Date/Time: Fri, 13 Nov 2026 10:00:04 +0000
ticks
View Count: 860
[2017-05-22 16:56:45]
Dennis B. - Posts: 303
On one instance the price increments go .25.50 .75 etc. that's fine. On another instance it goes 90.01, 90.02, 90.03 etc. Referring to the ES contract. Can't figure out how to correct this.
[2017-05-22 17:01:49]
Provide an image of the chart or Trade DOM showing this, by following these instructions:
[2017-05-22 17:26:14]
That won't work in this case, I know there is an advanced setting to correct this, like I said other instance is fine. Just can't remember where it is. Will keep poking around...thx.
[2017-05-22 18:36:28]
The chart helps us give us a clue as to what the problem might be.
Maybe the Price Multipliers are not set correctly in Chart >> Chart Settings >> Advanced Settings 2.
