Date/Time: Fri, 13 Nov 2026 10:00:01 +0000
2nd computer in alternat location question
View Count: 880
| [2017-05-22 12:47:17] |
| RonW - Posts: 105 |
I want to load and use Sierra in a second location when I am not at my primary location. In other words, the second location will be rarely used, and the two locations will never be in use at the same time. So I am hoping that as long as I do not have them both on at the same time, there is no additional fee. Is this true? Is there anything in particular I have to do to set up the second location? Thanks |
| [2017-05-22 16:43:04] |
This can be done. Refer to: Sierra Chart Purchase and License Information: Licensing / Number of Systems They can also be used at the same time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
