME_CO pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: GC.20170600.CME_CO. ID: 21 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: GC.20170600.CME_CO. ID: 21 | 2017-05-21 06:58:41 CTS T4 FIX | Using primary service for historical data for GC.20170600.CME_CO | 2017-05-21 06:58:41 Intraday data recording state for symbol GC.20170600.CME_CO is set to download 'Pending'. | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZT.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: ZT.20170600.CME_F. ID: 22 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: ZT.20170600.CME_F. ID: 22 | 2017-05-21 06:58:41 CTS T4 FIX | Using primary service for historical data for ZT.20170600.CME_F | 2017-05-21 06:58:41 Intraday data recording state for symbol ZT.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The HO.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: HO.20170700.CME_NY. ID: 23 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: HO.20170700.CME_NY. ID: 23 | 2017-05-21 06:58:41 CTS T4 FIX | Using primary service for historical data for HO.20170700.CME_NY | 2017-05-21 06:58:41 Intraday data recording state for symbol HO.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:58:41 CTS T4 FIX | Received Account List collateral report. | 2017-05-21 06:58:41 CTS T4 FIX | Subscribing to account: May* | 2017-05-21 06:58:41 Requesting market depth updates for: GC.20170600.CME_CO if supported. | 2017-05-21 06:58:41 Supported exchange: CME_CO (SIM:COMEX Futures) | 2017-05-21 06:58:41 Supported exchange: CME_EqOp (SIM:CME Equity Options) | 2017-05-21 06:58:41 Supported exchange: CME_NYOp (SIM:NYMEX Options) | 2017-05-21 06:58:41 Supported exchange: CME_AgOp (SIM:CME Agricultural Options) | 2017-05-21 06:58:41 Supported exchange: CME_Eq (SIM:CME Equity Futures) | 2017-05-21 06:58:41 Supported exchange: CME_In (SIM:CME Interest Rate Futures) | 2017-05-21 06:58:41 Supported exchange: CME_C (SIM:CBOT Commodity Futures) | 2017-05-21 06:58:41 Supported exchange: CME_KOp (SIM:KCBT Options) | 2017-05-21 06:58:41 Supported exchange: CME_F (SIM:CBOT Financial Futures) | 2017-05-21 06:58:41 Supported exchange: CME_E (SIM:CBOT Equity Futures) | 2017-05-21 06:58:41 Supported exchange: CME_COp (SIM:CBOT Commodity Options) | 2017-05-21 06:58:41 Supported exchange: CME_K (SIM:KCBT Futures) | 2017-05-21 06:58:41 Supported exchange: CME_EOp (SIM:CBOT Equity Options) | 2017-05-21 06:58:41 Supported exchange: CME_NY (SIM:NYMEX Futures) | 2017-05-21 06:58:41 Supported exchange: CME_Fo (SIM:CME Foreign Exchange Futures) | 2017-05-21 06:58:41 Supported exchange: CME_Ag (SIM:CME Agricultural Futures) | 2017-05-21 06:58:41 Supported exchange: CME_FoOp (SIM:CME Foreign Exchange Options) | 2017-05-21 06:58:41 Supported exchange: CME_FOp (SIM:CBOT Financial Options) | 2017-05-21 06:58:41 Supported exchange: CME_InOp (SIM:CME Interest Rate Options) | 2017-05-21 06:58:41 Supported exchange: CME_COOp (SIM:COMEX Options) | 2017-05-21 06:58:41 Symbol Error - 6A.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:58:41 CTS T4 FIX | Received 0 security definitions for underlying symbol 6A | 2017-05-21 06:58:41 Requesting market depth updates for: CL.20170700.CME_NY if supported. | 2017-05-21 06:58:41 Requesting market depth updates for: ZB.20170600.CME_F if supported. | 2017-05-21 06:58:41 CTS T4 FIX | Using primary service for historical data for ZB.20170600.CME_F | 2017-05-21 06:58:41 Intraday data recording state for symbol ZB.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:58:41 CTS T4 FIX | Using primary service for historical data for 6B.20170600.CME_Fo | 2017-05-21 06:58:41 Intraday data recording state for symbol 6B.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6C.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: 6C.20170600.CME_Fo. ID: 24 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: 6C.20170600.CME_Fo. ID: 24 | 2017-05-21 06:58:41 CTS T4 FIX | Using primary service for historical data for 6C.20170600.CME_Fo | 2017-05-21 06:58:41 Intraday data recording state for symbol 6C.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6J.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: 6J.20170600.CME_Fo. ID: 25 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: 6J.20170600.CME_Fo. ID: 25 | 2017-05-21 06:58:41 CTS T4 FIX | Using primary service for historical data for 6J.20170600.CME_Fo | 2017-05-21 06:58:41 Intraday data recording state for symbol 6J.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The ZN.######00.CME_F pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: ZN.20170600.CME_F. ID: 26 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: ZN.20170600.CME_F. ID: 26 | 2017-05-21 06:58:41 CTS T4 FIX | Using primary service for historical data for ZN.20170600.CME_F | 2017-05-21 06:58:41 Intraday data recording state for symbol ZN.20170600.CME_F is set to download 'Pending'. | 2017-05-21 06:58:41 HD Request # 425 | Downloading Intraday chart data for CL.20170700.CME_NY to the file CL.20170700.CME_NY.scid. Service: cts | 2017-05-21 06:58:41 HD Request # 425 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 06:58:41 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: CL.20171200.CME_NY. ID: 27 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: CL.20171200.CME_NY. ID: 27 | 2017-05-21 06:58:41 CTS T4 FIX | Using primary service for historical data for CL.20171200.CME_NY | 2017-05-21 06:58:41 Intraday data recording state for symbol CL.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: ES.20170600.CME_Eq. ID: 28 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: ES.20170600.CME_Eq. ID: 28 | 2017-05-21 06:58:41 Requesting market depth updates for: ES.20170600.CME_Eq if supported. | 2017-05-21 06:58:41 CTS T4 FIX | Using primary service for historical data for ES.20170600.CME_Eq | 2017-05-21 06:58:41 Intraday data recording state for symbol ES.20170600.CME_Eq is set to download 'Pending'. | 2017-05-21 06:58:41 CTS FIX Historical Data socket (0) | Resolved address fix-chart-sim.t4login.com to IP 74.201.6.229. | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The RB.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: RB.20170700.CME_NY. ID: 29 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: RB.20170700.CME_NY. ID: 29 | 2017-05-21 06:58:41 CTS T4 FIX | Using primary service for historical data for RB.20170700.CME_NY | 2017-05-21 06:58:41 Intraday data recording state for symbol RB.20170700.CME_NY is set to download 'Pending'. | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: 6E.20170600.CME_Fo. ID: 30 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: 6E.20170600.CME_Fo. ID: 30 | 2017-05-21 06:58:41 CTS T4 FIX | Using primary service for historical data for 6E.20170600.CME_Fo | 2017-05-21 06:58:41 Intraday data recording state for symbol 6E.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM.######00.CME_E pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: YM.20170600.CME_E. ID: 31 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: YM.20170600.CME_E. ID: 31 | 2017-05-21 06:58:41 CTS T4 FIX | Using primary service for historical data for YM.20170600.CME_E | 2017-05-21 06:58:41 Intraday data recording state for symbol YM.20170600.CME_E is set to download 'Pending'. | 2017-05-21 06:58:41 Using Bid/Ask average for last trade price for AUDJPY | 2017-05-21 06:58:41 SC DTC Data | Starting real-time market data updates for: AUDJPY. ID: 32 | 2017-05-21 06:58:41 SC DTC Data | Connecting to the server ds3.sierracharts.com. Port 10048 | 2017-05-21 06:58:41 SC DTC Data | Requesting security definition data for: AUDJPY. ID: 32 | 2017-05-21 06:58:41 Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2017-05-21 06:58:41 DTC Client (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2017-05-21 06:58:41 Delaying start of download for AUDJPY | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6S.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: 6S.20170600.CME_Fo. ID: 33 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: 6S.20170600.CME_Fo. ID: 33 | 2017-05-21 06:58:41 CTS T4 FIX | Using primary service for historical data for 6S.20170600.CME_Fo | 2017-05-21 06:58:41 Intraday data recording state for symbol 6S.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:58:41 CTS FIX Historical Data socket (2195) | Connected. | 2017-05-21 06:58:41 CTS FIX Historical Data socket (2195) | Starting TLS 1.0 connection. | 2017-05-21 06:58:41 Requesting market depth updates for: 6E.20170600.CME_Fo if supported. | 2017-05-21 06:58:41 DTC Client (2196) | Connected. | 2017-05-21 06:58:41 SC DTC Data | Connected to server. | 2017-05-21 06:58:41 SC DTC Data | Sending Encoding Request to server | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The HO.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: HO.20171200.CME_NY. ID: 34 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: HO.20171200.CME_NY. ID: 34 | 2017-05-21 06:58:41 CTS T4 FIX | Using primary service for historical data for HO.20171200.CME_NY | 2017-05-21 06:58:41 Intraday data recording state for symbol HO.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6N.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: 6N.20170600.CME_Fo. ID: 35 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: 6N.20170600.CME_Fo. ID: 35 | 2017-05-21 06:58:41 CTS T4 FIX | Using primary service for historical data for 6N.20170600.CME_Fo | 2017-05-21 06:58:41 Intraday data recording state for symbol 6N.20170600.CME_Fo is set to download 'Pending'. | 2017-05-21 06:58:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The RB.######00.CME_NY pattern/symbol will not use the SC Exchange Data Feed. | 2017-05-21 06:58:41 CTS T4 FIX | Starting real-time market data updates for: RB.20171200.CME_NY. ID: 36 | 2017-05-21 06:58:41 CTS T4 FIX | Requesting security definition data for: RB.20171200.CME_NY. ID: 36 | 2017-05-21 06:58:41 CTS T4 FIX | Using primary service for historical data for RB.20171200.CME_NY | 2017-05-21 06:58:41 Intraday data recording state for symbol RB.20171200.CME_NY is set to download 'Pending'. | 2017-05-21 06:58:41 SC DTC Data | Setting DTC encoding to Binary VLS | 2017-05-21 06:58:41 SC DTC Data | Sending logon request message. | 2017-05-21 06:58:41 CTS FIX Historical Data socket (2195) | SSL connection established. | 2017-05-21 06:58:46 Requesting market depth updates for: 6B.20170600.CME_Fo if supported. | 2017-05-21 06:58:46 Requesting market depth updates for: YM.20170600.CME_E if supported. | 2017-05-21 06:58:46 SC DTC Data | Received logon response. | 2017-05-21 06:58:46 SC DTC Data | Server Name: SC Realtime Server. | 2017-05-21 06:58:46 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2017-05-21 06:58:46 SC DTC Data | Successfully connected. | 2017-05-21 06:58:46 SC DTC Data | Trading is not supported. | 2017-05-21 06:58:46 SC DTC Data | Restarting real-time data updates for symbol: AUDJPY | 2017-05-21 06:58:46 SC DTC Data | Received security definition for symbol AUDJPY | 2017-05-21 06:58:46 Requesting market depth updates for: 6J.20170600.CME_Fo if supported. | 2017-05-21 06:58:46 Requesting market depth updates for: NQ.20170600.CME_Eq if supported. | 2017-05-21 06:58:46 CTS T4 FIX | Sending security definition request for symbol 6A.20170600.CME_Fo | 2017-05-21 06:58:46 CTS T4 FIX | Received matching security definition for symbol 6A.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:58:46 CTS T4 FIX | Received 1 security definitions for underlying symbol 6A | 2017-05-21 06:58:46 Contract specifications for 6A.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:58:46 CTS FIX Historical Data: Sending the Logon message. | 2017-05-21 06:58:46 Delaying start of download for AUDJPY | 2017-05-21 06:58:48 CTS FIX Historical Data: Connected to Historical data server. | 2017-05-21 06:58:48 CTS T4 FIX | Received 'Account Update/Balance Data' collateral report. | 2017-05-21 06:58:48 CTS T4 FIX | Sending security definition request for symbol 6B.20160900.CME_Fo | 2017-05-21 06:58:48 Symbol Error - 6B.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:58:49 CTS T4 FIX | Received 0 security definitions for underlying symbol 6B | 2017-05-21 06:58:49 Requesting market depth updates for: 6B.20160900.CME_Fo if supported. | 2017-05-21 06:58:51 Requesting market depth updates for: 6E.20160900.CME_Fo if supported. | 2017-05-21 06:58:51 Requesting market depth updates for: 6J.20160900.CME_Fo if supported. | 2017-05-21 06:58:51 Requesting market depth updates for: 6N.20170600.CME_Fo if supported. | 2017-05-21 06:58:51 Requesting market depth updates for: CL.20160800.CME_NY if supported. | 2017-05-21 06:58:51 Requesting market depth updates for: CL.20170100.CME_NY if supported. | 2017-05-21 06:58:51 Requesting market depth updates for: CL.20170600.CME_NY if supported. | 2017-05-21 06:58:51 Requesting market depth updates for: CL.20171200.CME_NY if supported. | 2017-05-21 06:58:51 Requesting market depth updates for: ES.20160900.CME_Eq if supported. | 2017-05-21 06:58:51 Requesting market depth updates for: GC.20160800.CME_CO if supported. | 2017-05-21 06:58:51 Requesting market depth updates for: GC.20170400.CME_CO if supported. | 2017-05-21 06:58:51 Requesting market depth updates for: NQ.20160900.CME_Eq if supported. | 2017-05-21 06:58:51 Requesting market depth updates for: YM.20160900.CME_E if supported. | 2017-05-21 06:58:51 Requesting market depth updates for: ZB.20160900.CME_F if supported. | 2017-05-21 06:58:51 Requesting market depth updates for: ZB.20170300.CME_F if supported. | 2017-05-21 06:58:51 CTS T4 FIX | Requesting Open Orders for account: May*. Request ID: 9498950 | 2017-05-21 06:58:51 CTS T4 FIX | Sending security definition request for symbol 6B.20170600.CME_Fo | 2017-05-21 06:58:51 CTS T4 FIX | No open orders for account May18CCwmitchel | 2017-05-21 06:58:51 CTS T4 FIX | Received matching security definition for symbol 6B.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:58:51 CTS T4 FIX | Received 1 security definitions for underlying symbol 6B | 2017-05-21 06:58:51 Contract specifications for 6B.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 6.25 | 2017-05-21 06:58:51 HD Request # 426 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-05-21 06:58:51 HD Request # 426 | Download start date-time: 2017-05-19 16:57:58.000 | 2017-05-21 06:58:51 HD Request # 426 | Using server: ds3.sierracharts.com port 10149 | 2017-05-21 06:58:51 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2017-05-21 06:58:51 Socket (2198) | Connected. | 2017-05-21 06:58:52 HD Request # 426 | Setting DTC encoding to Binary VLS | 2017-05-21 06:58:52 HD Request # 426 | Sending historical data logon request message. | 2017-05-21 06:58:52 CTS T4 FIX | Sending security definition request for symbol 6C.20160900.CME_Fo | 2017-05-21 06:58:52 HD Request # 426 | Requesting Intraday data. Start date-time: 2017-05-19 16:57:58. Record interval: 1. Symbol: AUDJPY | 2017-05-21 06:58:52 HD Request # 426 | Decompressing data. | 2017-05-21 06:58:52 HD Request # 426 | Receiving Intraday data for AUDJPY starting at 2017-05-19 16:57:58 | 2017-05-21 06:58:52 HD Request # 426 | Timestamp of first Intraday data file record written: 2017-05-19 16:57:58 | 2017-05-21 06:58:52 Socket (2198) | Shutdown and closed. | 2017-05-21 06:58:52 The network socket for historical data has been closed. | 2017-05-21 06:58:52 HD Request # 426 | Received 1 record from 2017-05-19 16:57:58 to 2017-05-19 16:57:58 (0.0 seconds) and wrote 1 record for AUDJPY | 2017-05-21 06:58:52 HD Request # 426 | Intraday download COMPLETE for AUDJPY. Completion time: 1s. Unique request ID: 753 | 2017-05-21 06:58:52 Removed historical data download ID 753 | 2017-05-21 06:58:52 Real-time Intraday chart data file updates started for AUDJPY | 2017-05-21 06:58:52 Opened cached Intraday file: C:\SierraChart1\Data\AUDJPY.scid | 2017-05-21 06:58:52 Intraday chart data file opened for AUDJPY | 2017-05-21 06:58:52 Symbol Error - 6C.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:58:52 CTS T4 FIX | Received 0 security definitions for underlying symbol 6C | 2017-05-21 06:58:52 CTS T4 FIX | Sending security definition request for symbol 6C.20170600.CME_Fo | 2017-05-21 06:58:53 CTS T4 FIX | Received matching security definition for symbol 6C.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:58:53 CTS T4 FIX | Received 1 security definitions for underlying symbol 6C | 2017-05-21 06:58:53 Contract specifications for 6C.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 5 | 2017-05-21 06:58:53 CTS T4 FIX | Sending security definition request for symbol 6E.20160900.CME_Fo | 2017-05-21 06:58:55 Symbol Error - 6E.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:58:55 CTS T4 FIX | Received 0 security definitions for underlying symbol 6E | 2017-05-21 06:58:55 CTS T4 FIX | Sending security definition request for symbol 6E.20170600.CME_Fo | 2017-05-21 06:58:56 CTS T4 FIX | Received matching security definition for symbol 6E.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:58:56 CTS T4 FIX | Received 1 security definitions for underlying symbol 6E | 2017-05-21 06:58:56 Contract specifications for 6E.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-05-21 06:58:57 CTS T4 FIX | Sending security definition request for symbol 6J.20160900.CME_Fo | 2017-05-21 06:58:57 Symbol Error - 6J.20160900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:58:57 CTS T4 FIX | Received 0 security definitions for underlying symbol 6J | 2017-05-21 06:58:57 CTS T4 FIX | Sending security definition request for symbol 6J.20170600.CME_Fo | 2017-05-21 06:58:59 CTS T4 FIX | Received matching security definition for symbol 6J.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:59:00 CTS T4 FIX | Received 1 security definitions for underlying symbol 6J | 2017-05-21 06:59:00 Contract specifications for 6J.20170600.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-05-21 06:59:00 CTS T4 FIX | Requesting historical Fills for account: May*. Request ID: 9498955 | 2017-05-21 06:59:00 CTS T4 FIX | Received Account List collateral report. | 2017-05-21 06:59:00 CTS T4 FIX | Server provided no historical order fills for account 1A297B51-A416-42D4-A1C8-C9B1B4125155 | 2017-05-21 06:59:00 CTS T4 FIX | Sending security definition request for symbol 6N.20170600.CME_Fo | 2017-05-21 06:59:01 CTS T4 FIX | Received matching security definition for symbol 6N.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:59:01 CTS T4 FIX | Received 1 security definitions for underlying symbol 6N | 2017-05-21 06:59:01 Contract specifications for 6N.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:59:01 CTS T4 FIX | Sending security definition request for symbol 6S.20170600.CME_Fo | 2017-05-21 06:59:02 CTS T4 FIX | Received matching security definition for symbol 6S.20170600.CME_Fo. Subscribing to data. | 2017-05-21 06:59:02 CTS T4 FIX | Received 1 security definitions for underlying symbol 6S | 2017-05-21 06:59:02 Contract specifications for 6S.20170600.CME_Fo. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 12.5 | 2017-05-21 06:59:02 CTS T4 FIX | Sending security definition request for symbol CL.20160800.CME_NY | 2017-05-21 06:59:04 Symbol Error - CL.20160800.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:59:04 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2017-05-21 06:59:04 CTS T4 FIX | Sending security definition request for symbol CL.20170100.CME_NY | 2017-05-21 06:59:05 Symbol Error - CL.20170100.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:59:05 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2017-05-21 06:59:05 CTS T4 FIX | Sending security definition request for symbol CL.20170600.CME_NY | 2017-05-21 06:59:06 CTS T4 FIX | Received matching security definition for symbol CL.20170600.CME_NY. Subscribing to data. | 2017-05-21 06:59:06 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:59:06 Contract specifications for CL.20170600.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:59:08 CTS T4 FIX | Sending security definition request for symbol CL.20170700.CME_NY | 2017-05-21 06:59:08 CTS T4 FIX | Received matching security definition for symbol CL.20170700.CME_NY. Subscribing to data. | 2017-05-21 06:59:08 CTS T4 FIX | Received matching security definition for symbol CL.20170700.CME_NY. Requesting historical data. | 2017-05-21 06:59:08 HD Request # 425 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 06:59:08 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:59:08 Contract specifications for CL.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:59:09 CTS T4 FIX | Sending security definition request for symbol CL.20171200.CME_NY | 2017-05-21 06:59:09 HD Request # 425 | Receiving Intraday data for CL.20170700.CME_NY starting at 2017-05-18 18:00:00 | 2017-05-21 06:59:10 HD Request # 425 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 06:59:10 HD Request # 425 | Total records received: 33722 | 2017-05-21 06:59:10 HD Request # 425 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 06:59:10 CTS T4 FIX | Received matching security definition for symbol CL.20171200.CME_NY. Subscribing to data. | 2017-05-21 06:59:10 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2017-05-21 06:59:10 HD Request # 425 | Total records received: 33722 | 2017-05-21 06:59:10 HD Request # 425 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 06:59:10 Contract specifications for CL.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 06:59:10 HD Request # 425 | Total records received: 33722 | 2017-05-21 06:59:10 HD Request # 425 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 06:59:10 HD Request # 425 | Total records received: 33722 | 2017-05-21 06:59:10 HD Request # 425 | Requesting historical Second data for CL.20170700.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 06:59:10 HD Request # 425 | Received 33722 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for CL.20170700.CME_NY | 2017-05-21 06:59:10 HD Request # 425 | Intraday download COMPLETE for CL.20170700.CME_NY. Completion time: 26s. Unique request ID: 737 | 2017-05-21 06:59:10 Removed historical data download ID 737 | 2017-05-21 06:59:10 Real-time Intraday chart data file updates started for CL.20170700.CME_NY | 2017-05-21 06:59:10 Opened cached Intraday file: C:\SierraChart1\Data\CL.20170700.CME_NY.scid | 2017-05-21 06:59:10 Intraday chart data file opened for CL.20170700.CME_NY | 2017-05-21 06:59:10 Delaying start of download for 6A.20170600.CME_Fo | 2017-05-21 06:59:10 Chart #9 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 06:59:10 Chart #16 has tagged chart #15 for full recalculation. Chartbook: Futures.cht | 2017-05-21 06:59:10 CTS T4 FIX | Sending security definition request for symbol ES.20160900.CME_Eq | 2017-05-21 06:59:12 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 06:59:12 Symbol Error - ES.20160900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 06:59:12 CTS T4 FIX | Received 0 security definitions for underlying symbol ES | 2017-05-21 06:59:12 Chart #3 has tagged chart #1 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:59:12 Chart #3 has tagged chart #4 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:59:12 Chart #3 has tagged chart #5 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:59:12 Chart #3 has tagged chart #8 for full recalculation. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:59:12 CL.20170700.CME_NY 30 Sec #4 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:59:12 CL.20170700.CME_NY 3 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:59:12 CL.20170700.CME_NY 3 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 06:59:12 6C.20170600.CME_Fo 3 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 06:59:12 CTS T4 FIX | Sending security definition request for symbol ES.20170600.CME_Eq | 2017-05-21 06:59:12 CTS T4 FIX | Received matching security definition for symbol ES.20170600.CME_Eq. Subscribing to data. | 2017-05-21 07:00:00 CTS T4 FIX | Received 1 security definitions for underlying symbol ES | 2017-05-21 07:00:00 Contract specifications for ES.20170600.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 12.5 | 2017-05-21 07:00:00 CL.20170700.CME_NY 3 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: MTF charts by instrument.cht | 2017-05-21 07:00:00 CTS T4 FIX | Sending security definition request for symbol GC.20160800.CME_CO | 2017-05-21 07:00:00 Symbol Error - GC.20160800.CME_CO is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 07:00:00 CTS T4 FIX | Received 0 security definitions for underlying symbol GC | 2017-05-21 07:00:00 CTS T4 FIX | Sending security definition request for symbol GC.20170400.CME_CO | 2017-05-21 07:00:02 Symbol Error - GC.20170400.CME_CO is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 07:00:02 CTS T4 FIX | Received 0 security definitions for underlying symbol GC | 2017-05-21 07:00:02 CTS T4 FIX | Sending security definition request for symbol GC.20170600.CME_CO | 2017-05-21 07:00:03 CTS T4 FIX | Received matching security definition for symbol GC.20170600.CME_CO. Subscribing to data. | 2017-05-21 07:00:04 CTS T4 FIX | Received 1 security definitions for underlying symbol GC | 2017-05-21 07:00:04 Contract specifications for GC.20170600.CME_CO. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2017-05-21 07:00:04 CTS T4 FIX | Sending security definition request for symbol HO.20170700.CME_NY | 2017-05-21 07:00:06 CTS T4 FIX | Received matching security definition for symbol HO.20170700.CME_NY. Subscribing to data. | 2017-05-21 07:00:06 CTS T4 FIX | Received 1 security definitions for underlying symbol HO | 2017-05-21 07:00:06 SC DTC Data | There has been no activity on the network socket for 40 seconds. Will reconnect. | 2017-05-21 07:00:06 DTC Client (2196) | Shutdown and closed. | 2017-05-21 07:00:06 SC DTC Data | Disconnected from the server. | 2017-05-21 07:00:06 SC DTC Data | Data feed disconnected. Will reconnect in 2 seconds. | 2017-05-21 07:00:06 Contract specifications for HO.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 07:00:06 CTS T4 FIX | Sending security definition request for symbol HO.20171200.CME_NY | 2017-05-21 07:00:07 CTS T4 FIX | Received matching security definition for symbol HO.20171200.CME_NY. Subscribing to data. | 2017-05-21 07:00:07 CTS T4 FIX | Received 1 security definitions for underlying symbol HO | 2017-05-21 07:00:07 Contract specifications for HO.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 07:00:07 CTS T4 FIX | Sending security definition request for symbol NQ.20160900.CME_Eq | 2017-05-21 07:00:08 SC DTC Data | Connecting to the server ds4.sierracharts.com. Port 443 | 2017-05-21 07:00:08 Symbol Error - NQ.20160900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 07:00:08 CTS T4 FIX | Received 0 security definitions for underlying symbol NQ | 2017-05-21 07:00:08 DTC Client (0) | Resolved address ds4.sierracharts.com to IP 192.81.56.146. | 2017-05-21 07:00:08 DTC Client (2199) | Connected. | 2017-05-21 07:00:08 SC DTC Data | Connected to server. | 2017-05-21 07:00:08 SC DTC Data | Sending Encoding Request to server | 2017-05-21 07:00:08 SC DTC Data | Setting DTC encoding to Binary VLS | 2017-05-21 07:00:08 SC DTC Data | Sending logon request message. | 2017-05-21 07:00:08 SC DTC Data | Received logon response. | 2017-05-21 07:00:10 SC DTC Data | Server Name: SC Realtime Server. | 2017-05-21 07:00:10 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2017-05-21 07:00:10 SC DTC Data | Successfully connected. | 2017-05-21 07:00:10 SC DTC Data | Trading is not supported. | 2017-05-21 07:00:10 Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2017-05-21 07:00:10 SC DTC Data | Restarting real-time data updates for symbol: AUDJPY | 2017-05-21 07:00:10 Delaying start of download for AUDJPY | 2017-05-21 07:00:10 CTS T4 FIX | Sending security definition request for symbol NQ.20170600.CME_Eq | 2017-05-21 07:00:10 SC DTC Data | Received security definition for symbol AUDJPY | 2017-05-21 07:00:10 CTS T4 FIX | Received matching security definition for symbol NQ.20170600.CME_Eq. Subscribing to data. | 2017-05-21 07:00:10 CTS T4 FIX | Received 1 security definitions for underlying symbol NQ | 2017-05-21 07:00:10 Contract specifications for NQ.20170600.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 5 | 2017-05-21 07:00:10 CTS T4 FIX | Sending security definition request for symbol RB.20170700.CME_NY | 2017-05-21 07:00:11 CTS T4 FIX | Received matching security definition for symbol RB.20170700.CME_NY. Subscribing to data. | 2017-05-21 07:00:11 CTS T4 FIX | Received 1 security definitions for underlying symbol RB | 2017-05-21 07:00:11 Contract specifications for RB.20170700.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 07:00:12 CTS T4 FIX | Sending security definition request for symbol RB.20171200.CME_NY | 2017-05-21 07:00:12 CTS T4 FIX | Received matching security definition for symbol RB.20171200.CME_NY. Subscribing to data. | 2017-05-21 07:00:12 CTS T4 FIX | Received 1 security definitions for underlying symbol RB | 2017-05-21 07:00:12 Contract specifications for RB.20171200.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 4.2 | 2017-05-21 07:00:13 CTS T4 FIX | Sending security definition request for symbol YM.20160900.CME_E | 2017-05-21 07:00:13 Symbol Error - YM.20160900.CME_E is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 07:00:15 CTS T4 FIX | Received 0 security definitions for underlying symbol YM | 2017-05-21 07:00:15 HD Request # 427 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-05-21 07:00:16 HD Request # 427 | Download start date-time: 2017-05-19 16:57:58.000 | 2017-05-21 07:00:16 CTS T4 FIX | Sending security definition request for symbol YM.20170600.CME_E | 2017-05-21 07:00:16 HD Request # 427 | Using server: ds4.sierracharts.com port 10149 | 2017-05-21 07:00:16 Socket (0) | Resolved address ds4.sierracharts.com to IP 192.81.56.146. | 2017-05-21 07:00:16 Socket (2200) | Connected. | 2017-05-21 07:00:16 HD Request # 427 | Setting DTC encoding to Binary VLS | 2017-05-21 07:00:16 HD Request # 427 | Sending historical data logon request message. | 2017-05-21 07:00:16 HD Request # 427 | Requesting Intraday data. Start date-time: 2017-05-19 16:57:58. Record interval: 1. Symbol: AUDJPY | 2017-05-21 07:00:16 CTS T4 FIX | Received matching security definition for symbol YM.20170600.CME_E. Subscribing to data. | 2017-05-21 07:00:16 CTS T4 FIX | Received 1 security definitions for underlying symbol YM | 2017-05-21 07:00:16 HD Request # 427 | Decompressing data. | 2017-05-21 07:00:16 HD Request # 427 | Receiving Intraday data for AUDJPY starting at 2017-05-19 16:57:58 | 2017-05-21 07:00:16 HD Request # 427 | Timestamp of first Intraday data file record written: 2017-05-19 16:57:58 | 2017-05-21 07:00:16 Socket (2200) | Shutdown and closed. | 2017-05-21 07:00:16 The network socket for historical data has been closed. | 2017-05-21 07:00:16 HD Request # 427 | Received 1 record from 2017-05-19 16:57:58 to 2017-05-19 16:57:58 (0.0 seconds) and wrote 1 record for AUDJPY | 2017-05-21 07:00:16 HD Request # 427 | Intraday download COMPLETE for AUDJPY. Completion time: 0s. Unique request ID: 758 | 2017-05-21 07:00:16 Removed historical data download ID 758 | 2017-05-21 07:00:16 Real-time Intraday chart data file updates started for AUDJPY | 2017-05-21 07:00:16 Opened cached Intraday file: C:\SierraChart1\Data\AUDJPY.scid | 2017-05-21 07:00:16 Intraday chart data file opened for AUDJPY | 2017-05-21 07:00:16 Contract specifications for YM.20170600.CME_E. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 5 | 2017-05-21 07:00:16 CTS T4 FIX | Sending security definition request for symbol ZB.20160900.CME_F | 2017-05-21 07:00:17 Symbol Error - ZB.20160900.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 07:00:17 CTS T4 FIX | Received 0 security definitions for underlying symbol ZB | 2017-05-21 07:00:17 CTS T4 FIX | Sending security definition request for symbol ZB.20170300.CME_F | 2017-05-21 07:00:19 HD Request # 428 | Downloading Intraday chart data for 6A.20170600.CME_Fo to the file 6A.20170600.CME_Fo.scid. Service: cts | 2017-05-21 07:00:19 HD Request # 428 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 07:00:19 HD Request # 428 | Requesting historical Second data for 6A.20170600.CME_Fo from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 07:00:19 Symbol Error - ZB.20170300.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2017-05-21 07:00:19 CTS T4 FIX | Received 0 security definitions for underlying symbol ZB | 2017-05-21 07:00:19 HD Request # 428 | Receiving Intraday data for 6A.20170600.CME_Fo starting at 2017-05-18 18:00:00 | 2017-05-21 07:00:19 HD Request # 428 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 07:00:19 HD Request # 428 | Total records received: 6413 | 2017-05-21 07:00:19 HD Request # 428 | Requesting historical Second data for 6A.20170600.CME_Fo from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 07:00:19 HD Request # 428 | Total records received: 6413 | 2017-05-21 07:00:19 HD Request # 428 | Requesting historical Second data for 6A.20170600.CME_Fo from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 07:00:19 HD Request # 428 | Total records received: 6413 | 2017-05-21 07:00:20 HD Request # 428 | Requesting historical Second data for 6A.20170600.CME_Fo from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 07:00:20 HD Request # 428 | Total records received: 6413 | 2017-05-21 07:00:20 HD Request # 428 | Requesting historical Second data for 6A.20170600.CME_Fo from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 07:00:20 HD Request # 428 | Received 6413 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for 6A.20170600.CME_Fo | 2017-05-21 07:00:20 HD Request # 428 | Intraday download COMPLETE for 6A.20170600.CME_Fo. Completion time: 0s. Unique request ID: 738 | 2017-05-21 07:00:20 Removed historical data download ID 738 | 2017-05-21 07:00:20 Real-time Intraday chart data file updates started for 6A.20170600.CME_Fo | 2017-05-21 07:00:20 Opened cached Intraday file: C:\SierraChart1\Data\6A.20170600.CME_Fo.scid | 2017-05-21 07:00:20 Intraday chart data file opened for 6A.20170600.CME_Fo | 2017-05-21 07:00:20 Delaying start of download for NQ.20170600.CME_Eq | 2017-05-21 07:00:20 CTS T4 FIX | Sending security definition request for symbol ZB.20170600.CME_F | 2017-05-21 07:00:20 CTS T4 FIX | Received matching security definition for symbol ZB.20170600.CME_F. Subscribing to data. | 2017-05-21 07:00:20 CTS T4 FIX | Received 1 security definitions for underlying symbol ZB | 2017-05-21 07:00:20 Contract specifications for ZB.20170600.CME_F. Multiplier: 0.00001000. Tick Size: 0.03125. Value Format: 132. Currency Value per Tick: 31.25 | 2017-05-21 07:00:20 CTS T4 FIX | Sending security definition request for symbol ZN.20170600.CME_F | 2017-05-21 07:00:21 CTS T4 FIX | Received matching security definition for symbol ZN.20170600.CME_F. Subscribing to data. | 2017-05-21 07:00:21 CTS T4 FIX | Received 1 security definitions for underlying symbol ZN | 2017-05-21 07:00:21 Contract specifications for ZN.20170600.CME_F. Multiplier: 0.00000100. Tick Size: 0.015625. Value Format: 132. Currency Value per Tick: 15.625 | 2017-05-21 07:00:21 CTS T4 FIX | Sending security definition request for symbol ZT.20170600.CME_F | 2017-05-21 07:00:23 CTS T4 FIX | Received matching security definition for symbol ZT.20170600.CME_F. Subscribing to data. | 2017-05-21 07:00:23 CTS T4 FIX | Received 1 security definitions for underlying symbol ZT | 2017-05-21 07:00:23 Contract specifications for ZT.20170600.CME_F. Multiplier: 0.00000010. Tick Size: 0.0078125. Value Format: 228. Currency Value per Tick: 15.625 | 2017-05-21 07:00:24 HD Request # 429 | Downloading Intraday chart data for NQ.20170600.CME_Eq to the file NQ.20170600.CME_Eq.scid. Service: cts | 2017-05-21 07:00:41 HD Request # 429 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 07:00:41 HD Request # 429 | Requesting historical Second data for NQ.20170600.CME_Eq from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 07:00:41 HD Request # 429 | Receiving Intraday data for NQ.20170600.CME_Eq starting at 2017-05-18 18:00:00 | 2017-05-21 07:00:42 HD Request # 429 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 07:00:42 HD Request # 429 | Total records received: 24898 | 2017-05-21 07:00:42 HD Request # 429 | Requesting historical Second data for NQ.20170600.CME_Eq from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 07:00:42 HD Request # 429 | Total records received: 24898 | 2017-05-21 07:00:42 HD Request # 429 | Requesting historical Second data for NQ.20170600.CME_Eq from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 07:00:42 HD Request # 429 | Total records received: 24898 | 2017-05-21 07:00:44 HD Request # 429 | Requesting historical Second data for NQ.20170600.CME_Eq from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 07:00:44 HD Request # 429 | Total records received: 24898 | 2017-05-21 07:00:44 HD Request # 429 | Requesting historical Second data for NQ.20170600.CME_Eq from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 07:00:44 HD Request # 429 | Received 24898 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for NQ.20170600.CME_Eq | 2017-05-21 07:00:44 HD Request # 429 | Intraday download COMPLETE for NQ.20170600.CME_Eq. Completion time: 3s. Unique request ID: 739 | 2017-05-21 07:00:44 Removed historical data download ID 739 | 2017-05-21 07:00:44 Real-time Intraday chart data file updates started for NQ.20170600.CME_Eq | 2017-05-21 07:00:44 Opened cached Intraday file: C:\SierraChart1\Data\NQ.20170600.CME_Eq.scid | 2017-05-21 07:00:44 Intraday chart data file opened for NQ.20170600.CME_Eq | 2017-05-21 07:00:44 Delaying start of download for GC.20170600.CME_CO | 2017-05-21 07:00:44 HD Request # 430 | Downloading Intraday chart data for GC.20170600.CME_CO to the file GC.20170600.CME_CO.scid. Service: cts | 2017-05-21 07:01:06 HD Request # 430 | Download start date-time: 2017-05-19 16:59:57.000 | 2017-05-21 07:01:06 HD Request # 430 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 07:01:06 HD Request # 430 | Receiving Intraday data for GC.20170600.CME_CO starting at 2017-05-18 18:00:00 | 2017-05-21 07:01:07 HD Request # 430 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:57 | 2017-05-21 07:01:07 HD Request # 430 | Total records received: 26821 | 2017-05-21 07:01:07 HD Request # 430 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 07:01:07 HD Request # 430 | Total records received: 26821 | 2017-05-21 07:01:07 HD Request # 430 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 07:01:07 HD Request # 430 | Total records received: 26821 | 2017-05-21 07:01:09 HD Request # 430 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 07:01:09 HD Request # 430 | Total records received: 26821 | 2017-05-21 07:01:09 HD Request # 430 | Requesting historical Second data for GC.20170600.CME_CO from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 07:01:09 HD Request # 430 | Received 26821 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:57 (23.0 hours) and wrote 1 record for GC.20170600.CME_CO | 2017-05-21 07:01:09 HD Request # 430 | Intraday download COMPLETE for GC.20170600.CME_CO. Completion time: 3s. Unique request ID: 740 | 2017-05-21 07:01:09 Removed historical data download ID 740 | 2017-05-21 07:01:09 Real-time Intraday chart data file updates started for GC.20170600.CME_CO | 2017-05-21 07:01:09 Opened cached Intraday file: C:\SierraChart1\Data\GC.20170600.CME_CO.scid | 2017-05-21 07:01:09 Intraday chart data file opened for GC.20170600.CME_CO | 2017-05-21 07:01:09 Delaying start of download for ZT.20170600.CME_F | 2017-05-21 07:01:09 Chart #1 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 07:01:09 Chart #1 has tagged chart #14 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 07:01:09 Chart #1 has tagged chart #17 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 07:01:09 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 07:01:09 Chart #13 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:09 Chart #13 has tagged chart #15 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:09 Chart #13 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:09 Chart #13 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:09 Chart #13 has tagged chart #4 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:09 Chart #13 has tagged chart #5 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:09 ZB.20170600.CME_F 30 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 07:01:09 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 07:01:09 ZB.20170600.CME_F [C] 30 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:01:09 Chart #15 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:09 Chart #15 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:09 Chart #15 has tagged chart #26 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:09 6J.20170600.CME_Fo [C] 30 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:01:09 Chart #5 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:09 Chart #5 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:09 ES.20170600.CME_Eq 30 Sec #17 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 07:01:09 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 07:01:09 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 07:01:09 Chart #17 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 07:01:09 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:01:09 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:09 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:09 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:09 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:09 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:01:09 6C.20170600.CME_Fo [C] 30 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:01:09 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:01:13 Chart #1 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 07:01:13 Chart #1 has tagged chart #14 for full recalculation. Chartbook: Futures.cht | 2017-05-21 07:01:13 Chart #1 has tagged chart #17 for full recalculation. Chartbook: Futures.cht | 2017-05-21 07:01:13 Chart #1 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 07:01:13 Chart #1 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 07:01:13 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 07:01:13 ZB.20170600.CME_F [C] 15 Min #26 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:01:13 6J.20170600.CME_Fo 3 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 07:01:13 Chart #14 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 07:01:13 ZB.20170600.CME_F 3 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 07:01:13 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 07:01:13 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 07:01:13 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:01:13 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:13 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:13 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:01:13 6J.20170600.CME_Fo 30 Sec #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 07:01:13 NQ.20170600.CME_Eq 30 Sec #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 07:01:13 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:01:13 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 07:01:13 ES.20170600.CME_Eq 3 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 07:01:13 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures.cht | 2017-05-21 07:01:13 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 07:01:13 Chart #17 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 07:01:13 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 07:01:13 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 07:01:18 6J.20170600.CME_Fo 3 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 07:01:18 Chart #14 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 07:01:18 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 07:01:18 HD Request # 431 | Downloading Intraday chart data for ZT.20170600.CME_F to the file ZT.20170600.CME_F.scid. Service: cts | 2017-05-21 07:01:38 HD Request # 431 | Download start date-time: 2017-05-19 16:59:59.000 | 2017-05-21 07:01:38 HD Request # 431 | Requesting historical Second data for ZT.20170600.CME_F from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 07:01:38 HD Request # 431 | Receiving Intraday data for ZT.20170600.CME_F starting at 2017-05-18 18:00:00 | 2017-05-21 07:01:39 HD Request # 431 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:59 | 2017-05-21 07:01:39 HD Request # 431 | Total records received: 3447 | 2017-05-21 07:01:39 HD Request # 431 | Requesting historical Second data for ZT.20170600.CME_F from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 07:01:39 HD Request # 431 | Total records received: 3447 | 2017-05-21 07:01:39 HD Request # 431 | Requesting historical Second data for ZT.20170600.CME_F from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 07:01:39 HD Request # 431 | Total records received: 3447 | 2017-05-21 07:01:39 HD Request # 431 | Requesting historical Second data for ZT.20170600.CME_F from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 07:01:39 HD Request # 431 | Total records received: 3447 | 2017-05-21 07:01:39 HD Request # 431 | Requesting historical Second data for ZT.20170600.CME_F from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 07:01:39 HD Request # 431 | Received 3447 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:59 (23.0 hours) and wrote 1 record for ZT.20170600.CME_F | 2017-05-21 07:01:39 HD Request # 431 | Intraday download COMPLETE for ZT.20170600.CME_F. Completion time: 0s. Unique request ID: 741 | 2017-05-21 07:01:39 Removed historical data download ID 741 | 2017-05-21 07:01:39 Real-time Intraday chart data file updates started for ZT.20170600.CME_F | 2017-05-21 07:01:39 Opened cached Intraday file: C:\SierraChart1\Data\ZT.20170600.CME_F.scid | 2017-05-21 07:01:39 Intraday chart data file opened for ZT.20170600.CME_F | 2017-05-21 07:01:39 Delaying start of download for HO.20170700.CME_NY | 2017-05-21 07:01:39 Chart #9 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 07:01:41 Chart #9 has tagged chart #13 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 07:01:41 GC.20170600.CME_CO 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 07:01:41 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 07:01:41 Chart #9 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 07:01:41 Chart #9 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 07:01:41 Chart #9 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 07:01:41 ZB.20170600.CME_F 30 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 07:01:41 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 07:01:41 Chart #12 has tagged chart #13 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:41 Chart #12 has tagged chart #15 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:41 Chart #12 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:41 Chart #12 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:41 ZB.20170600.CME_F [C] 30 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:01:41 Chart #15 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:41 Chart #15 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:41 Chart #15 has tagged chart #26 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:41 ZB.20170600.CME_F 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 07:01:41 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:01:41 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:41 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:41 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:41 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:41 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:01:41 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 07:01:45 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:01:45 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 07:01:45 ZB.20170600.CME_F [C] 15 Min #26 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:01:45 ZB.20170600.CME_F 3 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 07:01:45 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 07:01:45 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 07:01:45 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:01:45 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:45 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:01:45 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:01:45 GC.20170600.CME_CO [C] 30 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:01:45 Chart #13 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:45 Chart #13 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:45 Chart #13 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:45 Chart #13 has tagged chart #4 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:45 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:01:45 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:45 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:45 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:45 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:45 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:01:45 6C.20170600.CME_Fo [C] 30 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:01:45 NQ.20170600.CME_Eq 3 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 07:01:45 6E.20170600.CME_Fo 3 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 07:01:49 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:01:49 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:01:49 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:01:49 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:01:49 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:01:49 HD Request # 432 | Downloading Intraday chart data for HO.20170700.CME_NY to the file HO.20170700.CME_NY.scid. Service: cts | 2017-05-21 07:02:07 HD Request # 432 | Download start date-time: 2017-05-19 16:59:53.000 | 2017-05-21 07:02:07 HD Request # 432 | Requesting historical Second data for HO.20170700.CME_NY from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 07:02:07 HD Request # 432 | Receiving Intraday data for HO.20170700.CME_NY starting at 2017-05-18 18:00:00 | 2017-05-21 07:02:08 HD Request # 432 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:53 | 2017-05-21 07:02:08 HD Request # 432 | Total records received: 7519 | 2017-05-21 07:02:08 HD Request # 432 | Requesting historical Second data for HO.20170700.CME_NY from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 07:02:08 HD Request # 432 | Total records received: 7519 | 2017-05-21 07:02:08 HD Request # 432 | Requesting historical Second data for HO.20170700.CME_NY from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 07:02:08 HD Request # 432 | Total records received: 7519 | 2017-05-21 07:02:08 HD Request # 432 | Requesting historical Second data for HO.20170700.CME_NY from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 07:02:08 HD Request # 432 | Total records received: 7519 | 2017-05-21 07:02:08 HD Request # 432 | Requesting historical Second data for HO.20170700.CME_NY from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 07:02:08 HD Request # 432 | Received 7519 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:53 (23.0 hours) and wrote 1 record for HO.20170700.CME_NY | 2017-05-21 07:02:10 HD Request # 432 | Intraday download COMPLETE for HO.20170700.CME_NY. Completion time: 2s. Unique request ID: 742 | 2017-05-21 07:02:10 Removed historical data download ID 742 | 2017-05-21 07:02:10 Real-time Intraday chart data file updates started for HO.20170700.CME_NY | 2017-05-21 07:02:10 Opened cached Intraday file: C:\SierraChart1\Data\HO.20170700.CME_NY.scid | 2017-05-21 07:02:10 Intraday chart data file opened for HO.20170700.CME_NY | 2017-05-21 07:02:10 Delaying start of download for ZB.20170600.CME_F | 2017-05-21 07:02:10 Chart #20 has tagged chart #16 for full recalculation. Chartbook: Futures.cht | 2017-05-21 07:02:10 Chart #20 has tagged chart #9 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:02:10 CL.20170700.CME_NY [C] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:02:10 Chart #9 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:02:10 Chart #5 has tagged chart #16 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 07:02:10 CL.20170700.CME_NY 3 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 07:02:10 Chart #16 has tagged chart #15 for full recalculation. Chartbook: Futures.cht | 2017-05-21 07:02:10 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:02:11 CL.20170700.CME_NY 30 Sec #16 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 07:02:11 6C.20170600.CME_Fo 3 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 07:02:11 HD Request # 433 | Downloading Intraday chart data for ZB.20170600.CME_F to the file ZB.20170600.CME_F.scid. Service: cts | 2017-05-21 07:02:32 HD Request # 433 | Download start date-time: 2017-05-19 16:59:56.000 | 2017-05-21 07:02:32 HD Request # 433 | Requesting historical Second data for ZB.20170600.CME_F from 2017-05-19 00:00:00 to 2017-05-19 00:00:00 (US Central Time). | 2017-05-21 07:02:32 HD Request # 433 | Receiving Intraday data for ZB.20170600.CME_F starting at 2017-05-18 18:00:00 | 2017-05-21 07:02:32 HD Request # 433 | Timestamp of first Intraday data file record written: 2017-05-19 16:59:56 | 2017-05-21 07:02:32 HD Request # 433 | Total records received: 6509 | 2017-05-21 07:02:32 HD Request # 433 | Requesting historical Second data for ZB.20170600.CME_F from 2017-05-20 00:00:00 to 2017-05-20 00:00:00 (US Central Time). | 2017-05-21 07:02:32 HD Request # 433 | Total records received: 6509 | 2017-05-21 07:02:32 HD Request # 433 | Requesting historical Second data for ZB.20170600.CME_F from 2017-05-21 00:00:00 to 2017-05-21 00:00:00 (US Central Time). | 2017-05-21 07:02:32 HD Request # 433 | Total records received: 6509 | 2017-05-21 07:02:32 HD Request # 433 | Requesting historical Second data for ZB.20170600.CME_F from 2017-05-22 00:00:00 to 2017-05-22 00:00:00 (US Central Time). | 2017-05-21 07:02:32 HD Request # 433 | Total records received: 6509 | 2017-05-21 07:02:33 HD Request # 433 | Requesting historical Second data for ZB.20170600.CME_F from 2017-05-23 00:00:00 to 2017-05-23 00:00:00 (US Central Time). | 2017-05-21 07:02:33 HD Request # 433 | Received 6509 records from 2017-05-18 18:00:00 to 2017-05-19 16:59:56 (23.0 hours) and wrote 1 record for ZB.20170600.CME_F | 2017-05-21 07:02:33 HD Request # 433 | Intraday download COMPLETE for ZB.20170600.CME_F. Completion time: 1s. Unique request ID: 743 | 2017-05-21 07:02:33 Removed historical data download ID 743 | 2017-05-21 07:02:33 Real-time Intraday chart data file updates started for ZB.20170600.CME_F | 2017-05-21 07:02:33 Opened cached Intraday file: C:\SierraChart1\Data\ZB.20170600.CME_F.scid | 2017-05-21 07:02:33 Intraday chart data file opened for ZB.20170600.CME_F | 2017-05-21 07:02:33 Delaying start of download for 6B.20170600.CME_Fo | 2017-05-21 07:02:33 Chart #13 has tagged chart #1 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 07:02:33 Chart #13 has tagged chart #14 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 07:02:33 Chart #13 has tagged chart #17 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 07:02:33 Chart #13 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 07:02:33 Chart #15 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:02:33 Chart #15 has tagged chart #13 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:02:33 Chart #15 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:02:33 Chart #15 has tagged chart #26 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:02:33 Chart #15 has tagged chart #5 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:02:33 6J.20170600.CME_Fo [C] 30 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:02:33 Chart #5 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:02:33 Chart #5 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:02:33 ES.20170600.CME_Eq 30 Sec #17 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 07:02:33 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 07:02:33 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 07:02:33 Chart #17 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 07:02:33 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:02:33 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:02:33 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:02:33 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:02:33 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:02:33 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:02:33 ZB.20170600.CME_F [C] 30 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:02:36 YM.20170600.CME_E 30 Sec #21 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 07:02:36 ZB.20170600.CME_F [C] 15 Min #26 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:02:36 Chart #13 has tagged chart #1 for full recalculation. Chartbook: Futures.cht | 2017-05-21 07:02:36 Chart #13 has tagged chart #11 for full recalculation. Chartbook: Futures.cht | 2017-05-21 07:02:36 Chart #13 has tagged chart #14 for full recalculation. Chartbook: Futures.cht | 2017-05-21 07:02:36 Chart #13 has tagged chart #17 for full recalculation. Chartbook: Futures.cht | 2017-05-21 07:02:36 Chart #13 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 07:02:36 GC.20170600.CME_CO [C] 30 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:02:36 Chart #19 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:02:36 ZB.20170600.CME_F [C] 30 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:02:36 6J.20170600.CME_Fo 30 Sec #14 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 07:02:36 NQ.20170600.CME_Eq 30 Sec #2 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 07:02:36 NQ.20170600.CME_Eq [C] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:02:36 GC.20170600.CME_CO 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: Futures II.cht | 2017-05-21 07:02:36 Chart #1 has tagged chart #21 for full recalculation. Chartbook: Futures II.cht | 2017-05-21 07:02:36 GC.20170600.CME_CO [C] 30 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:02:36 Chart #13 has tagged chart #10 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:02:36 Chart #13 has tagged chart #18 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:02:36 Chart #13 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:02:36 Chart #13 has tagged chart #4 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:02:36 ES.20170600.CME_Eq 3 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: Futures.cht | 2017-05-21 07:02:36 Chart #17 has tagged chart #14 for full recalculation. Chartbook: Futures.cht | 2017-05-21 07:02:36 Chart #17 has tagged chart #2 for full recalculation. Chartbook: Futures.cht | 2017-05-21 07:02:36 Chart #17 has tagged chart #7 for full recalculation. Chartbook: Futures.cht | 2017-05-21 07:02:36 ES.20170600.CME_Eq [C] 30 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:02:36 Chart #10 has tagged chart #11 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:02:36 Chart #10 has tagged chart #19 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:02:36 Chart #10 has tagged chart #22 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:02:36 Chart #10 has tagged chart #23 for full recalculation. Chartbook: multi instrument.cht | 2017-05-21 07:02:36 AUDJPY [C] [M] 30 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: multi instrument.cht | 2017-05-21 07:02:36 6C.20170600.CME_Fo [C] 30 Min #4 | Performing a full recalculation because it has been tagged. C |
| [2017-05-22 20:58:07] |
It is not possible for their ever to be conflicts which would cause this: conflicts that are causing the SSL disconnects
If there are any connectivity issues, refer to help topic 1.2: Data/Trading Service Connection and Symbol Issues Chart #1 has tagged chart #13 for full recalculation. Chartbook: Futures.cht | 2017-05-21 07:01:13 http://www.sierrachart.com/index.php?page=doc/helpdetails30.html#h30.3 http://www.sierrachart.com/index.php?page=doc/helpdetails30.html#h30.9 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
